Heat Pump Efficiency UK: Performance, COP and Energy Use
One of the primary urges for the UK public to switch from conventional heating to a heat pump is efficiency. A heat pump does not generate heat directly from electricity but moves heat from the outside air or another source to the inside of the house. This allows a system to deliver several units of useful heat from one unit of electricity. With the increasing electrification of homes, efficiency is also important in terms of overall electricity demand, and longer-term solar and battery storage planning, as they rely more on the grid for heating, appliances and other loads.
But when it comes to how efficient heat pumps are, the answer is not set in stone. This depends on outside temperatures, the design of the heating system, the flow temperature, the level of insulation and the amount of heat required on a property. A heat pump that performs well in moderate climates will consume more electricity in cold weather, and the same type will produce different results in two homes with varying insulation and radiator sizes.
This is why homeowners shouldn't rely on a single headline efficiency score. COP and SCOP are good starting points, but real heat pump efficiency is tested by what happens between the equipment and the building over a full heating season.
Heat Pump Efficiency Explained Through COP and SCOP
COP and SCOP are both terms used to describe the efficiency of heat pump systems; However, they apply to different time frames. COP is an indicator of efficiency under a specific set of operating conditions, while SCOP shows a seasonal perspective. By considering both, homeowners can avoid making decisions based on a single laboratory number.
COP as a measure of instantaneous heat pump efficiency
COP is a ratio of useful heat output to the electric power input to the heat pump at a specific instant or a specific test condition. So, if the COP is 3, the system will generate about 3 units of heat per one unit of electricity. A higher COP thus means that the heat pump performs better under those conditions. COP varies, however, with outdoor and water temperature and heating demand, and should not be considered a guaranteed value throughout the year. The COP is only a snapshot of performance and should not be the only measure used when comparing heating technologies for a homeowner.
SCOP as a better indicator of seasonal heat pump heating efficiency
Seasonal Coefficient of Performance (SCOP) provides a better indication of the heat pump heating efficiency throughout a larger range of temperatures and operating conditions during the heating season. This makes it more useful than single COP value for a comparison of the performance of systems over a typical year. During mild conditions, a heat pump can achieve an impressive COP, but become less efficient in colder weather or at higher flow temperatures. SCOP better reflects that variance, allowing homeowners to compare models on a more representative basis of real-world seasonal use than on one test point.
Electrical input versus useful heat output when judging how efficient a heat pump is
To understand the efficiency of a heat pump, you must distinguish between the electrical energy required for operation and the heat delivered to the heat pump's application. A 3kW electrical input does not mean the house is only getting 3kW of heat as the heat pump is moving more heat from the ambient environment. This is not the same as direct electric resistance heating where ratio of electrical input to useful heat output is much closer to 1:1. It's also essential to maintain power and energy units clearly, The difference between kW vs kWh can be beneficial when contrasting equipment ratings with usage over time.
Seasonal Conditions That Change Heat Pump Performance
Even the best heat pump will not generate the same amount of heat pump efficiency all year round. Real performance is influenced by outdoor temperature, moisture, flow temperature and heat needs of the property. In the UK, in particular, This is significant because the heating needs can fluctuate significantly between mild autumn temperatures and colder winter conditions.
Outdoor temperature and its effect on air source heat pump efficiency
Air source heat pump efficiency generally falls as the outdoor temperature drops because the system must work harder to extract useful heat from colder air and raise it to the temperature required indoors. In mild climates, the gap between the outside and heating system air temperature is reduced and the compressor typically needs less electricity to produce the same amount of heat. Although it is possible to use air source heat pumps in sub zero temperatures, Homeowners should be aware that COP will fluctuate as opposed to staying constant during the heating season.
Defrost cycles and colder weather reducing short-term heat pump efficiency
When the temperature is cold and damp, moisture can freeze on the outside heat exchanger and can interfere with airflow. The system may then go back into the defrost cycle to reverse operation and remove the ice. During this period, electricity is consumed, but the heat pump cannot provide the same efficiency as it does for normal space heating. Defrosting is a normal operating feature and not a fault, although frequent defrosting can impact performance during the season. With appropriate commissioning, outdoor-unit placement, and maintenance, the heat pump can deliver reliable performance even in colder UK weather.
Flow temperature and heating demand influencing winter efficiency of heat pump systems
The temperature of water used in radiators or underfloor heating also influences the winter performance. A heat pump operating at lower flow temperatures is typically more efficient because it needs to provide less temperature lift. If they are too small, the system may have to heat the water to a higher temperature, which reduces heat pump efficiency. In colder weather, household heating needs also increase, even if the equipment itself is functioning properly, which in turn increases electricity use. Monitoring household electricity usage can help homeowners determine whether seasonal fluctuations are normal or whether usage has increased abnormally.
Property Design as a Driver of Heating Efficiency
As much as the equipment, a heat pump's performance depends on the property. Factors affecting the difficulty of the work are insulation levels, heat emitters and the accuracy of the original heat-loss calculation. Optimising these building parameters can enable energy-efficient heat pumps to run at lower temperatures while still providing good seasonality.
Insulation and draught reduction supporting an energy efficient heat pump
With good insulation, less heat will flow out of roofs, walls, floors, and windows, and an energy-efficient heat pump will need to work less to achieve comfortable indoor temperatures. Further reduction of heat loss around doors, windows, and other openings in the building envelope can be achieved through draught-reduction techniques. This means that in an inadequately insulated home, the heat pump might have to run longer or at higher temperatures to make up for heat loss from the home. This can lead to further savings in heating requirements if the fabric is improved first, giving the system the opportunity to run more efficiently throughout the season.
Radiator sizing and underfloor heating allowing lower operating temperatures
Heat pumps work best when they can provide heat at lower water temperatures than a traditional boiler. The bigger the radiator, the more surface area it offers, so rooms can receive the right amount of heat with water that isn't that hot. Underfloor heating, which covers a larger area, can be especially recommended. By using the correct emitter size, Better heat pump heating efficiency is therefore achieved by reducing the temperature lift the compressor has to work. Not all existing radiators need to be replaced, but they should be assessed against the heat required for each room.
Accurate heat-loss calculations preventing oversized or undersized systems
When selecting the right size heat pump, a detailed room-by-room heat-loss calculation is required. An undersized system could struggle in cold conditions and require additional heating sources more often, while an oversized system could cycle on and off more often than needed. Both conditions can negatively affect the practical heat pump efficiency and comfort. Insulation, glazing, ventilation and room size and design temperatures for outside should be taken into account. By sizing the heat pump appropriately, it is much more likely to run within its design specifications and maintain steady efficiency.
Air Source, Ground Source and Air-to-Air Efficiency Compared
The efficiency patterns of different heat-pump technologies are not the same, as they absorb heat from various sources. Outdoor air temperature fluctuates rapidly, while ground temperature varies less throughout the year. Air-to-air systems also differ from wet heating systems because they heat air directly, rather than heating water in radiators or underfloor circuits.
Air source vs ground source heat pump efficiency across changing seasons
When comparing air source vs ground source heat pump efficiency, the ground-source system provides a more consistent heat source, as ground temperatures vary less than air temperatures. Air-source systems can be very efficient in cold weather but suffer most from the seasonal drop as temperatures fall. Ground-source heat pumps can deliver more consistent performance throughout winter, though they tend to be more complex to install and require the right ground conditions, area, or boreholes. Efficiency is not the only factor in choosing between the two; it should be based on the condition of the property, installation feasibility, heating demand, and overall system design.
Ground temperatures supporting more stable heat-pump performance
Ground-source heat pumps draw heat from underground pipes or boreholes that have relatively stable temperatures throughout the year compared to the air. This smaller variation can lead to a smaller temperature lift during cold periods of time and more stable seasonal performance. But, even when the theoretical efficiency of heat pump equipment is high, the proper size of the loops, the flow temperatures and the building heat demand are essential. Ground-source systems also require more work and a higher initial installation cost, and the efficiency benefits must be weighed against site considerations, building type, and the family's heating needs.
Air to air heat pump efficiency for space heating without wet radiators
Air to air heat pump efficiency can be excellent since the heat is transferred directly into the air inside rather than heating the water in the central-heating system. Many units can also cool in the warmer months, so they benefit properties that need both functions. But, most often, domestic hot water is not available in the air-to-air systems, which means another solution may be needed. They are only truly effective when certain parameters are met, such as ambient weather, internal temperatures, correct system size, and ventilation, and are therefore best suited to some open-plan, electrically heated properties, not every UK home.
Heat-pump type
Main heat source
Efficiency pattern
Common UK application
Main consideration
Air source
Outdoor air
More variable with outdoor temperature
Whole-home heating and hot water
Efficiency can fall during colder weather
Ground source
Ground
Generally more seasonally stable
Larger properties with suitable ground access
Higher installation complexity and cost
Air-to-air
Outdoor air
Efficient for direct space heating
Selected homes, extensions and open-plan areas
Usually does not provide domestic hot water
Identifying the Most Efficient Heat Pump for a Home
The most efficient heat pump will not necessarily be the one advertised with the highest COP. The equipment's effectiveness depends on its compatibility with the property, climate conditions, and heating system. When comparing seasonal efficiency data, the correct sizing and installer design will provide a better idea of the amount of electricity the system might need throughout the entire heating season.
SCOP, operating temperature and climate data when comparing the most efficient heat pump
SCOP is one of the most useful metrics when comparing heat pumps, since it accounts for performance across a range of test points and seasons. The Buyer should also verify the temperatures at which published figures were obtained, including the required temperature of the heating water. An efficiently working system operating at a 35°C flow temperature might not function the same way if the property requires 50°C or higher. Therefore, the UK climate, winter temperatures, and the home's heat requirements should be considered alongside the headline SCOP before comparing models.
Correct system sizing when choosing the most efficient air source heat pump
The most efficient air source heat pump is selected by ensuring that the heat pump capacity matches the property's calculated heat loss. If it is undersized, it might not keep you comfortable in the colder months, and if it is oversized, it cycles more often and does not operate in its most efficient zone. This means that larger doesn't necessarily equal better. Select capacity based on room-by-room heat loss, expected outdoor design temp and anticipated heating-emitter requirements as calculated by the installer. An appropriate size lets the heat pump run more evenly and makes the dwelling unit even more efficient and comfortable during a season.
Installer design quality carrying as much weight as headline efficiency ratings
Even the most efficient equipment will not perform well if the overall heating system is poorly designed. However, a heat pump's efficiency is affected after installation by pipework, radiator sizing, flow temperatures, controls, and commissioning. For this reason, an installer should not only inform users about the recommended model, but also the assumptions used to calculate heat loss and the expected operating temperatures. When choosing a system, homeowners should compare system designs and not just the brand or headline efficiency. Proper installation design and correct equipment sizing can deliver better real-world performance than a higher-rated heat pump installed under the wrong conditions.
Improving Heat Pump Efficiency After Installation
After installation, system operation significantly affects heat pump efficiency, while good design supports strong performance. Flow temperatures, maintenance and control settings can all influence the amount of electricity required to achieve the desired comfort level. Simple system changes can be more effective than continually turning the system on and off, or cranking it up out of proportion.
Weather compensation and steady operation improving heat pump efficiency
Weather compensation: This automatically changes the heating-water temperature depending on the outdoor temperature. In mild weather, the system can be set for a lower flow temp and colder weather will cause the system to increase temp when a higher heat is needed. This can make the heating pump more efficient, as it does not require very hot water year-round. Heat pumps also work well when the internal temperature can be kept fairly constant, rather than frequently reheating a cold house. Homeowners should have the proper controls and should not run the heat pump the same way they would a traditional boiler, hoping for hot, quick bursts of heat.
Lower flow temperatures reducing electricity needed for space heating
Reducing the flow temperature can improve heat pump heating efficiency because the compressor has a smaller temperature difference to overcome between the heat source and the heating system. The lowest suitable setting depends on the size of the radiators or underfloor heating, the outdoor weather, and the property. Temperatures are not lowered just to make rooms more comfortable; the goal is to find the lowest setting that still achieves the desired room temperature. For a given home, a well-sized emitter combined with good insulation creates more flexibility to operate efficiently at lower emitter flow temperatures.
Servicing, system balancing and controls protecting long-term performance
Also, if the heating system is not properly balanced and maintained, the heat pump efficiency system may not be as efficient in the long run as it could be. Blocked filters, incorrect control settings, poor water flow or faults can cause the equipment to work harder than necessary. Periodic servicing can help identify developing issues, and system balancing can help spread heat evenly around radiators or underfloor circuits. Homeowners should also note shifts in electricity usage and home comfort as an increase in energy use may be a sign that settings or equipment should be paid attention to. Maintaining the synergy between controls, emitters and the heat pump ensures efficient operation over time.
Managing the Electricity Demand of an Efficient Heat Pump
There is a potential for improving the efficiency of the heat pump and hence the amount of electricity needed to produce a useful unit of heat, but even when the heat pump is efficient, it can be a significant electrical load for the house during the winter months. After optimising heating performance, homeowners can consider when electricity is needed and how solar generation or battery storage may affect broader home energy management.
Heat-pump electricity profiles alongside solar generation and household demand
The demand for heat pumps is highly seasonal, and electricity demand typically increases during colder times when space heating demand becomes more pronounced. However, the production is not the same with solar energy, so homeowners should make a comparison between the heating demand and daytime production, evening loads and other appliances before they choose the storage. A home energy monitor can help reveal when electricity is being consumed. This allows battery storage to shift available solar generation to later times without increasing the COP or SCOP of the heat pump itself.
EcoFlow STREAM 5000 for new solar, storage and electric-heating planning
Households without solar can use EcoFlow STREAM 5000 to help manage more coordinated solar generation, solar storage and future demand for electric heating. It offers a 5,024Wh capacity, 5000W PV input, 3000W AC output, and expandability for households that grow their storage needs. Homeowners should not size solar or batteries based only on the heat pump; they should also size them to cover heating and all other electric loads.
EcoFlow STREAM 5000
5.24kWh energy storage capacity for household energy management. Supports up to 4000W PV input for a professionally planned solar installation. Provides up to 3000W off-grid AC output for supported off-grid operation. Intelligent Mode+ manages stored and generated energy according to household demand. Compact 45.4kg design reduces the space required for installation. Expandable up to 90kWh if household storage requirements increase later.
EcoFlow STREAM AC 5000 for existing solar homes adding battery capacity
Once PVs are installed on a roof, there is no starting point. The EcoFlow STREAM AC 5000 is designed to work with an existing solar system, offering 5,024Wh of storage and up to 3,000W AC output. This can mean keeping more solar energy from the day for the rest of the house's needs, such as when the demand for electricity and heating persists after solar power has subsided. Thus, energy retrofit and energy planning are relevant, not replacing an existing solar installation.
Designed for households that already have solar panels and want additional storage capacity. Provides 5.24kWh of battery storage for retaining surplus solar electricity for later household use. Supports 800–3000W grid-connected AC output. Local Mode allows continued system operation when internet connectivity is unavailable. Intelligent energy management coordinates existing solar generation, battery storage and household consumption. Can operate as an extended storage device within an existing photovoltaic installation.
The COP alone is not sufficient to ensure a high efficiency heat pump. A system's efficiency over a full heating season depends on the material and thickness of the property insulation, the size of the emitters, accurate heat-loss calculations, SCOP, and outdoor temperature. This means the most efficient heat pump is typically not the one with the highest rating you can find, but the one that is the right size for your home and properly matched.
Weather compensation, reduced appropriate flow temperatures, balanced heating circuits, and routine maintenance are other factors that can enhance real-world performance after installation. These measures ensure the heat pump runs smoothly and prevent any unnecessary electricity consumption while maintaining comfort levels in the building.
After optimising heating efficiency, households can consider how they use the electricity they still need. EcoFlow STREAM 5000 is ideal for homes looking to build solar in the future and adding battery storage to power those needs; EcoFlow STREAM AC 5000 is for homes with existing solar installations that want to add battery storage and use more of their existing solar power outside daylight hours.
Why does air source heat pump efficiency fall in very cold weather?
When the outside air temperature drops, air source heat pump efficiency can decrease because it takes more effort to extract heat from the colder air and warm it to the desired indoor air temperature.
  • The temperature lift becomes greater.
  • Defrost cycles may temporarily increase electricity use.
  • Household heating demand is usually higher.
The heat pump will still work, but not as well as in colder weather and COP will be reduced.
Does turning a heat pump off overnight improve heat pump efficiency?
Usually, simply powering off a heat pump at night does not necessarily increase its heat pump efficiency. Heat pumps are more effective at delivering lower flow temperatures when the air temperature in the building is relatively stable. Cooling the property down a lot can make the system work harder to reheat it in the morning. Depending on insulation and the design of the heating system and the household comfort needs, a modest setback in temperature may be more appropriate than a total shut down.
Can an older house still use an energy efficient heat pump successfully?
Yes, an energy efficient heat pump can be applied to an older property, but this depends on the heat loss and the condition of the heating system.
  • Improve insulation where practical.
  • Check whether existing radiators are adequately sized.
  • Complete a room-by-room heat-loss assessment.
Older homes do not automatically require very high-temperature heating. Appropriate fabric improvements and good system design can allow a correctly sized heat pump to operate efficiently.
Can battery storage reduce the electricity consumed by a heat pump?
Battery storage does not directly reduce the amount of electricity a heat pump uses to generate heat. It primarily shifts when and where that electricity comes from.
  • It can store surplus daytime solar electricity.
  • Stored energy can support later household demand.
  • Smart charging may shift grid imports to suitable tariff periods.
The heat pump's lower electricity requirement results from better COP, insulation, and flow temperatures.
Can a home battery store solar electricity for heat-pump use overnight?
Yes, a suitably configured home battery can store surplus daytime solar electricity and make it available when a heat pump is operating later. However, during winter, the heating requirements can be very high which may not be able to be met by solar alone, so the battery may not be able to be fully charged from solar energy. It is therefore useful to base storage capacity on actual solar surplus rather than matching the battery size to the rated heat pump power, and to consider evening consumption and seasonal heating loads.
Home Solutions
