kW to Amps: How to Convert Kilowatts to Amperes for Common Appliances
Understanding how to convert kilowatts (kW) to amps (A) is essential for anyone working with electrical systems, whether at home, in an RV, or when using generators, solar setups, or a portable power station. While kilowatts measure electrical power, amperes indicate the flow of electric current. Knowing how these two units relate helps ensure circuits, batteries, and power equipment are sized correctly and operated safely.
In this guide, we’ll explain how to convert kW to amps using clear formulas for DC, single-phase AC, and three-phase AC systems. You’ll also find step-by-step calculation examples, a quick reference table, and guidance on when to use an online calculator. Whether you’re planning a solar installation, checking generator capacity, or evaluating the power demands of household appliances, this article will help you calculate amperage accurately and with confidence.
What Are Kilowatts?
A kilowatt (kW) is a unit of electrical power that measures the rate at which energy is used or produced. One kilowatt equals 1,000 watts, and it represents how much electrical energy a device consumes per unit of time.
For example, if a heater is rated at 2 kW, it uses 2,000 watts of power continuously when running. Kilowatts are commonly used to describe the power output of generators, appliances, solar panels, and even electric vehicles.
What Are Amps?
Amps, short for amperes (A), measure the flow of electrical current in a circuit. In simple terms, current is the amount of electric charge moving through a conductor per second. You can think of it like water flowing through a pipe: while kilowatts measure the energy, amps measure how much “electric charge” is actually moving at a given moment.
One ampere represents one coulomb of charge passing a point in one second. For example, a 15-amp household circuit can safely carry a flow of 15 amperes of electric current.
How to Convert kW to Amps
Basic Formulas for Converting kW to Amps
Converting kilowatts (kW) to amps (A) is essential for understanding how much current a device, circuit, or generator draws. The calculation depends on the type of electrical system you’re using: DC, single-phase AC, or three-phase AC.
1. DC Circuits
For direct current (DC) systems, the formula is straightforward:
  • Amps (A)=Kilowatts (kW)×1000÷Voltage (V)
kW = power in kilowatts
V = voltage of the system
Example: A 3 kW DC device operating at 48V draws:
A=3×1000/48=62.5 A
2. Single-Phase AC Circuits
For single-phase alternating current (AC), the formula also accounts for the power factor (PF), which represents the efficiency of the load:
  • Amps (A)=Kilowatts (kW)×1000 ÷(Voltage (V)×PF)
PF is typically between 0.8 and 1 for most appliances.
Example: A 5 kW appliance at 240V with PF = 0.8:
A=5×1000 ÷(240×0.8)=26.04 A
3. Three-Phase AC Circuits
For three-phase AC systems, the formula becomes:
Amps (A) = Kilowatts (kW) × 1000 ÷ (√3 × Voltage (V) × PF)
  • Voltage here is line-to-line RMS voltage
  • √3 ≈ 1.732
Example: A 10 kW three-phase motor at 400V with PF = 0.9:
A=10×1000 ÷(1.732×400×0.9)≈16.0 A
Tip: If your system specifies apparent power in kVA, first convert to kW using kVA to kW to ensure accurate current calculations.
How to Calculate Amps Manually
Calculating amps manually is easier than it sounds once you understand the formulas. Here’s a simple step-by-step guide for DC, single-phase AC, and three-phase AC circuits.
Step 1: Identify the System Type
Before starting, determine whether your device or circuit is:
  • DC (Direct Current) – typically found in solar panels, batteries, or portable power stations, labeled “DC 12V/24V.”
  • Single-phase AC – Standard in households and small businesses, using 230 V Type M or N sockets.
  • Three-phase AC – Alternating current with three live wires (L1, L2, L3), typically used in commercial or industrial installations.
This is important because the formula for amps changes depending on the type.
Step 2: Gather Necessary Information
You’ll need:
  • Power in kilowatts (kW) – usually listed on the appliance, generator, or battery
  • Voltage (V) – system voltage, e.g., 12V, 120V, 240V, or 400V
  • Power Factor (PF) – for AC systems; if unknown, use 0.8 as a safe estimate
Step 3: Apply the Correct Formula
DC Circuits:
A=kW×1000÷V
Single-Phase AC:
A=kW×1000÷(V×PF)
Three-Phase AC:
A=kW×1000÷(3×V×PF)
Step 4: Perform the Calculation
Example 1: DC Circuit
Power: 2 kW
Voltage: 24V
A=2×1000÷24=83.33 A
Example 2: Single-Phase AC
Power: 5 kW
Voltage: 240V
Power Factor: 0.8
A=5×1000÷(240×0.8)=26.04 A
Example 3: Three-Phase AC
Power: 10 kW
Voltage: 400V (line-to-line)
Power Factor: 0.9
A=10×1000÷(1.732×400×0.9)≈16 A
Using a kW to Amps Calculator
Using an online kW to Amps calculator is a quick and reliable way to convert kilowatts into amps without doing manual math. These calculators automatically apply the correct formulas for DC, single-phase AC, and three-phase AC systems, taking into account voltage and power factor.
One useful online tool is the kW to Amps Calculator, which allows you to:
  • Select your system type (DC, single-phase AC, or three-phase AC)
  • Enter the power in kilowatts (kW)
  • Specify the voltage (V)
  • Input the power factor for AC systems
Once the inputs are entered, the calculator instantly shows the current in amps (A), making it easy to assess the power draw of each appliance. Beyond online calculators, smart portable power stations can also help you monitor and manage household electricity usage, track consumption over time, and optimize energy efficiency.
If you’re working with a medium-capacity device, the EcoFlow DELTA 2 Portable Power Station provides a practical example. It allows you to estimate how many amps your appliances draw at different voltages, helping you plan and manage power usage efficiently.
With a 1024 Wh capacity and 1800 W AC output, the EcoFlow DELTA 2 Portable Power Station can power a 60 W laptop for up to 16 charges. Using the EcoFlow App, you can monitor power usage, customize charging data, and adjust charging speed. Thanks to X-Stream fast charging, it can be fully charged in just 80 minutes via AC input, making it easy to manage your energy efficiently. Note: AC Plug Cable is needed to connect the Power Station with a Transfer Switch.
For higher-power scenarios, the EcoFlow DELTA Pro 3 Portable Power Station provides a practical solution for running demanding appliances while giving you real-time insight into your energy usage.
The EcoFlow DELTA Pro 3 Portable Power Station features a 4096 Wh capacity and 4000 W output, capable of running a 1000 W coffee maker for around 3.3 hours. It offers 6 unique and 18 combo charging methods for maximum flexibility, and X-Stream fast charging technology lets you go from 0 to 80% in just 1 hour. The EcoFlow App records power usage and helps optimize appliances, making it easy to manage and monitor your energy consumption.
kW to Amps Quick Reference Table
The kilowatts to amps quick reference table below provides an easy way to estimate electrical current based on power and voltage. These values are calculated using standard electrical conversion formulas and assume a single-phase system with a constant voltage supply.
Please note that this table is intended for general reference only. Actual current may vary depending on factors such as power factor, system efficiency, and load characteristics. For precise results, always confirm your system specifications or use a dedicated kW to amps calculator.
Kilowatts (kW)
Amps at 120V
Amps at 208V
Amps at 240V
1 kW
6.014 A
3.47 A
3.007 A
2 kW
12.028 A
6.939 A
6.014 A
3 kW
18.042 A
10.409 A
9.021 A
4 kW
24.056 A
13.879 A
12.028 A
5 kW
30.07 A
17.348 A
15.035 A
7 kW
42.098 A
24.288 A
21.049 A
10 kW
60.141 A
34.697 A
30.07 A
15 kW
90.211 A
90.211 A
90.211 A
20 kW
120.28 A
69.393 A
60.141 A
25 kW
150.35 A
86.741 A
75.176 A
Referred source: Inch Calculator
Accurately converting kW to amps helps you safely plan and manage electricity for household appliances and portable power stations. These calculations ensure circuits, batteries, and devices operate reliably while allowing you to monitor and optimize energy use efficiently.
How much is 1 kW in amps?
The number of amps in 1 kW depends on the voltage and the type of electrical system. In a single-phase AC system, which is common in homes, the formula is amps = (kW × 1000) ÷ (voltage × power factor). For example, at 120 V with a power factor of 1, 1 kW equals about 8.33 amps. At 240 V, the same 1 kW draws roughly 4.17 amps. In DC systems, power factor does not apply, so 1 kW at 48 V would draw about 20.8 amps. Always confirm the system voltage before calculating.
How to convert kW to amps 3 phase?
To convert kilowatts to amps in a three-phase system, you need to account for voltage and power factor. The standard formula is: amps = (kW × 1000) ÷ (√3 × voltage × power factor). Voltage refers to the line-to-line voltage, commonly 400 V in many regions. For example, a 10 kW three-phase load operating at 400 V with a power factor of 0.9 draws approximately 16 amps per phase. This calculation is essential for selecting the correct cables, breakers, and protection devices in commercial or industrial installations.
How many kW is 30 amps?
The kilowatt value of 30 amps depends on voltage, system type, and power factor. In a single-phase AC system at 240 V with a power factor of 0.8, the calculation is kW = (amps × voltage × power factor) ÷ 1000. Using this formula, 30 amps equals about 5.76 kW. At 120 V with a power factor of 1, 30 amps would equal 3.6 kW. For three-phase systems, the result will differ again, so it’s important to use the correct formula for your setup.
Industry Knowledge
