Portable Generators in Canada: 5 Options Compared
Portable generators can support a home, RV, campsite, or jobsite, but the unit must match your loads, fuel, voltage, location, and expected outage length. If you're comparing portable generators, you may see both fuel-powered models and battery power stations in search results, even though they supply electricity differently.
Fuel units generate electricity while their engines run. Battery power stations store electricity supplied by the grid, compatible solar panels, or another supported charging source.
For selected indoor plug-in loads, the EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh) includes a DELTA 3 Max model with 2,048 Wh capacity and 2,400 W continuous output.
EcoFlow DELTA 3 Max (2048Wh)
• 2400 W AC output with 4,800 W surge output • 2048 Wh battery capacity for home backup and mobile power • 4 charging options, with 0–80% in 68 minutes using wall or generator charging • 20.3 kg design with a 10 ms auto-switch for compatible critical devices
Start by choosing the equipment type that can operate safely where you need power.
What Counts as a Portable Generator?
A portable generator normally uses an engine and fuel to produce electricity. A portable power station supplies stored electricity from a rechargeable battery, so it creates no combustion exhaust during battery operation.
The main categories include open-frame generators, enclosed inverter generators, dual-fuel models, and battery power stations.
An inverter generator still has a combustion engine. Electronic controls produce stable AC power and can slow the engine as demand falls.
“Portable” may only mean the unit has handles or wheels. Some models exceed 100 kg, and every fuel-burning unit must remain outdoors.
A listing labelled portable generator doesn’t name another product type. Treat it as repeated search wording, then identify whether the unit burns fuel or stores electricity.
Quick answer: A portable generator produces electricity from fuel. An inverter model controls that output electronically, while a portable power station supplies stored battery energy without combustion exhaust.
What Should Canadians Compare Before Buying?
First, compare continuous output, startup output, energy supply, voltage, location, and connection method. These figures show what the unit can run.
Specification
What It Controls
Common Mistake
Continuous watts
The normal combined load
Comparing this figure with another model’s surge output
Starting watts
Short demand from motors and compressors
Treating it as permanent output
Watt-hours
Stored battery energy
Treating capacity as output
Fuel runtime
Operation at a stated fuel level and load
Assuming the result applies at every load
Voltage
Equipment compatibility
Assuming every model supplies 240V
Handles and wheels help on flat ground, but they do not make a 118 kg generator easy to load.
Check outlets, transfer compatibility, noise test conditions, warranty support, recalls, and Canadian service. A portable generator Canada category doesn’t confirm that every model has an accepted Canadian approval mark.
Filters written as generators portable are retailer wording, not a technical class. Confirm the model, serial number, voltage, certification, and cold-weather limits.
Cold can hinder engine starting and limit battery charging or output. Follow the manual for winter use and storage.
5 Portable Generator and Battery Backup Options for Canada
These five options serve different settings and loads, so there is no useful overall winner. Compare their continuous output, voltage, energy source, weight, and safe operating location.
Type
Output Basis
Energy Source
Voltage
Best-Suited Use
EcoFlow DELTA 3 Max
2,400 W continuous, 4,800 W surge
2,048Wh battery
Product-specific outlets
Selected indoor plug-in loads
Cummins Onan P4500i
Inverter generator
3,700 W running, 4,500 W peak
Gasoline
120 V
RVs and direct plug-in loads
Honda EU7000isCT1
Inverter generator
5,500 W continuous, 7,000 W maximum
Gasoline
120 V/240 V
Larger selected backup loads
FIRMAN P08004
Open-frame generator
8,000 W running, 10,000 W starting
Gasoline
120 V/240 V
Higher-output selected circuits
EcoFlow DELTA Pro Ultra
Expandable battery system
7,200 W continuous, 10.8 kW surge
6,144 Wh base battery
120 V/240 V
Integrated larger-load backup
EcoFlow DELTA 3 Max for selected indoor loads
The DELTA 3 Max stores 2,048 Wh and supplies 2,400 W continuously. Its 4,800 W surge rating covers short startup demand, while X-Boost is not added to continuous output.
It can support selected plug-in loads such as refrigeration, a router, lights, and phones. Runtime changes with load, cycling, temperature, settings, and conversion losses.
Its vents need clear space, and it doesn’t energize hardwired circuits by itself.
Cummins Onan P4500i for RV and campsite power
The Cummins Onan P4500i supplies 3,700 running watts and 4,500 peak watts at 120 V. Its RV outlet, handle, wheels, and 44 kg dry weight suit vehicle-based travel.
Cummins lists up to 18 hours from its 12.8-litre tank at 25% load. Higher loads shorten that time, and the unit must stay outdoors. It doesn’t supply 240V and is not listed as manual-transfer-switch ready.
Honda EU7000isCT1 for larger inverter-generator loads
The Honda EU7000isCT1 provides 5,500W continuously and 7,000W maximum at 120 V or 240 V. Its enclosed inverter design suits larger selected loads.
At 118.1 kg dry, transport needs planning. Honda lists 6.5 hours at maximum continuous output or 18 hours at 25% load from 19.2 litres.
Health Canada recalled specific EU7000is serial numbers sold from December 2022 to May 2023. Check the serial number and confirm the required repair before buying or using an affected unit.
FIRMAN P08004 for higher-output fuel backup
The FIRMAN P08004 supplies 8,000 running watts and 10,000 starting watts at 120V or 240V. Its outlets can support larger direct loads or approved transfer equipment.
FIRMAN states up to 12 hours from 30.3 litres at 50% load. The open frame brings engine noise, fuel care, maintenance, and outdoor-placement needs.
EcoFlow DELTA Pro Ultra for integrated battery backup
The EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) supports larger selected loads and compatible household circuits without running a fuel engine.
•7.2kW AC output, expandable up to 21.6 kW with supported configurations • 6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 •Automatic battery self-heating below 0°C for cold-weather operation
One inverter and battery provide 6,144 Wh, 7,200 W continuous output, and 10.8 kW surge. Added batteries or inverters are required for larger configurations.
Integrated circuit control requires compatible equipment such as EcoFlow Smart Home Panel 2. A qualified electrician must install hardwired connections under local rules.
Fuel generators and a battery power station shown in safe operating locations Fuel generators and a battery power station shown in safe operating locations
What Size Portable Generator Will Run a House?
Generator size should be based on selected loads rather than the home’s floor area. Two similar houses can have very different heating, pumping, cooking, and water-heating needs.
Use these four steps to find an initial output target:
  1. List the appliances and circuits needed during the outage.
  2. Record the running watts for each load.
  3. Add the loads that may operate at the same time.
  4. Add the largest extra startup demand from one motor or compressor.
Use this planning formula:
Required output = simultaneous running watts + largest additional startup demand
Suppose the selected loads use 3,200 W while running. If the largest motor needs another 1,200 W during startup, the initial output target is 4,400 W. Voltage, outlets, connection equipment, and operating conditions still need separate checks.
An advertised 10,000 W figure may describe starting output rather than continuous power. EcoFlow’s 10,000-watt generator sizing guide explains the distinction without using house size as a shortcut.
Battery systems need an energy calculation as well:
Estimated energy needed = average load in watts × operating hours
The result is a planning estimate, not promised runtime. Appliance cycling, conversion losses, temperature, battery condition, and changing loads affect real use.
Should You Choose a Fuel Generator or Battery Power Station?
Fuel generators suit longer operation where fuel and safe outdoor space are available. Battery systems support indoor loads but need stored energy and recharging.
Factor
Fuel Generator
Energy supply
Gasoline, propane, or another approved fuel
Stored electricity
Operating location
Outdoors only
Follow indoor placement and ventilation instructions
Runtime
Depends on fuel, load, and engine efficiency
Depends on usable capacity and load
Noise
Engine noise
Fan noise may occur under load or charging
Maintenance
Engine, oil, filters, and fuel care
Battery, charging, firmware, and temperature care
Exhaust
Produces combustion exhaust
No combustion exhaust during battery operation
Refill or recharge
Refuel after cooling as directed
Grid, solar, vehicle, or compatible generator charging
Home connection
Approved transfer equipment may be required
Product-specific integration equipment may be required
The deeper comparison of gas generators and portable power stations covers fuel storage, charging, maintenance, and outage planning in more detail.
Compare the load, operating time, fuel access, recharge options, maintenance, and safe placement for your setting.
How Do You Operate Portable Generators Safely in Canada?
Fuel generators must remain outdoors, away from buildings and openings. Household wiring needs an approved connection that prevents backfeeding utility lines.
Health Canada’s generator guidance says to operate a fuel generator at least six metres from any building and direct its exhaust away from windows and doors. Close nearby or downwind openings, and keep people and pets away.
Never run one inside a home, garage, shed, vehicle, camper, or tent. A carbon-monoxide shutoff doesn’t make indoor use safe, so install a certified battery-backed alarm near sleeping areas.
Safe electrical and fuel use also requires a few firm checks:
  • Keep the generator dry and away from water-damaged equipment.
  • Use grounded, outdoor-rated cords sized for the load.
  • Uncoil cords fully so heat cannot build up.
  • Let the engine cool before adding fuel.
  • Store fuel under the rules that apply in your location.
  • Never feed household wiring through a wall outlet.
  • Use approved transfer equipment for household circuits.
  • Check the model and serial number in Canada’s recall database.
Ontario’s Electrical Safety Authority generator guidance requires approved transfer equipment for permanent connections and recommends a licensed contractor. Other provinces and territories have separate permits, codes, and inspections, so check locally.
Portable fuel generator operating safely away from a Canadian home Portable fuel generator operating safely away from a Canadian home
Choose Backup Power From Your Essential Loads
List what must run, calculate continuous and startup demand, then estimate the required operating time.
Confirm the voltage, safe location, fuel or charging plan, and connection method before comparing models.
Canadian buyers can then compare fuel generators with battery systems on equal terms, using the loads rather than the product’s largest advertised number.
What is the best portable generator for home use?
The best option covers the chosen running and startup loads, required voltage, fuel, operating space, and connection method. A selected-load plan is often more practical than powering every circuit.
What size house can a 10,000-watt generator run?
House size cannot provide a reliable answer. Heating, pumps, water heaters, and cooking equipment can give similar homes very different power needs.
Can a portable generator be used indoors?
A fuel-burning generator cannot be used indoors. A battery power station may support indoor loads when kept dry, properly ventilated, and used under its manual.
Can a portable generator power 240 V equipment?
Only a unit with 120 V/240 V output, enough running and startup power, the correct outlet, and an approved connection can support 240 V equipment.
Home Backup
