EcoFlow 100W
EcoFlow 100W
Rigid Solar Panel
100W Rigid Solar Panels
With a compact design and high-efficiency rating, string together several of these industry-leading solar panels to quickly charge your LFP batteries and power your RV for days.
    Use Highly Efficient Monocrystalline Cells
    Charge Faster with High Solar Conversion.
    Our 100W rigid solar panel has an excellent conversion rating of 23%, allowing you to charge even faster. Combine as part of your Power Kits setup or EcoFlow portable power station, and the integrated MPPT algorithm optimizes your solar input.
      Pre-Drilled Slots on Solar Panel for Secure Mounting
      Ready to Install on Your Surfaces.
      With pre-cut holes on the panel, the 100W rigid panel is ready to mount on your van or off-grid build. Pair with the 100W Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
        IP68* Waterproof Rating
        Stand Through All Weather.
        Our 100W rigid solar panel is designed for outdoor weather. With an IP68* waterproof rating, the panel can withstand dirt, low-pressure water jets, extreme winds of up to 130 mph, and even heavy snowfalls.
          Coated with Highly Protective Lamination and Tempered Glass
          Durable Structure Design for Long-Lasting Performance.
          Built with a robust anti-corrosive aluminum frame, our 100W rigid solar panel is designed for maintaining solar collection outdoors for years. Its monocrystalline cells are coated with highly protective lamination and tempered glass to enhance performance and offer long-lasting durability.
            Highly Protective
            Anti-Corrosive
            Solar Cable for Universal Compatibility
            Connect with Your Power Systems at Ease.
            Using an all-inclusive solar connector, our 100W rigid solar panel can be readily connected with any of your existing third-party solar systems. You can charge up 48v power systems and portable power stations with one or multiple panels.
              What's in the box?
              What's in the box?
              1.2 x 100W Rigid Solar Panel 2.User Manual and Warranty Card *The solar to XT60 charging cable is included in EcoFlow portable solar panels.
              You might also like
              View more
              • EcoFlow
              Product Introduction
