Extreme Weather in the UK: Causes, Effects, Examples and How to Prepare
Predicting and dealing with extreme weather events as they become a normal part of daily life is challenging. While the UK generally enjoys a relatively mild climate, hot spells, wet and windy weather, significant storms, and snow and ice can present a significant threat to homes, businesses, transport, and outdoor activities.
It's important for anyone living in or travelling around the UK to have some knowledge of extreme weather, not just about wearing the right clothes. Being aware of the primary hazards, making an Emergency Kit, and having a plan for power outages can make severe weather easier to handle. Always having a backup power system ready, can also help you keep your important devices powered and some of your appliances working when the electricity goes out.
In this article, we will discuss extreme weather in the UK. It will help you to understand the causes and effects of extreme weather and how you can prepare yourself for this extreme weather.
What Counts as Extreme Weather in the UK?
Extreme weather is weather that is exceptionally bad, more extreme than what is normally experienced in a specific location, season, or time of year. No single temperature, rainfall amount, or wind speed identifies all extreme weather events in the UK. When evaluating how unusual an event is, meteorologists take into account the severity, duration, location, and impacts.
The geography of the UK also means that extreme weather in the UK may be very different in different areas. Strong winds and storm surge may affect the coastal regions, and flooding, drought, or extreme temperatures may occur in some inland regions.
Examples include:
  • Exceptionally high temperatures
  • Prolonged heatwaves
  • Exceptional rainfall
  • River and surface-water flooding
  • Severe windstorms
  • Heavy snowfall and ice
  • Thunderstorms and hail
  • Prolonged dry weather and drought
It does not take much for an event to be disruptive if it affects only parts of the country. A severe storm or precipitation event can be very disruptive within a relatively small geographic area.
Causes of Extreme Weather in the UK
There are several factors behind severe UK weather. Some are linked to short-term atmospheric patterns, while others are associated with longer-term changes in the climate.
Jet Stream Patterns
The jet stream is a stream of air in the upper-level atmosphere that can affect weather systems in the UK as well as in the rest of Europe, and can move at high speeds. It can influence the movement of highs and lows, and its shape and position can influence that movement.
If the weather pattern is persistent, the same type of weather may persist in a given area for a longer period. This can impact extended periods of rain, drought, cold, or hot conditions depending on the configuration.
Atlantic Weather Systems
The Atlantic Ocean has a significant effect on the UK. During autumn and winter, low-pressure systems can roll over the Atlantic, bringing rain, strong winds, and storms.
These systems can cause damage to buildings, power lines, and trees, and disrupt transportation when they are deep or traverse sensitive areas, leading to loss of life and property.
Seasonal Weather Patterns
Different seasons naturally bring different risks.
Storms, snow, freezing temperatures, and ice are possible in the winter. June, July, and August can be hot, with thunderstorms and very dry weather. Heavy rain and fast-changing weather conditions can occur in the Spring and Fall.
Seasonal hazards may not be extreme hazards. The severity and persistence of the conditions are important factors.
Climate Change and Increasing Weather Extremes
The role of climate change in the UK's extreme weather is also crucial to the debate on the causes of extreme weather in the UK. An increase in temperature will lead to an increase in moisture in the atmosphere and an increase in the occurrence of some types of extreme heat.
There have been some significant high-temperature events reported by the Met Office in 2026. In July, the temperature in the UK weather record was at least 35°C for the first time in May, June and July.
This is not to say that climate change is the only cause of individual storms, flooding and heatwaves. Climate change, however, has the potential to change the background conditions under which specific weather events happen.
Types of Extreme Weather Events in the UK
Numerous types of extreme weather events can occur in the UK. Some are only temporary, while others can last for days or weeks.
Heatwaves and Extreme Heat
A heatwave is defined as a prolonged period of time during which the temperature is unusually high. They have the potential to impact health, agriculture, transport, and infrastructure.
High temperatures for long periods can lead to dehydration and heat-related illnesses. Roads and railways may also be impacted by extended high temperatures, and dry vegetation may pose a wildfire hazard.
Extreme heat has already proved to be a great deal in 2026. The Met Office identified three different heatwaves between the end of spring and the end of July, including a very extended heatwave in July.
Heavy Rainfall and Flooding
Storms can overload drainage systems water courses. There are many types of flooding, such as:
  • Flash flooding
  • River flooding
  • Surface-water flooding
  • Coastal flooding
Flooding may cause damage to homes and businesses, and roads and railway lines are potentially unsafe or unusable. The impact of relatively localised rainfall can be significant.
Severe Wind and Storms
Damage may occur due to strong winds, which can topple trees, damage roofs, and disrupt power lines. Severe weather may also lead to high winds and heavy rain, lightning, or hail.
One of the most disruptive effects that can result from a big storm is a loss of electrical power. If the power is off, it may impact your lighting, phone calls, refrigerator, and charging of your necessary devices.
Heavy Snow and Ice
In many areas of the UK, it is more likely to get snow than rain, but heavy snow and ice can disrupt large areas.
Roads may be difficult to use, public transport could be delayed or cancelled, and remote communities may be temporarily inaccessible. Frozen pipes can also be caused by freezing temperatures.
Thunderstorms and Lightning
Thunderstorms may bring multiple hazards including heavy rainfall, lightning, sudden strong wind gusts and hail.
Heavy rain falling from lightning showers can lead to localised flooding, especially if large amounts of water are delivered in a short time period, and the drainage system cannot handle it.
Drought and Prolonged Dry Weather
The period of drought is much longer than a thunderstorm or a storm. Droughts can cause lower water supplies and impact agriculture, rivers, wetlands, and wildlife when they occur.
Dry vegetation can also increase wildfire risk, particularly when combined with high temperatures and strong winds.
The UK recently saw some extreme weather events. Some extreme weather events recently in the UK.
Extreme Weather Events in the UK Recently
The highest temperatures recorded in May, June, or July were 35°C or more, for the first time in all three months in the UK weather record. Additionally, the Met Office stated that there were eight days above 34°C in July, breaking the previous record of six days in 2020 and 1976.
The summer has also been abnormally dry in some areas. The UK rainfall series observed by the Met Office in the first 26 days of July saw only 21.3mm of rainfall, compared to 90.4mm in June.
It is worth considering these developments in terms of the importance of preparation. Weather extremes can impact various regions of the country in varying ways, and it can be unpredictable.
Therefore, it makes sense to review the most current official forecast and warnings when planning travel and camping/outdoor activities, rather than using historical expectations.
What Are the Effects of Extreme Weather in the UK?
The impact of extreme events in the UK can be more than just temporary discomfort.
Effects on Homes and Property
Flood water can cause structural damage, loss of electrical function, and damage to furniture. Roofs may be damaged by strong winds, trees may be knocked over, and freezing temperatures may lead to burst or frozen pipes.
Where heat is retained and ventilation and cooling are limited, extreme heat can cause other problems as well in the home.
Effects on Transport
Travel may be difficult or unsafe during severe weather conditions.
Road closures may be necessary due to flooding, and icy roadways can be hazardous. Fallen trees and other obstacles may result from strong winds. Heavy weather can also cause delays or cancellations to rail services or airports.
Effects on Energy and Power Supply
Storms may take out power lines and cause power outages. Meanwhile, extremes of cold or heat may drive up electrical consumption due to the use of heating or cooling appliances.
Even a brief power outage can cause a headache for households where phones, lighting, refrigeration, and other critical equipment require power.
Effects on Agriculture and Food Supply
Farmers are particularly exposed to weather conditions. Drought may lead to limited water supply, and flooding may cause damage to crops and fields.
Extremes can also have an impact on livestock and growth conditions. When severe weather persists, these effects can have wider implications for food production.
Effects on Wildlife and Natural Habitats
Extreme conditions are another factor that may affect wildlife. Habitats may be stressed by heat, drought, or lack of water, and flooding can also change ecosystems and affect breeding or feeding patterns.
The impact is not the same for all species and habitats, which means extreme weather is not equally harmful to all aspects of the natural environment.
Evidence of Extreme Weather in the UK
Understanding whether the weather is genuinely extreme requires more than simply saying that a particular day felt unusually hot or cold.
Over a long period of time, meteorologists refer to past data and measurements to make comparisons. Useful evidence includes:
  • Temperature records
  • Rainfall measurements
  • Wind-speed observations
  • Flood records
  • Historical weather datasets
  • Climate averages
  • Records of weather-related impacts
The Met Office provides one of the official sources of weather and climate information for the UK. To help scientists determine the abnormality of a given event, it is compared with the average.
For instance, the very unusual temperature experienced in 2026 can provide a measurable record of extreme weather in the UK, not just anecdotal evidence.
It is good that long-term records are kept, as the weather can range from one event to another. Climate trends are measured over a much longer time period than can be measured during a hot summer or wet winter.
Extreme Weather Hazards in the UK
Different types of severe weather create different hazards. Understanding these risks makes it easier to prepare appropriately.
Weather hazard
Possible risks
Extreme heat
Dehydration, heat exhaustion, wildfires
Flooding
Property damage, unsafe roads, contaminated water
Strong winds
Falling trees, structural damage, power cuts
Heavy snow
Travel disruption, isolation, frozen pipes
Ice
Slips, road accidents, transport delays
Thunderstorms
Lightning, flooding, hail
Drought
Water shortages, crop damage, wildfires
The most appropriate response depends on the specific weather warning. A heatwave requires very different preparation from flooding or a severe windstorm.
How to Prepare for Extreme Weather in the UK
Preparation doesn't have to be a complicated process. A small Emergency Kit and a plan for common disruptions can make a difference.
Creating an Emergency Kit
Consider keeping the following items readily available:
  • Drinking water
  • Non-perishable food
  • First-aid supplies
  • Torches
  • Spare batteries
  • Essential medicines
  • Warm blankets
  • Important documents
  • Portable phone chargers
  • Basic hygiene supplies
Keep the kit somewhere accessible rather than storing everything in a difficult-to-reach location.
Prepare for Power Cuts
It is a well-known fact that during extreme weather such as storms, power failures are a frequent problem.
Charge phones and other critical electronics before a significant weather event. Have alternative lighting and ensure you know where torches and batteries are stored.
A portable power station can offer another level of backup power for compatible equipment should an outage last for a longer period of time.
Featured Product: EcoFlow DELTA 3 Max Plus for Extreme Weather Preparedness
While the most common backups are typically generators that can run all of your household appliances, they're not always the best when a power outage is caused by severe weather. They can be used to power the essentials when the mains supply is not available.
The capacity of EcoFlow DELTA 3 Max Plus is 2,048Wh, and its AC output is 3,000W, providing ample power for a variety of bigger appliances and smaller electronics.
EcoFlow DELTA 3 Max Plus Portable Power Station (2,048Wh)
Industry-leading 3,000W AC output — runs garden tools, lighting, and appliances simultaneously. • 2,048Wh capacity, expandable to 10kWh — powers your garden room through a full day and beyond. • Charges to 80% in just 47 minutes with X-Stream fast charging technology. • Solar charging compatible — charge via solar panels for a fully off-grid outdoor setup. • Smart Output Priority — app-based presets automatically manage essential vs non-essential loads. • EcoFlow OASIS app — real-time monitoring of battery status, usage, and solar generation. • Built to last 10 years with automotive-grade full-tab LFP cells and 24/7 smart BMS protection.
Backup Power During Storm-Related Outages
If the power goes out due to the storm, phones, lighting, and other devices may lack a convenient power source to charge them. The DELTA 3 Max Plus is capable of powering critical electronic functions, such as lighting, communication devices, and laptops, together with smartphones.
It has a capacity of 2,048 Wh, which is much more than a normal small power bank. The length of time will depend on the devices being connected and their energy usage.
Additionally, the station can prioritise output, which means that users can prioritise the most important loads, rather than giving every device connected to the station the same priority. When EcoFlow mentions this feature, they refer to using it to prioritize equipment like a refrigerator during a power outage.
Useful During Cold Weather and Winter Emergencies
A power outage can be more difficult to deal with when the weather is cold, especially in homes that rely on electrically powered equipment.
The DELTA 3 Max Plus operates from a discharge temperature range of -10°C to 45°C, and features low-temperature protection in its battery management system. The charging temperature range is 0℃-45℃, which needs to be distinguished from discharge performance.
It's applicable for camping and outdoor preparedness in colder climates, where phones, lights, and other gear still require electricity in the cold.
The power station itself, however, is not a source of heat. When using a heating appliance, the suitability will depend on the wattage of the appliance as well as the output and remaining charge of the power station.
Power for Outdoor Emergency Preparedness
Extreme weather can impact those who are not in their homes. There is a need for a reliable camp electrical connection if mains power is not available.
The DELTA 3 Max Plus is compatible with lighting, communication devices, laptop computers, cameras, and select camping appliances. The 3,000W AC output is especially beneficial for items that require more power.
Thus, it can be used for two reasons – to provide power when the house loses electricity and to power outdoor activities when they require electricity.
Supporting High-Power Appliances
A higher-power output power station's practical benefit is that it is capable of operating equipment that small portable batteries are not capable of operating.
The DELTA 3 Max Plus is capable of running appliances such as a microwave, kettle, refrigerator, or blender, depending on their power needs, according to EcoFlow.
Outside of the campground, it might involve bringing a portable power supply or using a portable refrigerator to make hot drinks, or lighting devices without a campsite electrical hookup.
The actual running time will always vary depending on the appliance's wattage, frequency, and remaining energy in the DELTA 3 Max Plus.
Keep Food Fresh During Extreme Weather and Power Cuts
When there is a power outage because of bad weather, another real consideration is food preservation. The EcoFlow GLACIER Classic Portable Fridge Freezer can be useful for outdoor trips and as a portable refrigeration option when mains electricity isn't readily available.
EcoFlow GLACIER Classic Portable Fridge Freezer (35L / 45L / 55L)
Available in 35L, 45L, and 55L — fits 58, 72, or 90 cans of 330ml soda respectively. • Dual-zone storage (45L & 55L only) — keeps fresh and frozen food simultaneously with precise ±1°C temperature control. • Keeps items chilled at 4°C for up to 43 hours (35L) or 39 hours (45L/55L) with the optional plug-in battery. • 40% more compact than standard electric coolers — leaves more room for camera gear and camping equipment. • High-efficiency copper wire compressor delivers 40% lower power consumption than standard fridges. • IPX4 weather resistance — suitable for outdoor and in-vehicle use. • EcoFlow app control — monitor and adjust temperature remotely via Wi-Fi or Bluetooth.
Protect Fresh Food During Power Outages
A portable fridge/freezer will be useful if the regular refrigeration system is not available, especially during a temporary power loss.
You can use it to store fresh meat, dairy products, fruit, vegetables, drinks, and ready-to-eat food – depending on the space available. It is not, however, a guarantee that food will be safe for an extended period of time during a prolonged emergency and should be considered as a supplemental refrigeration method.
This GLACIER Classic's insulation and sealing capabilities work to keep the temperature stable, and the compressor-cooled cooling system offers an ice cooler alternative.
Useful for Outdoor Adventures in Unpredictable Weather
The same setup is useful outside the home. So it's not always possible to keep food cold when traveling by car or going on a camping trip.
You have the flexibility to cook fresh foods instead of just foods that you can keep for a long period of time. It can also help make longer outdoor days more comfortable when the weather turns unexpectedly.
Practical Capacity for Different Needs
The GLACIER Classic comes in three capacities:
  • 35L: Up to 58 cans
  • 45L: Up to 72 cans
  • 55L: Up to 90 cans
The 35L model uses a single cooling zone that can be switched between fridge and freezer modes. The 45L and 55L models feature dual-zone storage, which can be useful when you need chilled and frozen food at the same time.
With the optional 298Wh plug-in battery, the manufacturer states up to 43 hours of cooling for the 35L model, while the 45L and 55L models can provide up to 39 hours under specified test conditions.
How to Stay Safe During an Extreme Weather Event in the UK
The correct answer will depend on the type of weather. Do not take advice or emergency instructions over official warnings.
During Extreme Heat
Stay hydrated and avoid unnecessary strenuous activity during the hottest part of the day. Maintain as cool a temperature as possible indoors and monitor individuals who could become more susceptible to heat.
Don't underestimate the severity of extreme heat. The Met Office in July 2026 issued a statement that estimates 2,700 more deaths in the UK for the heatwaves of May and June.
During Flooding
Never assume that shallow-looking flood water is safe to cross. Never walk or drive in flood water and obey evacuation or emergency orders.
If possible, relocate valuable items to an upper level in a building prior to flooding.
During Severe Storms
Avoid going outside if conditions are hazardous and avoid windows. Tie down loose items in the outdoor area before severe weather and refrain from unnecessary travel during hazardous weather.
In case of a storm that could affect electricity supply, charge critical devices in advance and ensure emergency lighting is available.
During Snow and Ice
Verify road and travel conditions before traveling. Ensure suitable footwear and warm clothing are worn, and have an emergency kit on hand if travelling is not an option.
Please share your travel plan and return time if you are going somewhere out of the way.
  1. What is extreme weather in the UK?
Extreme weather is weather that is extremely cold, hot, wet or dry, or is especially intense for a given time and location. These include extreme heat waves, flooding, extreme storms, heavy snow and ice, and extended drought.
  1. What causes extreme weather in the UK?
UK extreme weather events are due to atmospheric circulation, jet stream patterns, Atlantic weather systems and seasonality. Climate change is also impacting the chances and strength of certain extremes of heat and rainfall.
  1. What are the effects of extreme weather in the UK?
Impacts may range from property damage, flooding, transport disruption, power failures, agricultural losses, impacts to health, wildlife and natural habitats.
  1. What are some examples of extreme weather in the UK?
These include extreme heatwaves, severe storms, heavy rainfall and flooding, heavy snowfall, widespread ice, thunderstorms and droughts.
  1. What are the main extreme weather hazards in the UK?
Extreme weather events which pose a threat to UK health and safety include heat-related illnesses, flooding, strong winds, falling trees, snow and ice, lightning strikes, water shortages, and wildfires.
  1. What should I do during an extreme weather event in the UK?
Listen to official weather forecasts, follow emergency messages, avoid needless travel when weather is hazardous, and have supplies on hand. An emergency kit that includes food, water, lighting, first-aid supplies, and medicines/charging equipment can be helpful.
Although extreme weather may not occur as regularly in the UK as in some other places, when it does, it can have a serious impact. Homes, transport, energy, agriculture and natural habitats can be impacted by heatwaves, flooding, storms, snow and ice, thunderstorms and drought.
What we have seen in recent weather has demonstrated the need for preparation. One of the most unusual weather patterns that can occur in different areas of the country is the heat seen in 2026.
To stay informed, watch official weather warnings and be ready for hazards that apply to you. A "Kit" and backup charging can help to make power outages easier to handle.
The EcoFlow DELTA 3 Max Plus is designed for households and outdoor enthusiasts who require more power backup, with 2,048Wh of capacity and 3,000W of AC output, capable of powering a variety of essential devices and compatible appliances.
The EcoFlow GLACIER Classic can be used to complement the power station when camping, for a road trip, or for temporary refrigeration requirements, where food and beverages need to be kept cool without using mains refrigeration. It comes in various sizes as well as off-the-grid, battery-powered cooling, adding another practical aspect for outdoor situations.
The aim is not to forecast all extreme weather events in the UK. It is to be prepared to the extent that, in the event of a severe weather event, you are able to respond calmly and safely.
Tips
