How to Make Phone Charge Faster: 11 Tips for Quick Charging
We've all been there: your phone battery is almost empty, you're in a hurry, and your phone seems to take forever to charge. Luckily, there are practical ways to speed things up and get your device juiced up quickly. In this guide, we’ll share 11 proven ways on how to make phone charge faster, saving you time and frustration when you need your phone most. Read on!
Why Is My Phone Charging So Slowly?
Before learning how to charge the phone fast, it helps to understand why it might be taking so long in the first place. Several common issues can slow things down. They include:
  • Weak or Faulty Charger: Not all chargers are made equal. If you’re using an old or cheap charger, it might not be delivering enough power to your phone. Damaged cables or low-quality adapters can also limit charging speed.
  • Low Power Source: Plugging into a laptop USB port or a car’s dashboard often provides much less power than a wall outlet. For faster charging, the power source matters.
  • Background Apps and Screen Time: If your phone’s doing a lot in the background, like running apps, syncing data, or keeping the screen on, it eats up power while charging. That can slow everything down.
  • Dirty or Damaged Charging Port: Dust, lint, or debris inside the charging port can block a proper connection. Even a slight obstruction can reduce charging speed or stop it entirely.
  • Battery Health Issues: Over time, lithium-ion batteries wear out. If your phone’s a few years old and charges slowly no matter what, the battery itself might be the problem.
11 Ways on How to Make Your Phone Charge Faster
Speeding up your phone’s charging process isn’t complicated. With a few adjustments, you'll notice immediate improvements. Here are 11 simple yet highly effective strategies you can try right now.
1. Switch to Airplane Mode
When you're in a rush, flipping on Airplane Mode can give your charging speed a noticeable boost. It shuts off your phone’s connection to Wi-Fi, mobile networks, and Bluetooth, which are constantly using energy in the background.
2. Close Unused Apps
It’s easy to forget about all the apps running quietly in the background. Music players, social media, even a weather app—if they’re open, they’re using up energy.
Before charging, do a quick app cleanup. Swipe away anything you’re not actively using. It helps your phone stay focused on filling up the battery instead of juggling background tasks.
3. Keep Your Phone Cool
Phones don’t charge well when they’re hot. In fact, most devices will slow down charging automatically to avoid overheating, which can make the process take longer than it should.
If your phone feels warm, take it out of the case, move it to a cooler area, and avoid putting it in direct sunlight while charging. A cool phone is a faster-charging phone.
4. Use a High-Wattage Charger
Not all chargers are created equal. A charger with more power, measured in watts, can send energy to your phone much faster than a basic one. If your phone supports fast charging, get a charger that matches or exceeds what your phone can handle.
5. Use a Certified Fast-Charging Cable
Sometimes the cable is the real bottleneck. Even with a strong charger, a cheap or worn-out cable can slow things down a lot.
Stick with certified cables made for your phone model or brand. They’re designed to handle higher power levels safely and consistently, and that can shave several minutes off your charge time.
6. Avoid Using the Phone While Charging
Using your phone while it's plugged in might seem harmless, but it drains power as it's being recharged. Watching videos, scrolling through apps, or gaming during charging can slow things to a crawl. If you can, give it a break. The battery will fill up faster, and your phone will stay cooler, too.
7. Turn Off Your Phone While Charging
Want the fastest possible charge? Power the phone off completely. No apps, no notifications, no background activity—just a straight shot of power going to the battery.
It’s especially handy if you're in a hurry or your phone’s battery is really low. A quick 15- to 30-minute charge with the phone powered off can boost the battery noticeably.
8. Clean the Charging Port
Over time, pocket lint and dust can sneak into your charging port and mess with the connection. That weak connection might be the reason your phone charges more slowly than usual.
Use a toothpick or a small brush to gently clear out the debris. Just be careful not to poke too hard, as delicate pins inside can be damaged easily.
9. Lower Your Screen’s Brightness
Your screen eats up a lot of battery, especially if it’s turned up high. Even while charging, a bright display can slow the process down.
Try lowering the brightness manually or turning on auto-brightness to let your phone adjust itself. And if you’re not actively using it, just turn the screen off entirely to speed things up.
10. Enable Battery Saving Mode
Battery Saver mode is your friend when you're trying to charge faster. It cuts back on background tasks, limits performance, and reduces the drain on your battery during charging. Most phones let you switch it on with just a couple of taps.
11. Avoid Charging from Public Charging Stations
Public USB ports might seem convenient, but they’re not ideal for fast charging. They often deliver weak power, and in some cases, they may come with security risks, too.
If you’re out and about, bring your own charger or a small power bank. You'll get faster results and more peace of mind.
Bonus Tip: Use a Fast-Charging Power Bank on the Go
If you’re looking for how to fast charge a phone on the go, a fast-charging power bank can keep your phone powered up without wasting time. Here are three standout options designed for speed and portability.
EcoFlow RAPID Pro X Power Bank (27,650mAh, 300W)
Built for those who want serious power on the move, the EcoFlow RAPID Pro X Power Bank(27,650mAh,300W) combines ultra-fast output with thoughtful design. It supports up to 140W charging from a single port, or a whopping 300W when using multiple ports, enough to handle not just phones, but power-hungry devices like tablets and even laptops. The built-in retractable 140W USB-C cable adds real convenience for travel.
Better still, its 3.9-inch color screen shows real-time charging data clearly, and the built-in magnetic module makes it simple to top up your smartwatch.
EcoFlow RAPID Power Bank
EcoFlow RAPID Power Bank (25,000mAh, 170W)
The EcoFlow RAPID Power Bank(25,000mAh 170W) is a solid all-rounder for anyone who needs high-speed charging in a travel-friendly design. With 140W single-port output and a total of 170W when using multiple ports, it can charge your phone quickly, even while powering another device at the same time. It's a great match for users who carry more than one gadget.
Despite the powerful specs, it stays compact. The cylindrical build makes it easy to slip into a bag or carry-on, and yes, it’s airline-approved. Fast, portable, and reliable—it checks all the right boxes for everyday use.
The EcoFlow RAPID Power Bank delivers high-speed, multi-device charging in a compact, travel-friendly design. With 140W output from a single port and up to 170W total from multiple ports, it powers phones, tablets, and USB-C laptops without sacrificing performance. Its 25,000mAh capacity meets airline carry-on limits, while the cylindrical shape makes it easy to pack. A clear TFT display shows real-time charging status, and the X-Guard chip monitors safety with millions of daily temperature checks. Built for fast, reliable power on the move, it’s ideal for busy users who need efficient charging anywhere.
EcoFlow RAPID Mag Power Bank (5,000mAh, 7.5W Wireless)
Perfect for casual use, the EcoFlow RAPID Mag Power Bank (5,000mAh,7.5w, MagneticCharging) offers a slim and lightweight build that’s easy to carry, even in your pocket. It supports fast wired charging up to 20W, and 7.5W magnetic wireless charging that works seamlessly with compatible phones.
Its standout features are comfort and convenience. Strong N52 magnets keep it securely attached during wireless charging, while EcoFlow’s X-Cooling tech keeps temperatures in check, even during extended use. If you’re after a sleek, minimal option for quick boosts during the day, this little charger delivers exactly that without the bulk.
Charging your phone faster can be easier than it seems. With a few smart adjustments and the right accessories, you’ll notice real improvements in charging speed and overall convenience. Knowing how to make phone charge faster gives you an edge when you're in a rush or on the go. And if you need power beyond the wall socket, EcoFlow offers fast-charging power banks that are well suited for life on the move.
How do I increase my phone charging speed?
You can increase your phone’s charging speed by using a certified fast charger and cable, enabling airplane mode, or turning off your device completely. Keeping your phone cool, cleaning the charging port, and closing unused apps will also help boost charging speed considerably, giving you quicker and more efficient charges.
How do I put my phone on fast charge?
To put your phone on fast charge, use a compatible high-wattage fast charger and certified fast-charging cable. Most modern phones support quick charge protocols like Qualcomm Quick Charge or USB Power Delivery (PD). Check your phone’s specifications and ensure you use compatible accessories for the fastest charging results.
Does putting your phone in airplane mode make it charge faster?
Yes, putting your phone in airplane mode does make it charge faster. It disconnects wireless connections like Wi-Fi, Bluetooth, and cellular data, significantly reducing battery consumption. With less power being drained, your phone can direct more energy to charging, shortening the overall charging time effectively.
Power Banks
