Why Does My Phone Get Hot: Reasons and How to Prevent It
You’ve probably been there—your phone suddenly becomes uncomfortably warm, apps slow down, the battery drains faster than usual, or worse, the screen pops up a warning telling you it’s “too hot to function.” It’s annoying, inconvenient, and sometimes downright alarming, especially when you rely on your phone for navigation, work, photography, or staying connected on the go.
While overheating is common, especially during heavy use or extreme weather, it isn’t something you should ignore. The good news is that most causes are easy to understand, and even easier to fix once you know what to look for. So why does your phone get hot in the first place, and what can you do to stop it? Let’s break down the most common reasons and the practical steps you can take to keep your phone cool, whether you’re dealing with a biting cold Prairie winter or a sunny summer hike in Banff.
Symptoms of Phone Heating Issues
Before you start digging into the causes, it helps to know what overheating actually looks like. Your phone will usually give you a few warning signs, its way of letting you know something isn’t quite right.
1. Device Feels Hot to the Touch
This is the most obvious sign that your phone is overheating. If the back, sides, or especially the area around the camera module feels uncomfortably warm or even too hot to touch, it’s clear your device is struggling with heat. It’s a good idea to give it a break and let it cool down before continuing to use it.
2. Sluggish Performance or Lagging
When your phone gets too hot, its processor kicks into something called "thermal throttling." This is a safety measure where the CPU slows down intentionally to reduce heat. As a result, you’ll notice apps lagging, screens stuttering, or frustrating delays when trying to open or use different features. It's a clear sign your phone is working hard to cool down.
3. Screen Dimming or Turning Black
Most modern smartphones automatically dim the screen when they start overheating. Since the display uses a lot of power, lowering the brightness helps reduce heat. In more extreme cases, the screen might even go black until the phone cools down enough to resume normal use.
4. Charging Stops or Slows Down
Excessive heat while charging can be harmful to your battery. If your phone gets too hot during charging, it might automatically slow down or even stop charging completely until it cools down to a safer temperature. This is a protective measure to help prevent any damage to the battery.
5. Temperature Warning Alerts
Most smartphones will display a clear warning when they’re overheating, often with a thermometer icon, telling you to let the device cool down before using it again. Ignoring this warning can lead to permanent damage, so it’s best to take a break and let your phone cool off when you see it.
6. Rapid Battery Drain
Heat and battery life don’t mix well. If you notice your battery percentage dropping quickly, even when you're not actively using your phone, overheating might be the cause. Higher temperatures speed up the discharge rate, causing your battery to drain faster than usual.
Why is My Phone Getting Hot
Understanding the reasons behind overheating is key to finding a lasting solution. It’s not usually just one thing causing the problem; overheating is often the result of a mix of external factors and heavy internal usage. By identifying the underlying reasons, such as running resource-intensive apps, exposure to heat, or charging habits, you can take proactive steps to help prevent your phone from overheating and extend its lifespan.
1. Intensive Gaming or Heavy Usage
If you’re spending a lot of time playing a demanding mobile game or constantly switching between heavy apps, your phone’s CPU and GPU are working overtime. This kind of intense processing is one of the main reasons your phone can heat up quickly. Whether you're gaming or juggling multiple tasks, your phone is working hard, which generates a lot of internal heat.
2. Direct Sunlight and High Temperatures
If you leave your phone on the dashboard during a hot summer drive through the Canadian Prairies in July, you’ll quickly run into an overheating issue. Phones absorb external heat from direct sunlight or a hot environment, making it hard for their cooling systems to keep up. The intense heat can cause the internal components to work harder than they should, which leads to overheating. Even if you’re just parked and not actively using your phone, the heat can build up quickly. This is why it’s best to keep your phone out of direct sunlight when you're outdoors, and never leave it in a hot car for too long.
3. Running Too Many Background Apps
Even when you’re not actively using an app, it can still run in the background, using up resources and generating heat. Whether it’s updating content, syncing data, or constantly refreshing, these apps can add up and cause your phone to heat up over time. The more apps running in the background, the harder your phone’s processor has to work, which can lead to higher temperatures. It’s a good idea to regularly check and close apps you’re not using to keep things running cooler and more efficiently.
4. Software Bugs or Outdated System
If your apps aren’t optimized well or your iPhone’s operating system (OS) is out of date, it can cause the processor to get stuck in a high activity loop. This means your phone is constantly working harder than it should, draining power and generating extra heat. Software bugs can sometimes prevent your phone from properly managing resources, causing unnecessary strain on the CPU. Keeping your apps and OS up to date helps keep everything running smoothly and prevents overheating caused by glitches or inefficiencies.
5. Faulty or Incompatible Charging Accessories
Using cheap or non-certified chargers and cables can cause inefficient power transfer, which leads to resistance and excessive heat at both the charging port and inside the battery. Poor quality accessories don’t deliver the steady power your iPhone needs, which can make your phone overheat while charging. Always stick to certified, high quality chargers and cables to ensure your phone charges safely and without causing unnecessary strain on the battery.
6. Streaming High-Quality Video for Long Periods
Whether you’re binge watching your favourite series during a long train ride across Canada or streaming a live 4K event, the combination of your phone’s screen, processor, and Wi Fi or cellular modem working at full capacity can lead to overheating. Streaming high quality video uses a lot of power, and after a while, your phone can struggle to keep up, especially if it's been running for hours. It’s a good idea to take breaks and give your phone a chance to cool down during long streaming sessions.
7. Aging or Damaged Battery
As your battery gets older, its chemical components begin to break down, which makes it less efficient and more likely to overheat during both charging and use. An aging battery struggles to hold a charge like it used to, and the extra strain can cause it to generate more heat than when it was new. If your phone has been in use for a while, this could be the reason why it’s getting hotter than usual, even during everyday tasks. If you're also wondering why my phone battery is draining so fast, it’s likely due to the declining capacity of an old battery, which can't hold a charge as effectively as it once did.
EcoFlow RAPID Mag Power Bank (10,000mAh, 15W)EcoFlow RAPID Mag Power Bank (10,000mAh, 15W)
How to Cool Down My Phone Immediately
If your phone is feeling hot, it’s important to cool it down quickly to avoid long term damage. Here are some steps you can take to bring the temperature down right away:
1. Remove the Protective Case Immediately
Your phone case, especially if it’s thick or dark colored, can trap heat and make things worse. Take it off right away to give your phone a chance to cool down properly. Without the case, the phone’s surface can release heat more easily.
2. Move the Device to a Shaded or Cool Spot
The first thing you should do is get your phone out of direct sunlight. If you’re outside, find a shaded area to place your phone in. If you're at home, move it away from any heat sources, like near a sunny window or a warm appliance. Even a slight shift to a cooler location can help reduce the heat and give your phone’s cooling system a chance to work.
3. Switch to Airplane Mode or Power Off
When your phone is hot, it’s working harder than it should. Turning on Airplane Mode will cut off wireless connections (like cellular, Wi-Fi, and Bluetooth), reducing the load on your phone and stopping it from generating extra heat. If the phone is still too hot, powering it off entirely is the most effective way to give it a full break. This will stop all activities and let the phone cool down without any distractions.
4. Place Near a Fan or Air Conditioning Vent
If you're inside and have access to air conditioning, use it to your advantage. Place your phone near a vent to let the cool air do its job. If you don't have air conditioning, a small desk fan will also help cool things down. Just make sure not to put your phone in the fridge or freezer, the rapid temperature change can cause condensation inside your phone, which could lead to serious damage.
5. Stop All Active Apps and Dim the Screen
Swipe away all active apps from the multitasking screen and manually lower the screen brightness to minimize the energy consumption and thermal output.
Apps running in the background are using up your phone's power and adding to the heat. Close out any unnecessary apps to give your phone a break. Also, manually lowering the screen brightness can help reduce heat, as the display is one of the biggest power drains.
How to Avoid Phone Overheating
The best way to deal with overheating is to prevent it in the first place. By adopting smarter habits, you can drastically reduce the chances of your phone ever reaching critical temperatures.
1. Manage High-Drain Apps and Settings
Regularly check which apps are consuming the most power in your phone’s battery settings. Apps that are constantly updating or running in the background can contribute to overheating. If you rarely use certain apps, consider uninstalling them or limiting their background activity. This will reduce the strain on your phone’s processor and help keep it cool.
2. Keep the Device Out of Direct Sunlight
It’s essential to be mindful of where you place your phone, especially when you're outdoors. Whether you’re on a patio in Montreal or camping in Banff National Park, try to keep your phone in a cool, shaded spot. If you’re carrying it around, use a pocket or keep it in a bag to avoid direct sunlight.
3. Select Stable Magnetic Charging Solutions
When you’re charging, make sure to use stable and efficient magnetic charging solutions. If the connection isn’t secure or the power transfer is inefficient, it can create excess heat. This is especially true when you’re using power banks on the go. To avoid this, consider using a high quality power bank like the EcoFlow RAPID Mag Qi2 Magnetic Power Bank (10,000mAh, 15W). With its stable magnetic alignment, this charger ensures smooth, efficient power delivery, keeping your phone cool while topping it up, whether you’re out in the Canadian wilderness or at a remote campsite.
With military-grade N54 magnets, RAPID delivers up to 11N of magnetism—strong enough to stay attached throughout the day, whether you're cycling or on the subway.
4. Ensure Efficient Power Delivery with Quality Cables
If you’re concerned about your iPhone overheating while charging, using the right cable is essential. Friction at the connection points and inefficient cables are common culprits when it comes to generating heat. Low quality or incompatible cables often cause the phone to overheat because they don’t deliver a consistent power flow, which makes your device work harder. A great solution is the EcoFlow RAPID Mag Qi2.2 Magnetic Power Bank (10,000mAh, 25W, Built-in USB-C Cable). This power bank comes with an integrated USB-C cable that provides a stable, high efficiency connection, helping avoid the heat caused by poor contact or inferior cables. By using this, your phone charges smoothly and safely, without unnecessary thermal stress, allowing for faster, more efficient charging when you need it most.
Go beyond standard wireless charging with 25W Qi2.2-certified speed—up to 3× faster than Qi1. Fully optimized for iPhone 17 and MagSafe-certified, it delivers the fastest, safest, and most seamless wireless charging experience.
5. Remove Cases During Heavy Loads
If you’re gearing up for a long gaming session or transferring large files, it’s a good idea to remove your phone case. While cases provide protection, they can trap heat, making it harder for your phone to cool down naturally. By taking the case off, you’re giving your device the best chance to release heat efficiently.
6. Update Software to Fix Glitches
Make sure your iPhone’s operating system and apps are always up to date. Developers regularly roll out updates that include performance improvements and bug fixes. These updates not only help with the smooth operation of your device but also reduce the likelihood of apps running inefficiently and generating unnecessary heat.
7. Adopt Smart Daily Habits
Small changes in how you use your phone every day can make a big difference in keeping it cool. For instance, try to avoid using your device while it’s charging, whether you’re gaming or streaming, both the battery and processor are working at full capacity, which generates extra heat. If your phone has a high refresh rate display, like 90Hz or 120Hz, consider switching it to 60Hz for regular use. This reduces power consumption and helps lower the thermal load. Also, be mindful of your screen brightness. Keeping it at maximum brightness for long periods is one of the biggest contributors to overheating.
Overheating is more than just a nuisance, it can impact your phone’s performance, battery health, and overall lifespan. By recognizing the signs, understanding the causes, and following these tips to prevent overheating, you can keep your device in top shape for the long run. Whether you’re tackling the snowy peaks of Whistler, enjoying a summer festival in Vancouver, or simply exploring your hometown, adopting smart habits and using quality accessories such as power banks will ensure your phone stays cool, reliable, and ready to capture every moment of your Canadian adventures.
Taking care of your phone’s temperature can help you avoid frustrating performance issues and extend its lifespan, so you can get the most out of it year after year. Stay mindful of how you use and care for your device, and it’ll stay with you through all your travels and everyday moments, no overheating required.
1. Why does my phone get hot when I am not using it?
If your phone heats up while you’re not actively using it, it’s likely due to background processes. These can include things like app updates, cloud backups (such as syncing photos), or even malware. Sometimes, a software bug can cause your processor or cellular modem to stay active, even when you’re not using the device. In Canada, where temperatures can drop to below freezing in winter, you may notice your phone heating up more often when it’s trying to perform heavy background tasks in cold weather.
2. Is it normal for my phone to get hot during an update?
Yes, it’s pretty common for phones to get hot during updates. Software updates require the processor to work continuously to download, verify, and install files. This constant high activity leads to a temporary surge in heat. While it's normal for the phone to warm up a bit, it shouldn't get uncomfortably hot. If it does, it might be worth checking that the update is progressing as expected and not running into issues.
3. Does overheating permanently damage the battery?
Yes, it can. Prolonged exposure to high temperatures, particularly over 35°C (95°F), accelerates the chemical degradation of your phone’s lithium-ion battery. This leads to a permanent reduction in its capacity and overall lifespan. If you’re out enjoying summer festivals in Vancouver or hiking the Canadian Rockies, keeping your phone out of direct sunlight is key to protecting the battery’s health.
4. Why does my phone get hot while charging?
Heat is a natural byproduct of the chemical reaction that occurs when charging your phone. However, excessive heat can be a sign of something else going on. It could be due to using the phone while charging, faulty cables or adapters, or an aging battery that struggles to maintain a charge. If you’re charging your phone while gaming or streaming, that can push it to heat up faster than usual.
5. Does wireless charging make the phone hotter than wired charging?
Generally, yes, wirelessly charging your phone tends to make your phone heat up more than wired charging. This is because wireless charging is less efficient, energy is lost as heat during the transfer from the charging pad to the phone’s internal charging coil. While it’s convenient, it often results in higher temperatures for your device. If you notice your phone overheating with wireless charging, consider switching to a wired charger to keep the temperature in check.
Smart Devices
