Solar Panel for Ring Doorbell: Best Options, Installation Guide & Buying Tips
A video doorbell is a great addition to home security, but what if the doorbell isn't working because the battery keeps dying? You miss a delivery, don't catch a visitor, and don't get that motion notification because the battery died last night. It's infuriating when it comes to home security.
You can solve this issue quickly and permanently by installing a solar panel that will keep your doorbell running day in and day out, without removing it from the wall. And if you're feeling eco-friendly, there's a whole host of home solar battery solutions designed to power your entire home with solar energy — reducing your electricity bills while keeping every device running.
In this article, we've got you covered on making the right decision: why you should use a solar panel with a Ring doorbell, which solar panels work with which Ring doorbell, how to install a solar panel, and what to look for when purchasing one.
Why use a solar panel for a ring doorbell?
Ring doorbells are battery-powered - and batteries don't last as long as you might think. With variations based on how much people walk past your door, whether motion is detected or not, and the temperature, you may need to recharge your doorbell every two to four weeks. In cold months, when battery life is reduced, it's even closer.
The answer is a solar panel that trickle-charges your doorbell throughout the day. It needn't be sunny; on the cloudy days of the UK, even so, a good solar panel will provide enough charge to negate the average doorbell's use. So you get an uninterrupted doorbell, without charging.
There's also a security case. When a doorbell can't work, it doesn't record or send you a message. This gives you more security, with your camera constantly recording and motion alerts firing when someone gets to the door. It's also a more discreet setup, with no unsightly outdoor extension cable or ugly cables running down the wall.
Compatibility guide: Choosing the right solar panel for your Ring doorbell
Not all solar panels are compatible with all Ring doorbells. When shopping for solar panels, you'll want to know which Ring models support solar charging and what to look for in terms of compatibility.
Supported ring doorbell models
Ring Video Doorbell (1st Generation): The original Ring doorbell is charged with a micro-USB port. It can also be charged with a solar panel, but check to see if the panel you're considering uses the right connector. Be sure to check the cable type if you're looking for a solar panel for Ring doorbell 1 - this model uses a different connector.
Ring Video Doorbell 2: The Ring Video Doorbell 2 can be charged by solar panels using a special port. It was the first doorbell to be officially compatible with solar accessories. For those wondering how to install a solar panel for the Ring Doorbell 2, the cable connects the accessory to a port on the back, meaning it must temporarily remove the doorbell to do so.
Ring Video Doorbell 3: The Ring Video Doorbell 3 is fully supported with a charging port that doesn't require the doorbell to be removed from its housing. If you are wondering how to install a solar panel for a Ring doorbell 3, it's the easiest doorbell in the series to connect a solar panel to - the port is easily accessible and can be connected quickly.
Ring Video Doorbell 4: The Ring Video Doorbell 4 can be solar-charged and has an extended battery lifespan. A ring solar panel for doorbell 4 is an excellent match - the bigger battery means it stays charged with a minimal solar charge, even in busy locations.
Ring Battery Doorbell Plus: Ring Battery Doorbell Plus is Solar chargeable. This is a great choice for a solar panel for the Ring Battery Doorbell Plus. This model has a bigger battery and can be topped up by the sun, particularly in areas where the "mostly" detection often gets triggered during the day.
Video Doorbell Pro: The Video Doorbell Pro is wired. If you're looking for a solar panel for Ring Doorbell Pro, be certain to check your system requirements - the Pro is a hardwired model and does not depend on a battery being charged, as the battery-powered doorbells do.
Key Compatibility Factors to Consider
Connector type: Connectors vary by ring models. Check the cable used for the solar panel will link to the charging port of your doorbell. Most Ring-designed solar panels have the right connector, but third-party panels may not.
Output wattage: Ring doorbells draw low voltages and don't require panels with high wattage, but the panel's current output must be sufficient to compensate for use in your area. For the UK's dim conditions, we recommend panels that perform well under diffuse or overcast conditions.
Weather resistance: An outdoor panel should be robustly weatherproof. IP65 or better is required for a panel to be guaranteed to withstand UK conditions.
Cable length: The cable must be able to reach from the panel to the doorbell without tension. The vast majority of solar panels designed specifically for ring doorbells have cables between 1 and 2 metres long - this is something to consider when mounting the panel.
Best solar panel for Ring Doorbell (Top solutions)
For households that want to go further than just keeping a doorbell charged — using solar energy to actively reduce their electricity bills and power their homes — a home solar battery system is the natural next step.
The solutions below are designed for daily household energy use, not just device charging. They capture solar energy throughout the day, store it, and feed it directly into your home's electrical circuit — so your appliances run on free solar power rather than drawing from the grid. Your Ring Doorbell stays charged as part of a wider system that's quietly cutting your energy costs every single day.
1. EcoFlow STREAM Ultra X — Best all-in-one home solar battery
The STREAM Ultra X is a home solar battery with a built-in inverter, designed to connect directly to your home's electrical system. Solar panels charge the battery during the day; the system feeds that stored energy back into your home's circuit, so your appliances — including your Ring doorbell — run on solar power rather than grid electricity.
A single unit delivers up to 1,200W of continuous output. Add a second unit, and that jumps to 2,300W, enough for high-demand appliances like washing machines and ovens running simultaneously. Storage starts at 3.84 kWh and can expand up to 23 kWh by adding extra battery units — without needing to stack them.
For UK homes where overcast days are the norm, the system's 4 MPPT inputs and Low-Light Cells make a genuine difference. It captures usable energy even when the sky isn't clear.
Up to 2,300W AC output in dual-unit configuration 2,000W solar input with 4 MPPTs and Low-Light Cells Expandable from 3.84 kWh up to 23 kWh 15-year lifespan with high safety standards Compatible with Tiber, Matter, and Shelly smart home protocols
2. EcoFlow STREAM Ultra X All-in-One Home Storage Kit — Best complete package
For households that want a complete home solar setup without researching and matching individual components, this kit includes everything needed to get started — solar panels, battery units, cables, and mounting hardware in one package.
The built-in inverter handles DC-to-AC conversion without additional equipment, and the EcoFlow app provides real-time monitoring of energy generation, storage, and usage. For anyone looking for the best solar panel for a ring doorbell as part of a broader home energy solution, this kit removes guesswork entirely.
Save up to £1,729 annually on your electricity bills.¹ Enjoy up to 2300W AC output, easily powering high-demand appliances. Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. Features a 15-year lifespan, ensuring high safety and long-term reliability. Set up is effortless and requires no electricity. Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
How to install a solar panel for a ring doorbell (Step-by-step guide)
Mounting a solar panel with your ring doorbell is a task that can be accomplished in less than an hour by the average homeowner. No special electrical expertise is required, just some simple tools and an appropriate place to install them.
Tools and materials needed
  • Solar panel that will work with your Ring doorbell model.
  • Select and fit drill bits for your type of wall.
  • Screwdriver (flathead and Phillips)
  • Wall anchors and screws (typically provided with the panel)
  • Spirit level
  • Cable clips (not required, to keep the cable runs tidy)
  • A ladder to install at a height.
Step-by-step installation process
Step 1: Choose a location with maximum sunlight
Note the daylight pattern of the sun on your front wall before drilling. In the UK, south-facing walls get the most sun most of the time. Shadows caused by an overhang, trees, or any neighbouring buildings should be avoided; even partial shade can greatly decrease output. The panel must be cable reach of the doorbell, which is often 1-2 metres.
Step 2: Mount the solar panel securely
Fit the mounting bracket to the wall where you want it and make marks where the holes will be drilled. Check with a spirit level to make sure it is straight. Holes: drill holes, place wall anchors, and fasten the bracket using the screws provided with it. Join the panel to the bracket, but leave it not quite tightened yet - you will have a chance to change the angle in the next step.
Step 3: Connect the cable to the doorbell
Install the solar panel cable to your Ring doorbell and firmly plug the connector into the charging port. A free-flowing connection does not allow a stable charge. Cable clips will be necessary to keep the cable neat against the wall.
If you are curious about how to install a Ring solar panel for a doorbell system, such as the Ring 2, you will need to briefly remove the doorbell from the mount to access the charging port behind it. In the case of the Ring 3, 4, and Battery Doorbell Plus, the port can be accessed without being removed.
Step 4: Adjust the angle for best sun exposure
Tilt the panel southwards and tilt it at an angle of approximately 3045 out of horizontal. This angle is suited to strike a balance between the direct summer sun and the lower winter sun angles that provide the optimal performance during the year in the UK. After being satisfied with the placement, tighten all mounting screws.
Step 5: Test the charging status
Launch the Ring app and browse to the health section of your doorbell. When there is sunlight on the panel, you will see a solar charging indicator within a few minutes. When the indicator fails to show, recheck the cable connection and make sure that the panel is not shaded.
Model-specific installation tips
  • Ring Video Doorbell 2: Unmount to reach the back port, and then remount. Takes some minutes but is otherwise easy.
  • Ring Video Doorbell 3 and 4: Available port - does not have to be removed during mounting. Shortest time in the family.
  • Ring Battery Doorbell Plus: Like 3 and 4 in accessibility. The bigger battery makes it a perfect solar pairing for busy front doors.
  • Ring Video Doorbell (1st Gen): Micro-USB — make sure your panel can take this connector, purchase it.
Best placement tips for maximum solar efficiency
Placement is an even greater difference than most people anticipate. Poor positioning of a panel can only bring 50-60 per cent of what a well-positioned panel could bring in the UK, with already limited sun duration; this is the difference between solid charging and a battery that runs low.
  • Face south wherever possible. The most uniform UK sunlight is on south-facing surfaces. East or west walls will also work, but will produce less overall energy throughout the day.
  • Tilt at 30–45 degrees. A flat panel will fail to be efficient with the daily and seasonal variations of the sun's angle. A 30 45 degree tilt panel is a better capture of cross-sections of sunlight throughout the year.
  • Eliminate shading. Look at the shade with trees, gutters, or neighbouring buildings at other times of day, not only at the time of installation. A branch that does not shade at noon may shade for a few hours in the morning.
  • Occasionally, clean the panel. Dust and grime decrease production. A single or two wipe-downs with a damp cloth every two or three years will maintain a steady performance.
Common issues and troubleshooting
Solar panel, but the battery continues to run down. Typically indicates that the panel is not producing sufficient power to counter usage. Check shading, rub off the panel surface, and check the angle. A bigger panel can be required in extremely busy places where there is high movement alert.
The Ring is not viewing the solar charging indicator in the Ring app. First check the cable connection - this should be securely seated. The panel might not have adequate light if it is not secure. Attempt to view on a clearer day or change the position of the panel.
Charging is intermittent. Frequently, due to a loose connection or a tensioned cable. Make sure that there is ample slack on the cable and clips to hold the cable steady against the wall.
Resets the doorbell when connected to the solar panel. This is possible in certain older models of Ring. Unscrew and unscrew the panel. In case it continues, visit the support pages of Check Ring to download updates about the firmware to correct the behaviour.
Buying guide: how to choose the right solar panel for Ring Doorbell
Key features to look for
Low-light performance. Not negotiable in UK installations. A panel that works in diffuse light or in cloudy light will work much better than a panel that is made to work when the sun is shining. Specifications of check manufacturers with low-light performance ratings.
Output wattage. A panel with an output of 1.82.5W is a reliable charge in the case of a Ring doorbell used in the UK. Installing with higher traffic has a slightly better output.
IP rating. IP65 and above for truly outdoor use. This will keep off rain, wind, and moisture during the entire year.
Cable length and connector type. Make sure that they fit your particular Ring model and the location where you intend to mount it. Making a mistake in purchasing a connector that is not correct can be easily corrected.
Build quality and warranty. A 2-3 year warranty on a panel by a respected brand provides a significant safeguard against early outdoor corrosion.
Safety and compatibility tips
Check your Ring model number before buying. It's printed on the back of the device or visible in the Ring app under device information. Ring models look similar but use different connectors.
Don't use higher voltages than recommended. Some off-brand panels produce more voltage than Ring recommends, which can cause a load on the battery management system. Use panels that meet Ring's requirements.
Secure outdoor cables properly. An unsecured cable is prone to movement (from wind or snagging), which can strain the connector. Cable clips keep things tidy and prevent connection issues.
Be aware of what's behind the wall. Brick, render, and wood require different bits and fixings. The wrong fixings result in a bracket that may come loose.
Adding a solar panel to your ring doorbell is a quick fix for a real outcome. No more weak batteries, no more missed deliveries, and no more ladder climbing to swap batteries.
And the setup time is less than an hour for most UK properties. With the right positioning - sunny, facing south, and out of the shade - your doorbell will be running on free solar power for as long as the sun shines.
If you want to take that idea even further, a solar battery system for your home takes that same philosophy and applies it to your whole home. The EcoFlow STREAM series captures solar power during the day and delivers it back into the home circuit, cutting your energy and electricity costs, and ensuring that your Ring doorbell is topped up as part of the system.
The point is: whether you start with a single solar panel for your Ring doorbell, or expand into a whole home system, you're moving in the same direction: taking more control of your home, using less energy from the grid, and taking one step closer to a self-sustaining home.
  1. What is the best solar panel for a Ring doorbell?
The best solar panel for a Ring doorbell is one that works with low light, has the right-sized plug to fit your system, is waterproof (IP65-rated), and provides the necessary output for your Ring doorbell. For homeowners who want to save money on electricity costs, the best value for money is installing a solar panel for a doorbell as well as a home battery system.
  1. How to install a solar panel for a ring doorbell?
Position the panel on a south-facing wall, within reach of the cable, connect the cable to the charging port, tilt the panel at 30-45 degrees, and check for charging via the Ring app. The installation section above has complete instructions for specific models.
  1. Can a solar panel fully charge a ring doorbell?
Solar panels offer a trickle charge, not a fast charge. Assuming average UK lighting conditions, an optimally positioned panel provides ongoing trickle charging to offset battery discharge and maintain most Ring models at a steady battery level 24/7 - without the need for manual recharging.
  1. Does a solar panel work with all Ring models?
The Ring models that can be charged via solar energy are those with batteries: Ring Video Doorbell 1st Gen, 2, 3, 4, and Battery Doorbell Plus. The Ring Video Doorbell Pro is wired and doesn't support solar charging. Be sure to check compatibility with your model before buying.
  1. Where should I place my solar panel for the best performance?
A south-facing wall with no shading gives the best results in the UK. Aim for a tilt angle of 30–45 degrees and check for shade at different times of day before finalising the position. Keep the panel close to the doorbell to minimise cable length and maintain a clean installation.
Solar System
