How to Choose an Outdoor Heater for Canadian Conditions
- Which Type of Outdoor Heater Fits Your Setting?
- Can Portable Power Support Your Outdoor Heater?
- How Do Wind, Temperature and Placement Affect Warmth?
- How Much Energy Will Your Heater Use?
- What Safety Checks Come Before Switching It On?
- What Should You Check Before Buying?
- Plan the Heat and Power Together
- FAQs
Choose an outdoor heater based on where you'll use it, how it can be positioned safely, and the available power or fuel supply. Then check how long you need heat, because a short patio visit and an overnight camping stay need different plans.
Canadian fall evenings can turn cold before you're ready to go indoors. A suitable heater may extend a comfortable visit, but it can't replace clothing and safe shelter on a winter trip.
Start with those limits before comparing fuel, wattage, or battery capacity.
Compare outdoor heaters by their supply and the way they deliver heat. Gas and electric models can both use infrared, which warms people and surfaces directly.
That distinction helps you avoid choosing by fuel alone. A radiant heater still needs the correct position, distance, and conditions to reach the people using it.
Use the setting and supply columns together when narrowing your options.
Option | Where It May Fit | Main Limit to Check |
Outdoor-rated plug-in electric heater | An occupied seating area with a suitable supply | Voltage, current, exposure rating, clearances and energy use |
Propane patio heater | An open-air area where fuel appliances are permitted | Ventilation, cylinder handling, stability and fuel use |
Fixed electric or natural gas heater | A regularly used area with suitable infrastructure | Installation requirements and a qualified contractor |
Portable battery supply | Temporary power for a compatible electric heater | It supplies electricity, not heat. Energy and placement limits still apply. |
Some outdoor electric heaters plug in, while others need a hardwired supply. Don't assume two models use the same connection because they share a retail category.
Outdoor-only fuel heaters stay outside tents and enclosed shelters. Adding curtains or walls around a patio can make a previously suitable position unsafe.
Portable power is worth considering for a short session with a compatible electric heater. A suitable fixed supply is usually more practical for regular, long periods of heating.
DELTA 3000 Gen4 for a Defined Temporary Load
For an after-dinner patio visit, plan a finish time before choosing battery power.
The EcoFlow DELTA 3000 Gen4 stores 3,072 Wh and has 3,600 W of rated AC output. That makes it an option to assess for a temporary heater load, provided the heater's connection and operating conditions match.
Its 26 kg weight deserves a place in that decision too. Check the route from your vehicle or storage area before choosing where to set it down.
A heater that fits the output rating may still use the stored energy too quickly. Set the session length before deciding that a battery is enough.
DELTA 3800 Gen4 for More Energy Between Charges
If recharging between sessions would be difficult, consider the EcoFlow DELTA 3800 Gen4. It stores 3,763 Wh, while rated AC output stays at the 3000's 3,600 W.
You gain energy for the same load, rather than a higher heater setting. At 30.6 kg, the unit also needs a manageable lifting and storage plan.
Expansion may be worth reviewing later, once the exact Canadian configuration and accessories are confirmed. It doesn't remove the need to size the heating session first.
Check the power limits of the specific outlet you plan to use. Each NEMA 5-20 outlet is rated for up to 20A at 120V (2,400W), while the unit's total rated AC output is 3,600W across all connected loads. Don't assume support for a 240 V hardwired heater or all-night heat.
Before connecting anything, confirm both manuals permit the direct connection and planned conditions. Keep the battery outside the heater's heat and clearance zones, without blocking its vents or enclosing it to keep rain out.
Plan warmth around the seats people use, rather than the whole yard. Even electric outdoor heaters that direct radiant heat can't guarantee comfort in wind or severe cold.
Check the manufacturer's coverage conditions, mounting height, and wind limits before choosing a position. A heater pointed across an empty walkway won't help the people sitting outside its useful range.
Clearances apply above, beside and below the unit where the instructions specify them. Keep awnings, furniture and other materials outside those limits. A roof or gazebo doesn't automatically make a heater suitable for that location.
For a regularly used seating area, a permanent patio-heater installation plan can help you assess a fixed supply and mounting position. Arrange the installation before buying equipment that requires new wiring or gas service.
Camping calls for a different starting point. Warm layers, ground insulation, suitable shelter, and a weather-based exit plan come before powered comfort. Check campsite rules, and leave if conditions exceed your equipment or experience. Don't depend on a patio heater to make dangerous cold manageable.
Set the planned heating time before choosing how to supply it. Occasional use and repeated long sessions create different charging and cost demands.
Calculate the Session Before Estimating Battery Runtime
Multiply the heater's electrical input in watts by its hours of use. The result is energy in watt-hours, or Wh, rather than heat output.
These hypothetical examples assume a constant electrical draw. They aren't heater tests or measured Gen4 runtimes.
Assumed Heater Input | Time in Use | Energy Before Losses and Reserve |
750 W | 2 hours | 1,500 Wh |
1,500 W | 2 hours | 3,000 Wh |
1,500 W | 4 hours | 6,000 Wh |
The four-hour example exceeds either Gen4 model's nominal base capacity before losses. Even 3,000 Wh leaves too little margin to promise two hours from the 3000's 3,072 Wh battery.
Runtime needs the energy actually available through the outlet, divided by the average load. Allow for conversion losses, inverter use, other devices, temperature, and a reserve.
Use a lower setting in your calculation only if the heater supports it, and don't assume how often a thermostat cycles.
Compare Running Costs Without a Universal Price Claim
For mains electricity, multiply kilowatts by hours and your applicable electricity rate. For gas, compare the heater's stated fuel consumption with local refill or supply costs.
Battery-powered heat also carries charging losses and the equipment's purchase cost. Stored electricity isn't free simply because the heater isn't plugged into the grid while you sit outside.
Winter solar may contribute energy, but shade, short days, and clouds can limit the recharge. A solar-input rating doesn't show how much energy you'll collect before the next session.
If a location does not meet the heater's safety requirements, choose a different location rather than working around the instruction. Check the complete setup before switching on, including the supply, heater, and surrounding space.
Check Electric Supply, Weather Exposure and Clearances
Check for a recognised Canadian certification mark, such as CSA, cUL or cETL. Health Canada's electrical product guidance also says never to plug a portable electric heater into an extension cord or power bar.
Match voltage, current, and connection type, not just the headline wattage. Ask a qualified electrician about permanent wiring, circuit capacity, or outdoor electrical protection you can't confirm.
The heater's outdoor rating doesn't cover every connected component. Its plug, supply, and battery each have their own exposure and temperature limits. One weather rating isn't permission to leave the complete setup in rain or snow.
Keep vents clear, protect equipment from water, and keep cords away from heat. Stay present during use, and switch off and disconnect a portable heater before leaving or sleeping.
Keep Fuel Heat Outdoors and the Area Open
Fuel-burning patio heaters need the outdoor setting and clearances their instructions require. Ontario's TSSA patio-heater safety guidelines stress open-air use, stable placement, and supervision. They aren't a single installation code for every Canadian province.
Don't close the sides of a patio around a fuel heater to hold heat. Keep exits clear, and don't move the heater until it's off and cool.
Propane cylinders stay outdoors during storage. For fixed gas equipment, follow local requirements and use a qualified gas installer. A carbon monoxide alarm doesn't make an enclosed or otherwise unsuitable setup safe.
Compare the exact model's instructions and total setup cost before choosing a retailer. Similar-looking heaters can need different supplies, mounting work, or safe clearances.
When comparing outdoor heaters at Canadian Tire or another retailer, bring the requirements for your intended location. Use the same checks for every model on your shortlist.
Confirm outdoor-use instructions and recognised Canadian certification for the exact product.
Check plug-in versus hardwired supply, voltage and any installation costs.
Compare required clearances, wind limits and coverage conditions with your seating area.
Plan fuel or recharge access, replacement parts and the full cost of use.
Check local prices and stock when you're ready to buy, rather than assuming national availability. Pellet heaters and open flames also need a separate check against local restrictions.
Before buying an outdoor heater, write down where you'll use it and for how long. Confirm safe placement and a realistic source of energy for that session.
If portable electricity suits the plan, compare portable power stations against the heater's input, energy demand, and operating conditions. Choose a suitable fixed supply for frequent high-load use, and keep clothing and safe shelter at the centre of colder-weather camping plans.
What type of heater is best for outside?
Choose a heater that matches your location, available supply and permitted placement. Infrared describes how warmth reaches people and surfaces, so either gas or electric equipment may use it, with different fuel, connection, and ventilation needs.
What is the best outdoor heater for winter?
Choose a model rated for the temperature and setting where you'll use it. Higher output doesn't guarantee comfort in strong wind or severe cold, and a winter camping plan still needs suitable clothing, shelter, and a safe way to leave.
Can a portable power station run an outdoor heater?
A compatible electric heater may run from a power station when voltage, outlet, continuous input, and permitted conditions all match. Its energy use limits the session, while hardwired and incompatible high-voltage heaters need a different supply.
Can an outdoor electric heater stay outside in the rain?
Only leave it exposed when its exact instructions permit that use or storage. Check mounting, electrical connections, and the power source too, because a weather rating on the heater doesn't cover the whole setup.
