Refrigerator Wattage: How Much Power Does a Fridge Use?
Fridges use different amounts of power, so the number is never exactly the same. It becomes important when you need backup power for your refrigerator during an outage. Generator sizing, portable power stations, solar setups, and outage planning all begin with this number.
The power figure can mean different things depending on when and how the refrigerator uses electricity. Before reaching the backup sections, you need to know how much power your refrigerator actually requires.
EcoFlow DELTA 3 Max Plus appears after that figure is known for battery sizing. Without that figure, battery selection becomes guesswork instead of a decision based on demand. This guide explains refrigerator wattage, power measurements, backup planning, and where EcoFlow fits.
Keep a Compatible Refrigerator Powered with EcoFlow DELTA 3 Max Plus
EcoFlow DELTA 3 Max Plus Portable Power Station
Stores 2,048 Wh of energy for longer refrigerator backup during outages. Provides 3,000 W of continuous AC output for compatible household appliances. Offers additional surge capacity to help handle refrigerator compressor startup demand. Can support a compatible full-size refrigerator as local backup rather than whole-home power. Battery runtime depends on the refrigerator’s average energy use, compressor cycling, room temperature, and other connected devices. Compatible solar panels can help extend available backup by recharging the station during longer outages. Refrigerator running wattage and startup surge should be checked before relying on the unit for backup.
How Much Wattage Does a Refrigerator Use?
The model and size can affect how much wattage a refrigerator uses, so check those first. Treat these ranges as a planning baseline:
Refrigerator Type
Typical Running Power
Startup Consideration
Main Factor Affecting Consumption
Mini Refrigerator
50W–150W
Smaller compressor, lower startup demand
Compact size and insulation
Top-Freezer
150W–400W
Compressor startup can briefly raise power demand
Efficient layout and capacity
Bottom-Freezer
Varies by model
Compressor startup creates a temporary power increase
Capacity and efficiency
Side-by-Side
Varies by model
Larger compressors may require more startup power
French Door
Varies by model
Startup demand depends on compressor size
Capacity and door configuration
Older Refrigerator
Often higher than newer models
Older compressors may have higher startup demand
Age and overall efficiency
Energy-Efficient Model
Lower than comparable models
Startup demand still depends on the compressor
Efficiency and annual energy use
For your own appliance, the nameplate is more reliable than any published wattage range. See our guide on how many watts a fridge uses for more detail.
Running Watts vs. Starting Watts for a Refrigerator
Refrigerator watts can mean different things when running power and startup demand get mixed together. Knowing the difference helps you choose backup power that can start and run the refrigerator:
Running Wattage
Running wattage is the power a refrigerator uses while it runs normally. The compressor does not run all day, so the refrigerator does not use the same power. Fans and defrost cycles can raise the power draw at different times.
Starting Wattage
Starting wattage is the extra power the compressor needs when it first starts. The startup surge can be several times higher than normal running power for some compressors. Backup equipment must handle this surge as well as the refrigerator's normal running demand.
Look at the table below to see how wattage for fridge use differs during starting and normal operation:
Aspect
Running Wattage
Starting Wattage
Duration
During normal operation
Brief startup surge
Purpose
Runs the refrigerator
Starts the compressor
Why It Matters
Sets normal power needs
Sets surge power needs
Backup Use
Continuous output
Peak output
Where to Find it
Manual or measured draw
Manufacturer data or measurement
How to Find the Wattage on Your Refrigerator
Refrigerator watts vary by model, so the right place to check depends on your appliance. Canada's EnerGuide label shows annual energy use in kWh and the model number. You can find your refrigerator power rating in several places on the appliance.
  • Find the manufacturer nameplate for the electrical rating.
  • Check inside the refrigerator for its label.
  • The door frame may also have a label.
  • A label may appear on the rear panel.
  • Refer to the user manual for specifications.
  • Enter your model number on the manufacturer website.
Calculate Watts From Volts and Amps
Some refrigerator nameplates show only voltage and current, which you can use to estimate wattage. Multiply volts by amps to get watts, so 120 V at 5 A equals 600 W.
Keep in mind that this rating can represent the maximum electrical demand, not typical daily use. For longer estimates, use measured consumption or manufacturer data, as our guide to calculate wattage explains.
Refrigerator Watts vs kWh: What Is the Difference?
Wattage on a refrigerator shows its power demand at a specific moment. kWh shows the energy your refrigerator uses over a period of time. The table below shows how watts and kWh differ in practical use:
Question
Watts (W)
Kilowatt-hours (kWh)
What It Measures
Power demand at a given moment
Energy consumed over time
How It Is Used
Sizing equipment output
Estimating energy use and cost
Generator Sizing
Determines required output capacity
Helps estimate fuel and runtime
Battery Sizing
Determines whether it can handle the load
Helps determine how long it can run
Electricity Bills
Not normally billed as usage
Used to calculate energy charges
A refrigerator rated at 400 W does not draw 400 W throughout the entire day. Its compressor cycles as needed, so daily energy use stays below 400W multiplied by 24 hours.
What Affects Refrigerator Wattage?
Natural Resources Canada recommends keeping wattage for a refrigerator efficient by setting it between 1.7°C and 3.3°C. Let’s look at the main factors that can affect how much power it uses:
  • Appliance size and overall design
  • Older units use more
  • Type of compressor technology
  • Temperature around the refrigerator
  • Chosen refrigerator temperature setting
  • Frequency of door openings
  • Amount and temperature of food
  • Frequency of defrost cycles
  • Ice maker and dispenser use
  • Condition of the door seals
Mini Refrigerator Wattage vs Full-Size Refrigerator
Mini refrigerator wattage often matters when choosing backup power for smaller cooling units. The comparison is more nuanced than the headline numbers suggest:
Factor
Mini Refrigerator
Full-size Refrigerator
Roughly 1.7 to 4.5 cubic feet
Commonly 14–28 cubic feet
Running Power
50W–150W
150 W upward by type and size
Startup Power
Roughly 150W–300W
Varies by compressor and model
Daily Energy
Well under 1 kWh
Varies by model, size, and efficiency
Typical Use
Dorms, offices, secondary storage
Primary household refrigeration
Backup Requirement
Modest output and capacity
Higher output and stored energy
Space
Fits under a desk or counter
Needs a dedicated kitchen position
Lower power use does not always mean better efficiency for mini fridges. See our mini refrigerator wattage guide for suitable use cases.
How Much Electricity Does a Refrigerator Use Per Day?
Let’s see how much wattage a refrigerator uses per day and what affects that total:
  • Compressor duty cycle, often around a third of the day.
  • Total daily operating time.
  • The annual energy figure on the EnerGuide label.
  • Household conditions such as kitchen temperature.
  • Seasonal variation, since summer raises cooling demand.
Using Measured Daily Consumption
A plug-in energy meter tracks the refrigerator's power use through each compressor cycle and defrost event. Keep it connected for 24 hours, so it records a full day's actual energy use. The result reflects your specific refrigerator and the conditions inside your kitchen.
Using Annual EnerGuide Consumption
If you do not have a meter, use the annual kilowatt-hour figure on the EnerGuide label. Divide the yearly figure by 365 to get an average daily energy estimate. For example, 500 kWh per year works out to about 1.37 kWh daily.
How Much Does It Cost to Run a Refrigerator?
Once you have the daily energy figure, electricity rates can help estimate the cost of running it:
  • Daily cost = Daily kWh × Electricity rate per kWh
  • Yearly cost = Annual kWh × Electricity rate per kWh
Use your local electricity rate, since prices differ across Canadian provinces. Hydro One says lower EnerGuide numbers mean lower annual energy use.
How Much Generator Power Does a Refrigerator Need?
Wattage for fridge backup depends on several power figures, as shown in the table below:
Figure
What it Must Satisfy
Refrigerator Running Demand
Continuous output
Refrigerator Startup Demand
Surge capacity
Other Essential Loads
Total running demand
Generator Continuous Output
All running loads
Generator Surge Capacity
Startup demand
Remaining Available Output
Additional loads
Use your refrigerator’s actual specifications instead of relying on a general estimate. Our guide to watts needed to run a refrigerator explains how to size the generator.
Can a Portable Power Station Run a Refrigerator?
Refrigerator wattage must match the station’s output and battery capacity. Several key figures help determine if the power station can run it.
  • Refrigerator running power
  • Startup surge power
  • Station rated AC output
  • Supported surge output
  • Battery capacity in watt-hours
  • Desired backup duration
  • Other connected devices
  • Available outage recharging options
EcoFlow DELTA 3 Max Plus for Refrigerator Backup
Some households need more stored energy than a small battery system provides. The EcoFlow DELTA 3 Max Plus can support a compatible full-size refrigerator during an outage, as local backup rather than whole-home power.
refrigerator power from delta max plusrefrigerator power from delta max plus
Key Specifications
  • Holds 2,048 Wh for longer refrigerator backup during outages.
  • Provides 3,000 W of continuous output for running appliances.
  • Offers extra surge capacity to handle compressor startup demands.
How to Estimate Battery Runtime for a Refrigerator
Refrigerator wattage helps estimate runtime by comparing usable battery capacity with average power demand. The table below shows the main factors that can change the actual runtime:
Condition
Effect on Runtime
Heavier Compressor Usage
Reduces
High Room Temperature
Reduces
Frequent Door Opening
Reduces
Several Devices Sharing the Battery
Reduces
An Older, Less Efficient Appliance
Reduces
An Efficient Refrigerator
Extends
Keeping the Doors Closed
Extends
Lower Cooling Demand
Extends
Powering Essential Loads Only
Extends
Additional Compatible Battery Capacity
Extends
Recharging During The Outage
Extends
Can Solar Panels Power a Refrigerator?
Solar panels can power a refrigerator through a battery or power station, depending on the wattage for a refrigerator. The setup depends on several figures working together, not just the panel rating:
  • Solar panel output rating
  • Realistic daily solar energy production
  • Refrigerator daily energy consumption
  • Battery capacity for overnight use
  • Inverter output for running demand
  • Starting wattage for compressor startup
  • Seasonal sunlight and weather conditions
Compatible panels feeding a DELTA 3 Max Plus lengthen what the battery can cover, without guaranteeing continuous operation. Production changes with sunlight, weather, season, orientation, and system limits, as our guide to solar generator size for a refrigerator sets out.
using delta max plus solar panelsusing delta max plus solar panels
How to Reduce Refrigerator Electricity Use
Daily energy use can fall even when the wattage for the fridge stays the same. These simple changes can help your refrigerator use less electricity each day:
  • Keep temperature settings at recommended levels.
  • Avoid opening the door without reason.
  • Check seals for gaps or damage.
  • Leave enough space around the refrigerator.
  • Keep coils and vents clean.
  • Let hot food cool before refrigeration.
  • Replace inefficient models when savings justify it.
Refrigerator Wattage Checklist for Backup Power
Refrigerator wattage helps you compare backup equipment against your appliance’s actual power needs. The table below lists the ten figures to gather before choosing equipment:
Figure to Record
Where it Comes From
Voltage
Nameplate electrical rating
Amperage
Running watts
Nameplate, manual, or volts times amps
Startup or Surge Watts
Manufacturer specification
Annual kWh
EnerGuide label
Estimated Daily kWh
Annual figure divided by 365
Product specification
Generator Surge Output
Battery Capacity in Wh
Required Runtime
Your own outage expectations
To summarize, wattage for a refrigerator varies from one appliance to another, so fixed figures can mislead. Published ranges give you a useful starting point, but your own appliance provides the better reference. Check its label and actual power needs before making plans for backup during an outage. EcoFlow can help when you need a portable backup option for your refrigerator.
1. Does a refrigerator use more electricity when it is empty or full?
A moderately filled fridge can retain cold when opened, but overfilling may reduce efficiency. Leave enough space for proper internal air circulation. Keep some space between items because an overfilled fridge can restrict air movement.
2. Does refrigerator wattage increase when the compressor starts?
Yes, refrigerator wattage rises substantially for a brief moment when the compressor starts. Startup demand commonly reaches 2 or 3 times running power for a fraction of a second. This surge makes surge capacity important when choosing backup equipment for your refrigerator.
3. Can a 1000-watt generator run a refrigerator?
Often, a 1000-watt generator can run smaller or efficient refrigerators during normal operation. A refrigerator running at 150W may still need several hundred watts during compressor startup. Check your refrigerator's running and startup figures before relying on a 1000W generator.
4. Does an older refrigerator use more electricity than a new one?
Generally, an older refrigerator uses more electricity than an efficient certified model. Energy Star estimates older refrigerators use 35% more energy than certified models. Improved compressors and door seals help newer refrigerators use less electricity overall.
5. Does a refrigerator use more power in hot weather?
Hot weather makes the compressor run more often, which raises daily electricity use. Good airflow around the refrigerator also helps keep power use from climbing.
Home Backup
