How Many Watts Does a TV Use? The Ultimate Guide to Energy Consumption
How many watts does a TV use? This is a question that can help you take control of your household’s power consumption. The TV is one of the most consistently used appliances, and on average runs for several hours each day. However, not many people know how much electricity TVs consume at any given moment. This is where your power bills can start inflating, especially if you own TVs running on older display technologies, such as plasma.
This guide provides detailed information and answers the question, how many watts does a TV use. It also provides factors that affect TV power consumption, alternative solar powered devices that can help you minimize energy consumption, and all the information you need to make informed decisions.
How Many Watts Does a TV Use? (General Averages)
A question that many people usually is how many watts does a TV use on average. Modern TV sets use between 20 and 250 watts. The factors affecting the energy consumption are:
  • Screen size
  • Display technology
  • Brightness settings
People running on older, larger, or high-brightness TVs usually pay more on energy bills due to their higher consumption.
How Many Watts Does a Flat Screen TV Use?
How many watts does a flat screen TV use? Flat screen TVs, including LED, LCD, OLED, and QLED panels, consume between 20 and 150 watts. Flat screen TVs include a wide range of technology display technologies and sizes. This is why the range is so broad. Modern LED flat screens are more energy-efficient than their predecessors. Of these, the 40-50 inch models consume between 20 to 80 watts during typical viewing.
How Many Watts Does an LCD TV Use?
How many watts does an LCD TV use? Liquid Crystal Display (LCD) televisions consume about 30 and 100 watts. LCD panels use a backlight for illuminating the screen. For a 40-inch LCD TV, you can expect to use about 50-70 watts during active use.
How Many Watts Does a Plasma TV Use?
How many watts does a plasma TV use? Plasma TVs are less energy-efficient than LCDs and OLED TVs. Typically, they consume between 100 and 400 watts. However, the larger plasma sets may exceed this range. The high energy draw and heat output is one of the reasons the Plasma technology was phased out.
TV Power Consumption by Size
One of the main factors that affect TV power consumption is its screen size. For screen sizes above 65 inches, they require more backlighting to maintain image quality. In the table below, we have provided a detailed energy consumption across the various screen sizes, and answering key questions such as:
  • How many watts does a 30 inch tv use
  • How many watts does a 40 inch tv use
  • How many watts does a 50 inch tv use
  • How many watts does a 60 inch tv use
  • How many watts does a 75 inch tv use
Screen Size
Typical Wattage (LED/LCD)
Typical Wattage (OLED)
30 inch
25–40W
N/A
40 inch
40–65W
55–75W
50 inch
65–100W
85–110W
60 inch
95–130W
110–150W
75 inch
120–200W
150–220W
How Many Watts Does a 30-Inch TV Use?
30-inch TVs are among the most energy-efficient TVs. The LED/LCD models consume between 25 and 40 watts, making them ideal for bedrooms and home offices.
How Many Watts Does a 40-Inch TV Use?
40-inch LED models use between 40 and 65 watts. OLED ones use between 55 to 75 watts, depending on your picture settings.
How Many Watts Does a 50-Inch TV Use?
Most LED/LCD 50-inch TV screens consume between 65 and 100 watts. OLED ones use between 85 to 110 watts. The consumption is directly affected by the brightness of the TV and picture mode.
How Many Watts Does a 60-Inch TV Use?
LED/LCD 60-inch TVs consume between 95 and 130 watts, whereas OLED ones can go up to 150 watts. If you watch a 60 inch TV for 4-5 hours daily, you’ll start noticing an impact on your energy bill.
How Many Watts Does a 75-Inch TV Use?
A 75-inch TV is in the large TV screens category. Large screens like these consume about 120 and 200 watts for LED/LCD models and 220 watts for OLED models. However, premium 75 inch screens come with energy-saving models that lower these consumption rates. To answer the question how many watts does a large TV use, this method can give you the actual energy consumption for any TV.
How many watts does a Samsung TV use?
Samsung TV energy consumption depends on screen size, display technology, and the picture settings. On average, Samsung TVs consume between 30W and 200W. However, larger 8K models and TV running in vivid mode can exceed 300W. Check out the table below for a breakdown of how many watts does a Samsung TV use:
Screen Size
Crystal UHD (Standard LED)
QLED / Neo QLED (Mini-LED)
OLED (S90/S95 Series)
32"
30W – 50W
45W – 60W
N/A
43"
50W – 80W
65W – 95W
N/A
50"
65W – 100W
85W – 130W
N/A
55"
75W – 120W
95W – 150W
80W – 140W*
65"
95W – 160W
120W – 200W
110W – 180W*
75"
120W – 210W
150W – 270W
140W – 220W*
85"+
160W – 280W
210W – 350W+
180W – 300W
Note: Government regulatory bodies are the ones which determine energy efficiency ratings and criteria for UK Energy Labels (Class A to G) and are updated periodically to encourage manufacturers to produce more efficient hardware
What Are the Factors Affecting TV Wattage?
How many watts does a TV use? To effectively answer this question, you must understand what affects TV wattage and why some consume more energy than others.
1. Screen Size
As the TV screen sizes increase, the energy consumption also increases. When the size increases, the total surface area that needs illumination grows, and this requires a more extensive backlight system to provide a consistent high-quality picture. A large number of light-emitting diodes (LEDs) or higher intensity light sources are used to ensure there is quality backlight across the screen. This results in higher hardware demand which increases the TVs wattage.
2. Display Technology
What makes Organic Light Emitting Diode (OLED) screens unique is that each pixel produces its own lit. Wattage for these TV screens changes depending on the type of content you are watching. For example, a dark scene uses little power while a bright scene spikes consumption.
LED/LCD screens use a backlight to illuminate pixels. Although they are often known as the most efficient, models with full array local dimming (FALD) use more power to manage high-brightness zones.
Plasma is a legacy technology. If you are using older plasma screens, just know they consume two to three times the wattage of a modern LED of the same size.
Let’s also answer the question, how many watts does a 4K TV use. If you compare a 4K TV and a 1080P TV of the same screen size, the power consumption is almost similar. Screen resolution adds minimal overhead. What affects the TVs power consumption is the size and display technology.
3. Brightness and Picture Settings
Using your TV with high brightness levels, the power draw increases. Modern TVs have automatic brightness control (ABC) or ambient light sensor that adjusts the video/ picture output based on the room lighting conditions. If the room is darker, they automatically lower the screen's brightness. However, if the room has a lot of lighting, to ensure you clearly see, they increase the TVs brightness. A quick hack to control and minimize your TV consumption, switch the display mode from Vivid to Standard or Echo. This small setting can reduce your wattage by 10-30%, without affecting the quality of the output.
Understanding Energy Metrics: Watts vs. Watt-Hours
How Many Watt-Hours Does a TV Use?
These two questions are closely related:
  • How many watt hours does a TV use?
  • How many watts does a TV use per hour?
Here is how to calculate watt-hours:
Watt-Hours = Watts × Hours of Use
For example, if you have a 75-watt TV and it runs for 4 hours, it will consume 300Wh or 0.3kWh.
Note: In 2026, the current electricity rate is 24.67p per kWh. This figure is subject to change, always confirm from Ofgem energy price cap updates to get the updated pricing information.
Using this figure, for a 75-watt TV, it equates roughly to 7.2p per day or about £2.16 per month for daily use.
How many watts an hour does a TV use?
Watts are not technically measured per hour. That unit is watt-hours and is used to ask about hourly energy consumption. And to get that, you just multiply your TV’s wattage by the number of hours it is in use.
Reliable Power Solutions for Your Entertainment Setup
Having a reliable, cost-effective, and independent energy source can help you manage your home’s energy bills. An energy source you can rely on during outages and peak tariff periods. If you want to integrate solar energy in your set up, these solutions can make a bigger difference.
EcoFlow STREAM Ultra X
The EcoFlow STREAM Ultra X is designed to provide a whole-home backup and energy independence. This home battery system has a 3.84kWh capacity. It has the ability to support expandable storage. Using the EcoFlow STREAM Ultra X, you can power a 100-watt TV for over 38 hours, keeping you online even when there are power interruptions. To ensure it delivers a long cycle life and consistent performance, it’s built on LiFePO4 battery chemistry. This is a smart choice if you are looking to reduce grid reliance and the total energy bills in your household.
Large 3.84kWh capacity that can store enough energy to keep you online for days 6000 life cycles that ensure dependable power for fifteen years 2000W solar input for quickly recharging the battery Four MPPT trackers for harvesting energy efficiently even in shade IP65 rating that guarantees the unit can withstand harsh weather Silent 30dB operation guaranteeing no noise disturbance at home 10-year warranty giving you long term protection
EcoFlow STREAM Series Plug-In Solar Battery
If you want further energy independence, the EcoFlow STREAM Series Plug-In Solar Battery is a must-have solution. This is a comprehensive bundle that includes:
  • EcoFlow STREAM Ultra battery
  • EcoFlow 400 W Rigid Solar Panel
The EcoFlow STREAM Series Plug-In Solar Battery includes intelligent maximum power point tracking (MPPT) charge management and supports up to 2,000W solar input. It stores sufficient energy you can use to power your TV and other household devices, such as refrigerators, washing machines, microwaves, dehumidifiers, televisions, vacuum cleaners, and air conditioners, among others. If your household still uses larger, higher-wattage televisions, with the EcoFlow STREAM Series Plug-In Solar Battery, you can reduce your daily electricity costs.
EcoFlow STREAM Ultra X Home Solar Battery
3.84kWh capacity that stores sufficient energy to power your home 800W grid output that feeds solar energy into your sockets 6000 life cycles guaranteeing over 10 years of battery use IP65 protection guaranteeing long-term performance even in harsh weather conditions 4 MPPT inputs to maximize energy gain from multiple solar panels It has 30dB noise level, which means it runs silently without disturbing your space 10-year warranty giving you protection for your investment and peace of mind
How many watts does a TV use is a question that can help you properly manage your monthly electricity bills. Once you know exactly how much electricity your TVs consume, you can easily make energy related decisions, such as upgrading to TV sets with low consumption rates, or even looking for an alternative energy source. There is a big difference between how much energy different TVs consume. The major factors that bring about this gap are the screen size, display technology, and brightness and picture settings. With understanding your TV watt-hours, you can easily apply the local energy rate to get a clear picture of how much the TV consumes and identify realistic opportunities for savings.
EcoFlow offers reliable, high-quality solutions, such as the EcoFlow STREAM Ultra X, and EcoFlow STREAM Series Plug-In Solar Battery that can power your home entertainment setup more efficiently. Our products are designed to provide reliable, consistent, and clean power. WIth these products, you can reduce your daily electricity costs, and reduce over dependence on the grid. Ready to achieve true energy independence and protect your home from rising utility costs? Check our main website to learn about our ecosystems, and our official shopping platform to find the perfect power solution.
Frequently Asked Questions (FAQs)
Does a smart TV use more electricity than a regular TV?
Yes, a smart TV uses marginally more electricity than a standard TV of the same size and display type. What makes this so is that the smart TV has Wi-fi connectivity, bluetooth, built in apps, and background processes that a regular TV doesn’t have. The difference is around 5-10 watts, and largely negligible in terms of running costs.
How much does it cost to run a TV for 24 hours?
The total cost depends on your TV’s wattage and the local electricity rates. If we use the current UK average of approximately 24.67p per kWh, if you are watching a 75-watt smart TV for 24 hours, it will consume 1.8 kWh which translates to 43p. A larger 200-watt TV will consume 4.8 kWh over the same 24 hour period and it will cost about £1.15.
Note: The average electricity price is always changing. Check on the official Ofgem Ofgem energy price cap updates to get the current electricity costs and calculate based on that.
Does leaving a TV on standby waste a lot of power?
Leaving TVs on standby consumes negligible power of between 0.5 watts and 3 watts. If this energy accumulates across the year, it can amount to a few pounds at most. However, if you own more than one TV and leave all of them on standby, their combined draw increases and you can experience it when paying your electric bills. To avoid this, always switch off the wall socket when you are not watching your TV to eliminate standby energy consumption.
Note: The current UK and EU regulations require new TVs not to exceed 0.5 watts when in standby mode. Always refer to the European Commission official website for any updates to this law.
Home Solutions
