Octopus Energy Heat Pump UK: Costs, Tariffs and Reviews
- The Octopus Energy Heat Pump Offer
- Cosy Heat Pump Models and Smart Heating Features
- Property Suitability Before Choosing an Octopus Heat Pump
- Octopus Energy Heat Pump Costs, Grants and Finance
- Cosy Octopus Heat Pump Tariff and Running Costs
- Octopus Energy Heat Pump Reviews and Real-World Performance
- Combining Heat Pump Electricity Demand With Solar and Storage
- Conclusion
- FAQs
The Octopus Energy heat pump lets UK households replace their gas, oil, or LPG heating system with an electrically powered air-source heat pump, including survey, installation, controls, and aftercare. Octopus' offer currently focuses on the Cosy range, and alternative Daikin and Grant systems may be recommended if appropriate for the property. If a household anticipates increasing its electricity use upon electrification, it may be beneficial to consider a longer-term planning horizon for solar/battery storage, in addition to the heat-pump purchase.
Octopus Energy's heat pumps offer more than just the hardware. The service may include the home survey and heat-loss assessment, system design, installation, Grant administration, and access to the Cosy Octopus smart tariff. Costs depend heavily on the property's requirements and whether pipework, radiators, ground preparation, or electrical work is needed.
In this guide, we will examine the current Cosy range, other heat pumps provided by Octopus, property suitability, costs and grants, tariff options, and actual performance. It also shows where solar generation and battery storage can come into play once the heating system itself has been adequately assessed.
When it comes to installing a heat pump, Octopus thinks beyond the sale of the unit; they think of the heating system. The specific system will vary based on the heating requirements of the residential property, current heating systems and survey findings; two seemingly identical homes may be installed with different equipment and/or final installation costs.
Cosy as the main Octopus Energy heat pump range
The Cosy range is the main Octopus Energy heat pump family developed for residential heating. There are three models of Cosy available at present - Cosy 6, Cosy 9 and Cosy 12; each have a different heating capacity and is suited to different property requirements. Customers don't choose based on house size alone; Instead, a home survey is used to calculate heat loss and select the right model. Cosy systems can also be remotely diagnosed and updated, so control and operation features can improve over time.
Daikin and Grant alternatives within Octopus Energy heat pumps installations
Not all properties will be suitable for a Cosy unit. However, Octopus states that it can also match customers with a suitable Daikin or Grant heat pump where the latter is better suited for the building heating requirements. This provides greater flexibility across Octopus Energy heat pumps than a single-product solution. The final recommendation should therefore be based not on brand name alone, but on calculated heat loss, available space for installation, heating-water requirements, and existing property conditions. Additionally, homeowners can understand how heat pumps operate and costs in UK households before weighing the different types.
Heating, controls and installation included within the wider Octopus service
A normal Octopus quotation includes more than just the heat-pump itself. Items may include a compatible hot-water cylinder, plumbing and pipework, electrical components, delivery, labour, configuration and grant administration depending on the final design. Additionally, Octopus claims all required radiators are part of its design and installation, and some non-standard property work could incur an additional charge after the survey. Users should not judge an Octopus Energy heat pump based on equipment cost alone; instead, they should consider the entire installed package.
The Cosy range is designed for a variety of home heating needs, not a single unit. In addition to model sizing, the Octopus Energy air source heat pump focuses on control via its application, remote diagnostics, and software updates, and is therefore not just hardware but part of a larger smart-heating system.
Cosy 6, Cosy 9 and Cosy 12 for different household heat demands
Currently, Octopus has 3 models on the market: Cosy 6, Cosy 9, and Cosy 12, with varying levels of heating power. The option you select depends on a home heat-loss assessment, not just the number of bedrooms or the home's square footage. At -5°C ambient temperature and 65°C flow conditions, the three Octopus heat capacities are approximately 5.2kW, 8.1kW and 10kW, respectively. Additionally, SCOP varies between models, so rather than selecting the biggest Octopus Energy heat pump, the final recommendation should consider required output, operating temperature, and seasonal performance.
App controls and remote optimisation built into the Octopus Energy air source heat pump
The Octopus Energy air source heat pump can be controlled using the Octopus Energy app, which lets users set heating and hot water temperatures, add heating schedules and view information on a phone. The application can also allow access to operating modes and features like Hush Mode. This gives households greater flexibility in when heating and hot water are generated, which may be important for aligning production with occupancy or when using a time-of-use tariff. While smart controls can increase convenience, good schedules must still consider comfort requirements and the property's thermal characteristics.
Software updates and smart controls supporting long-term system performance
A unique aspect of Octopus Energy heat pumps is that, after installation, Cosy systems can be remotely updated via software. Like other connected devices, these updates can improve how the heat pump operates, enhance performance, and add new features over time, Octopus says. It can also be useful for remote diagnostics to help determine system issues without the need for a site visit. These capabilities are not a substitute for proper design, commissioning, and maintenance, but can optimise long-term performance and enable heating controls to develop as software features improve.
The next step is to see if the property can accommodate the proposed system efficiently. Before final design and quote, Octopus employ an in-home survey to determine heat loss, radiator performance, pipework and hot-water requirements, and potential equipment locations.
Home heat-loss assessment before selecting an Octopus Energy heat pump
A heat-loss assessment estimates the rate of heat loss from the property and, consequently, the heat capacity needed in colder weather. This allows Octopus to determine which system is best suited: Cosy 6, Cosy 9, Cosy 12 or other systems. When selecting an Octopus Energy heat pump, relying solely on the number of bedrooms can sometimes be misleading as additional factors such as insulation, glazing, room size and ventilation contribute to the demand. The survey thus provides a more reliable foundation for sizing the system and predicting its performance.
Existing radiators, pipework and hot-water arrangements considered during the survey
The survey also checks whether existing radiators and pipework can cope with the lower, more constant heat pump temperatures. According to Octopus, some homes will require larger radiators, and Cosy systems can use suitable microbore pipework from 10mm. The heat pump keeps domestic hot water in a separate cylinder; therefore, a compatible hot-water cylinder is also required. These checks assess whether the current heating system infrastructure is compatible with efficient use of an Octopus Energy air source heat pump, or whether upgrades are necessary; if so, they should be incorporated into the final installation design.
Property conditions that may require additional work before installation
Some properties require prep prior to installation. There may be constraints or interferences on the outdoor unit or the hot-water cylinder, and there may be inappropriate pipework, interferences on site groundworks or planning requirements that influence the final proposal. As Octopus points out, further costs could arise if non-standard work is found during the home survey; however, a better-insulated home can reduce heat loss and improve heating performance. Homeowners should treat the first online estimate as tentative and wait for the survey to determine what work is needed to make the property heat-pump ready.
After confirming whether the property is suitable, the next step is financial commitment. Octopus Energy heat pump prices depend on the system designed, grant eligibility, and any further work identified during the home survey. Please remember that this online quote is only a starting price, and the final price may vary.
Typical Octopus Energy heat pump costs after an eligible government grant
Octopus currently reports a typical post-survey heat-pump price of around £4,459 after the standard £7,500 Boiler Upgrade Scheme grant, based on its quoted installations from September 2025 to February 2026. Actual costs may still vary substantially from property to property. The BUS is offered in England and Wales, and eligible air-to-water heat pumps will generally be offered £7,500. There is currently £9,000 available for qualifying off-gas-grid homes switching from oil or LPG heating. When comparing wider UK heat pump prices, it's also worth considering typical heat pump installation costs and grants.
Property-specific upgrades that can change the final installation quote
The final Octopus Energy heat pump costs may rise when the survey identifies work beyond the standard installation. Larger radiators, extra pipework, electrical changes, hot water cylinder replacement, site preparation or unusual equipment positioning can all impact the overall total. Where a building has high potential heat loss, such as in areas with poor insulation under a flat roof or around windows, improved insulation may be recommended to reduce heating needs. Octopus provides the confirmed price after the home survey so the customer can review the extra work needed to install the system before signing the installation contract. This is significant for the survey, both for system sizing and for the total project budget.
Upfront payment and finance routes for an Octopus Energy heat pump
The Octopus Energy heat pump price doesn't have to be settled up front by the customer. At the moment, Octopus accepts a refundable deposit of £200 to reserve the home survey. Once the home survey and final agreement are signed, any monies remaining after the £200 deposit will be payable on completion of installation and operation. Those who want to pay monthly can also be referred to Novuna for finance, which is currently offered for a 5 to 10-year period, depending on status and affordability. While financing can help to reduce the initial cost, households should consider the total cost to be paid back over the life of the loan, not just the monthly repayments.
After installation cost, the ongoing electricity bill becomes the next major consideration. The Octopus Energy heat pump tariff (Cosy Octopus) is built up around less expensive times than the evening peak, when households can heat or hot water for less, and a higher-priced evening peak. The actual savings will also be dependent on the effectiveness of the demand shift in the home, and the efficiency of the heat pump.
Three discounted daily periods under the Octopus Energy heat pump tariff
Cosy Octopus currently provides three lower-priced periods each day: 04:00–07:00, 13:00–16:00 and 22:00–00:00. According to Octopus, this is approximately 51% off of the regional Day rate, and gives 8 hours of discount throughout the day. These windows help households heat the property or water before more expensive periods. The tariff can be used by eligible homes that have a heat pump or other qualifying electric heating system, though it doesn'tt require the system to be installed by Octopus.
Peak-period pricing and the value of shifting heating away from expensive hours
The tariff also features a higher rate between 16:00 and 19:00, currently about 50% higher than the regional Day rate. This is why scheduling matters: Octopus suggests heating water or rooms slightly more during lower-cost periods and less during higher-cost evening periods. A well-insulated house with high thermal retention could potentially shift demand without compromising comfort. Smart controls can help automate some of this behavior, but households should still check their heating patterns against their usual ones – not for price – but to make sure they are comfortable.
Household insulation, heat-pump efficiency and usage affecting actual running costs
The Octopus Energy heat pump tariff can reduce the amount some bills are charged for certain electricity, but it doesn't save every household the same. Insulation, heat loss, system efficiency, indoor temperature settings, and kilowatt-hours used still affect running costs. The figure quoted is an Octopus fleet average, meaning cosy customers on the tariff saved about £224 on average over the most recent year compared to an 85%-efficient gas boiler on its standard variable tariff, but this is not guaranteed. Knowing how much electricity the home consumes can help a homeowner better assess how much the home needs.
Headline tariff and specifications tell only part of the story. Fleet data and Octopus Energy heat pump reviews offer further insights into comfort, running costs, and the everyday experience after installation. But survey results published by the company is only an indication and not a guarantee that each and every property will have the same result.
Comfort and control themes appearing in Octopus Energy heat pump reviews
After installation, Octopus surveys customers and compares their experience with their previous heating system. The majority of the customers said maintenance was just as easy or easier. Noise is also viewed positively, with 83% stating their heat pump was as quiet as or quieter than their previous boiler. Based on these Octopus Energy heat pump reviews, comfort isn't only about the outdoor unit's performance; it also requires good controls, stable heating, and proper system design.
Fleet performance data behind Octopus running-cost claims
Octopus also publishes operating data from thousands of installed Cosy systems. It shows that its fleet dashboard has an average seasonal performance factor of 3.77 over the past year, a significant improvement. Based on real energy usage and past tariff prices, Octopus estimated that 99.6% of the Cosy systems it monitored would have cost less than its comparison gas boiler, with the average Cosy customer on the tariff saving £227 per annum. These are Octopus' calculations and actual household results may vary.
Survey, installation and aftercare factors to consider in an Octopus Energy heat pump review
A useful Octopus Energy heat pump review should consider the whole ownership process rather than judging the outdoor unit alone. The accuracy of the survey, radiator replacement, installation quality, commissioning, app controls and aftercare can all impact comfort and electricity usage. Insulation, heating system settings, and household habits differ, so published fleet averages do not necessarily reflect performance for any particular home. Once installed, the monitoring of household electricity use can enable owners to check expected performance against actual consumption and if no control or change is observed in the normal consumption, it may be a reason to review the system settings or seek technical assistance.
Tariff optimisation is one piece of the puzzle when planning for long-term energy use, as an Octopus Energy heat pump can help to move a higher proportion of household heating onto electricity. If the heating system is properly designed and performing well, Homeowners may want to ask whether solar generation and battery storage would contribute to the broader home energy demand. The purpose is not to increase the heat pump's efficiency, but to make better use of existing solar electricity and reduce grid electricity use, insofar as possible.
Solar generation and heat-pump operating hours across different seasons
Demand for heat pumps and solar generation can occur at different times. Generally, heating needs are higher in colder, darker months, while solar output is higher on longer summer days. An Octopus Energy heat pump can even continue to run when solar production has reduced, within a single day. Hence, it is important for the homeowners to evaluate the seasonal generation, daytime consumption and evening demand before choosing the storage capacity. Knowing how solar panels and battery storage are connected can help distinguish solar surplus that benefits the grid from solar energy that is still negative.
EcoFlow STREAM 5000 for new solar, storage and electric-heating plans
For households without an existing PV system, EcoFlow STREAM 5000 allows solar generation and storage to be considered along with higher electricity demands from electric heating. It has 5,024Wh of battery capacity, a maximum PV input of 5,000W via four MPPT channels, and a maximum AC output of 3,000W. As storage needs to meet household demand increase, the system can be scaled to accommodate them, making it useful for homeowners considering solar, battery storage, and other electrical loads in a single system.
EcoFlow STREAM AC 5000 for existing solar homes adding storage
Homes that already have rooftop solar need a different approach. This EcoFlow STREAM AC 5000 battery can be retrofitted and installed in parallel with an existing solar system, offering a maximum charging rate of 3,000W for the battery system, 3,000W AC output and 5,024Wh battery capacity. It can store more PV daytime electricity for use later in the day, when household electricity demand peaks, instead of replacing the existing PV installation. If a solar home uses an Octopus Energy heat pump, storage is an additional way to increase solar self-consumption, in addition to tariff optimisation via the chosen electricity tariff.
An Octopus Energy heat pump is made up of equipment, installation, smart controls and access to time of use tariffs, however the value achieved will depend on property suitability, the design of the system, the eligibility for grants and the efficiency with which the household manages heat demand. Survey results and actual running patterns matter more than headline prices or fleet averages.
EcoFlow STREAM 5000 is ideal for new solar-and-storage planning, while EcoFlow STREAM AC 5000 is for existing solar properties that are introducing battery storage. In both instances , Storage is used to enable broader management of electricity and not directly to increase the efficiency of the heat pump.
Do you need to be an Octopus Energy customer to buy an Octopus Energy heat pump?
No, you don't have to be an electricity customer with Octopus in order to buy an Octopus Energy heat pump.
Heat-pump installation can be arranged separately.
Tariff eligibility is a different consideration.
Some Octopus smart tariffs may require a compatible smart meter.
Therefore, the heat pump and the energy-supply contract should be treated as two interdependent but separate decisions.
Can a home battery charge during cheaper Octopus Energy heat pump tariff periods?
Yes, if the system and tariff permit, the compatible home battery may be programmed to charge at less expensive Octopus Energy heat pump tariff times when using a heat pump. This can help to reduce the amount of electricity from the grid at more expensive times. However, economics depend on battery efficiency, tariff charges, household demand, and available solar generation, so grid charging should be planned with the broader household energy profile in mind, not automated.
Can another installer fit a heat pump and still use the Octopus Energy heat pump tariff?
Yes, the Cosy Octopus tariff doesn't apply only to heat pumps directly installed by Octopus.
The property must have a qualifying electric heating system.
A compatible smart meter is normally required.
Tariff eligibility conditions should be checked before switching.
This ensures installers are comparable without taking the Octopus tariff into account in the end.
Does the Octopus Energy heat pump tariff work with a smart meter?
Yes, a compatible smart meter is important because the Octopus Energy heat pump tariff uses different electricity prices at different times of day. The meter logs usage in half-hour increments, allowing Octopus to rate usage at discounted and peak rates. A smart meter may therefore be necessary for households to switch to the tariff if they are not already equipped with one.
Can battery storage reduce the running cost of an Octopus heat pump?
Potentially yes; However, in practice, battery storage does not directly affect the heat pump's power requirement.
It can store surplus solar for later use.
It may charge during cheaper tariff periods.
It can reduce some higher-priced grid imports.
Actual savings depend on battery losses, tariff structure, solar generation, and household heating patterns. The battery, therefore, should be used in conjunction with a well-designed heat-pump system, not to make up for poor system design.
