EcoFlow 220W
EcoFlow 220W
Bifacial Portable Solar Panel
Portable Solar Panels
Power your everyday appliances at home and off-grid with sustainable solar energy.
    More energy with a two in one bifacial design.
    EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
      *The above data shows the panel's rear side solar gain using different surfaces.
      Built to last.
      Built to last.
      The thin, one-piece tempered glass design makes it five times tougher than comparable panels with half the thickness of traditional tempered glass. Capable of withstanding heat up to 300°F, it's safe to say it can resist the elements.
      • 4XMoreRear Side Heat Dissipation
      • <10%Power Degradation Over 10 Years
      *Compared to standard portable solar panels.
      Powerfully portable.
      It’s a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input.
        More than a carry case.
        It comes with its own carry case so you can take it anywhere. Once you arrive at your destination, simply unfold it and use it as a kickstand to get your sun exposure just right.
          And it’s waterproof too.
          We’ve raised the bar with this panel. It's completely water and dust-tight. Rain, wind or shine, your panel is safe with an IP68 waterproof rating.
            *IP68: maximum water depth of 1 meter for up to 24 hours.
            You might also like
            View more
            • EcoFlow
            Product Introduction
