Prepaid Electricity Meter Price in South Africa: What You May Pay
- Key Takeaways
- Prepaid Electricity Meter Price at a Glance
- What Affects the Cost of a Prepaid Electricity Meter?
- What Should You Budget for Beyond the Prepaid Meter?
- Can You Get a Prepaid Electricity Meter for Free?
- What Does a Prepaid Sub-Meter Cost for Landlords?
- Is Prepaid Electricity Cheaper than Postpaid?
- Can a Portable Power Station Help Manage Prepaid Electricity Costs?
- Conclusion
- FAQs
Prepaid electricity meter prices in South Africa are not the same everywhere. In 2026/27, an existing single-phase household meter change is listed at R2,870, including VAT through Eskom and R3,875.30 for a standard City of Cape Town credit-to-prepaid retrofit. This guide breaks down the main meter charges, extra costs, private sub-meter pricing and when a meter change may be free.
Key Takeaways
Eskom and municipalities set their own prepaid meter charges, so there is no single nationwide price.
Private sub-meters for rental properties are separate from Eskom or municipal meters and are generally priced differently.
Electrical labor, a CoC, a meter enclosure or non-standard connection work can increase the total beyond the meter charge.
Eskom meter changes carried out as part of an Eskom conversion programme may have no meter-change fee.
A prepaid meter does not automatically mean cheaper electricity; the final cost still depends on the applicable tariff and household usage.
Prepaid electricity meter prices in South Africa vary depending on the electricity supplier, meter type and whether the meter is supplied through Eskom, a municipality or bought privately as a sub-meter.
Scenario | 2026/27 Cost | Note |
Eskom single-phase meter conversion | R2,870 incl. VAT | Maybe free under an Eskom conversion programme |
Eskom three-phase meter conversion | Varies | Priced according to the work required |
Cape Town 60A credit-to-prepaid retrofit | R3,875.30 incl. VAT | Customer-side cable work may cost extra |
Cape Town's new single-phase split prepaid meter | R3,157 incl. VAT | Meter only |
Cape Town's new three-phase split prepaid meter | R4,405 incl. VAT | Meter only |
For an existing single-phase household supply, the 2026/27 benchmark is R2,870 including VAT through Eskom, compared with R3,875.30 for a standard 60A credit-to-prepaid retrofit in Cape Town. Three-phase pricing is less standardized and may be calculated according to the specific supply arrangement.
The biggest difference is not usually the brand of the meter, but the type of installation you need.
Your Electricity Supplier
Eskom and municipalities set their own connection, conversion and metering charges. The same type of household meter can therefore cost a different amount depending on who supplies electricity to the property. Cape Town, for instance, uses its own electricity connection application and tariff schedule rather than Eskom's residential conversion fee.
New Connection or Existing Meter Conversion
Changing an existing credit meter to prepaid is different from installing a meter as part of a new electricity connection. Both Eskom and the City of Cape Town price these scenarios separately, and new connections may include network, cable or connection costs beyond the meter itself.
Single-Phase or Three-Phase Supply
A standard single-phase conversion may have a published fee, while three-phase work is more likely to be charged according to the equipment and work required. Eskom lists three-phase meter changes at standard metering or allocated cost, while Cape Town's published split-PPM price is higher for three-phase than for single-phase new connections.
The meter itself is only part of the budget. A meter enclosure, electrical laborand a Certificate of Compliance (CoC) can add to the total, while more substantial supply changes may involve separate Eskom or municipal charges. Here are the line items to plan for:
Possible Extra Cost | 2026 Reference Cost | When It May Apply |
Registered electrician | R400–R800/hour | Cabling or electrical alterations |
Electrical CoC | R900–R1,900 | Inspection and certification where required |
Basic meter enclosure | R590–R713 | New or replacement meter box |
Meter relocation | Quote required | Moving the existing meter |
Phase or supply change | Actual cost / quote | Changing phase or supply capacity |
Network or connection work | Quote required | New or modified grid connection |
A basic meter enclosure typically costs around R590–R713, while electrician laboris about R400–R800 per hour and a CoC is roughly R900–R1,900. Extra cabling, repairs, meter relocation or changes to the property's phase or supply can push the total higher, so the final cost depends on the work needed at the property.
A meter change may be free when it forms part of an Eskom or municipal replacement programme. Outside these programmes, the normal conversion or meter-change charge still applies.
When Eskom Covers the Meter Change
Eskom's 2026/27 fee schedule lists R2,870 including VAT for changing an existing single-phase conventional meter to prepaid. The same schedule states that the meter-change charge falls away when the work forms part of an Eskom conversion programme.
Eskom is also rolling out smart meters by area between 2025 and 2029, with affected customers notified when their area is scheduled. This wider rollout should not be treated as a blanket guarantee that every prepaid meter replacement is free.
Municipal Replacement Programmes
Municipal arrangements vary by area. In Cape Town, the City's compulsory meter replacement programme is still active in 2026 and replaces selected old credit meters, as well as some older prepaid meters, with new prepaid meters at no cost when an area is scheduled.
If your meter is not covered by a replacement programme, check your supplier's requirements or see how to apply for a prepaid electricity meter.
What If an Older Prepaid Meter Was Not Recoded?
The national KRN2/TID rollover took effect on 24 November 2024, so this is no longer an upcoming deadline. Eskom completed its prepaid-meter rollover project in November 2024 and continues to assist customers whose meters still have KRN-related problems. Meter recoding itself is free.
A landlord sub-meter is separate from the Eskom or municipal prepaid meter discussed above. It is installed downstream of the main supply to record electricity use for individual rental units, while the main account remains with the property owner.
How Much Does a Private Sub-Meter Cost?
Private sub-meters do not have a regulated national price, but current South African supplier listings give a useful indication of the market:
Sub-Meter Type | Current Market Reference |
Basic single-phase prepaid meter | From about R120 |
Integrated single-phase meter | Around R400–R700 |
Single-phase split meter with CIU | Around R1,200–R1,300 |
Three-phase sub-meter | Around R1,600–R2,200 |
Source: nationalprepaid
These figures are market references rather than Eskom or municipal tariffs, so the actual price depends on the meter type and private metering provider.
What Should Landlords Budget for Installation?
Installation is usually quoted separately because the cost depends on the rental unit's existing wiring and distribution board. One South African prepaid metering provider lists a basic single-phase meter at R119 supply only and R890 supplied and installed, while a three-phase option is listed at R1,580 supply only and R2,190 supplied and installed.
Additional wiring or distribution-board work can increase the total. The private sub-meter should be installed through an appropriately registered electrical contractor and remains separate from the property's main Eskom or municipal meter.
A prepaid meter does not automatically make electricity cheaper. It mainly changes how you pay and monitor consumption, while the actual bill still reflects the tariff that applies to your supply.
What Determines the Cost?
Tariff rules differ between Eskom and municipalities, and may also vary by residential category, usage level and applicable fixed charges. Cape Town's meter replacement programme, for instance, keeps customers on the same tariff after conversion to prepaid; qualifying households may instead move onto the Lifeline tariff, which includes Free Basic Electricity.
That means prepaid should not be treated as a lower-rate tariff by default. The relevant Eskom or municipal tariff schedule is the better place to compare what you would actually pay.
Can Prepaid Make Usage Easier to Manage?
Where prepaid can help is visibility. Seeing the remaining credit makes it easier to notice how quickly electricity is being used and adjust consumption before the next top-up. The City of Cape Town similarly notes that customers who actively monitor prepaid use often change their consumption patterns, although the meter itself does not reduce the tariff.
Managing prepaid electricity costs is largely about reducing how much grid electricity your household needs to buy. A portable power station can support that by storing solar energy for later use, allowing selected appliances to draw from stored power instead of the prepaid supply when solar energy is available.
The EcoFlow DELTA 3 Max Portable Power Station has a 2,048Wh capacity, 2,400W AC output and up to 500W solar input. It suits households that want to shift a smaller group of everyday loads, such as a fridge, router, TV or lighting, onto stored solar energy for part of the day.
The EcoFlow DELTA 3 Ultra Plus Portable Power Station offers more room to manage a larger share of household use, with 3,072Wh of capacity, 3,600W AC output and up to 1,600W solar input. Its larger battery and higher solar input make it better suited to homes looking to store more daytime solar generation and use it across a broader range of appliances later on.
Prepaid electricity meter prices in South Africa vary by supplier and meter type. In 2026/27, an existing single-phase meter change is listed at R2,870, including VAT through Eskom and R3,875.30 for a standard Cape Town credit-to-prepaid retrofit, while private landlord sub-meters can start at around R120, with split models generally costing more. Check whether your meter is covered by a replacement programme and allow for any additional electrical or compliance costs before budgeting.
Is it cheaper to have a prepaid electricity meter?
Not automatically. Your electricity cost depends on the tariff set by Eskom or your municipality, your tariff category and how much electricity you use. Prepaid metering can make usage easier to monitor, but the meter itself does not guarantee a lower electricity rate.
What are the two types of prepaid meters?
The two common formats are integrated and split meters. An integrated meter combines the meter and keypad in one unit, while a split meter uses a separate customer interface unit (CIU), usually positioned inside the property, to enter tokens and check the balance.
How do I update or unlock my prepaid meter?
If your prepaid meter rejects tokens, shows a KRN-related error or becomes blocked after a fault or tamper event, first check with Eskom or your municipality to confirm the cause. For common lockout or tamper-code issues, see our guide on the code to unlock the prepaid meter.
Can I install a prepaid electricity meter myself?
No. Electrical installation work should be handled by an appropriately registered electrical contractor. Where a Certificate of Compliance is required, it must be issued by a registered person after the relevant installation has been inspected and tested.
