How to Claim Solar Tax Rebate in South Africa?
With the rising demand for renewable energy, South Africa has introduced attractive solar power incentives to encourage its adoption. One key incentive is the solar panel tax rebate, which allows homeowners to recover some of their costs. However, to fully benefit from these savings, it's crucial to understand eligibility, rebate calculations, and the claim process. This blog will explore everything you should know about the solar rebate. Read on to maximize savings while staying legally aligned.
What Is the Solar Panel Tax Rebate?
The solar panel tax rebate is a government-backed incentive to encourage South African households to invest in renewable energy. Launched as part of efforts to reduce reliance on the national grid and ease the strain of load shedding, this rebate allows individuals to claim back a portion of their solar installation costs through their annual tax return.
Specifically, South African taxpayers can receive up to 25% of the cost of new solar panels, with a maximum rebate of R15,000 per individual. The rebate applies to solar PV panels (excluding inverters and batteries) purchased and installed between 1 March 2023 and 29 February 2024, provided they meet minimum size and certification requirements.
To qualify, the system must be installed at a primary residence and produce electricity directly for the home. Only new and unused solar panels are eligible, and proper documentation, such as a certificate of compliance, is essential.
This rebate reduces the upfront cost of going solar. By combining tax incentives with efficient systems like solar generators, homeowners can boost their energy independence and financial resilience in the long term.
Eligibility Criteria for Claiming the Rebate
To claim the tax rebate for solar panels in South Africa, you must meet specific criteria set by the National Treasury. The South African Revenue Service (SARS) has also offered more detailed guidance to ensure the rebate supports genuine residential solar adoption and excludes non-qualifying installations.
  1. Individual Taxpayer
Only individuals who pay personal income tax in South Africa are eligible to claim the rebate. Companies or trusts apply for different solar tax incentives.
  1. New and Unused Panels
The rebate applies only to new, unused solar PV panels, with a minimum output of 275W. Second-hand or refurbished components do not qualify.
  1. Installation Period
The solar panels must be purchased and installed between 1 March 2023 and 29 February 2024.
  1. Primary Residence
The installation must take place at a residential property. It does not require property ownership. So, installations by landlords or renters are eligible for it. However, only the party that paid for the solar panels can claim the rebate.
  1. Certificate of Compliance (CoC)
A valid electrical Certificate of Compliance must be provided to confirm proper and safe installation.
  1. Solar PV Panels Only
The rebate applies to solar panels. If you invest in a solar generator that includes solar panels, batteries, and inverters, the rebate will be for the solar panels solely; other components and installation labor costs are excluded.
How to Claim the Rebate?
Claiming the solar panel tax rebate in South Africa is relatively straightforward if you meet the eligibility criteria. Here's how to do it.
Step 1. Keep Your Proof of Purchase: You must retain a valid VAT invoice that lists the cost of the solar PV panels separately from other components like inverters or batteries.
Step 2. Obtain a Certificate of Compliance (CoC): A certified electrician must issue a CoC confirming that the system was installed according to safety regulations.
Step 3. Submit During Tax Season: The rebate must be claimed when you file your personal income tax return for the tax year 2023/2024. Then, log in to SARS eFiling and ensure you include all supporting documents.
Step 4. Calculate Your Rebate: You can claim 25% of the cost of qualifying solar panels, up to a maximum of R15,000 per individual. Once verified, SARS will automatically apply the rebate.
What's the Calculation of the Solar Rebate?
The solar panel tax rebate in South Africa allows individual taxpayers to claim 25% of the cost of new and unused solar photovoltaic (PV) panels purchased and installed between 1 March 2023 and 29 February 2024. However, the rebate is capped at R15,000 per taxpayer.
Here’s how the calculation works:
  • If you install solar panels worth R40,000, the 25% portion is R10,000. So, you’ll be eligible for a R10,000 rebate.
  • If your solar panels cost R100,000, 25% would be R25,000, but the rebate is capped, so you can only claim R15,000.
It’s important to note that the solar tax rebate only applies to the cost of the panels, not inverters, batteries, or installation labor. This makes choosing high-efficiency panels vital to maximize your return.
Benefits of Solar Tax Incentives
Solar tax incentives do more than ease the financial load. They give South Africans a real opportunity to reduce their reliance on the national grid. By claiming back a portion of your solar panel expenses (up to R15,000), you lower the upfront cost and make clean energy more accessible for your home.
  • Environmental Sustainability: As more homeowners install solar systems, national energy demand from fossil fuels drops, supporting a greener grid and helping combat climate change.
  • Economic and Environmental Benefits: They stimulate the local renewable energy market, encourage energy independence, and help build a more resilient, self-sufficient South Africa.
  • Immediate Return on Investment: The rebate helps you recover part of your installation costs, which can be used to enhance your setup, such as upgrading appliances or adding energy storage. Over time, lower electricity bills and protection from rising tariffs add up to long-term savings.
One smart way to make use of the rebate is by investing in a solar generator. The EcoFlow DELTA 2 960 Solar Generator (PV220W) is a flexible option, offering 1–3kWh expandable capacity, fast AC charging, and long-lasting performance. It’s perfect for storing daytime solar energy to use later.
For even greater efficiency, pair it with the EcoFlow PowerStream Microinverter. Together, they create a compact, grid-tied balcony solar system that powers your home during the day and stores energy for use at night, maximising both your rebate and energy independence.
The EcoFlow DELTA 2 960 Solar Generator is the best choice to make the most of your returned rebates for long-term energy independence. It is equipped with South African standard plugs. You never need to worry about compatibility. When paired with an EcoFlow PowerStream Microinverter, you’ll gain a grid-tied solar energy solution. The 1-3 kWh expandable capacity and up to 3040Wh output can powers your home day and night with the 1-3 kWh expandable capacity.
The solar tax rebate offers a meaningful incentive for South Africans to invest in clean energy. A full understanding of it is key. This blog covers its benefits, eligibility, calculations, and the full rebating process in advance. If you're planning to go solar with the solar tax rebates, be sure to follow the guide and proper steps wisely. Going solar is not just smart for the environment. It’s now smarter for your wallet, too.
What is the tax rebate for solar panels in South Africa?
The solar power tax rebate involves individuals and companies. The incentive ends on February 28, 2025, with a 125% deduction on renewable energy assets for businesses. For individuals, it lasts from March 1, 2023, to February 29, 2024, with a rebate of 25% of the cost of new and unused solar PV panels, capped at R15,000. Besides, this applied only to the panels themselves, not inverters or batteries, and was for panels installed at a primary residence.
Is solar a 125% tax deduction?
Yes — under Section 12BA of South Africa’s Income Tax Act, companies that first bring new, unused renewable energy assets (like solar PV systems or related structures) into use between 1 March 2023 and 28 February 2025 can claim a 125% upfront deduction of the asset’s cost. This incentive aims to accelerate private investment in renewables amid the energy crisis and applies to wind, solar, hydro, biomass, and related equipment. Businesses should retain invoices and proof of first use. Note also that if the asset is disposed of before 1 March 2026, a recoupment may apply.
*Disclaimer: Before reading this guidance, please remember that tax matters can be highly individualized and complex. EcoFlow does not provide any assurances or guarantees concerning potential tax credits associated with our products. Any information in this guidance is solely for educational purposes and shall not be construed as legal advice. We recommend you rely on the expertise of tax professionals for accurate and personalized tax advice.
