Watts to Amps: How to Convert Watts to Amps
Need to check how much current an appliance draws? To convert watts to amps in a DC circuit, divide watts by volts. Single-phase AC also requires power factor, while balanced three-phase loads use a different formula. This guide covers the calculations, quick reference charts for 230V mains and 12V DC systems, and practical examples to help you check appliance loads and compare backup power options without overlooking socket limits or startup requirements.
Key Takeaways
The basic formula is Amps = Watts ÷ Volts for DC circuits like batteries and solar panels.
On single-phase AC, use Amps = Watts ÷ (Volts × Power Factor).
For balanced three-phase loads, use Amps = Total Input Watts ÷ (√3 × Line-to-Line Volts × Power Factor).
Keep loads within the applicable continuous ratings of the power source, sockets, plugs and cables, and follow manufacturer instructions and local installation requirements.
Skip the maths with the 230V and 12V quick reference charts below.
What Are Watts, Amps, and Volts?
The difference between volts, amps, and watts is what each unit measures. Watts (W) measure electrical power, or how quickly a device uses or delivers energy. Amps (A) measure electrical current, the rate of electric charge flow. Volts (V) measure the electrical potential difference that drives current.
How Watts, Amps, and Volts Are Related
For DC circuits, Watts = Amps × Volts. For single-phase AC, the relationship also includes power factor: Watts = Amps × Volts × Power Factor. When the power factor is 1, the simpler formula applies.
Why Voltage Matters When Converting Watts to Amps
The same wattage can correspond to different currents at different voltages. For example, a 120W DC load draws 10A at 12V but 5A at 24V. Always check the operating voltage before calculating.
Watts to Amps Formulas for Different Circuit Types
To convert watts to amps, first find the electrical input power and operating voltage, identify the circuit type, then use the matching formula below. For AC loads, include the power factor where applicable.
DC Circuits: Watts to Amps Formula
Batteries, solar panels, and vehicle DC outlets supply direct current. At a given operating voltage, use:
For example, a camping fridge drawing 120W at its 12V DC input draws 120 ÷ 12 = 10A while operating at that power. No power factor adjustment is needed, but calculating battery current for an AC load supplied through an inverter also requires accounting for inverter losses.
Single-Phase AC: Watts to Amps at 230V
South Africa’s nominal single-phase mains supply is 230V at 50Hz, supplied through Eskom or municipal electricity networks. For AC calculations, power factor (PF) is the ratio of real power in watts to apparent power in volt-amperes.
Simple resistive loads, such as a kettle’s heating element, have a PF close to 1. A 2300W kettle operating at 230V therefore draws approximately 2300 ÷ (230 × 1) = 10A.
To calculate amps for appliances with motors or compressors, use manufacturer data or a measured power factor rather than assuming a fixed range. For example, a fridge drawing 400W of electrical input power at 230V with PF 0.8 draws 400 ÷ (230 × 0.8) ≈ 2.2A, compared with 1.7A at PF 1.
Three-Phase AC: Watts to Amps at 400V
Three-phase supplies are used in workshops, farms and commercial premises, as well as some homes. A nominal 230/400V supply provides 400V between phases and approximately 230V between a phase and neutral.
For a balanced three-phase load, use:
Here, watts represent the total electrical input power across all three phases, and the result is the current in each line.
For example, a balanced load consuming 5000W on a 400V supply at PF 0.9 draws 5000 ÷ (1.732 × 400 × 0.9) ≈ 8.0A per line.
If using line-to-neutral voltage instead, the equivalent formula is:
Amps = Total Input Watts ÷ (3 × Line-to-Neutral Volts × Power Factor)
These formulas assume balanced loads; unbalanced loads require each phase to be assessed separately. If a motor’s stated wattage is its mechanical output rather than electrical input, its efficiency must also be included in the calculation.
Watts to Amps Chart: Quick Reference for 230V and 12V
These watts-to-amps charts cover nominal 230V single-phase mains supply and a 12V DC example. The first table assumes a power factor of 1.
Power (W) | Current (A) at 230V |
100 W | 0.43 A |
500 W | 2.17 A |
1000 W | 4.35 A |
1500 W | 6.52 A |
2000 W | 8.70 A |
2300 W | 10.00 A |
3000 W | 13.04 A |
3500 W | 15.22 A |
4000 W | 17.39 A |
5000 W | 21.74 A |
*Values assume 230V AC and PF = 1. For other power factors, use Amps = Watts ÷ (230 × PF). The 4000W and 5000W entries exceed a 16A socket’s nominal current rating.
The next table shows current drawn at a 12V DC input. For systems operating at other voltages, recalculate using the actual operating voltage.
Power (W) | Current (A) at 12V |
50 W | 4.17 A |
100 W | 8.33 A |
200 W | 16.67 A |
300 W | 25.00 A |
500 W | 41.67 A |
1000 W | 83.33 A |
1500 W | 125.00 A |
2000 W | 166.67 A |
*Values use Amps = Watts ÷ 12, with watts measured at the DC input. When supplying AC appliances through an inverter, battery-current calculations must also account for inverter losses.
For the same power, a lower voltage means a higher current. This makes appropriate cable sizing and fuse selection especially important in low-voltage battery systems; current estimates alone are not enough to select either.
How to Use Watts-to-Amps Calculations in Real Life
You can use these calculations to check appliance loads, understand battery current and estimate runtime.
Checking Appliance Loads Against Connection Limits
Many household wall sockets are rated at 16A, but check your socket, plug, extension lead, and circuit breaker rather than assuming a 20A circuit. A 2300W kettle draws about 10A at 230V, so running several high-wattage appliances on the same connection can exceed its rating.
Check your appliances’ input ratings and keep the combined load within the limits of each connection and the supplying circuit. Avoid overloading plugs and extension leads, and follow the equipment’s continuous ratings and operating instructions.
Understanding Battery-Side Current
Low-voltage DC systems require extra attention because current increases quickly. A 3000W inverter delivering full output draws approximately 278A at a battery voltage of 12V and an assumed efficiency of 90%: 3000 ÷ (12 × 0.9). Actual current varies with battery voltage and inverter efficiency. Cable and DC fuse selection should follow the manufacturer’s requirements, cable current-carrying capacity, and installation conditions.
Motors and compressors can briefly draw several times their running current when starting. Protective-device selection should also account for normal startup current and wiring protection requirements.
Estimating Battery Runtime from Current Draw
Estimate runtime by dividing usable battery capacity in amp-hours by average battery current in amps. A fridge drawing 60W at 12V uses 5A while running, so 100Ah of usable capacity would theoretically provide 20 hours of continuous operation. If the fridge cycles on and off, its average draw may be lower. Actual runtime also depends on battery chemistry, discharge limits, temperature, and system losses.
Choosing a Portable Power Station Using Watts and Amps
Watts-to-amps calculations help you match appliance loads to a portable power station. Check your combined load in watts against the unit’s total continuous AC output, and each appliance’s current against the relevant AC socket or port limit. Estimate runtime by dividing usable battery energy in watt-hours by average load in watts, allowing for conversion losses and the unit’s own consumption. Motor startup requirements also matter.
For example, a 2300W kettle draws about 10A at 230V. The outlet must support that current, while the unit’s total output must cover the kettle and any other appliances running alongside it.
If short outages interrupt your work or evening routine, the EcoFlow DELTA 3 Max Portable Power Station can help keep everyday essentials running, with a portable design you can move between your workspace and living area. Quiet operation at lighter loads suits working or relaxing at home, while fast recharging helps you prepare for the next interruption. Energy monitoring lets you track consumption as you add or switch devices.
For longer outages or times when several household appliances need power together, consider the EcoFlow DELTA 3 Ultra Plus Portable Power Station. Its output capacity supports simultaneous loads within its limits, and compatible extra batteries let you extend backup time. Solar charging with suitable panels can replenish energy during daylight, depending on sunlight conditions. Fast UPS switchover can also help compatible equipment stay running when mains power fails.
Start by listing the appliances you want to run together and checking their input ratings. Use the appropriate watts-to-amps calculation to estimate current, then compare it with your connections’ limits. When choosing backup power, check continuous output, startup requirements, and battery capacity for your intended runtime. If you need to change wiring or protective devices, have a qualified electrician assess the installation.
Is 1 Watt Equal to 1 Amp?
No. Watts measure power, while amps measure current. At 1V DC, a 1W load draws 1A, but the units are not interchangeable. At 230V single-phase AC, 1A corresponds to 230W only when the power factor is 1.
How Many Amps Is 3000 Watts at 230V?
A load drawing 3000W of electrical input power at 230V draws approximately 13.04A at PF 1. At PF 0.8, it draws approximately 16.3A, exceeding a 16A socket’s nominal rating. Check the actual connection ratings and other loads on the supplying circuit.
How Many Watts Can a 16A Socket Handle?
At 230V, a 16A socket corresponds to 3680W for a load with PF 1. At a lower power factor, real power is 230 × 16 × PF watts. Follow the ratings and operating instructions of the socket, plug, extension lead, and supplying circuit.
How Do You Calculate Watts to Amps for a 12V Battery?
For a load drawing power directly at 12V DC, divide its input watts by 12. A 60W load draws 5A. For an AC load supplied through an inverter, include efficiency: 1000W ÷ (12V × 0.9) ≈ 92.6A at an assumed 90% efficiency. Estimate runtime using usable battery capacity and average battery current.
What Power Factor Should I Use?
Use the power factor listed in your appliance’s specifications or measured with a suitable power meter. For simple resistive loads, such as a kettle’s heating element, PF ≈ 1 is a reasonable estimate. Motors, compressors, and electronic devices vary, so avoid assuming a fixed value such as 0.8. If PF is unknown, use the manufacturer’s rated input current where available. DC calculations do not require a power factor.
