Solar Shingles Canada: What They Are, What They Cost, and If They're Worth It
Solar shingles are making waves in the clean energy world and for good reason. They promise the same power-generating potential as traditional panels but with a sleeker, more seamless look. In Canada, where weather extremes are a real consideration, many homeowners are now wondering: are solar shingles practical, and are they worth the cost?
This article breaks down everything you need to know about solar shingles in Canada. From how they work to how much they cost, what incentives are available, and how they compare to panels, you’ll get a full picture to help make an informed decision.
What Are Solar Shingles and How Do They Work?
Solar shingles, also called solar roof tiles, are building-integrated photovoltaic (BIPV) products. That means they serve a dual purpose: they act as both roofing material and solar power generators.
Each solar shingle contains photovoltaic cells that capture sunlight and convert it into usable electricity. Once installed, they connect to your home's electrical system or a solar battery. The energy produced can either power your appliances right away or be stored for use later, depending on your setup.
Installation is seamless. The shingles are laid flat on the roof, just like asphalt or slate tiles, maintaining a streamlined appearance. That’s a big plus for homeowners who want renewable energy without the look of bulky panels.
In Canada, solar shingles are becoming more popular thanks to their durability. They're built to handle snow loads, strong winds, and even hail. They also meet local building codes and often qualify for solar incentives, which adds to their appeal for energy-conscious homeowners.
Solar Shingles vs Solar Panels: What's the Difference?
If you’re trying to choose between solar shingles and traditional panels, you need to understand their differences. They both capture solar energy, but they vary quite a bit in appearance, efficiency, and installation, etc.
Installation Style
Solar panels are mounted onto an existing roof using racking systems. They sit on top of your current shingles and can be tilted to improve sun exposure. Solar shingles, however, are installed in place of standard roofing material. They form part of the roof itself, offering a cleaner, more integrated finish.
Aesthetic Appeal
If looks matter, solar shingles usually come out on top. They blend seamlessly with your roof and suit modern homes or those with design restrictions, like heritage-listed buildings. Panels are more visible and can appear bulky, especially if placed on older or irregular rooftops.
Efficiency and Output
Solar panels tend to be more efficient. Most high-quality models reach around 21–24% efficiency, while solar shingles generally hover just under 20%. That means panels typically produce more power per square metre, especially when mounted at optimal angles.
A good example is the EcoFlow 100W Rigid Solar Panel, which uses monocrystalline cells and achieves a strong 23% conversion rate. It's designed to charge quickly and works well in fixed home systems or mobile power setups.
Another choice is the EcoFlow 175W Rigid Solar Panel. It has a higher conversion efficiency rate of up to 25%. Thanks to its N-Type TOPCon cell technology, it performs well even in low light or on hot days.
The EcoFlow 175W Rigid Solar Panel delivers outstanding performance with up to 25% conversion efficiency, thanks to advanced N-Type TOPCon cells. It’s built for reliable energy production in a wide range of conditions, from low light to high heat. A robust anti-corrosive aluminum frame, tempered glass, and IP68 waterproof rating ensure long-term durability.
Cost Considerations
Solar panels are more cost-effective per watt and usually offer a faster return on investment. Shingles, on the other hand, combine roofing and energy generation, which makes them a smart financial choice only when you’re already planning a new build or roof replacement.
Roof Flexibility and Orientation
Panels can be installed on a wide range of roof types—flat, sloped, or irregular—and their positioning can be optimized for sunlight. Shingles are tied to your roof’s existing pitch and layout, which limits your ability to fine-tune their orientation for better performance.
Overall, choose a solar panel system for home when your current roof is in good shape and you want maximum output for the lowest price. On the other hand, solar shingles work best during major renovations or new builds where design and structure are being planned from scratch.
Pros and Cons of Installing Solar Shingles
Choosing a new energy system is a big decision. Let's weigh the good and the not-so-good when it comes to solar roof shingles in Canada.
Pros:
  • Aesthetically pleasing: They blend in naturally with your roof, especially in upscale or design-conscious builds.
  • Space-saving design: Perfect for homeowners with limited roof space for traditional panels.
  • Dual function: Serve as both roofing material and energy source, saving space and time during construction.
  • Durability: Built to handle Canadian snow loads and harsh winters.
  • Long-term investment: Increase property value and reduce utility bills over time.
Cons:
  • Higher upfront cost: Significantly more expensive than standard panels.
  • Limited installer options: Fewer certified installers in Canada compared to solar panels.
  • Lower efficiency: You may need more shingles to achieve the same power output as panels.
  • Not ideal for all roofs: Best suited for new homes or major roof replacements, not simple retrofits.
How Much Do Solar Shingles Cost in Canada?
Solar shingles in Canada cost around $22 per square foot. For a standard 6kW system, that adds up to roughly $36,000, compared to about $29,000 for a similar solar panel setup. So, expect about a 20% higher upfront cost with shingles.
However, if you're building a new home or replacing an old roof, the cost difference starts to shrink. Since solar shingles act as both a roofing material and energy generator, you can subtract the price of traditional shingles from the total. For example, asphalt shingles often range from $3 to $6 per square foot.
Keep in mind that you'll still need the same supporting equipment, like an inverter and battery, regardless of which option you choose.
Rebates can help reduce your out-of-pocket expenses. Many provinces offer incentives, and federal programs can also apply. For example, the Canada Greener Homes Grant offered up to $5,000 per household for green upgrades. This grant could also be combined with local funding, making solar installations more accessible.
What to Consider When Choosing Solar Energy Shingles in Canada?
Not every home or homeowner is a match for solar shingles. Here are important things to think through before making the investment.
1. Roof Orientation and Pitch
Solar shingles are fixed in place, so they follow the angle and direction of your roof. South-facing roofs with a slope between 30–45 degrees typically perform best in Canada. If your roof faces east or west, or has a flatter pitch, energy output may be lower.
2. Local Climate and Durability
Canadian winters can be harsh, so look for shingles rated for snow, wind, and hail. Many solar shingles are built to withstand tough weather, but double-check the specs to ensure long-term performance in your region.
3. Efficiency and Available Roof Space
Since solar shingles are slightly less efficient than panels, you’ll need more surface area to generate the same amount of power. Make sure your roof has enough usable space to meet your energy needs.
4. Warranty and Manufacturer Reputation
Check both the energy production and roofing warranties. A good solar shingle should come with coverage for 20–25 years or more. Choosing a trusted manufacturer can also ensure product quality and easier access to support.
5. Incentives and Rebates
Explore available incentives in your province or territory. Some federal programs, like the Canada Greener Homes Grant, have offered up to $5,000 for solar-related retrofits. Pairing these with local rebates can improve the return on your investment.
Solar shingles in Canada offer a sleek, durable, and space-efficient way to go solar, especially if you’re building a new home or replacing your roof. While the upfront cost is higher, long-term savings, clean energy, and growing rebate programs are making them an increasingly viable option. If aesthetics, property value, and sustainability matter to you, solar shingles are worth a closer look.
Are solar shingles worth it?
Solar shingles can be a smart investment in Canada if you’re constructing a new home or replacing your roof. Unlike traditional panels, shingles integrate seamlessly with regular roofing materials, offering a clean aesthetic and eliminating bulky racks. Although upfront costs are higher—often 20–30 % more than standard PV panels—solar shingles generate comparable electricity (typically 50–60 W per shingle) and qualify for the same net-metering rates across most provinces. Over a 25- to 30-year lifespan, they can offset significant energy costs, particularly in regions like Southern Ontario or the Prairies where sunlight is abundant. If roof appearance and long-term savings matter more than initial outlay, solar shingles are worth considering.
Can you get rebates or incentives for solar shingles in Canada?
Yes. The federal Canada Greener Homes Grant provides up to $5000 for eligible solar retrofit projects—that includes solar shingles, provided they meet CSA certification and are part of an EnerGuide energy assessment. In addition, interest-free loans up to $40000 (10-year term) are available through the Canada Greener Homes Loan program for deeper retrofits. Many provinces also offer net-metering credits at retail rates (e.g., Ontario’s IESO program, BC Hydro’s Solar Incentive Program), which improve payback timelines. Always check your local utility or provincial energy office, as some municipalities provide additional rebates or low-interest financing.
What is the life expectancy of solar shingles?
Most solar shingles installed in Canadian climates have a rated lifespan of 25–30 years, matching or exceeding standard roofing materials. Leading manufacturers back this with product warranties that cover both performance (typically 25 years at ≥ 80 % output) and weather resistance (10–25 years against defects). Factors such as roof pitch, installation quality, and local weather (e.g., heavy snow loads in Alberta or hail in Saskatchewan) can affect durability. Routine maintenance—keeping shingles clear of debris and inspecting flashing—ensures shingles continue producing at designed efficiency throughout their life cycle. When properly installed, solar shingles can reliably power your home for decades.
Tips
