Freezing Rain: What It Is and How to Stay Safe
Freezing rain can look like ordinary rain while falling, then form glaze on roads, walkways, trees and power equipment. This article explains how it forms, why it is hazardous and how to prepare before, during and after an event.
What Is Freezing Rain?
To answer what is freezing rain, it is liquid precipitation that freezes when it strikes a sufficiently cold surface and forms glaze. The atmospheric temperature layers above the ground determine whether precipitation reaches the surface as rain, ice pellets or snow.
Freezing Rain Definition
The freezing rain meaning used by Environment and Climate Change Canada is rain that freezes on impact, forming clear glaze on the ground and exposed objects. The drops remain liquid until contact because of the atmospheric temperature profile above the surface.
How Does Freezing Rain Form?
Most freezing rain begins as snow, high in the atmosphere where the air is well below freezing. On the way down, the flakes pass through a band of air warmer than 0°C and melt completely into raindrops. Near the ground, the droplets then cross a shallow layer of sub-freezing air that is not deep enough to refreeze them into ice pellets, so they arrive as supercooled liquid. The moment they meet a cold road, sidewalk, tree branch, or hydro line, they freeze on contact and gradually build up a smooth coat of glaze ice.
What Temperature Does Freezing Rain Occur At?
Freezing rain depends on the temperature profile from the cloud to the surface. It can form when liquid drops become supercooled and then freeze on contact with a surface at or below freezing; local observations may differ from a nearby reported air temperature.
Freezing Rain vs. Sleet vs. Snow
These terms are often used as if they were interchangeable, and a messy Tuesday can deliver all three in one afternoon. They are not the same thing, though, formed differently aloft and behaving differently underfoot:
Precipitation Type | Atmospheric Temperature Profile | What You See Falling | Texture on the Ground |
Snow | Consistently below 0°C from cloud to ground | Soft, crystalline flakes | Fluffy, packed, or slushy |
Sleet (Ice Pellets) | Melts in a warm layer, then completely refreezes in a deep cold layer before landing | Translucent, hard ice pellets | Bouncy grains that crunch underfoot |
Freezing Rain | Melts in a warm layer, then crosses a shallow freezing layer without refreezing mid-air | Liquid raindrops | Solid, mirror-smooth sheet of glaze ice |
The practical giveaway is underfoot. Snow packs, ice pellets crunch and bounce, and freezing rain leaves a clear coating of black ice you may not see until you are on it.
Why Is Freezing Rain Dangerous?
Freezing rain creates clear glaze on roads, walkways, trees and power equipment. The combination of poor traction and accumulating ice can lead to collisions, falls, falling branches and outages.
Icy Roads and Dangerous Driving Conditions
Glaze ice can sharply reduce tire traction and may look like wet pavement. Bridges, overpasses, hills and ramps can become hazardous quickly. Avoid travel where possible and follow official road closures and advisories.
Slippery Sidewalks, Steps and Driveways
Glaze can make sidewalks, steps, decks and driveways difficult to see and use safely. Avoid unnecessary walking, use handrails where available and apply an appropriate traction or de-icing material according to its label.
Ice Buildup on Trees and Power Lines
Ice builds up quickly on trees, power lines, and poles:
Just 6 mm (1/4 inch) of radial ice can add hundreds of pounds of extra load to a span of overhead utility wire.
At 12 mm (1/2 inch), mature birch, pine, and maple limbs begin to splinter under the strain.
By 20 mm or more, hydro poles and lines can come down, damaging parked cars and blocking residential streets.
Power Outages During Freezing Rain and Ice Storms
Freezing rain can weigh down branches and electrical equipment, leading to outages. Restoration time varies with the extent of damage, road access, ongoing weather and available crews. Households that depend on electric heat, pumps or medical devices should prepare for the possibility of a longer interruption.
When Does Freezing Rain Become an Ice Storm?
Environment and Climate Change Canada issues a freezing rain warning when freezing rain is expected to create hazardous icing. “Ice storm” is a descriptive term for a damaging icing event rather than a single national accumulation threshold, so follow the impacts and instructions in the local alert.
How to Prepare for Freezing Rain in Canada
Prepare before ice begins to accumulate. Monitor alerts, reduce travel, protect access routes and assemble supplies for a possible outage.
Check Freezing Rain Warnings and Weather Alerts
Monitor the official freezing rain warning and other alerts through WeatherCAN or the Environment and Climate Change Canada forecast page. Pay attention to the stated location, timing, expected impacts and updates before travelling.
Prepare Your Home Before the Storm
Before ice begins, prepare safe traction materials, clear drainage where possible and move vehicles away from weak or overhanging branches. Test sump-pump and backup arrangements if winter rain or melting snow could affect the property. The checklist for how to prepare your home for an ice storm covers additional household planning steps.
Stock an Emergency Kit
Keep a 72-hour kit with water, ready-to-eat food, a manual can opener, medications, first-aid supplies, flashlights, batteries, warm clothing and a radio. The emergency supplies for a power outage checklist can help adapt the kit for household health, mobility and communication needs.
Prepare for Possible Power Outages
Freezing rain can damage branches and power infrastructure with limited notice. Prepare lighting, communications and other essential loads in advance. A portable power station may support selected devices indoors when used according to its instructions.
EcoFlow TITAN 5000 Classic Whole-Home Backup Power may support selected essential devices during an outage when it is charged, correctly sized and operated according to its instructions. Actual runtime depends on battery configuration, appliance demand and environmental conditions.
Avoid Unnecessary Travel
Avoid unnecessary travel during freezing rain. If travel is essential, check official road information, reduce speed and be prepared for rapidly changing conditions.
How to Stay Safe During and After Freezing Rain
Staying indoors is often the safest choice while ice is accumulating. After precipitation ends, remain alert for falling ice, damaged branches, slippery surfaces and downed lines.
Stay Indoors When Conditions Are Dangerous
Keep children and pets indoors while ice is accumulating. If wind increases, stay away from rooms beneath large ice-laden branches and follow local emergency instructions.
What to Do If You Must Drive in Freezing Rain
If an emergency puts you on a glazed road, drive as if the pavement were polished marble:
Cut Speed Drastically: Travel well below the posted limit, and remember that four-wheel drive improves acceleration on snow, not braking on ice.
Triple Your Following Distance: Leave 8 to 10 seconds between you and the vehicle ahead to allow ample stopping distance.
Brake Smoothly: Avoid sudden steering corrections or hard jabs at the brake pedal, which can send you into a skid.
Watch Overpasses: Bridges freeze well before city streets because frigid air circulates both above and below the bridge deck.
Pack an In-Car Kit: Keep an ice scraper, a collapsible shovel, booster cables, a warm parka, boots, and a bag of traction sand or kitty litter in the trunk.
Stay Safe During a Power Outage
A prolonged winter outage can affect food storage, communications and electrically dependent heating equipment. Plan essential loads and expected runtime in advance. A power station may support selected devices, but capacity and output must match the equipment being powered.
For higher household loads, EcoFlow TITAN 5000 Plus Whole-Home Backup Power may be considered as part of a professionally designed backup system. Actual coverage and runtime depend on capacity, connected loads, installation and operating conditions. Never run a fuel-burning generator, camp stove or charcoal grill indoors, in a garage or near doors, windows or vents because carbon monoxide can cause serious illness or death.
Avoid Falling Ice, Branches and Downed Power Lines
Hazards can remain after precipitation stops. Stay away from ice-laden trees, roof edges and utility equipment. Treat every downed line as energized, keep people and pets at least 10 metres away, and contact emergency services or the local utility as appropriate.
Clear Ice Safely After the Storm
Once the weather calms down, spread rock salt or calcium chloride on the icy stretches and give it time to work before clearing. After the salt has loosened the bond, a flat-edged ice chopper or a snow pusher will lift the ice cleanly, but hacking at hard ice directly can damage the concrete underneath. For a car glazed in ice, don’t pour boiling water on the windshield to speed things up. Run the defroster and let the ice loosen gradually before scraping.
Freezing rain can make travel hazardous, damage trees and power lines and cause outages. When it is forecast, monitor official alerts, prepare supplies before ice accumulates and avoid unnecessary travel. Afterward, watch for falling ice, damaged branches and downed lines until local authorities and utilities indicate conditions are safer.
How Long Does Freezing Rain Usually Last?
Duration varies from brief periods to prolonged events, depending on the atmospheric temperature profile and movement of the weather system. Follow local alerts because even a short period can create hazardous surfaces.
Is Freezing Rain More Dangerous Than Snow?
Both can be dangerous. Freezing rain creates hard-to-see glaze and adds weight to trees and lines, while snow can reduce visibility, block roads and create other hazards. The safer response depends on the warning, accumulation and local conditions.
Can Freezing Rain Happen Above 0°C?
It can occur when exposed surfaces remain below freezing even if the reported air temperature is slightly above 0°C. Local surface temperature, recent weather and precipitation temperature all affect whether glaze forms.
Can Freezing Rain Damage a Car?
Yes. Ice-loaded limbs can collapse onto the roof and hood, improper de-icing can crack a windshield, and forcing frozen doors or windows can damage their mechanisms.
Does Salt Work on Freezing Rain?
De-icing products work differently as pavement temperature changes. Follow the product label, protect pets and vegetation, and use sand or another traction material when a de-icer is unsuitable or ineffective.
Where Is Freezing Rain Most Common in Canada?
Freezing rain occurs in several Canadian regions when warm, moist air overruns a shallow layer of colder air near the surface. Frequency and severity vary by location and weather pattern, so use local climatology and current forecasts rather than assuming one region will always be affected most.
