Different Types of Batteries: Sizes, Uses, Lifespan, and Disposal
Different types of batteries power everything from TV remotes and hearing aids to cars, solar systems, and portable power stations. The clearest way to compare them is to start with two groups: primary batteries for single use and secondary batteries for recharging. From there, chemistry, size, voltage, capacity, lifespan, and safety determine the best fit. This guide compares different types of batteries and their uses, along with common sizes, typical lifespan, solar and backup applications, and safe disposal in South Africa.
Key Takeaways
Batteries fall into two main groups. Primary batteries are single-use, while secondary batteries are rechargeable.
Battery chemistry affects performance. Common types include alkaline, lithium-ion, NiMH, lead-acid, and NiCd.
Battery size does not define chemistry. AA, AAA, C, D, and 9V mainly describe battery form factor.
LFP works well for frequent cycling. It is widely used in solar storage and portable power stations.
Used batteries need proper disposal. South African households should use recognised collection or recycling points.
What Are the Different Types of Batteries?
Batteries fall into two main categories: primary batteries for single use and secondary batteries that you can recharge. Within each category, different chemistries serve different devices and energy needs. Battery size and battery chemistry are also two separate things. An AA battery, for example, can use alkaline, primary lithium, or rechargeable NiMH chemistry. The same distinction applies to larger battery packs, which may use lead-acid or different lithium-ion chemistries.
Battery Types at a Glance
The table below gives a quick comparison of the main battery types, including common formats, nominal voltage, typical lifespan, and uses:
Battery Type | Rechargeable? | Common Formats | Typical Nominal Voltage | Typical Life Reference | Common Uses |
Alkaline | No | AAA, AA, C, D, 9V | 1.5V per cell | Often 5–10 years shelf life | Remotes, clocks, toys, torches |
Zinc-Carbon | No | AAA, AA, C, D, 9V | 1.5V per cell | Generally shorter shelf life than alkaline | Clocks, radios, low-drain devices |
Primary Lithium | No | AA, AAA, coin cells | Varies by chemistry and format | Often 10+ years shelf life | Cameras, sensors, key fobs, security devices |
Silver-Oxide | No | Button cells | Around 1.55V | Several years of shelf life | Watches, calculators, compact electronics |
Lithium-Ion (NMC, LCO, NCA, LMO) | Yes | Cylindrical, pouch and custom packs | Around 3.6–3.7V per cell | Commonly hundreds to around 2,000 cycles | Phones, laptops, power tools, EVs |
LFP / LiFePO4 (Lithium-Ion) | Yes | Cylindrical, prismatic and custom packs | Around 3.2V per cell | Commonly several thousand cycles | Solar storage, home backup, portable power stations |
Lead-Acid | Yes | Starter, flooded, AGM, gel | Around 2.0V per cell | Varies widely by design and use | Vehicles, UPS, backup power, deep-cycle storage |
NiMH | Yes | AA, AAA, battery packs | 1.2V per cell | Hundreds to 1,000+ cycles depending on design | Controllers, cameras, toys, hybrid vehicles |
NiCd | Yes | Cylindrical cells, battery packs | 1.2V per cell | Often around 1,000 cycles under suitable conditions | Older tools, emergency lighting, industrial equipment |
*Battery size and chemistry are not the same thing. AA and AAA describe physical formats, while codes such as CR2032 or SR44 identify more specific cell formats and chemistries. Always match the battery code and voltage required by the device.
Primary Batteries (Non-Rechargeable)
Primary batteries provide single-use power and do not support normal recharging. They remain common in household electronics, sensors, watches, hearing aids, and other devices where long storage life or simple battery replacement matters.
Alkaline Batteries
Alkaline batteries use zinc and manganese dioxide chemistry and rank among the most common household battery types. They offer good shelf life, broad availability, and more usable capacity than basic zinc-carbon cells under many everyday loads. Common applications include TV remotes, wall clocks, toys, wireless accessories, and torches.
Zinc-Carbon Batteries
Zinc-carbon batteries provide a simple, low-cost option for devices with modest power demands. They generally store less usable energy than alkaline batteries and lose voltage more quickly under heavier loads. Basic clocks, radios, torches, and other low-drain electronics remain their most typical uses.
Primary Lithium Batteries
Primary lithium refers to several non-rechargeable lithium chemistries and should not be confused with rechargeable lithium-ion batteries. These cells offer high energy density, low self-discharge, and reliable operation across a broad temperature range. Cameras, security sensors, key fobs, smoke alarms, meters, and other devices that may remain unused for long periods commonly use primary lithium batteries.
Silver-Oxide and Zinc-Air Batteries
Silver-oxide and zinc-air represent two different chemistries that commonly appear in compact button-cell formats. Silver-oxide batteries maintain a stable discharge voltage, which makes them useful in watches, calculators, and other precision electronics. Zinc-air batteries draw oxygen from the surrounding air and provide high energy density in a small cell, making them especially common in hearing aids.
Secondary Batteries (Rechargeable)
Secondary batteries can be recharged and used through repeated charge and discharge cycles. They cover a wide range of applications, from rechargeable household cells and vehicle batteries to solar storage, backup systems, and portable power.
Lithium-Ion Batteries
Lithium-ion is a broad family of rechargeable batteries known for high energy density, relatively low weight, and low self-discharge. Common chemistries include LCO, LMO, NMC, NCA, LFP, and LTO, with each offering a different balance of energy density, power output, lifespan, and thermal stability. Lithium-ion batteries now power smartphones, laptops, cordless tools, electric vehicles, and many energy-storage systems.
Lithium Iron Phosphate (LiFePO4 or LFP)
LFP is a lithium-ion chemistry that uses iron phosphate in the cathode. It offers strong thermal stability and a long cycle life, though its energy density is generally lower than that of chemistries such as NMC or NCA. These characteristics make a LiFePO4 battery particularly relevant to solar storage, home backup systems, and portable power stations that undergo frequent cycling.
Lead-Acid Batteries
Lead-acid remains one of the most established rechargeable battery technologies. Its ability to deliver high surge current keeps it widely used in vehicle starter batteries, while deep-cycle versions support UPS systems, caravans, backup power, and some solar installations. Flooded, AGM, and gel designs serve different charging and maintenance needs, and all remain relatively heavy for the amount of energy they store.
Nickel-Metal Hydride (NiMH) Batteries
NiMH offers higher energy density than older NiCd technology and avoids the cadmium used in NiCd cells. Rechargeable AA and AAA NiMH batteries remain useful for gaming controllers, cameras, toys, portable electronics, and other devices that go through disposable batteries regularly. Some hybrid vehicles have also used larger NiMH battery packs.
Nickel-Cadmium (NiCd) Batteries
NiCd batteries can deliver high current and tolerate demanding operating conditions, which made them common in cordless tools, two-way radios, emergency lighting, and industrial equipment. They can also experience memory-related capacity effects under certain charging patterns. Cadmium toxicity remains the larger concern, and NiMH or lithium-ion technologies have replaced NiCd in many consumer applications.
How to Choose the Right Battery Type
Start with the device or system you need to power. Check its basic requirements first, then consider how often you use it and whether a rechargeable battery makes practical sense.
Check Compatibility and Usage Requirements
A battery needs to match both the device and the way you use it. Focus on these five points before making a choice:
Size and Code: Match the required format, whether the device takes a standard AA cell, a CR2032 coin cell, or another specific battery code.
Voltage: Check the required nominal voltage, especially when switching between different battery chemistries.
Power Demand: A wall clock and a camera may use the same battery size but place very different demands on it, so check whether the device has low or high power requirements.
Usage Frequency and Rechargeability: Single-use batteries work well for devices that need occasional power, while rechargeable options make more sense for equipment you use frequently.
Charging Requirements: Use charging equipment that matches the battery chemistry and voltage.
Match the Battery to the Application
The intended use quickly narrows the options. Small household electronics, vehicles, solar storage, and backup systems all place different demands on their batteries:
Low-drain household devices: Alkaline batteries work well for remotes, wall clocks, and other devices that use small amounts of power over long periods.
Frequently used AA or AAA devices: Rechargeable NiMH batteries make sense for gaming controllers, cameras, toys, and other devices that go through disposable batteries quickly.
Vehicle starting: Lead-acid starter batteries deliver the high current needed to start petrol and diesel engines.
Solar and home backup: LFP batteries handle frequent charging and discharging well, making them a common choice for solar storage and backup power systems.
Portable backup power: An LFP portable power station combines battery storage, AC power, charging, and battery management in one system. For home backup, the right model mainly depends on how much power you need and how long you want essential devices to keep running.
For moderate home backup, the EcoFlow DELTA 3 Max Portable Power Station can keep essential appliances, home-office equipment, lights, and personal devices powered for shorter backup periods. Its integrated LFP battery and UPS function also make it practical for setups that need reliable backup in a relatively compact unit.
For heavier household loads or longer backup periods, the EcoFlow DELTA 3 Ultra Plus Portable Power Station provides more capacity and output for demanding home backup needs. Its 3–7kWh expandable capacity and 3600W AC output make it suitable for running multiple household appliances while giving users room to increase backup capacity if needed.
Safe Battery Use and Disposal
Good storage and charging habits reduce the risk of leaks, overheating, and short circuits. Once a battery reaches the end of its useful life, keep it separate from general household waste and use an appropriate collection or recycling route.
Store Batteries in the Right Conditions
Keep batteries cool and dry: Store them away from direct sunlight, heaters, and damp areas. High temperatures can increase self-discharge and raise the risk of leakage.
Keep loose terminals separated: Leave batteries in their original packaging or use a non-metal storage container. Avoid contact with keys, coins, or other metal objects that could cause a short circuit.
Do not mix batteries: Replace cells as a set and avoid combining old and new batteries or different chemistries in the same device.
Remove any battery that shows swelling, leakage, corrosion, or serious physical damage and keep it away from normal batteries until you can arrange safe disposal.
Charge Rechargeable Batteries Safely
Use a charger that matches the battery chemistry and voltage. Never try to recharge alkaline, zinc-carbon, or another battery that does not carry a rechargeable label.
During charging, keep the battery or portable power system away from direct sunlight and other heat sources, and leave ventilation openings clear. Stop using a pack if you notice swelling, leakage, an unusual smell, or other signs of damage.
Dispose of Used Batteries Properly
Used batteries should stay out of general household waste. South Africa has formal collection and recycling routes for portable batteries, so households can usually use retailer drop-off points, municipal facilities, or specialist recyclers depending on the battery type.
Use local collection points: Johannesburg residents can check whether a nearby Pikitup site accepts e-waste or use a retailer battery collection point. Cape Town residents can also use selected retailer or municipal facilities that accept batteries.
Keep larger batteries separate: Return lead-acid vehicle batteries to battery dealers or specialist recyclers. Larger lithium battery packs may require an e-waste or dedicated battery recycling facility.
Protect exposed terminals: Tape lithium battery terminals before storage or transport where needed to reduce the risk of short circuits.
Different types of batteries serve different devices and energy needs. Start with the required size and voltage, then decide whether you need a single-use or rechargeable battery and compare the chemistry, capacity, and expected lifespan. LFP works particularly well for solar storage and portable power that involves frequent cycling. Always use the correct charger and a suitable recycling route when the battery reaches the end of its useful life.
What Is the Difference Between AA and AAA Batteries?
AA and AAA describe physical size, not a single chemistry. AA cells are larger and normally provide more capacity than comparable AAA cells, while AAA cells fit smaller devices. Both sizes are available in several chemistries, including alkaline and rechargeable NiMH, and some markets also offer primary lithium versions. Always match the device’s required chemistry and voltage rather than assuming that size alone determines compatibility.
Which Battery Type Is Best for Solar Storage?
Lead-acid and lithium-based batteries are common choices for household solar storage. Among lithium chemistries, LFP is widely used because it supports frequent cycling, long service life, and strong thermal stability. The best option still depends on usable capacity, inverter compatibility, daily energy demand, available space, budget, and expansion plans.
Can Used Batteries Go in Household Rubbish in South Africa?
Use a recognised battery collection or recycling route and keep used batteries out of ordinary household waste. South Africa has an Extended Producer Responsibility scheme for portable batteries, and municipalities or retailers may provide collection options. Store spent batteries so terminals cannot short, check local acceptance rules, and use specialist guidance for damaged lithium packs or lead-acid batteries. Local drop-off arrangements can differ from one municipality to another.
