Are You Eligible for the Great British Insulation Scheme? Find Out Now
Feeling the chill when your heating is on? Watching your energy bill climb and wishing you could do something about it? You're not alone. Many of us here in the UK are living in homes that are simply leaking heat, and money, straight out of the windows and walls.
But what if there was a government-backed initiative designed specifically to help you tackle this? Good news: there is. It's called the Great British Insulation Scheme, and it could be the key to a warmer home and lower energy costs. This guide will walk you through exactly what the scheme is, how to check if you qualify, and the simple steps to get started. Let's dive in and see how you can stop overpaying to heat the great outdoors.
What Is the Great British Insulation Scheme?
In a nutshell, the Great British Insulation Scheme (or GBIS) is a government programme run by the Department for Energy Security and Net Zero (DESNZ). Its primary goal is straightforward: to help thousands of households across England, Scotland, and Wales slash their energy bills by making home insulation more affordable.
Think of it as a helping hand from the government to upgrade your home's thermal efficiency. By adding proper insulation to places like your loft or cavity walls, your home retains heat for much longer. This means your boiler works less hard, you use less energy, and you save a significant amount on your bills year after year. It’s a long-term solution for managing the average electric bill and gas costs. It's worth noting that this scheme often works alongside the wider ECO4 scheme, but with a broader eligibility net, which we'll get into next.
Great British Insulation Scheme Eligibility: Who Can Apply?
This is the big question, and the answer might be more inclusive than you think. The scheme has two main pathways to eligibility, and you only need to qualify under one of them.
Eligibility Based on Your Home
This is the most common route for many households. You're likely eligible if your home meets these criteria:
  • Your Council Tax Band: This is a key factor. Your home must be in Council Tax band A-D in England, or bands A-E in Scotland or Wales. This captures a huge number of properties across the UK.
  • Your Home's Energy Performance Certificate (EPC): Your property should have an EPC rating of D or below. If you don't have an EPC or can't find it, don't worry—this will be checked during the assessment.
  • Your Current Insulation: Your home needs to have little or no existing insulation in the area being assessed. For example, you might have less than 100mm of loft insulation (the recommended is 270mm+) or no cavity wall insulation at all.
Eligibility Based on Your Circumstances
The second pathway is linked to income and benefits. If you receive certain means-tested benefits, such as Universal Credit, Pension Credit, or Income-based Jobseeker's Allowance, you may qualify for more extensive support under the linked ECO4 scheme. The good news is that when you apply for the Great British Insulation Scheme eligibility check, the provider will typically assess you for both GBIS and ECO4 to see which one offers you the best support.
How to Apply for the Great British Insulation Scheme
Ready to take the next step? The process to apply for Great British Insulation Scheme funding is designed to be as smooth as possible for you, the homeowner or tenant. Here’s a breakdown of what to expect.
Step 1: The Quick Eligibility Check
Your first port of call is the official government channels or a trusted, Ofgem-regulated installer. You can use the Simple Energy Advice website or contact a certified installer directly. They will ask for basic details about your property, like your postcode and Council Tax band, to give you a quick, initial yes or no. This takes just a few minutes and involves no commitment.
Note: The service to check if you’re eligible for free or cheaper home insulation has now closed, but some energy suppliers are still accepting applications—check with your supplier.
Step 2: The Home Assessment
If you pass the initial check, the next step is a free, no-obligation survey of your home. A certified assessor will visit to confirm your home's suitability. They'll check things like your wall type (to see if it's suitable for cavity wall insulation) and measure your current loft insulation. This is a crucial step to ensure the recommended measures will actually work for your property.
Step 3: Installation by Certified Professionals
Once your assessment is complete and you agree to proceed, the scheme provider will arrange for a professional, certified installation team to carry out the work. All installers are vetted and must meet strict quality standards, giving you peace of mind that the job will be done right. The best part? You don't have to manage the relationship with the installer—the scheme handles that for you.
Note: The installation work must be completed by 31 March 2026, as the scheme will end then.
What Insulation Measures Are Covered?
So, what exactly can be installed under this scheme? The Great British Insulation Scheme focuses on the most cost-effective ways to reduce heat loss. The main measures include:
  • Loft Insulation: A classic for a reason. Upgrading your loft insulation is one of the simplest and most effective ways to trap heat.
  • Cavity Wall Insulation: If your home has cavity walls (built typically between the 1920s and 1990s), filling the gap with insulation can dramatically reduce heat loss.
  • Solid Wall Insulation: For older homes with solid walls, both internal and external insulation may be an option in some cases.
  • Underfloor Insulation: Stopping heat from escaping through the ground floor can make a noticeable difference in comfort.
  • Flat Roof Insulation: Specifically tailored for homes with flat roof structures.
Each of these measures targets a key area where heat escapes, helping you create a more sealed and efficient living environment. For those looking for immediate, tech-driven ways to manage power usage during peak times, pairing these home improvements with a reliable portable power station can offer further control over your energy consumption.
The Benefits of Improving Your Home's Insulation
Investing in your home's insulation isn't just about ticking a government scheme box. It's about making a tangible improvement to your daily life and finances. Here’s what you stand to gain:
  • Slash Your Energy Bills: This is the number one benefit. Proper insulation means your heating system doesn't have to work overtime. You'll use less gas and electricity, which directly translates to lower bills. It's one of the most effective permanent changes you can make to save energy and money.
  • A Warmer, More Comfortable Home: Say goodbye to cold spots, drafts, and constantly feeling like you need to wear a jumper indoors. A well-insulated home maintains a consistent, comfortable temperature throughout.
  • Reduce Your Carbon Footprint: Using less energy isn't just good for your wallet; it's good for the planet. A more efficient home contributes to the UK's broader net-zero goals.
  • Increase Your Property's Value: An energy-efficient home with a better EPC rating is increasingly attractive to potential buyers, potentially boosting your property's market value.
Making these insulation upgrades is a foundational step towards a more energy-independent home. But true energy resilience means being prepared for the unexpected and having control over your power, no matter the situation. This is where modern, clean energy solutions truly shine, complementing your home's new efficiency.
For managing the electricity you do use more effectively—whether during an unexpected outage, to avoid costly peak-time tariffs, or even for powering your garden shed or home office—a device like the EcoFlow DELTA 3 Plus Portable Power Station is a game-changer. Imagine a sudden power cut: while the neighbours are in the dark, your essential devices—lights, Wi-Fi router, fridge, and kettle—stay on, providing not just light but also peace of mind and continuity. Its compact size belies a powerful capacity and incredibly fast charging, meaning you're never without power for long.
Capacity: 1,024Wh AC Output: 1,800W (3,600W surge) Solar Input: Up to 1,000W Battery Type: LFP (LiFePO₄, 4000+ cycles to 80+% capacity) Noise Level: Under 30dB Perfect for: Home backup essentials, camping & RV trips, powering tools and home offices.
For families seeking even greater capacity to run more appliances seamlessly during extended outages or for off-grid adventures, a scalable system like the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) offers a robust solution. This powerful power station provides 3000W of continuous AC output (6000W surge), enabling multiple high-power appliances — for example, an oxygen concentrator, a chest freezer and an induction hob — to run simultaneously, and its <10 ms UPS function instantly bridges power interruptions, so critical devices stay online without interruption.
Capacity: 2,048Wh (Expandable to 10kWh) AC Output: 3,000W (6,000W surge) Solar Input: Up to 1,000W UPS: <10ms Noise Level: Under 25dB Perfect for: Extended home backup, powering kitchens and medical devices, long camping trips.
The Great British Insulation Scheme presents a fantastic, often low-cost or no-cost, opportunity to fundamentally improve your living situation. If you're tired of high bills and a cold home, this could be the solution you've been waiting for. The eligibility criteria are broader than many realise, encompassing a wide range of households simply based on their Council Tax band.
Taking that first step to check your eligibility is the most important move. The process is straightforward, and the long-term benefits—a warmer home, lower bills, and a smaller carbon footprint—are undeniable. Don't let another winter go by paying to heat an inefficient home. Check your eligibility today and invest in your comfort and your future.
Is the Great British Insulation Scheme a grant?
It's not a direct grant that you pay into. Instead, the government obligates large energy companies to provide funding. This funding is then passed directly to you as a subsidy or a fully funded installation through registered installers, so you never have to handle the money yourself.
Is the scheme really free?
For many households, especially those on qualifying benefits or where the installation is straightforward, the insulation can be completely free. For others, there might be a heavily subsidised cost. The exact details will be confirmed after your home assessment.
How long does the installation process take?
From the initial eligibility check to completion can take several weeks. The survey itself is relatively quick, but scheduling the installation crew may take some time depending on demand in your area.
What if my home isn't suitable for the main insulation types?
If your home isn't suitable for the primary measures under GBIS, it's worth exploring the broader ECO4 scheme, which may offer other energy-saving improvements. Furthermore, to immediately gain more control over your power usage and calculate electricity bill impact from various appliances, investing in a modern solar generator system can be a brilliant complementary move.
Saving Bills
