Hunting & Fishing Trips in Canada: Guided Excursions, Lighting, and Trip Planning
Canadian hunting trips range from guided lodge stays to remote drive-in, boat-access, and fly-in outings. Your choice depends on location, season, licenses, transport, lodging, equipment, and outfitter support. Transport Canada’s guidance for hunters and anglers also highlights planning and water safety. Low light matters on early starts, late evenings, and night fishing. Plan lighting before reaching the dock or campsite.
For longer base camps, the EcoFlow DELTA 3 Max Plus can power lights and essential electronics. The EcoFlow GLACIER Classic fridge freezer can also run from portable power. These products make more sense for independent camps than short guided lodge trips.
Power Camp Electronics and Lighting with EcoFlow DELTA 3 Max Plus
EcoFlow DELTA 3 Max Plus (2048Wh)
• Provides 2,048 Wh of stored energy for multi-day, vehicle-accessible camps. Includes multiple AC and USB outputs for connecting compatible camp devices. •Can power portable lighting, GPS devices, cameras, communication equipment, and fish finders. Accepts compatible solar charging to replenish stored energy during longer stays. • Can be moved between vehicle, campsite, and cabin locations as power needs change. Intended for camp electronics rather than hunting equipment. Fly-in travelers should confirm operator and aircraft battery restrictions before taking the unit.
Keep Food and Drinks Cold with EcoFlow GLACIER Classic
• Provides portable powered cooling for food and drinks at remote base camps. Supports cooling temperatures reaching -20 °C (-4°F). •Stores seven days of temperature history through the app for monitoring cooling conditions. Can operate with a portable power station such as the DELTA 3 Max Plus. • Suits multi-day camps, RV trips, and remote lodge-based outings where powered refrigeration is practical. Provides an alternative to relying solely on ice during several-day stays.
What Types of Hunting and Fishing Trips Can You Book?
Start by deciding whether guided hunting fits the type of trip you want. The seven options below differ mainly in logistics, support, and planning requirements:
Trip Type
What It Usually Includes
Best Fit
Guided Hunting Trip
Guide, transport, accommodation
First-timers, unfamiliar regions
Semi-Guided Excursion
Partial guiding and logistics
Experienced hunters wanting local knowledge
Lodge-Based Fishing Trip
Accommodation, boats, often meals
Comfort-focused anglers
Fly-in Fishing Trip
Air access, boats, remote camp
Water few others reach
Drive-in Wilderness Trip
Cabin or camp, road access
Independent travellers
Hunting and Fishing Combo
Both activities in one stay
Variety within limited days
Self-Guided Trip
Little or nothing supplied
Where legally permitted
Inclusions vary enormously from one operator to the next. Never assume guides, meals, boats, transport, licenses or equipment come with a package until the operator confirms each in writing.
Guided Hunting vs. Self-Guided Hunting
The choice between guided and self-guided hunting excursions comes down to support, independence, cost, and preparation, as the table below shows:
Factor
Guided
Self-Guided
Local Knowledge
Comes with the guide
Built over repeat visits
Scouting
Done before you arrive
Your own responsibility
Transportation
Usually provided
You arrange it
Accommodation
Included in most packages
You source it
Equipment Supplied
Varies by outfitter and package
You bring everything
Regulatory Assistance
Outfitter guidance available
Your own research
Cost
Higher
Lower
Flexibility
Set by the itinerary
Complete
When a Guide Makes More Sense
The choice often depends on experience and local conditions. For hunting excursions, these five situations make an outfitter more practical, while Ontario’s Sunset Country hunting guidance highlights the importance of checking local rules before booking:
  • A first trip to an unfamiliar region.
  • Genuinely remote wilderness.
  • Species-specific trips needing local knowledge.
  • Complicated access by water, air, or private land.
  • Areas where rules require guides or outfitter involvement.
Requirements can vary by Wildlife Management Unit, species, and location, so check the applicable provincial regulations before booking.
Popular Hunting Excursions in Canada
The type of game you pursue shapes the trip, season, location, and preparation. Popular hunting trips in Canada include the following species and activities:
Hunt Type
Typical Setting
Main Planning Consideration
Whitetail Deer
Mixed forest and farmland edges
Tag allocation and management unit
Moose
Northern forest and wetland
Draw systems and outfitter requirements
Black Bear
Forest, bait or spot-and-stalk
Seasonal timing and licensing
Waterfowl
Marshes, fields and shorelines
Federal and provincial rules apply
Grouse and Upland Birds
Bush roads and forest edges
Seasons and licence requirements
Wolf and Predator Hunts
Remote northern areas
Only where legal and offered
Species, seasons, tags, permitted methods and outfitter requirements all differ by province and management area. Check current regulations for the exact area you intend to hunt, as our hunting in Canada guide sets out.
Hunting and Fishing Combo Trips
Some travelers want more than one activity from the same getaway, making hunting and fishing trips a practical choice. Combination packages can make limited travel days more productive, especially for visitors traveling long distances.
Advantage
What It Means in Practice
More Activities In One Trip
Two pursuits without Two bookings
Better Use of Travel Time
Long journeys justify longer stays
Shared Accommodation
One lodge covers both activities
Guided Transportation
Operator moves you between them
Different Licenses Apply
Each activity carries its own requirements
Additional Gear Needed
Two kits rather than one
Weather Flexibility
A poor day for one may suit the other
Andy Myers Lodge currently pairs waterfowl or grouse hunting with guided fishing, one example among many. Verify which activities a package includes rather than assuming both are guided. Our overview of freshwater fishing in Canada covers the angling side.
How to Choose the Right Hunting or Fishing Outfitter
The outfitter can shape your entire experience, so compare what each package actually provides before booking hunting or fishing trips. Look beyond the advertised rate and check what you need to bring yourself:
What to Check
Why It Matters
Species or Fish Targeted
Confirms the operator's specialty
Guide Experience
Shapes the entire trip
Group Size
Affects attention and access
Accommodation and Meals
The largest cost lines
Boats, ATVs and Transport
Included or charged separately
Remote Access
How you actually reach camp
Equipment Supplied
Determines your packing list
License and Tag Responsibilities
Almost always yours
Fish and Game Handling
Cleaning, packaging and storage
Cancellation Policy
Weather disruption is common
Insurance Requirements
Some operators require proof
Accessibility
Terrain and facilities vary widely
Emergency Communication
Critical at remote camps
Planning for Remote and Light-Access Trips
Remote guided hunting trips require careful planning because access methods determine what you can realistically transport to camp.
  • Day trips need far less than multi-day excursions.
  • Vehicle-accessible lodges allow heavier equipment than outposts.
  • Boat access limits both weight and bulk.
  • Fly-in trips can have strict baggage and battery constraints.
  • Backpack travel rules out anything heavy entirely.
  • Recharging varies from full power to none.
Vehicle-supported trips allow more room for power and food-storage equipment. Fly-in and backpack trips impose tighter limits, so this outfitter’s hunting guidance is useful when checking transport restrictions before packing substantial gear.
Lighting for Early-Morning and Evening Fishing Trips
Low-light conditions make preparation especially important on hunting fishing light trips, since remote fishing at dawn or dusk requires suitable lighting before leaving camp:
  • Headlamps, which keep both hands free.
  • Boat and deck lighting.
  • Dock lighting where you are based.
  • Portable LED camp lights.
  • Fishing lights, where permitted and appropriate.
  • A backup flashlight, always.
Fishing lights come in above-water, underwater, dock, and ice-fishing designs. Keep safety and navigation lights separate from fish-attraction lighting. Check Transport Canada’s boating safety guidance and local fishing rules before heading out.
Power for a Multi-Day Vehicle-Supported Hunting or Fishing Trip
On multi-day hunting trips, power needs can quickly add up. Lighting is only one demand, while several other devices may also need charging during the trip:
  • Phones and communication equipment.
  • GPS and navigation devices.
  • Cameras and fish finders.
  • Portable LED lights.
  • Laptop or tablet, plus other low-power electronics.
EcoFlow Delta 3 Max Plus (2048Wh) for Camp Electronics and Lighting
That accumulated load is what justifies dedicated storage on multi-day vehicle-accessible camps. The EcoFlow Delta3 Max Plus (2048Wh) covers compatible lighting, GPS, cameras, communication equipment and fish finders:
 ecoflow delta 3 max plus ecoflow delta 3 max plus
  • 2,048 Wh of storage with multiple AC and USB outputs.
  • Accepts compatible solar charging for longer stays.
  • Can move between vehicle, camp and cabin locations.
This covers camp electronics only and has nothing to do with hunting equipment. A short guided lodge trip with reliable electricity needs none of it, and fly-in travelers should check operator and aircraft battery restrictions first.
Keeping Food and Drinks Cold at a Remote Base Camp
A hunting trip can quickly create food-storage challenges at a remote base camp. Ice may work for a short stay, but powered refrigeration becomes more useful when the trip lasts several days:
EcoFlow GLACIER Classic Portable Fridge Freezer for Vehicle-Accessible Trips
On multi-day camps, RV trips, and remote lodge-based outings, the EcoFlow GLACIER Classic Portable Fridge Freezer gives steady cooling for packed food and drinks:
ecoflow glacier classic portable fridgeecoflow glacier classic portable fridge
  • Portable cooling for food and drinks, with temperatures reaching -20°C (-4°F).
  • Seven days of temperature history through the app.
  • Compatibility with a portable power station such as the DELTA 3 Max Plus.
It is not hunting equipment and is impractical for most backpack or fly-in travel. For legally harvested fish or game, follow current local food-handling and transport guidance rather than any general storage claim.
What to Pack for Hunting and Fishing Trips
Packing for hunting and fishing trips depends on your access, outfitter, and camp facilities. Start with navigation and safety gear, including offline maps, GPS, a compass, first-aid supplies, emergency communication, and a headlamp. Add activity gear, weather-ready clothing, waterproof footwear, optics, spare batteries, and repair supplies. Depending on the trip, you may also need food, medication, chargers, dry bags, and portable refrigeration.
Licenses, Regulations, and Trip Rules
None of that planning matters if the paperwork is wrong. Regulations change by province, species, fishery, and season, so treat the following as a checklist to verify:
  • For hunting, confirm your provincial licence, any species-specific tag, the applicable management area, and open season. Then check non-resident rules, outfitter requirements, and transport or export rules.
  • For fishing, confirm the licence, zone, open seasons, catch and possession limits, bait rules and size restrictions. Our guides to Ontario hunting season and fishing in Ontario cover the provincial detail.
Safety for Remote Hunting and Fishing Excursions
Legal requirements are only part of staying safe on hunting excursions. Remote areas require extra preparation, and these ten habits can help reduce common risks:
  • Share your itinerary with someone at home.
  • Carry reliable navigation and emergency communication.
  • Monitor the weather throughout.
  • Dress for rapid temperature changes.
  • Follow boating and water-safety requirements.
  • Maintain adequate food and drinking water.
  • Follow your outfitter's instructions.
  • Keep appropriate distance from wildlife.
  • Carry emergency lighting.
  • Know the nearest emergency-access route.
How Much Do Guided Hunting and Fishing Trips Cost?
Once your guided hunting or fishing trip is planned, the price depends on several separate costs. Canadian rates vary widely, so compare the individual components rather than relying on one average figure:
Cost Factor
Why It Moves the Total
Trip Length
The largest single driver
Species or Activity
Some hunts carry premium pricing
Guide Ratio
One-on-one costs considerably more
Fly-in Transportation
Often quoted separately
License and Tag Costs
Almost always extra
Group Size
Per-person rates fall with numbers
The outfitter table above covers the rest. Lodge level, meals, transport and supplied equipment move the price as much as they shape the trip. Confirm any quoted figure with the operator.
The best hunting fishing trips match your available days with the right format, outfitter, season, access, and equipment. Guided packages simplify remote travel, while combo trips add variety. For longer vehicle-accessible stays, portable power and refrigeration can make camp easier. EcoFlow offers useful options for keeping essential gear powered and food chilled.
1. Are guided hunting trips worth it for first-time hunters?
Usually yes, particularly in unfamiliar or remote country. A guide assists with scouting, access and local regulations, which can save newcomers considerable preparation time. The cost buys knowledge that would otherwise take several seasons to build.
2. Can you combine hunting and fishing in the same Canadian trip?
Yes, and several Ontario operators sell exactly that. Each activity carries its own licenses, seasons and regulations, so confirm both sets before traveling. Combination packages suit anyone traveling a long way for a limited number of days.
3. What should you ask a hunting outfitter before booking?
Ask what is included, what you must bring, the guide ratio, license responsibilities, cancellation terms, and emergency communication arrangements. Ask about success rates carefully, since definitions vary between operators and no outfitter can promise an outcome.
4. Are fishing lights legal everywhere in Canada?
No, and rules differ by province and by water body. Some jurisdictions restrict artificial lights for attracting fish, while boating regulations separately govern required navigation lighting. Check current provincial fishing regulations for the specific water before using any fishing light.
5. What is the difference between a guided trip and an outfitted trip?
A guided trip means someone accompanies you in the field. An outfitted trip means a business supplies logistics such as accommodation, transport, and equipment, which may or may not include guiding. Many packages combine both, so confirm which you are buying.
