Small Solar Panels in Canada: What They Can Run, What They Make, and Where to Put Them
Small solar panels are one of the easiest ways to try solar power without a rooftop project. They can charge a phone at a campsite, keep a shed light working, or top up a power station in an RV. Canadian conditions add several considerations. Summer days are long, but winter sun is low and brief. Snow, cold, and building rules also shape what works. This guide explains what small panels can power, how much they produce here, and practical places to set one up.
What Counts as a Small Solar Panel?
There is no official size cutoff for a small solar panel. In everyday use, the term covers panels from about 10W up to roughly 400W. That range runs from a palm-sized trickle charger to a folding panel that can recharge a mid-size power station.
Small panels are made to move, or to serve one shed, van, or campsite. Rooftop systems are fixed, wired into the home, and sized for a household. The way a solar cell turns light into electricity is the same at both sizes.
Common Size Bands
Size band | Typical form | Typical use |
10W to 30W | Small rigid or flexible panel | Trickle charging a vehicle battery, garden pump, trail camera |
50W to 120W | Folding portable panel or small rigid panel | Phones, lights, laptops, topping up a small power station |
160W to 220W | Larger folding panel or rigid panel | Camping, van trips, shed lighting and tools |
300W to 400W | Large folding panel or full-size rigid panel | Faster power station recharging, RV and cabin use |
Portable Folding Panels vs Rigid Panels
Folding panels pack down like a briefcase and stand up on a kickstand. They suit camping and balconies where nothing can be permanently fixed. Rigid panels have an aluminium frame and glass front. They usually cost less per watt and stay mounted on a shed, cabin, or RV roof. Folding panels win on flexibility, while rigid panels win on cost and permanence.
Once you know which style fits your space, the next question is what that panel can actually keep running.
What Can Small Solar Power Panels Realistically Run?
A small panel works best as a charger that refills a battery while the sun is out. That battery, usually a portable power station, then runs your devices day and night.
Everyday Loads and Realistic Expectations
Use | What a small setup can handle | Realistic panel size |
Phones, tablets, headlamps | Easy daily charging | 10W to 60W |
LED lights and a router | Evening lighting, short outages | 60W to 120W |
Laptops and camera gear | Remote work or photo trips | 100W to 220W |
A fridge top-up | Slows battery drain; cannot carry a fridge alone | 200W to 400W plus a power station |
RV or van | Lights, fans, water pump, device charging | 200W to 400W or more |
Shed or workshop | Lights, battery tool chargers | 100W to 400W |
Cabin weekends | Lights, phones, small appliances | 400W or more plus storage |
Balcony | Phones, laptop, small fan or lights | 100W to 220W |
The key idea is balance. A panel adds energy each day, and the battery decides how much you can use at once. Planning portable solar power for vanlife starts with this same daily energy budget.
EcoFlow Options That Fit Small Solar Setups
These two panels cover both ends of a small setup. Each pairs with a power station, such as the DELTA 3 Classic, for storage.
The 110W panel sits right in the middle of the small panel range. It suits balconies, campsites, and light daily charging.
The 400W panel marks the top of the small panel range. It helps when winter sun is short or the load is an RV or cabin.
Knowing what you want to run is half the picture. The other half is how much energy a small panel can collect in Canadian conditions.
How Much Power Does a Small Solar Panel Produce in Canada?
A panel's wattage is its output under ideal test conditions. Real output depends on location, season, angle, and system losses. A simple formula gets you close enough.
The Simple Formula
Daily energy (Wh) = panel watts × peak sun hours × loss factor
Panel watts: The rated output, such as 110W or 400W.
Peak sun hours: Hours of full-strength sun per day, which change by city and season.
Loss factor: This covers heat, dust, wiring, angle, and charging losses. Natural Resources Canada uses a performance ratio of 0.75 in its solar maps, so 0.75 is a fair planning number.
The same method behind sizing solar for a Canadian home works here, just on a much smaller scale.
What NRCan Data Says for Canadian Cities
Natural Resources Canada publishes the Photovoltaic potential and solar resource maps of Canada. Its ranking of major Canadian cities gives yearly output per kilowatt of panels. It assumes a south-facing panel tilted at the local latitude, with the 0.75 ratio included.
City | Yearly output per kW (NRCan) | Approx. daily average, 110W panel | Approx. daily average, 400W panel |
Regina | 1,361 kWh | About 410 Wh | About 1,490 Wh |
Toronto | 1,161 kWh | About 350 Wh | About 1,270 Wh |
Vancouver | 1,009 kWh | About 300 Wh | About 1,105 Wh |
These are year-round averages, and any single day can be much higher or lower. For other towns, the Open Government Portal dataset lists values for more than 3,500 municipalities.
Summer vs Winter
NRCan's research found that every panel orientation has its lowest average output across Canada in December. Short days, low sun, and snow all cut production. This example uses assumed peak sun hours to show the gap.
Scenario (assumptions) | 110W panel | 400W panel |
Clear summer day: 5 peak sun hours × 0.75 | About 410 Wh | About 1,500 Wh |
Clear winter day: 1.5 peak sun hours × 0.75 | About 125 Wh | About 450 Wh |
A 110W panel can refill a phone many times on a long July day. In December, it may only add a modest top-up. That is why winter users often choose larger panels.
With realistic output numbers in hand, choosing the right panel becomes much easier.
How to Choose a Small Solar Panel
Most small panels look alike in photos. The details that matter are on the spec sheet, so compare these points before you buy.
Wattage: Work backward from your daily energy need and your shortest-sun season. Size for the season you care about most.
Cell type and efficiency: Monocrystalline cells are now the norm and beat older polycrystalline cells. Higher efficiency means more watts from less space on a balcony or van roof.
IP rating: This shows how well a panel resists dust and water. Look for a high water rating if it will sit out in rain or snow.
Weight: A 100W class folding panel is easy to carry. A 400W panel is much heavier, so plan where it will travel.
Connectors: Many rigid panels use MC4 connectors, while many power stations accept XT60. Check that you have the right adapter cable.
Voltage and input limits: The panel's open-circuit voltage and wattage must fall within your power station or controller's input range. Cold weather raises panel voltage, so leave some headroom.
Controller or power station: A bare panel cannot charge a battery safely on its own. You need a charge controller, or a power station with a built-in solar charger.
Linking panels takes extra planning. Wiring solar panels in series or parallel changes the voltage and current your charger sees.
Once the panel and storage are sorted, the fun part is deciding where it will live.
Small Solar Panel Installation Ideas for Canadian Spaces
Small panels fit spots a rooftop system never could. The best location gets open southern sky for most of the day. These solar panel installation ideas work well in Canada.
Balcony Railing
A folding panel on a kickstand, or strapped to a south-facing railing, can charge devices daily. Secure it against wind and run the cable to a power station.
Shed or Workshop Roof
A rigid 100W to 200W panel on a shed roof can run LED lights and charge tool batteries. Mount it with brackets rated for local snow and wind. A power station or small battery bank inside stores the energy.
RV or Van Roof
Rigid or semi-flexible roof panels charge while you drive. A folding panel lets you park in shade and still set it in the sun. People comparing solar setups for different RV styles end up mixing both.
Off-Grid Cabin
A cabin can start with one or two panels and a power station for lights and phones, then add more later. If the cabin becomes a full-time home, designing a permanent rooftop solar array brings in roof, permit, and sizing questions.
Garden and Yard
Small 10W to 30W panels can run fountain pumps, gate openers, or trail cameras.
Camping Kickstand Setups
At a campsite, face the panel south on its kickstand. Re-angle it two or three times a day to follow the sun.
Snow and Angle Tips
Tilt panels more steeply in winter to catch the low sun and help snow slide off.
Brush snow off with a soft broom, and never chip at ice.
Avoid shade, since even partial shade can cut output sharply.
In summer, a flatter angle usually works better.
Rules to Check First
Condos and strata: Condo corporations and strata councils often limit what can be attached to balconies. Ask before you mount anything.
Wiring into a home: Connecting panels to a home's electrical system usually needs a permit and inspection. In Ontario, the Electrical Safety Authority oversees this under the Ontario Electrical Safety Code. Technical Safety BC lists solar equipment among work that needs a permit.
Who can do the work: Homeowner permit rules vary by province, so a licensed electrical contractor is the simplest route. Plug-in setups that only charge a power station avoid this step.
Small solar panels make the most sense when you match them to a clear job. Know what you want to run, and size for your darkest season. NRCan data and a simple formula show what to expect in your city. Then pair the panel with storage, check your connectors, and pick a sunny, approved spot. For a flexible starting point, the EcoFlow 110W or 400W portable solar panel pairs well with the DELTA 3 Classic.
Can a Small Solar Panel Run a Fridge?
Not on its own. A fridge cycles day and night, so it needs a battery. A 200W to 400W panel can slow the drain on a power station.
How Many Small Solar Panels Do I Need for an RV?
It depends on your daily use. Add up the watt-hours you use each day, then divide by your expected daily output per panel. Many weekend RV users start with 200W to 400W.
Do Small Solar Panels Work in Winter in Canada?
Yes, but output drops sharply. Short days, low sun, and snow cover all reduce production. Tilting the panel steeply and keeping it clear of snow helps.
Can I Plug a Small Solar Panel Straight Into My Phone?
Some small panels have USB ports, but output swings with every passing cloud. Charging a power station first gives steadier results.
Do I Need a Permit for a Small Solar Panel?
Usually not for a portable panel that only charges a power station. Anything wired into your home's electrical system generally needs a permit and inspection. Condo or strata rules may also apply.
