Quebec Snow Forecast 2026: How Bad Does It Look?
Winter in Québec is always unpredictable, but 2026 looks set to bring its share of surprises. According to the Old Farmer’s Almanac, southern Québec can expect warmer temperatures and lighter snow, while northern areas will see more frequent snowfalls and cold snaps.
Whether you’re planning a ski trip or preparing your home for winter storms, it pays to know what’s ahead. Here’s a look at this year’s snow forecast and how to stay safe, warm, and connected in Québec.
What Will Winter 2026 Be Like in Québec?
The Old Farmer’s Almanac is forecasting above-average temperatures and below-average snowfall for southern Québec, so that the south ski slopes might see fewer flakes than usual. However, Northern Québec is expected to be mild with more snow in the forecast.
Still, if you plan to travel to the northern part of the province, be prepared for extreme cold snaps, especially in January and February.
Timing & Intensity: When and Where Snowfalls Hit Hardest
The most snow is expected to hit the northern and eastern areas of the province. Expect several nor’easters, storm systems that bring snow and wind and may result in blizzards, especially in late January and February. On the other hand, southern areas are expected to experience more thaws and wetter weather, interspersed with cold snaps and snowfall.
To stay informed and prepared, monitor the weather using a weather app on your phone. You can use the EcoFlow RAPID Pro-X Power Bank as a battery backup, ensuring you stay connected no matter what life or the weather brings your way.
Impacts to Infrastructure, Travel & Daily Life
Blizzards in the northern parts of the province may cause disruptions to travel plans. Pack appropriately for snowstorms and blizzards, stay alert, and be ready to adjust your plans accordingly. Southern travellers should prepare for rain and wetter conditions.
What Québec Residents Can Do to Prepare
Winterize Your Vehicle
In Québec, you are required to have winter tires from December 1 to March 15. You should also have a mechanic inspect your brakes, battery, and fluid levels, and switch your washer fluid to one with a freezing point of -40°C so that it doesn’t freeze in your car.
Keep a fully stocked emergency kit in your vehicle, including jumper cables, blankets, dry clothes, non-perishable food, a snow brush, and an ice scraper. Before you drive after a snowfall, remove all snow and ice from the roof, hood, windows, and lights to prevent fines and potential accidents.
Winterize Your Home
You should also winterize your home for safety. Insulate any exposed pipes in unheated basements and attics, and let a faucet drip overnight if necessary to keep the water moving. Exterior taps should be drained and shut off before the winter freeze begins.
Also, check your roof for damaged shingles, clean out your gutters to prevent ice dams, and seal any leaks in your windows, doors, weather stripping, and caulking to reduce heat loss in the home. You should also have your heating system serviced before winter begins.
Emergency Home Battery Backup System
The odds are high that snow, wind, ice storms, or blizzards will strike at some point this winter, potentially knocking out the electrical grid. Depending on your location, this may happen several times, so it's essential to be prepared to stay safe during a blizzard.
The best option to deal with weather-related blackouts is an emergency home battery backup system. These are much safer than traditional gas generators that can never be brought indoors or used near air vents to the home due to the very real risk of lethal carbon monoxide poisoning that kills hundreds of people every year in Canada.
Instead, products like the EcoFlow DELTA 3 Ultra Plus (3072 Wh), with over 3000W standard output, can be used to run appliances such as freezers and refrigerators to prevent food spoilage or to power essential medical equipment. Its modular design also makes it easily expandable using additional batteries up to 11kWh, which is plenty of power to run an average home for 1-3 days, depending on your energy needs. If you rely heavily on electric heat in the winter, consider investing in additional batteries to ensure the security of your family's warmth.
Prepare Your Solar Panels For Snow
If you use solar panels to recharge your battery backup system, you may need to plan to deal with excess snow on your solar panels.
A light dusting of snow will not affect your solar output and doesn’t need to be addressed. This is because solar panels generate some heat when they convert sunlight to electricity, and will self-clean, melting light snowfall. However, blizzards can quickly cover panels and reduce efficiency to near zero. If you live in an area prone to blizzards or high snowfall, consider installing heaters, adjusting the angle of your solar panels, or using snow guards for added protection.
When Will It Start Snowing in Québec?
Depending on your location, snow may begin as early as October in Québec. Still, most areas typically expect their first snow in November, with the heaviest snowfall occurring from December through February.
What Is the Coldest Month in Québec?
January is typically the coldest month in Québec, with temperatures consistently remaining below freezing for extended periods. The average January temperatures range from a low of about -14°C (7°F) to a high of about -6°C (21°F).
While southern Québec may experience mild and wet weather this winter, northern regions are preparing for heavier snowfall and potential blizzards. The key to managing whatever comes is preparation. Winterize your home and vehicle, keep emergency supplies on hand, and ensure you have reliable backup power for when the grid goes down.
A system like the EcoFlow DELTA 3 Ultra Plus (3072Wh) provides a safe and efficient way to keep your essentials running during power outages. With a bit of planning and the right equipment, you can face Québec’s winter 2026 forecast with confidence, no matter how bad it looks.
Home Backup
