EcoFlow RAPID
Magnetic Power Bank
EcoFlow RAPID Magnetic Power Bank
A Magnetic Fast Charging Revolution
*Only RAPID 10000mAh includes a smart display screen and in-app customisation.
EcoFlow Image
Coming Soon
EcoFlow RAPID Magnetic Power Bank 5000mAh
Charge iPhone 15 Pro 1.1 times[1]
Qi2 15W wireless charge Up to 30W input/output
Buy Now
EcoFlow Image
Coming Soon
EcoFlow RAPID Magnetic Power Bank 10000mAh
Charge iPhone 15 Pro 2.2 times[2]
Qi2 15W wireless charge Up to 65W input/output
EcoFlow integrates cutting-edge battery and software technology into everyday portable use with RAPID, the new magnetic charging experience.
EcoFlow Image
30W/65W
Fast cable charging
EcoFlow Image
Kickstand for
upright/side
view
EcoFlow Image
15W
Wireless charging
EcoFlow Image
EcoFlow Image
Recharge 0-70%
in just 33 min[3]
EcoFlow Image
Intelligent app control
(10000mAh)
EcoFlow Image
Universally
compatible*
EcoFlow Image
Smart
digital display(10000mAh)
EcoFlow Image
30W/65W
Fast cable charging
EcoFlow Image
Smart
EcoFlow Image
15W
Wireless charging
EcoFlow Image
EcoFlow Image
Kickstand for
upright/side
view
EcoFlow Image
(10000mAh)
EcoFlow Image
Recharge 0-70%
in just 33 min[3]
EcoFlow Image
Universally
compatible*
Remote Work
On-the-go
  • Remote Work
  • On-the-go
Give your 13-inch MacBook Air a boost with the RAPID 10,000mAh for an extra 8 hours of power. The RAPID 5,000mAh can also provide up to 4 hours of emergency power for your MacBook.
Intelligent control using the EcoFlow app
Healthy Charging Mode
RAPID includes an Energy Management System that helps the battery health. Turn on 'Healthy Charging Mode' in the app for longer battery life.
EcoFlow Image
Find My Device
You'll never have to worry about misplacing your power bank. With 'Find My Device', you can easily locate your power bank with the built-in buzzer.
EcoFlow Image
View Status
Gain comprehensive insights into your power bank's performance, including port voltage, current, power, and even temperature.
EcoFlow Image
Kickstand for upright/side view
Anti-slip magnetism
  • Kickstand for upright/side view
  • Anti-slip magnetism
1. Place it vertically on a desk, to use your phone as a digital clock or make video calls. 2. Lay it horizontally to comfortably watch movies.
Exclusive structure maintains a low temp
Using advanced car-grade ultra-low internal resistance technology, along with a special internal cooling system, we significantly reduced magnetic charging overheating issues.
EcoFlow Image
Temperature sensor for real-time monitoring
RAPID's temperature sensor monitors the power bank 50 times per second, that's more than 4 million daily checks to prevent the power bank from overheating.
4.32
milliontimes per day
Power Up On the Go*
iphone16
90%
iphone16
iphone16 Pro
88%
iphone16 Pro
iphone16 Pro Max
67%
iphone16 Pro Max
iphone15
95%
iphone15
iphone15 Pro
90%
iphone15 Pro
iphone15 Pro Max
73%
iphone15 Pro Max
Wireless
Wire
Power Up On the Go*
Always ready
The battery maintains more than 95% of energy for a month[9]. Even if it isn't used for a while, you won't need to recharge it.
EcoFlow Image
EcoFlow RAPID Magnetic Power Bank (5000/10000mAh)
EcoFlow Image
Instruction Manual
EcoFlow Image
Warranty Card
EcoFlow Image
RAPID Magnetic Power Bank | Charge Everywhere | EcoFlow UK
