Quebec Ice Storms: History, Outages and Home Safety
A Quebec ice storm can coat roads, trees, wires, and buildings with heavy glaze, stopping travel and leaving homes without power or heat.
The best-known ice storm in Quebec struck in January 1998, yet each storm has its own path and effects. A new warning alone doesn't make the event another 1998.
When freezing rain is active, use live weather, outage, road, and city updates because conditions and repair estimates can change throughout the day.
What Is a Quebec Ice Storm?
An ice storm develops when freezing rain lasts long enough to coat exposed surfaces. The rain freezes on cold roads, trees, wires, and buildings, where added ice can make travel unsafe and weigh down power equipment.
High above the ground, snow falls through warm air and melts into rain. Those drops enter a shallow layer of sub-zero air near the surface and stay liquid until they hit a cold object.
Environment and Climate Change Canada explains an important difference. Ice pellets freeze before reaching the ground. Freezing rain reaches the ground as liquid water, then forms glaze ice.
Hazard
What reaches the ground
Main difference
Freezing rain
Liquid drops that freeze on contact
Coats exposed surfaces with glaze ice
Ice pellets
Frozen pellets
Freeze before reaching the ground
Snow
Ice crystals or flakes
Builds up as snow rather than clear ice
Flash freeze
Water or slush that freezes after a fast temperature drop
Can occur without ongoing freezing rain
Not every spell of freezing rain becomes a major Quebec ice storm. Damage changes with ice buildup, wind, duration, temperature, tree health, and location, so use ECCC forecasts instead of judging a branch yourself.
 How freezing rain forms above a cold surface How freezing rain forms above a cold surface
How Should You Prepare Before a Quebec Ice Storm?
Prepare before ice starts to form. Check ECCC weather alerts, Hydro-Québec, your municipality, and Québec 511. If roads have glazed over, a late supply trip adds risk instead of safety.
Build a three-day supply of water, food, medicine, warm clothes, lights, and batteries. Add a radio, charged phone, pet supplies, and a kit you can carry. Quebec's home emergency guidance can help you check the basics.
Keep exits clear and learn how to protect pipes if the house cools. Test smoke and carbon monoxide alarms. Make plans for children, older adults, mobility needs, and powered medical gear. Choose a safe place to go before your home becomes too cold.
For indoor backup, EcoFlow TITAN Classic can support a planned set of compatible 120 V plug-in loads. Those may include communication devices, safe lighting and a fridge.
• 5 kWh LFP battery capacity, expandable from 5–30 kWh with compatible TITAN Batteries •4 kW AC output for a planned group of compatible essential loads •120 V output only, so it doesn't support 240 V appliances • Up to 3.2 kW solar input through one MPPT
The base unit stores 5 kWh, expands from 5 kWh to 30 kWh, and supplies 4 kW at 120 V. Check each device's running watts, startup demand, plug, use time, and maker's guidance.
TITAN Classic doesn't supply 240 V equipment or hardwired circuits by itself. Keep the IP20 unit indoors, dry, level, and clear of heat and blocked vents. Extra batteries add stored energy, but they don't promise a fixed number of backup hours.
Why Do Ice Storms Cause Power Outages and Travel Danger?
Ice adds weight to branches, lines, poles, and exposed grid parts. A branch may bend slowly, then fall when wind moves the loaded tree and cause several local faults.
Before repairs begin, a utility may isolate damaged sections, and crews need safe road access. Fallen trees, blocked streets, and fresh ice can delay both damage checks and repairs.
The wider grid may still have enough electricity while your street stays dark, as our guide to how extreme weather affects Canada's power grid explains. One damaged branch, transformer, or local line can cut service to nearby homes.
Road danger also remains after rain stops. Glazed stairs, sidewalks, rail lines, and runways don't clear at once. Don't assume a wet-looking surface has traction.
What Happened During the Great Ice Storm of 1998?
Repeated freezing rain hit Quebec, eastern Ontario, and New Brunswick from January 4 to 10, 1998. It became Canada's defining ice-storm disaster because the damage covered a large region and outages lasted well beyond the rain.
The Public Safety Canada Disaster Database reports that more than 200 Quebec communities declared a disaster. At the peak, 1,291,500 Quebec residences lost power. The database links those homes to an estimated 3,228,750 people. It lists 35 deaths across the multi-province event.
Those labels matter because a residence isn't the same measure as a utility customer or person. Some records cover Quebec alone, while others combine all affected provinces. Death totals may also use different rules.
Heavy ice damaged trees, towers, lines, poles, and local equipment. Roads and communication links failed in many places. Some homes remained without power long after the sky cleared.
The Canadian Armed Forces supported the response through Operation Recuperation. Veterans Affairs Canada describes it as the country's largest peacetime military deployment at that time. Hydro-Québec later strengthened parts of its system and expanded ice research and vegetation work.
Areas affected by the January 1998 ice stormAreas affected by the January 1998 ice storm
Which Recent Quebec Ice Storms Matter?
Later storms show how much outcomes can vary. A similar warning label doesn't produce the same ice, wind, damage, or repair time in every region.
Event
Verified impact
Why the scope matters
January 1998
Multi-day disaster across Quebec, eastern Ontario, and New Brunswick
Keep Quebec figures separate from regional totals
April 2023
Hydro-Québec recorded 1,310,000 affected customers in total and 1,125,000 without power at the same time
The figures belong to that dated event, not every Quebec storm
March 2026
The Canadian Press reported more than 200,000 Quebec customers without power at the peak
Some places saw less impact than the forecast suggested
During the April 2023 event, fallen trees and branches caused most outages. Hydro-Québec's final account recorded 9,669 separate outages.
The March 2026 count came from a developing news report. The Canadian Press update gives it a clear date and context. A later official review should replace early figures when one becomes available.
Forecasts describe what may happen, while final reports measure what did happen. Keep the two apart when comparing storms.
Quebec ice storm timeline for 1998, 2023, and 2026Quebec ice storm timeline for 1998, 2023, and 2026
What Should You Do During and After an Ice Storm?
Once ice forms, shelter safely and avoid unnecessary travel. Treat every fallen line, and anything touching it, as live.
During the storm
Follow ECCC, municipal, Urgence Québec, Hydro-Québec, and Québec 511 updates. Charge and conserve phones. Keep fridge and freezer doors shut, and turn off unneeded devices when official guidance advises it.
If your service fails, you can check a Hydro-Québec outage guide. Treat its repair time as an estimate. Crews may find extra damage after reaching the site.
Never run a fuel generator, barbecue, camping stove, or fuel heater indoors. Don't run a vehicle in a garage, even with the door open. The Government of Quebec's storm safety page gives current provincial advice.
Leave when officials tell you to go or the home can't support safe warmth, health needs, water, or communication.
After the storm
Wait for road updates before driving. Stay back from fallen lines, damaged poles, and ice-loaded trees. Report outdoor electrical damage through the proper utility channel.
Check food against current public-health advice after a long outage. Inspect pipes, roofs, trees, and electrical gear from a safe place. Don't touch wet electrical equipment or turn damaged equipment back on.
Call qualified help for electrical, structural, fuel, or water damage. Take photos and keep receipts for insurance, but only when the area is safe.
Quebec household checking updates during an ice storm outageQuebec household checking updates during an ice storm outage
How Should You Plan Backup Power for an Ice-Storm Outage?
Start with the loads that protect health, safe shelter, food, water, and contact. Home size and storm labels don't reveal the power you need.
  1. List the devices and circuits that must run.
  2. Record each load's voltage and running watts.
  3. Add the loads that may run at the same time.
  4. Add the largest extra startup demand from one motor or compressor.
  5. Estimate daily energy and choose a safe way to recharge.
Required output = simultaneous running watts + largest additional startup demand
Estimated energy needed (Wh) = average load (W) × operating time (h)
The energy result is in watt-hours, so divide it by 1,000 before comparing kilowatt-hour capacity. For example, 4,000 Wh equals 4 kWh.
Heating needs a separate check. A gas furnace may still use power for controls and its blower. Boilers, heat pumps, baseboards, well pumps, and portable heaters have very different loads. Ask an electrician or HVAC professional to confirm hardwired heating gear.
For selected 120 V and 240 V circuits, EcoFlow TITAN Plus can form part of a professionally planned backup system.
EcoFlow TITAN Plus
•5 kWh LFP battery capacity, expandable from 5–30 kWh with compatible TITAN Batteries •7.2 kW battery-only output, reaching up to 10 kW when compatible battery and solar output work together •Up to 8 kW solar input through two independent 4 kW MPPTs • Works with EcoFlow Smart Home Panel 10 to back up and manage up to 10 selected circuits, with automatic switchover within 20 ms
TITAN Plus starts with 5 kWh and expands from 5 kWh to 30 kWh. Battery-only output is 7.2 kW. Its maximum 10 kW system output requires compatible solar and battery power working together.
With Smart Home Panel 10, the system can manage up to 10 chosen circuits. It can switch within 20 ms in a supported setup. A qualified electrician must review loads, permits, wiring, and local code requirements. Some devices may still reset during the transfer.
Keep the IP20 equipment indoors and away from water, dampness, dust, smoke, steam, and heat. Real runtime changes with usable energy, reserve settings, power losses, cycling loads, temperature, and daily habits. If the house becomes unsafe, leave even when battery power remains.
Prepare Before Freezing Rain Begins
Save official weather, outage, road, and local sources now. Build your three-day plan and choose a safe place to stay. List key electrical loads, then have any hardwired backup checked before winter.
Once you know the loads, voltage, and connection your home needs, compare EcoFlow whole-home backup power solutions against that plan.
When was the Great Ice Storm in Quebec?
The Great Ice Storm struck from January 4 to 10, 1998. Repeated freezing rain affected Quebec, eastern Ontario, and New Brunswick. The event caused widespread damage and long power outages.
What was the worst ice storm in Canada?
The January 1998 storm is widely treated as Canada's defining and most damaging ice-storm disaster. Public Safety Canada's record covers Ontario, Quebec, and New Brunswick, so it wasn't a Quebec-only event.
How long will an ice storm last?
There is no fixed length because freezing rain may last several hours or return in waves. Ice, blocked roads, outages, and repairs can remain long after the rain ends.
When was the ice storm in Ottawa?
Ottawa was heavily affected from January 4 to 10, 1998. The same storm also struck other parts of eastern Ontario, Quebec, and New Brunswick.
Home Backup
