Average Cost of Solar Panels in Canada Explained
The average cost of a residential solar panel system ranges from $2.50 to $3.50 per watt installed before incentives. This Canadian-dollar planning range was checked in September 2026.
It covers a full roof system tied to the grid, not loose panels alone. Tax, roof repairs, wiring upgrades, storage, loan fees, and grid work may raise your total.
If you also want stored energy, price it on its own. The EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) supports matching solar input and planned circuit backup. Storage doesn't promise lower bills or a shorter payback.
•7.2 kW AC output, expandable up to 21.6 kW with supported configurations • 6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 • Automatic battery self-heating below 0°C for cold-weather operation
Define what each quote includes before you compare the totals.
What Is the Average Cost of Solar Panels in Canada?
Installer assessing a Canadian home for a solar quoteInstaller assessing a Canadian home for a solar quote
The September 2026 planning range is $2.50 to $3.50 per installed watt. It reflects current Canadian market estimates, since no set price applies to every home.
Watts measure the array's power capacity. Kilowatt-hours measure the energy it makes over time. Solar firms use dollars per watt to compare systems of different sizes.
Installed project price before incentives ÷ solar array size in DC watts = installed cost per watt
The useful comparison is the complete installed cost per watt. The shelf price of one module leaves out most project work.
Compare the same scope in every quote. Remove batteries, roof replacement, loan costs, service upgrades, and other work before comparing the base solar panel cost.
Smaller projects may cost more per watt because permits and other fixed work cover fewer watts.
The table applies the range as simple arithmetic, not guaranteed prices.
DC system size
Cost at $2.50/W
Cost at $3.50/W
Scope
5kW
$12,500
$17,500
Before incentives and optional extras
6kW
$15,000
$21,000
8kW
$20,000
$28,000
10kW
$25,000
$35,000
What Does Solar Panel Cost Include?
A full quote often combines gear, design, labour, permits, checks, and the grid link. Tax, roof repairs, major wiring work, batteries, and loan costs may appear as extra charges.
The equipment list often covers modules, an inverter, racking, roof attachments, flashing, wiring, conduit, disconnects, labels, and monitoring. Some designs also use microinverters or module-level electronics.
Project work may include a site visit, roof review, wiring plan, permits, checks, and grid forms. Labour, lifts, travel, job management, and warranty support also affect the solar panel costs.
Portable solar panels serve needs that a fixed rooftop array doesn't. Their store prices don't show the full cost of an approved roof system.
Use the quote itself to check each item and any likely extra work.
Quote item
Often in the base price?
What to verify
Panels, inverter, racking, and wiring
Usually
Models, quantities, ratings, and warranties
Design, permits, inspection, and connection
Often
Fees, forms, and who submits them
Labour and access equipment
Usually
Roof access, travel, lifting, and workmanship warranty
Roof or structural work
Often separate
Repairs, engineering, cost, and timing
Electrical panel or service upgrade
Often separate
Scope, permits, utility work, and contractor
Battery storage
Separate unless bundled
Capacity, output, controls, and installation
Tax and financing
Varies
Cash price, tax, interest, fees, and total repayment
A low quote can become costly if it leaves out needed work. It may also use a smaller array, shorter warranty, or different gear.
How Much Will Solar Panels Cost for Your Home?
To learn how much solar panels will cost for your home, start with power use. Then choose your target offset and check the solar yield for your area.
Follow these steps to create a first budget:
  1. Gather at least 12 months of power use in kilowatt-hours.
  2. Add planned loads, such as an electric vehicle, heat pump, suite, or hot tub.
  3. Choose the share of yearly use you want solar to cover.
  4. Check local solar potential and ask the solar firm to model your roof.
  5. Find a first system size, then apply an installed price per watt.
Natural Resources Canada provides photovoltaic potential and solar resource maps. A final plan must also account for roof direction, tilt, shade, snow, gear, and system losses.
Target annual solar production in kWh ÷ local yield in kWh per kW per year = estimated system size in kW
Estimated system size in kW × 1,000 × installed cost per watt = planning price before incentives
These formulas give you a budget range, not a final design. Your solar firm must confirm roof space, grid rules, wiring limits, and planned output.
House size isn't a reliable input for the cost of solar panels. Two similar homes may not use the same amount of power. Roof space, shade, heating fuel, and future loads can also vary.
 Homeowner estimating solar size from annual electricity use Homeowner estimating solar size from annual electricity use
How Should You Compare Solar Quotes and Payback?
Compare the same project scope before you judge price or payback. Then test each output plan against local rates, export credits, fixed charges, and loan costs.
Start by dividing the pre-incentive cash price by the array's DC watts. Check that each solar firm uses the same power basis and includes the same work.
Review the planned first-year output and ask which sun data supports it. The quote should count shade, snow, clipping, downtime, losses, and panel wear.
Compare warranty terms for panels, inverters, racking, labour, output, and system tracking. Confirm who handles permits, meter work, roof review, and later service.
Use this table to compare two proposals without relying on their monthly payment alone.
Comparison field
Quote A
Quote B
Why it matters
DC system size
Fill from quote
Fill from quote
Confirms comparable capacity
Pre-incentive cash price
Fill from quote
Fill from quote
Removes financing distortion
Installed $/W
Calculate
Calculate
Normalizes system size
Estimated annual kWh
Fill from quote
Fill from quote
Shows expected production
Exclusions
List
List
Reveals possible later costs
Total financed repayment
If used
If used
Shows the full borrowing cost
These formulas can help you test the financial case:
Net project cost = cash price + financing costs + expected ownership costs − confirmed incentives
Simple payback in years = net project cost ÷ estimated annual net electricity savings
Simple payback has clear limits. Fixed service charges may remain after solar reduces grid purchases. Exported power may also receive a different credit from power used at home.
Rates, home use, output, upkeep, and gear faults can change the result. Treat payback as an estimate, not a promise.
Which Solar Incentives and Credits Can Reduce the Net Cost?
Solar support changes by province, city, power company, home, and project type. Check every rule before you count funding in your budget.
The Canada Greener Homes Grant is closed to new applicants. The Canada Greener Homes Loan stopped taking new applications in October 2025. New projects can't use either program.
Natural Resources Canada keeps a current list of home energy grants and loans by province and territory. Check the program page again before you buy gear or sign a contract.
Local aid may be a rebate, loan, tax break, or property-linked plan. A rebate lowers approved net cost, while a loan shifts payment and may add fees.
Net metering and self-generation credits affect future bills, not the project bill. Their rules and credit values differ by power company.
BC Hydro's July 2026 rules cover area, home type, listed gear, registered contractors, timing, and funding. They apply in British Columbia, not across Canada.
How Do Batteries and Portable Solar Change the Budget?
Battery storage adds gear and labour costs to a rooftop project. It can store solar power and support backup, but it doesn't cut your home's power needs.
The DELTA Pro Ultra base setup combines one inverter and one 6,144 Wh battery. It supplies 7,200 W continuously, reaches 10.8 kW during a surge, and supports 120 V and 240 V output. One inverter accepts up to 5.6 kW of compatible solar input.
Capacity, output, solar input, circuit coverage, and runtime measure different limits. A planned integrated setup needs matching gear, such as Smart Home Panel 2. A qualified electrician must handle hardwired work under local requirements.
Ordinary grid-tied solar also doesn't provide backup power on its own. Approved controls must keep the backup system apart from the grid.
Keep portable solar in its own budget. The EcoFlow 110W Solar Panel 2 is a small extra option for mobile charging.
EcoFlow 110W Solar Panel*2
• 220 W total rated solar output from two 110 W panels •Up to 23% solar conversion efficiency • IP68 waterproof rating for outdoor use • Portable, self-supporting folding design for easier setup and transport
The bundle provides 220W of rated panel capacity before real-world losses. It can charge a matching power station, but it stores no energy and doesn't replace an approved rooftop array.
Panel output changes with sunlight, shade, angle, temperature, cable losses, and input limits. Compare rooftop and mobile gear by its intended job, not its sticker price.
Choose rooftop solar for long-term power output at one home. Add storage when you have a clear rate, self-use, or outage purpose. Portable panels suit mobile charging or a small extra solar source.
Get an Itemized Quote Before Comparing Solar Options
Use the average cost of solar panels as a starting point, not a final budget. Gather 12 months of electricity use, choose your target offset, and request several quotes with the same scope.
Check the solar firm, permits, grid process, rebates, gaps, warranties, and storage plan before signing.
If you need selected-load backup or mobile charging, explore EcoFlow solar generators apart from a fixed roof project.
FAQs About the Average Cost of Solar Panels
What is the average price of solar panels in Canada?
Use $2.50 to $3.50 per installed watt as a September 2026 range before rebates. Area, roof work, storage, tax, and loans can move your quote outside it.
What is the 20% rule for solar panels?
There is no single Canadian 20% rule for every solar project. It may mean a rough buffer for losses or future use. Your installer must model the site and follow local rules.
What is the biggest downside to solar electricity?
The upfront installed price is the main barrier for many homeowners. Roof limits, winter output, loans, and storage also affect the choice.
What is the average cost of each solar panel?
Module prices vary by wattage, brand, type, warranty, and seller. Installed cost per watt also covers design, racking, inverters, labour, permits, and grid connection.
Solar Panels
