Combat the Air Fryer Running Cost Increase UK Now
Over the past few years, the air fryer running cost increase UK has become one of the most talked about subjects. Many people purchase air fryers to save household expenditure costs, particularly elec11tricity consumed by kitchen appliances. When purchasing an air fryer, the promise is faster cooking, lower energy consumption, and smaller electricity bills.
However, with the current Ofgem price caps, the amount you spend on electricity consumed by air fryers is increasing significantly. Each quarter, Ofgem revises the prices, chipping away your savings margins. This is why it’s crucial you know the answer to this question: how much does an air fryer cost to run in the current environment? Especially because the current electricity rates in the UK are no longer stable enough. Last year’s figures don’t apply today.
This guide looks at:
  • The air fryer running cost increase UK
  • Air fryer vs oven cost to run
  • Whether air fryer brand matters and its impact on electricity consumption
  • Recommended energy solutions to curb your air fryer running costs
  • Actionable tips for reducing your air fryer cost to run UK
Breaking Down the Air Fryer Running Cost Increase UK
How Much Does an Air Fryer Cost to Run in the Current Energy Market?
To get your air fryer cost to run, simply use this formula:
wattage ÷ 1000 × unit rate = hourly cost
In April 2026, Ofgem price cap was pushed to approximately 24.67p/kWh.
Note: All calculations in this article are based on this figure. Always check on the Ofgem official website for any changes to the figure to get the most current and accurate energy figure
Let’s do some quick math. In 2021, to run a typical air fryer the cost was 17 to 18 pence per hour. However, right now using the same air fryer for the same duration the price has increased significantly. Not that the air fryer has become less efficient, but because the grid is becoming more expensive.
Calculating the Hourly Air Fryer Cost to Run a 2000W air fryer
One of the most searched queries is the 2000W air fryer cost to run because most fullsize models sit at or around 2000W.
Using the current price cap of 24.67p/kWh, to run a 2000W air fryer for 1 hour, the cost you have to pay is 49p. For a 30 minute cooking session, the cost is roughly around 24-25p. If you are using it daily with an average 45-minute duration, the cost is approximately 37p. And translating this figure to monthly expenditure, the total amount is approximately £11.10.
Note: We have calculated these figures using the current Ofgem price cap of 24.67p/kWh. This figure is subject to change depending on Ofgem. Check out on Ofgem’s official website for the most up-to-date figures.
To know your appliance’s power consumption, check on the label. For a 1500W air fryer, the consumption is 37p per hour. For the 2400W model, the consumption pushes closer to 59p per hour.
Why Do Air Fryers Cost a Lot to Run Over Time?
Let’s look at a scenario before responding to the question: Do air fryers cost a lot to run? Let’s say that you are cooking chicken, chips, and vegetables, across three separate rounds and the air fryer runs for 90 minutes. If it's a 2000W air fryer, the total cost is about 74p. This means that batch cooking slightly increases your air fryer costs.
When you use keep warm modes that run at 400-600W for 15-20 minutes post cook, you are adding up the total consumption in a month. An air fryer on standby can consume 2-5W continuously. If you factor all this into your air fryer cost to run UK figure, the total electricity consumed increases significantly.
Air Fryer vs Oven Running Cost
Air Fryer vs Oven Cost to Run, Which Wins in a High-Tariff Environment?
In an air fryer vs oven cost to run debate, the air fryer is always favored. However, right now the gap is narrowing. Let’s look at the numbers: Right now using Ofgem’s current 24.67pKwh, a standard 3000W electric oven costs about 73.5p per hour. For a 2000W air fryer, the total cost is 49p.
This is almost a 50% difference per hour in consumption. However, if you add the additional factors, such as volume, pre-heat time, and how many mouths you are cooking for, the figure reduces significantly.
Analysing Air Fryer vs Oven Running Cost for Family Meals
The air fryer vs oven running cost split is clearest at the extremes.
Baked potato test: One large potato takes about 45 minutes in an air fryer and 60-75 minutes in a pre-heated oven. The air fryer cost is 37p while the oven cost (including pre-heat) is 61p. This is a clear win for the air fryer.
Sunday roast: You can fit a 2kg joint, roasties, and vegetables in an oven simultaneously. However, for an air fryer, you need to run separate rounds. This means the air fryer cost to run can match or exceed oven cost.
The final verdict in the air fryer cost to run vs oven debate is that the oven’s capacity can handle several foods at once, and therefore, slightly cheaper. However, for a single cook session, the air fryer is more cost effective than the oven.
The Pre-Heating Phase: Air Fryer Cost to Run vs Oven Energy Waste
To heat a standard electric oven to reach 200°C, it will take you approximately 10-15 minutes. If the oven is rated at 3000W, the pre-heat phase costs you around 7-12p before you even place a single tray inside.
Air fryers reach this temperature in under 3 minutes, and this is where they are more efficient than ovens.
Comparing Alternative Tech: Halogen Oven vs Air Fryer Cost to Run
For those who feel budget is a priority, let’s do a quick comparison of halogen oven vs air fryer cost to run. Standard halogen ovens run at 1200-1400W. This means they cost around 30-35p per hour. This figure is cheaper when we compare against that of the 2000W air fryer which we found to be 49p.
Note: For this calculation, we are still using the 24.67p/kWh price cap. This figure is subject to change depending on Ofgem. Check out on Ofgem’s official website for the most up-to-date figures.
Even though the halogen oven looks to be cheaper on paper, you are trading speed for cost. The 1400W oven can take 35 minutes to heat chicken wings, while an air fryer takes 20 minutes to heat the same chicken wings. This means, both can be using almost the same energy amount to heat the food. In the long-term, the air fryer can be more cost effective, despite it having higher hourly wattage.
Does Brand Matter? The Ninja Air Fryer Cost to Run
Another most searched query in the UK is the Ninja air fryer cost to run. The Ninja Foodi MAX Dual Zone operates at 2470W when both zones are active. Using the current rates, it costs you approximately 60.9p per hour. If you run both zones for 25 minutes per session, the cost is around 25p. This is a competitive figure because of the volume produced.
However, if only one zone is active, the wattage drops to around 1740W. This reduces your hourly costs to roughly 43p. The Ninja Foodi MAX Dual Zone air fryer is more efficient when you are using both zones to cook, because you are cooking two portions at the same time. In a single zone model, you are only cooking one portion. The hidden cost in premium air fryers doesn’t lie in wattage but in increased frequency of use.
Ninja Foodi MAX Dual Zone Air Fryer
Shielding Your Home from Fluctuating Energy Prices
If you are searching for air fryer running cost increase UK, you are experiencing a symptom of grid dependency. Each time Ofgem revises the price caps, they pass directly to your cooking costs. The only way to deal with this issue is reducing your reliance on grid electricity, especially for high-consumption appliances, such as refrigerators, air conditioners, and water heaters.
With plug-in solar battery systems, anyone can access these modern energy solutions without incurring expensive installation costs. You can charge the batteries during off-peak or solar hours, and use the stored energy for cooking and running other kitchen appliances. With this, you are shifting from worrying about how to reduce energy you consume to controlling where your electricity comes from. That’s what smarter households are now doing to keep household electricity costs low.
Recommended Energy Solutions for UK Households
EcoFlow STREAM Series Solar Plant
Installing the EcoFlow STREAM Series Solar Plant can effectively tackle the root cause of air fryer running cost increase UK, which is grid dependency.
Instead of making you feel the pinch of each Ofgem price cap increase, the STREAM series lets you charge from solar panels during daylight, store that energy, and use it when cooking. If you run your 2000W air fryer from stored solar energy, you can bring your per-session cost to near zero once you recover the system investment costs.
The STREAM series handles high-wattage and short-burst demand that air fryers create. With this smart solution, you have a practical buffer against ongoing tariff charges and also a cost-saving measure during stable rate periods.
EcoFlow STREAM Ultra Pro Solar Plant
All-in-one hybrid system with energy storage and a built-in microinverter High solar input of up to 2,800W for capturing more solar energy 2,300W AC output sufficient to run two appliances at the same Scalable capacity from 1.92kWh up to 11.52kWh to match your increasing energy needs LFP battery that lasts up to 6,000 cycles, giving you around 15 years of use Low-light solar capture for generating power even on cloudy days AI-powered time-of-use (TOU) capabilities that automatically charges and discharges based on cheap and peak electricity pricing Runs at under 30 dB which is quieter than a library whisper
EcoFlow STREAM Ultra X Home Solar Battery
If you are exposed to the air fryer running cost increase UK, the EcoFlow STREAM Ultra X Home Solar Battery is built to help you keep your electricity consumption costs low. If you have a large household, you may run your air fryers in multiple daily cycles. With a high-capacity home battery with whole-home integration, means that you are not using electricity from the grid. You are using solar or energy stored in the STEAM Home Solar Battery. This battery is designed to handle higher continuous output loads, especially when you are running an electric kettle alongside a 2470W Ninja air fryer.
Large 3.84kWh capacity that can store enough energy to keep you online for days 6000 life cycles that ensure dependable power for fifteen years 2000W solar input for quickly recharging the battery Four MPPT trackers for harvesting energy efficiently even in shade IP65 rating that guarantees the unit can withstand harsh weather Silent 30dB operation guaranteeing no noise disturbance at home 10-year warranty giving you long term protection
Actionable Tips to Reduce Your Air Fryer Cost to Run UK
If you are looking for ways to reduce air fryer cost to run UK, implement the following measures:
  • Use preset programmes to calibrate temperature and time more precisely and avoid manual setting to cut unnecessary runtime
  • Clean the heating element regularly to remove grease and residue that force the element to work harder to reach temperature
  • Cook in one round to eliminate the second and third batch wherever possible
  • Charge a power station during the day and draw from stored solar energy at dinner time rather than peak-rate grid electricity
  • Power down immediately, don't leave the keep warm mode running
Future-Proof Your Kitchen Today
The air fryer running cost increase UK is not a temporary disruption but a structural shift. When grid-tied energy costs increase, your kitchen energy costs also increase. Air fryers are designed to be more efficient cooking methods. However, efficiency alone cannot protect you from rising unit rates. To deal with this issue, you have to address the source of the problem, where your electricity comes from. Transitioning to stored solar energy can help you keep your kitchen running costs low. This means that any changes to price caps won’t affect your energy costs. If you are tracking your bills closely, this move is not an extravagance but a logical next step toward low energy costs.
EcoFlow provides UK households with smart, sustainable energy solutions for eliminating dependency on the national electric grid. We have built a vast catalog of products that includes solar panels and battery systems. These smart solutions can help you capture, store, and use power on your own terms. When you integrate them into your household, you are effectively minimizing your energy costs which in turn helps you keep your annual expenditure low. Explore our energy-saving bundles today and take the first step toward a more self-sufficient, low-cost home.
Air Fryer Running Cost Increase UK Frequently Asked Questions (FAQs)
  1. Is an air fryer still cheaper than an oven after the energy price increase?
Yes, an air fryer is cheaper than an oven for meals up to 2-3 portions. In air fryers, there is no pre-heating required and they come with a lower wattage compared to ovens, keeping their operational costs lower. However, when you need large batch cooking, the oven can be cheaper than the air fryer.
  1. Can I run a 2000W Ninja air fryer off a portable power station?
Yes. A portable power station such as the STREAM Ultra X is designed to handle high-wattage kitchen appliances, including 2000W+ air fryer models, across normal cooking cycles.
  1. How many solar panels do I need to run my air fryer for free?
On a clear day, a standard 400W solar panel can generate around 1-1.5kWh. This energy is enough to charge a storage unit covering 2-3 air fryer cooking sessions daily, especially if you pair it with an EcoFlow STREAM system.
Tips
