Did Hurricane Melissa Really Hit Canada? How to Prepare Next Time
The short answer: no, Hurricane Melissa did not make landfall in Canada. Its remnants did reach Atlantic Canada as a post-tropical storm, brushing Newfoundland with wind and rain over Halloween weekend 2025. This piece covers what actually happened, then how to be ready if a future storm tracks closer to home.
What Was Hurricane Melissa?
Melissa formed on October 21, 2025, and rapidly intensified into one of the most powerful hurricanes ever recorded in the Atlantic basin. Understanding the scale of the storm in the Caribbean is what puts its much smaller Canadian footprint into perspective.
Melissa reached Category 5 strength with sustained winds near 295 to 305 km/h, tying it with the 1935 Labor Day Hurricane as the strongest landfalling Atlantic hurricane on record. It made landfall in western Jamaica on October 28 as a Category 5 storm, then struck Cuba the following day as it continued northeast. According to the National Hurricane Center, the storm was ultimately blamed for roughly 95 fatalities across Jamaica, Haiti, and the Dominican Republic, with damage estimates exceeding $12 billion USD, making it the costliest disaster in Jamaican history.
With the scale of the storm established, the next question is what it meant for Canada specifically.
Did Hurricane Melissa Hit Canada?
This is the question most people searching for this topic actually want answered, so here it is directly: Melissa never made landfall in Canada.
The storm was declared post-tropical on October 31 as it moved into the North Atlantic. Environment and Climate Change Canada's Canadian Hurricane Centre confirmed that Melissa tracked over southeastern Canadian waters, passing roughly 100 miles southeast of Newfoundland's Avalon Peninsula rather than making direct landfall. The Avalon Peninsula still saw wind gusts over 100 km/h and 25 to 75 mm of rain as the storm passed offshore.
Separately, a distinct low-pressure system pulled tropical moisture northward at the same time, contributing to heavy rain across Ontario and Quebec, including the Hamilton, Niagara, Toronto, and Kingston areas. This was a related moisture surge rather than a direct hurricane effect, but it is part of why the storm made national headlines well beyond Atlantic Canada. The same Halloween-weekend storm activity disrupted trick-or-treating in parts of New Brunswick, with at least two communities cancelling festivities due to wind and rain.
If the storm track had been just a bit closer to Newfoundland, this is the kind of equipment that would have kept Atlantic Canada homes running through a multi-day outage.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
Starts at 3,072Wh, expandable up to 11kWh with add-on batteries. 3,600W continuous output with a 7,200W surge, and a full charge from empty to 80 percent in about 48 minutes using solar and generator input together. Runs at a quiet 25dB, switches over in 10 milliseconds during an outage, and comes with up to a 5-year warranty. Sized for a household riding out a multi-day storm-related outage, not just a short blip.
Melissa was a near-miss for Canada this time, but it is a preview of what is worth planning for.
Why Atlantic Canada Is Exposed to Hurricane Remnants
hurricane melissa pathhurricane melissa path
Melissa's path was not unusual. It followed a pattern that repeats nearly every Atlantic hurricane season, which is worth understanding if you live anywhere east of Ontario.
Warm Gulf Stream waters extend well up the eastern seaboard, and the typical late-season storm track carries weakening hurricanes northeast toward Atlantic Canada each fall. By the time these systems reach Newfoundland or the Maritimes, they have usually transitioned to post-tropical or extratropical storms, weaker than at landfall further south, but still capable of producing damaging wind and rain. Our broader guide to hurricane remnants in Canada covers how these systems typically move inland through the St. Lawrence corridor and what that means season to season.
Understanding the risk is step one. Knowing how outages actually unfold is step two.
What a Storm-Related Power Outage Looks Like in Canada
Storm damage to the power grid follows a fairly predictable pattern, and knowing what to expect helps set realistic expectations if a future storm does hit harder than Melissa did.
Downed lines, flooded substations, and blocked access roads all slow restoration, and multi-day outages are common after any major wind or ice event, not just hurricanes. For scale, the table below compares three recent Canadian storm events by cause:
Storm Event
Peak Customers Affected
Typical Restoration Time
Post-tropical storm Fiona (2022, Nova Scotia)
Roughly 415,000 customers at peak
Average around 4 days; hardest-hit regions up to 17 days
May 2022 derecho (Ontario/Quebec)
Over 1 million homes
Most restored within 2 weeks; some longer
April 2023 ice storm (Ontario/Quebec)
Roughly 1.1 million Quebec customers at peak
Most restored within 5 days
How to Prepare Your Home Before the Next Storm
hurricane melissa emergency resourceshurricane melissa emergency resources
A basic emergency kit is the foundation, and it does not need to be complicated to be effective.
Public Safety Canada's general guidance is to have enough supplies for 72 hours of self-sufficiency: water, non-perishable food, flashlights, a battery or crank radio, medications, and a basic first aid kit, packed and ready before storm season rather than assembled in a panic once a warning is issued.
Food and medication safety deserve specific attention during a multi-day outage. Refrigerated medication like insulin, baby formula that needs to stay cold, and anything in the fridge or freezer are all at risk once the power has been out for more than a few hours. A full freezer will generally keep food safe for about 48 hours if left unopened, while a fridge is closer to 4 hours, so knowing this window in advance helps you decide what to eat first, what to move to a cooler with ice, and what to discard if the outage runs long. If you take refrigerated medication, talk to your pharmacist ahead of storm season about safe short-term storage options during an outage.
A kit covers the basics. Backup power is what keeps the rest of the household running.
Choosing Backup Power for Hurricane Season
Sizing backup power correctly comes down to being honest about what you actually need to keep running, not what would be nice to have.
For most households, that means a fridge, a Wi-Fi router or cell signal booster, any medical devices, and some lighting, rather than trying to power an entire house at once. This is worth thinking through even outside Atlantic Canada. Ontario picked up Melissa's moisture as heavy rain, and cities like Toronto see their own storm-related outage risk from summer and fall wind events entirely separate from hurricane remnants, so this sizing exercise is not just an East Coast consideration.
EcoFlow DELTA 3 Max Plus (2048Wh)
Holds 2,048Wh out of the box, expandable to 10kWh. 3,000W continuous output with a 6,000W surge, and a full charge from empty to 80 percent in about 43 minutes. Runs at a quiet 25dB with a 10-millisecond switchover during an outage, and comes with up to a 5-year warranty. A budget-friendly alternative to the Ultra Plus for smaller households or apartments that still want real outage coverage for the essentials.
With a plan and the right equipment, the next storm is a lot less stressful.
Melissa missed a direct Canadian landfall this time, but Atlantic Canada, and even Ontario and Quebec through its moisture surge, still felt its reach.
Build a kit, and add backup power sized to your household before the next storm season arrives rather than after the first warning is issued. The DELTA 3 Ultra Plus and DELTA 3 Max Plus linked above cover most households, whether you need whole-household headroom or a smaller, budget-friendly option.
Did Hurricane Melissa make landfall in Canada?
No. Melissa made landfall in Jamaica and Cuba as a hurricane. By the time it reached Canadian waters it had become a post-tropical storm and passed roughly 100 miles southeast of Newfoundland without making landfall.
How close did Hurricane Melissa get to Newfoundland?
The post-tropical storm passed about 100 miles southeast of the Avalon Peninsula, close enough to bring wind gusts over 100 km/h and 25 to 75 mm of rain without a direct hit.
Why did Ontario and Quebec get rain from Hurricane Melissa?
A separate low-pressure system pulled tropical moisture north from Melissa at the same time, bringing heavy rain to Hamilton, Niagara, Toronto, and Kingston. This was a related moisture surge, not a direct hurricane effect.
How many people died in Hurricane Melissa?
Roughly 95 people died across Jamaica, Haiti, and the Dominican Republic, according to post-storm reporting, making it one of the deadliest and costliest hurricanes in Jamaican history.
What should Canadian households keep in a hurricane emergency kit?
Water, non-perishable food, flashlights, a battery or crank radio, any needed medications, and a basic first aid kit, enough for 72 hours of self-sufficiency per Public Safety Canada's general guidance.
What size backup power station do I need for a multi-day outage?
It depends on what you need to run. A fridge, router, and some lighting can generally be covered by a smaller unit like the DELTA 3 Max Plus, while larger households or anyone wanting more headroom should look at something like the DELTA 3 Ultra Plus.
Home Backup
