What to Do When Southern Ontario's Freezing Rain Comes
Winter in Southern Ontario is about more than postcard-worthy snowfalls and frozen lakes. It often brings the far more dangerous spectacle of freezing rain, where beauty and risk arrive at the same time. From the busy streets of Toronto to the quieter suburbs of London, Mississauga, or Kitchener, an ice storm can coat everything in a smooth, glass-like layer within hours, turning familiar surroundings into hazardous terrain.
Freezing rain in Southern Ontario regularly leads to widespread power outages, dangerously slick roads, and costly damage to homes and vehicles. Unlike heavy snowstorms, ice storms strain infrastructure in ways that are harder to manage and slower to repair. This guide explains why freezing rain forms in this region, how to prepare your home ahead of time, and the practical steps you can take to stay safe and comfortable when an ice storm disrupts daily life.
Causes of Freezing Rain in Southern Ontario
Understanding how freezing rain develops is the first real step toward being prepared for it. Southern Ontario’s location, climate, and proximity to large bodies of water combine to make the region especially vulnerable to these complex and often disruptive winter weather events.
1. Warm Air Above a Cold Surface Layer
Freezing rain forms when snow falls through a layer of warm air higher in the atmosphere and melts into rain before reaching the ground. As that rain then passes through a shallow layer of sub zero air near the surface, it becomes “supercooled.” These liquid droplets don’t freeze until they hit something solid, such as roads, sidewalks, trees, or power lines, where they instantly turn to ice and begin to accumulate rapidly.
2. Great Lakes Influence on Winter Storms
The Great Lakes play a major role in Southern Ontario’s winter weather patterns. During colder months, moisture rich air from the lakes frequently collides with advancing Arctic air masses. This interaction can slow or stall storm systems over areas like the Golden Horseshoe, resulting in long lasting freezing rain events rather than short, intense snowfalls that clear more quickly.
.webp)
.webp)
3. Rapid Temperature Changes Near Freezing
Temperatures in Southern Ontario often sit right on the edge of freezing during winter storms. A change of just one or two degrees can determine whether precipitation falls as harmless rain or becomes a severe ice storm. These narrow temperature margins make freezing rain difficult to forecast accurately and leave residents with little time to adjust plans once conditions begin to deteriorate.
Risks of Freezing Rain in Southern Ontario
As freezing rain begins to build up, its effects ripple through nearly every part of daily life. The combination of added weight from ice and the near total loss of traction creates conditions that are dangerous not only for drivers, but also for homeowners, utility workers, and pedestrians across the region.
1. Slippery Roads and Transportation Hazards
Black ice is one of the most serious threats during freezing rain events, especially on major routes like Highway 401, the QEW, and busy urban arterials. Unlike snow, ice is often invisible, offering little to no visual warning and virtually zero traction. This leads to sudden skids, multi vehicle collisions, and significant delays, often forcing public transit systems to slow down or suspend service entirely during peak hours.
2. Power Outages and Utility Damage
Ice is deceptively heavy. Even a thin layer of ice can add hundreds of pounds of extra weight to tree branches and overhead power lines. During major ice storms, this buildup is one of the leading causes of prolonged power outages in Southern Ontario. As branches snap under the strain, they frequently take down utility lines with them, leaving entire neighbourhoods without electricity for days while crews work through hazardous conditions to restore service.
3. Structural and Property Risks
Homes and outbuildings are also vulnerable during freezing rain. Heavy ice can loosen roof shingles, pull gutters away from the fascia, and cause weaker structures like carports, fences, or sheds to collapse. As melting ice refreezes, water can expand inside small cracks in siding, brick, or concrete, accelerating long term damage to a home’s exterior and increasing future repair costs.
4. Health and Cold-Related Injuries
The risks extend well beyond slips and falls on icy driveways or sidewalks. Extended power outages during freezing rain events can expose households to hypothermia if heating systems fail. Improper use of alternative heat sources, such as fuel powered heaters or generators, also raises the risk of carbon monoxide poisoning, making preparation and proper ventilation especially important during severe winter storms.
How to Protect Your Property from Freezing Rain
Preparation is the most effective defence against the unpredictable swings of an Ontario winter. By taking a few practical steps ahead of time, strengthening your home’s exterior and planning for energy disruptions, you can reduce damage, maintain comfort, and avoid last-minute stress when freezing rain arrives.
1. Ensure Reliable Backup Power
During an ice storm, the electrical grid is often one of the first systems to fail, sometimes leaving homes without power for days. Relying solely on flashlights or candles quickly becomes impractical, especially in prolonged cold. A high capacity home backup power station can keep essential systems running when outages occur. For example, the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power is designed to support heating systems and critical household appliances during extended winter outages, helping maintain a safe indoor temperature even as ice builds up outside.
2. Reduce Ice Load on Roofs and Gutters
Clearing gutters before winter sets in is a simple but often overlooked task. When gutters are clogged, melting snow and rainwater have nowhere to go, allowing ice to form and create damaging ice dams. These ice dams can force water under shingles and into attic spaces, leading to leaks, insulation damage, and costly repairs once temperatures rise.
3. Prevent Basement Flooding
Freezing rain is frequently followed by sudden thaws or heavy rainfall, increasing the risk of basement flooding. Making sure your sump pump is working properly is essential before winter storms hit. Keeping a backup power option such as the EcoFlow DELTA Pro 3 Portable Power Station in the basement allows sump pumps to continue running during outages, helping prevent water damage that can easily reach into the thousands of dollars.
4. Protect Pipes from Freezing and Bursting
Pipes in unheated areas, such as garages, basements, or crawl spaces, are especially vulnerable during extended cold snaps. Insulating exposed pipes reduces the risk of freezing. If the power goes out, allowing a slow trickle of water to flow from faucets can help relieve pressure and prevent pipes from bursting, which is one of the most common and expensive winter plumbing emergencies.
5. Reinforce Doors, Windows, and Exterior Seals
Before the freezing rain season begins, take time to inspect weatherstripping and exterior seals around doors and windows. Even small gaps can allow freezing moisture to seep in, where it can expand, crack frames, or leave doors frozen shut when you need them most. Proper sealing improves energy efficiency and adds an extra layer of protection during severe winter weather.
Safety Tips for Navigating Roads During Freezing Rain
While the best option during a Southern Ontario ice storm is to stay indoors with a warm drink, travel isn’t always avoidable. When major routes like Highway 401, the QEW, or local regional roads turn into skating rinks, your driving habits need to change completely. Ice offers almost no traction, which means your vehicle will not respond the way it does on snow-covered or even wet pavement, and small mistakes can escalate quickly.
1. Avoid Unnecessary Travel
The safest decision during freezing rain is to stay off the roads altogether. In Ontario, freezing rain warnings are often paired with advisories from the OPP urging residents to remain home unless travel is absolutely essential. Before heading out, check the Ontario 511 website or mobile app for live traffic cameras, road closures, and collision reports. If ice is forecast, consider postponing trips into the GTA or delaying errands until road crews have had time to treat surfaces.
2. Drive Slowly and Increase Following Distance
If you have no choice but to drive, speed quickly becomes your biggest risk factor. On ice covered roads, braking distances can increase by as much as ten times compared to dry pavement, even at relatively low speeds. In normal Canadian winter driving, a two second following distance may be adequate, but during freezing rain it is not nearly enough. Leave at least a ten-to-twelve-second gap between your vehicle and the one ahead to allow for gentle, controlled braking. It’s also important to remember that posted speed limits are designed for ideal conditions, not for highways coated in nearly invisible ice.
3. Use Winter Tires and Check Vehicle Controls
In Ontario winters, winter tire safety is more than a recommendation, it’s a major safety advantage. Their rubber compounds remain flexible in cold temperatures, offering better grip on ice than all season tires. Before setting off, make sure your defroster is working properly and set to high. Freezing rain can build up on your windshield faster than wipers can clear it, and warm air helps prevent ice from bonding to the glass.
4. Be Cautious on Bridges, Ramps, and Hills
Road design and geography play a major role during ice storms. Bridges and overpasses freeze faster than surface roads because cold air flows above and below them. Steep areas, such as sections of the Niagara Escarpment or the rolling hills around Caledon, can become especially dangerous. Slow down well in advance, avoid sudden inputs, and try not to stop on inclines whenever possible.
5. Know What to Do If You Lose Control
Losing control on ice is frightening, but calm reactions make a difference. If your vehicle begins to skid or fishtail, immediately ease off the accelerator. Avoid slamming on the brakes, which can lock the wheels and eliminate steering control. Instead, look where you want the vehicle to go and steer gently in that direction. If your car has ABS, apply steady pressure to the brake; if not, pump the brakes carefully to regain traction.
Freezing rain is an unavoidable part of winter life in Southern Ontario. While it has the power to slow traffic, close schools, and strain infrastructure, it doesn’t need to turn into a household emergency. By understanding how Great Lakes weather systems behave and taking practical steps to prepare your home ahead of time, you can face ice storms with far more confidence and less disruption.
The key to getting through an ice storm comfortably is autonomy. When power lines buckle under the weight of ice, having a dependable portable power station, such as the EcoFlow DELTA series allows daily life to continue with minimal interruption. With thoughtful preparation, a potentially stressful event can become a quiet winter weekend indoors, staying warm while watching the ice shimmer safely from inside a powered, protected home.
1. What is a freezing rain warning?
In Canada, a freezing rain warning is an official alert issued by Environment and Climate Change Canada (ECCC). These warnings are triggered when freezing rain is expected to last for two hours or more, or when ice accumulation is forecast to reach levels that create widespread hazards. When a freezing rain warning is issued, residents are strongly advised to complete home preparations, secure outdoor areas, and avoid non-essential travel, as conditions can deteriorate rapidly.
2. What temperature does it have to be for freezing rain?
Freezing rain occurs under a very specific temperature setup often described as a “temperature sandwich.” Higher up in the atmosphere, temperatures must be above 0°C, allowing snowflakes to melt into rain as they fall. Near the ground, however, there must be a thin layer of air below 0°C. This causes the raindrops to become supercooled, staying liquid until the moment they hit a surface like a driveway, sidewalk, or power line, where they instantly freeze into solid ice.
3. Does it snow in Southern Ontario?
Yes, Southern Ontario regularly experiences snowfall, including significant lake effect snow coming off Lake Huron and Georgian Bay. However, because the region sits farther south than much of the rest of Canada, it often lies along a weather “transition zone.” This is where cold Arctic air meets warmer southern systems, making Southern Ontario more prone to mixed precipitation such as sleet and freezing rain compared to colder, drier northern regions.
4. Should you put salt down before freezing rain?
Yes, applying salt or ice melt before freezing rain begins can be very effective. Pre-salting creates a protective layer on concrete or asphalt that prevents ice from bonding tightly to the surface. While slush may still form and require cleanup later, this approach helps avoid the thick, solid ice sheets that make driveways, sidewalks, and walkways especially dangerous and difficult to clear once fully frozen.
