Ice Fishing Gear Checklist: What You Actually Need on the Ice
Most ice fishing gear checklists cover the same three things: the shelter, the auger, the rod. Fair enough, those matter. But plenty of trips end early for a much simpler reason, a dead phone, a fish finder that won't turn on, or a shanty that's gone cold by mid-afternoon. This checklist runs through the standard gear, then covers the power and heat setup most lists leave out completely, plus how to keep your equipment working trip after trip through a full Canadian winter.
The Core Ice Fishing Gear Checklist
Start with the basics, since none of this works without them.
  • Shelter: a pop-up or hub-style shanty blocks the wind and traps whatever heat you bring along. Hub shelters go up quickly and hold their shape better in wind, while flip-over models are easier to drag between spots if you'd rather move around than camp on one hole all day.
  • Auger: hand-crank or powered, this is what actually cuts through the ice.
  • Ice picks and cleats: worn around your neck and strapped to your boots, so you're not sliding around out there.
  • Rod and reel: ice rods run shorter and stiffer than what you'd use in open water, since you're dropping a line straight down a hole rather than casting.
  • Tip-ups: worth adding if you're after species that do well with a passive setup, letting you fish more than one hole at a time without holding a rod in each hand.
  • Tackle and bait: suited to whatever you're targeting.
  • Sled: for hauling everything across the lake. It matters more once you're carrying a shanty, an auger, and a cooler further than a quick walk from the truck.
  • Something to sit on: a bucket or a proper ice fishing seat, once you've picked your spot.
Clothing deserves as much thought as the shelter itself. You're sitting mostly still for hours in genuinely cold air, which is a different challenge than staying warm while hiking or skating. Layering works better than one heavy coat: something that wicks moisture next to your skin, insulation on top of that, and a windproof, waterproof shell over everything. Our rundown of what a first day on the ice actually requires from your gear gets into shelter and clothing choices in more detail if you're still putting your kit together.
That covers the standard list. There's one category almost every checklist forgets.
The Piece Most Checklists Miss: Power and Heat
A dead phone on the ice isn't just annoying. If you need to call for help or check current ice conditions partway through the day, it's a real problem, and an entirely avoidable one.
Cold weather is hard on batteries generally, and fish finders, underwater cameras, and shanty lights all drain faster out there than most anglers expect. If you're planning to run a heater long enough for it to actually matter, the trick is sizing your power setup to the load beforehand rather than hoping it holds up. Add up the wattage of what you'll run at once, a light, a fish finder, a heater on a lower setting, and check that total against your power station's continuous output, not its surge rating. Continuous output is the number that tells you what it can handle for hours, not just for a few seconds at startup.
EcoFlow WAVE 3 Portable Air Conditioner with Heater
The built-in heater is what makes this worth considering for a shanty, not just a summer cooling unit. It puts out 6,800 BTU of heat, enough to raise the temperature by 17°F in around 15 minutes, and 6,100 BTU of cooling for the warmer months. It runs cordless off its own battery and can pair with the Add-On Battery or a compatible EcoFlow DELTA series power station for up to 8 hours between charges. Quiet enough that it won't drown out a conversation in a small shelter.
EcoFlow DELTA 3 Max Plus (2048Wh)
Sized for a day out, or a couple of days if the fishing's good. 2,048 Wh covers a fish finder, shanty lighting, and phone charging for a full outing, with 3,000 W of continuous output and a 6,000 W surge for anything that pulls harder on startup. Pair it with the WAVE 3 in the same shanty to handle both heat and electronics without dragging a generator onto the ice. Charges to 80 percent in about 43 minutes once you're back near an outlet.
With power and heat sorted, don't skip the safety gear that has nothing to do with electronics.
Cold-Weather Safety Gear
ice fishing gear canadaice fishing gear canada
Ice picks worn around your neck and a solid pair of cleats are two of the cheapest things on this whole list, and also two of the most skipped. If you or someone with you goes through the ice, picks are what let you actually pull yourself back up onto solid footing instead of clawing at an edge that keeps crumbling.
Round out your safety kit with a life jacket or float suit, a rope or throw line, and a whistle in case you need to signal for help. Fishing with a partner and letting someone on shore know where you're headed and when you'll be back costs nothing and matters more than almost anything else here if something goes wrong. When it comes to actual ice thickness, Fisheries and Oceans Canada's general guidance is a reasonable starting point:
Ice Thickness
General Ice Thickness Guidelines
Under 10 cm (4 in)
Stay off — not safe for any activity
10 cm (4 in)
Walking alone or fishing on foot
12–18 cm (5–7 in)
Small groups, snowmobiles
20–30 cm (8–12 in)
ATVs and light vehicles
Those numbers assume clear, solid ice. White or cloudy ice can be roughly half as strong at the same thickness, and conditions shift from lake to lake and week to week, so last year's reading, or even last week's, isn't something to lean on. It's worth checking current conditions for the specific lake you're heading to rather than going by a general rule of thumb. Our seasonal guide to what changes on Ontario's lakes through the winter shows just how much that can shift over a single season.
Once your gear is sorted, a quick word on brand names you'll come across while shopping.
A Note on Brand Names You'll See While Shopping
A lot of shoppers search by brand name, Eskimo is a common one for shelters and augers, when what they're actually looking for is the category itself rather than that specific brand.
EcoFlow doesn't make shelters or augers. Its place in an ice fishing setup is the power and heat side of things, which works alongside whatever shelter or auger you already own or plan to buy. Think of the WAVE 3 and DELTA 3 Max Plus as an addition to your setup, not a replacement for the gear you're already choosing elsewhere.
Whatever you land on, a few habits will keep it working when you need it.
Keeping Your Gear (and Power) Ice-Ready [图片]
eskimo ice fishing geareskimo ice fishing gear
Charge everything fully before you leave home. Cold cuts into usable battery capacity, so a power station that's only partly charged at home can run out well before you expect it to on the ice.
Lithium batteries lose a real chunk of their usable capacity as the temperature drops, and knowing that ahead of time is the difference between a setup that lasts your whole trip and one that quits by early afternoon. Store your batteries and power stations somewhere the temperature stays reasonably stable between trips rather than leaving them in an unheated garage or a vehicle for weeks, since that kind of cold storage wears them down faster than regular use would. At the start of the season, check your auger blades, your shelter's zippers and poles, and your rod guides for wear, rather than finding out something's broken the first cold morning you're actually out there.
A complete ice fishing gear checklist comes down to shelter, an auger, your rod and tackle, a sled, and safety gear, plus power and heat, which is the piece most lists leave out entirely.
Build the standard kit first. Once that's covered, look at a heater built for a shanty, like the WAVE 3, and a power station with enough capacity to run it alongside your electronics for the day, like the DELTA 3 Max Plus, so a dead battery or a cold shelter never cuts a good day short.
What gear do I actually need to start ice fishing?
A shelter, an ice auger, ice picks and cleats, a rod and reel built for ice fishing, tackle and bait, and a sled to move it all across the lake. Power and heat are worth adding on top for anything longer than a quick trip.
How do I keep my phone and electronics charged while ice fishing?
A portable power station sized around 2,000 Wh covers a fish finder, shanty lighting, and phone charging for most single-day trips, which keeps you from relying on a phone battery in the cold.
Can I heat an ice shanty without a propane heater?
Yes. A battery-powered heater avoids the carbon monoxide risk that comes with a combustion heater in an enclosed shelter, and one that pairs with a power station can run for several hours between charges.
What safety gear should I bring onto the ice?
Ice picks worn around your neck, cleats, a life jacket or float suit, a rope or throw line, and a whistle in case someone needs to signal for help.
How thick does ice need to be for ice fishing?
Fisheries and Oceans Canada generally puts the minimum at 10 cm (4 inches) of clear, solid ice for walking or fishing on foot. White or cloudy ice can be roughly half as strong at that same thickness.
Do batteries drain faster in cold weather?
Yes. Lithium batteries lose usable capacity as the temperature drops, so a power station that shows a full charge at home can run down faster than expected after sitting in the cold on the ice for a few hours.
Outdoors
