What Is the BC Hydro Solar and Battery Rebate, and How Much Can I Get?
BC Hydro’s solar and battery rebate is helping British Columbia residents move toward energy independence. With new incentives for rooftop solar systems and battery storage, homeowners can reduce their reliance on the grid while lowering costs.
Whether you’re already exploring solar power or considering it for the first time, understanding how this rebate works—and how to take full advantage of it—can make a big difference in your installation choices. In this guide, we’ll explain how the rebate works, who qualifies, how much you can get, and how various power solutions can fit seamlessly into your setup.
What Is the BC Hydro Solar Battery Rebate?
The BC Hydro Solar and Battery Rebate is a provincial program that supports the installation of solar photovoltaic (PV) panels and battery storage systems for residential customers. It's part of British Columbia’s broader effort to improve energy efficiency, reduce greenhouse gas emissions, and modernize the electrical grid.
BC Hydro offers a financial rebate to homeowners who install eligible equipment—typically rooftop solar panels combined with battery storage—on their primary residence. This makes clean energy adoption more affordable and helps homeowners build resilience during grid outages or peak-demand periods.
How Does It Work?
Once you install a qualifying solar-plus-storage system, you can apply for the rebate directly through BC Hydro’s program portal. The system must meet specific technical standards and be installed by a certified contractor. After submitting proof of installation and payment, you’ll receive your rebate via direct deposit or cheque, depending on program guidelines.
EcoFlow products like the EcoFlow DELTA Pro 3 Solar Generator (PV400W) or the EcoFlow DELTA Series Solar Generators offer modular power solutions that align well with this rebate's goals, especially in terms of energy resilience and off-grid capability.
The rebate framework promotes immediate energy savings and long-term grid reliability, giving you more control over your power and costs.
Who Is Eligible for the BC Hydro Solar & Battery Rebate?
Not every homeowner automatically qualifies for the rebate, so confirming your eligibility is essential before starting the installation process.
The program is open to residential BC Hydro customers who own their home and have a primary residence within the utility’s service area. You must install a qualifying solar PV system with battery storage, and both the installer and equipment must meet BC Hydro’s eligibility criteria. Rental properties, secondary homes, and commercial buildings generally don’t qualify.
Your chosen system may also need to meet specific capacity or performance thresholds, such as minimum wattage for panels or backup capability for batteries. Using reputable equipment like the EcoFlow DELTA 3 Series Solar Generator (PV160W) helps ensure your system meets technical benchmarks.
Double-check program requirements before purchasing any equipment, and always work with a certified installer to avoid disqualification.
How Much Can You Get From the BC Hydro Rebate?
The rebate amount you can receive depends on the size and scope of your installation. BC Hydro provides funding based on both the solar panel system and the accompanying battery storage solution.
Homeowners can qualify for up to $10,000 in combined rebates, broken down as $5,000 for battery storage and up to $5,000 for solar panel installations. However, the exact figures may vary depending on total system size and your energy usage history. There may also be income-based or region-specific enhancements to the base rebate.
These savings help offset the upfront cost of investing in long-term energy resilience. Portable systems like those in the EcoFlow DELTA lineup offer scalable, solar-compatible backup power that can work as part of your home’s energy strategy, whether on-grid or off.
Combining these rebates with potential federal incentives can significantly improve the total return on your solar investment.
How to Apply
Applying for the BC Hydro Solar and Battery Rebate may seem daunting, but the process is manageable when broken into steps. Preparation and documentation are key. Below is a detailed guide to help you navigate the application and maximize your chances of approval.
1. Check Your Eligibility
Start by confirming that you are a residential BC Hydro customer and that your property is a primary residence. Ensure you're located within the BC Hydro service area. If you live in a condo or multi-unit building, check whether your building qualifies and whether the installation can be attributed to your individual utility account.
2. Understand the Program Requirements
Review the specific program guidelines on BC Hydro’s website. Your system must include both solar PV panels and a battery storage component. There are minimum equipment specifications, safety certifications, and installation standards that must be met.
3. Choose a Certified Installer
All installation work must be completed by a certified contractor who is either listed with BC Hydro or is part of a recognized provincial installation program. These professionals are familiar with local code, safety standards, and rebate requirements.
4. Select Approved Equipment
All solar and battery components must appear on BC Hydro’s eligible equipment list. This ensures the technology meets performance, efficiency, and safety standards. EcoFlow’s solutions—such as the EcoFlow DELTA Series Solar Generators or EcoFlow Mountable Solar Panels—offer the kind of high-quality specs that rebate programs are built around.
5. Complete the Installation
Once you’ve selected your contractor and equipment, the system can be installed. Make sure the contractor documents every stage of the process and retains all receipts, equipment spec sheets, and installation photos. If any upgrades to your home’s electrical system are required, those should be completed and permitted before submission.
6. Collect and Organize Documentation
After installation, gather the following:
  • Proof of purchase (invoices)
  • Technical specifications of installed equipment
  • Photos of the installed system
  • Electrical permits or inspection reports (if applicable)
Installer certification or credentials
7. Submit the Application
Go to the BC Hydro rebate portal and complete the application form. Upload all required documents and double-check that names, dates, and amounts match your receipts. If your installer submits on your behalf, request a copy of the full submission for your records.
Taking time to understand each phase of the process improves your rebate outcome and sets you up for long-term energy savings. With products like the EcoFlow DELTA 3 Series Solar Generator (PV160W) or EcoFlow DELTA Series Solar Generators, you're working with solutions that support rebate compliance and future scalability.
How Long Does It Take To Receive the Rebate?
Once you’ve submitted all documentation and your application is approved, rebates are typically issued within 6 to 8 weeks. Processing times may vary based on demand and application completeness.
The BC Hydro Solar and Battery Rebate is a powerful incentive for British Columbia homeowners looking to control their energy use. By combining solar power with battery storage, you can lower your bills, boost home resilience, and reduce your carbon footprint—all while saving thousands of dollars. Whether you’re planning a full solar install or starting with modular systems like the EcoFlow DELTA Series Solar Generators, EcoFlow has the tools to help you make the most of the rebate and your renewable energy future.
