EcoFlow 160W
EcoFlow 160W
Portable Solar Panels
Power your everyday appliances at home and off-grid with sustainable solar energy.
    Portable Solar Energy
    Power the great outdoors.
    Lightweight and travel-friendly, EcoFlow’s 60W, 110W, 160W, and 400W portable solar panels are ideal for camping and outdoor activities. Charge your portable power station in just a few hours to power up essentials like a coffee maker and laptop. Our foldable 400W portable solar panel is one of the first of its kind. Plug into your portable power station or home backup system for faster and more convenient charging.
      High-Efficiency Solar Cells
      Capture more rays.
      Made using highly efficient monocrystalline silicon cells. And with an exceptional energy conversion rate of 20-21%, you get more energy with every cell.
      Plus, when connected to an EcoFlow solar generator, the Maximum Power Point Tracking (MPPT) algorithm auto-adjusts, guaranteeing a constant and stable power supply.
    • Charge a Delta mini in
      Approx4hours
      with 6 x 60W portable solar panels.
      Approx5hours
      with 2 x 110W portable solar panels.
      Approx3.7hours
      with 2 x 160W portable solar panels.
      Approx3hours
      with 1 x 400W portable solar panel.
    • * All data is gathered under test conditions.
      Solar Connectors
      The perfect power couple.
      All EcoFlow portable solar panels use a universal solar connector, so they work with almost all third-party portable power stations as well as EcoFlow’s.
      Lightweight & Foldable
      Designed for portability.
      • solar_panel_swiper
        The handy case doubles as a self-supporting stand and adjusts 180 degrees for max sunlight absorption.
        Panels conveniently fold away inside the protective sleeve to carry or store when not in use.
        So lightweight and easy to transport, EcoFlow’s portable solar panels are a camping-trip must-have, keeping you powered up for longer.
      Long-lasting Materials
      Strong enough to weather a storm.
      An IP67 waterproof membrane protects solar cells from dust, debris, and rain. On the ground while you camp. On the roof of your home. And even on top of your RV for solar charging on the move. What's more, our 400W portable solar panels have an additional layer of fiberglass, protecting the cells from bending and damage.
        You might also like
        View more
        • EcoFlow
