Solar Panel Kits: A Guide to Home & Outdoor Energy Solutions
Solar panel kits are becoming a go-to solution for Canadians looking to cut costs, gain energy independence, and live more sustainably. With prices for photovoltaics dropping and numerous government incentives, there’s never been a better time to invest.
Whether you need backup power for your home, your RV or cabin energy, or portable panels for outdoor adventures, today’s kits make it simpler than ever. This guide covers the key benefits, what’s included, and how to choose the right kit for your needs.
Why Solar Panel Kits Are Gaining Popularity
There are several reasons why solar panels, also called photovoltaics, are gaining in popularity in Canada. Let’s take a look.
Cost Effective
Photovoltaics have declined in price while gas and other energy sources continue to increase, making solar more appealing. Then, factor in the years of free energy they will produce after you achieve your return on investment, and it’s no wonder everyone is turning to them.
In Canada, all the great interest-free loans, provincial rebates, tax credits, and the Canada Greener Homes Grant are also making them more appealing than ever.
Energy Independence
Canada has frequent power outages, and we are not immune to the fluctuating market prices of fossil fuels and other energy sources. Having photovoltaics provides energy independence and security with less reliance on the grid, so you can always keep your family safe and comfortable.
Sustainability
Solar energy is clean and renewable, producing zero greenhouse gas emissions and no air, water, or any other pollution during its use phase. This will reduce your carbon footprint significantly and help protect the beauty of Canada’s air and water for the 25+ years they remain in operation.
Ease of Use
Many photovoltaic kits now make it incredibly easy to get started. Once set up, they require less maintenance than any other energy system since there are no moving parts to clean and lubricate. Simply rinse your panels with fresh water once or twice a year to keep them running optimally and occasionally check the connections to ensure wind, animals, and other forces of nature have not loosened them.
An image showing a house with EcoFlow solar kits in the yard
What’s Included in a Typical Solar Panel Kit?
Let’s take a look at the primary components of a solar panel kit.
  • Solar panels are the core of your kit. They create direct current (DC) electricity from sunlight via the photovoltaic effect.
  • Charge controllers may be preinstalled on your photovoltaics, or they may come as a separate component. They regulate the flow of electricity between the panels and your batteries, preventing overcharging. It's a good idea to choose products like the EcoFlow 175W Rigid Solar Panel, which already have charge controllers built in, so you can add battery storage at any time.
  • Wiring and cables are the final components. These are used to connect the panels and the inverter or battery that you are using.
Choosing the Right Solar Kit for Your Needs
Choosing the right solar kit for your needs all depends on how you are going to use it.
Home Backup
If you’re looking for home backup, start by making a list of what essential appliances you will want to run, like a refrigerator, freezer, lights, and medical equipment. Find their wattages and multiply them by the number of hours they need to run each day to get watt-hours (Wh).
Then add up your total Wh for each appliance, and that is your base daily energy needs. After, add at least another 20% to that value to allow for days when the system is not performing optimally, and that is the size of the system you need.
Finally, it’s always a good idea to choose a system that is easily expandable, like the EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits). These high-quality monocrystalline models are easy to set up, so you can quickly get your essential appliances back up and running. Also, if your energy needs grow, these kits make adding more panels easy.
RVs, Cabins, & Van Life
Compact size and portability are often key for setting up solar panels outdoors, such as in cabins, RVs, and vans. First, assess your daily energy needs, just like we did above. Also, factor in shading since that will significantly reduce photovoltaic efficiency.
This is where portability is often the best answer, since you can move it around throughout the day to achieve maximum production in tricky lighting.
The EcoFlow 400W Portable Solar Panel is a powerful panel with a 23% conversion efficiency that is among the industry’s best. It’s ideal for less-than-ideal locations and has an easy kickstand that allows you to move it around quickly as needed.
Day Trips & Outdoor Adventures
For day trips and other lightweight outdoor adventures, you’ll want something small enough to fit in a backpack, like a 110W compact portable solar panel. Look for ones that fold up and are lightweight. Also, look for durable models with an IP68 waterproof and dustproof rating.
An image of an EcoFlow 400W Portable solar panel
Can I Power My Entire Home With a Solar Panel Kit?
Yes, you can absolutely run an entire home using photovoltaics, but it requires some planning to ensure you get a properly sized system to suit your needs. You’ll also need sufficient battery storage so you can still have electricity at night.
Are Solar Panel Kits Easy to Set Up?
It depends. Some kits are designed for easy DIY and even “plug-and-play” type systems. At the same time, other systems may contain more components and may require some level of technical expertise.
Solar panel kits offer a cost-effective, low-maintenance way to harness clean energy, whether for home backup, off-grid living, or outdoor adventures. With the right size system and quality components, you can enjoy reliable power for decades while lowering your energy bills and carbon footprint.
With easy options like the EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits), there’s a kit for every need. Invest today, and start enjoying energy independence, savings, and sustainability for years to come.
Off-Grid Power
