Load Shedding in Durban for 2025: Schedules, Causes, and Tips
If you live in Durban, living with load shedding as part of daily life is a constant struggle of checking the load shedding schedule. But besides checking the schedule, you also have to understand how it is organized. Load shedding in Durban is not just a minor inconvenience. It’s a repeating cycle that affects your day from the moment you wake up.
Despite the struggle, you still have to get used to checking the schedules, or it will leave you unprepared and ruin your plans. By keeping up with the schedule, you can feel in control and plan ahead of power cuts. In this guide, you will learn how to find today’s schedule, why Durban faces load shedding, what the load shedding table in Durban is, and power-saving tips.
Is There Load Shedding in Durban Today?
To determine if there is load shedding in Durban today, you have to check real-time updates from trusted platforms. These sources allow you to check whether your area is scheduled for a power outage. Here are platforms where you can see if there’s a power outage in Durban today:
1. Eskom Load Shedding Portal
Visit the Eskom Load Shedding Portal to check the national status and specific schedules. They have downloadable load shedding spreadsheets for Eskom customers. To find your schedule in the spreadsheet, identify and select the appropriate stage of load shedding. Next, identify and select your town, municipality, or city. Lastly, identify and select your suburb.
2. OurPower Website
Another helpful resource is the OurPower platform. It provides a simplified overview of the current and upcoming load shedding blocks across the eThekwini region. You can search by suburb to check if your block is part of a power outage in Durban today. If there are no scheduled load shedding, it will simply display “No load shedding.”
3. eThekwini Municipality Website
The eThekwini Municipality also helps you know if there is load shedding or no electricity in Durban today. They publish a PDF schedule by block, which is updated when Eskom announces new stages. You will need to know your block number, which can be found on your electricity bill. They offer official confirmation of what’s happening at the municipal level.
4. EskomSePush Mobile App
This app provides instant notifications on load shedding. Once you select your suburb, it will alert you to an upcoming power failure in Durban based on Eskom or municipal announcements. The app helps you stay prepared for scheduled electricity faults in Durban without checking multiple websites.
Why Durban Faces Load Shedding?
Load shedding in Durban happens because the national electricity supply from Eskom cannot meet the country’s total demand. Durban does not produce its power and relies entirely on the national grid, which becomes unstable when power stations break down. When supply drops too low, Eskom enforces scheduled blackouts in all major cities to prevent a total grid collapse.
One major reason for the electricity outage in Durban is the age and poor condition of Eskom’s coal-fired power stations, many of which are over 40 years old. These plants often break down, leaving the grid with far less electricity than needed. Another contributing factor is the lack of alternative energy sources, such as solar and wind, which could ease the load on the grid.
Moreover, there is a high energy demand during peak hours, especially at night. This overloads the system during winter and hot weather. To avoid a complete grid failure, Eskom cuts power in different areas at scheduled times. Until these issues are addressed, you will experience electricity faults in Durban.
Durban Load Shedding Schedule Table
The Durban Load Shedding Schedule Table is a detailed timetable created by the eThekwini Municipality to inform residents about planned load shedding in Durban. It helps you know exactly when your area will be affected during different stages of load shedding. This table is useful if you want to plan your day around power outages and avoid unexpected blackouts.
durban load shedding schedule table
The PDF begins with an alphabetical list of areas in Durban. Each was assigned a specific block number. You need to find your suburb and take note of the block it belongs to. After the tables of areas and blocks, the load shedding schedule table follows. You can see the schedule table of power outage in Durban, organized from Monday to Sunday.
Each daily schedule table is structured with a Time column on the left, showing two-hour intervals, and eight columns labeled Stage 1 (least severe) through Stage 8 (most severe). The block numbers listed under each stage indicate which areas will be affected during that time slot if that stage of load shedding is active.
For example, if it’s Wednesday and Eskom has declared Stage 3 load shedding, you only need to look at the Wednesday table, go to the “Stage 3” column, and check if your block appears in any of the time slots. If your block number appears in a time slot under the current load shedding stage, expect your electricity to be off during those hours.
Practical Power-Saving Tips to Outwit Load Shedding in Durban
For residents in Durban, they’re used to saying, “Load shedding affects our daily lives.” But just because load shedding in Durban is part of your daily life, you will always bear with its inconvenience. Consider practicing habits that can help you reduce your reliance on the grid and stay prepared for power cuts. Here are practical power-saving tips for you:
1. Know Load Shedding vs. Load Reduction
Understand the differences between load reduction and load shedding to help you prepare and adjust for these two common situations in Durban. Load shedding is a planned power cut due to a limited power supply. Load reduction means reducing power to those areas with illegal connections or a high risk of overloading. Load shedding is usually announced, but load reduction is sudden.
2. Set Up Reminders for Load Shedding Schedules
Consider installing the EskomSePush app to track if your area is part of a scheduled power outage in Durban. You can set alerts on your phone based on your suburb's block number. Having an app or setting calendar reminders helps you stay informed without checking updates on multiple websites.
3. Invest in a Portable Power Station
A portable power station is like a huge power bank. The thing is, it not only charges your phone but also your home appliances. It’s one of the most effective load-shedding solutions today. Unlike fuel generators, these stations are quiet, powerful, and portable. Some models can even be charged with solar panels, so you never run out of electricity.
4. Charge Your Devices Ahead of Schedule
Charge your devices in advance of an electricity outage in Durban. Your phone is almost a must in your daily routines, while your computer is essential for work. Keeping them charged helps you stay productive as you use them for important matters. Power banks are also a reliable backup for charging your small gadgets, such as phones.
5. Limit Use of Appliances at Peak Hours
Avoid using high-energy appliances during peak hours, such as at night when everyone is at home. Using fewer appliances can help reduce your electricity bills and reduce the stress on the grid. When all households are consuming high power, sudden power outages may occur, and you may not be prepared. Try using your appliances at off-peak times.
6. Cook with Gas When Possible
If you have an electric stove, consider cooking with a gas stove. Electric stoves are power-hungry appliances and completely useless during load shedding. Using a gas stove or portable gas cooker ensures you can still prepare meals during a load shedding in Durban. It’s a worthy addition to your kitchen during power cuts.
7. Use LED Bulbs or Solar Lights
Use LED lights as they consume less electricity than traditional bulbs. Consider also solar-powered lights that can be charged during the day or rechargeable lights that can be charged on power banks. When load shedding in Durban happens at night, your home will not go dark when you have backup lights. These are inexpensive and last longer.
8. Install Surge Protectors
Use surge protectors to safeguard your devices during power restoration. It can also help you save money on repairs or replacements. Power cuts in Durban are often followed by surges when electricity returns. These surges can damage sensitive equipment, including computers, TVs, and routers. It's a simple prevention that can help preserve your devices during frequent load shedding.
Meet Ecoflow: Back-Up Power Option for Durban Homes
With frequent load shedding in Durban, having a reliable power backup at home provides long-term benefits. In terms of power backups, portable power stations are at an advantage over fuel generators. If you’re looking for recommendations, here’s one of the most powerful portable power station options offered by EcoFlow:
The EcoFlow DELTA 2 Max Portable Power Station provides a robust 2048Wh capacity, capable of powering your entire family. Its expandable battery system can reach up to 6144Wh, enabling it to support 99% of your home appliances. Featuring advanced BMS (Battery Management System) protection, it safeguards against overloading and overheating. For added convenience, it can be recharged quickly using a dual solar panel setup, making it an excellent solution during power outages.
Thanks to its upgraded LFP battery, the DELTA 2 Max also offers a remarkable lifespan of 10 years or 3000 full charge cycles. This makes it not only a reliable backup for heavy appliances during load shedding but also a long-term investment for your power needs.
EcoFlow DELTA 2 Max portable power station
The EcoFlow DELTA 2 Max Portable Power Station offers expandable capacity from 2kWh to 6kWh, making it perfect for home backup, RVs, outdoor use, or everyday power needs. With its durable LFP battery, it provides over 3000 charge cycles, lasting up to 10 years. Featuring a powerful 3400W output, it can power 99% of home appliances. It boasts the world’s fastest recharging times, with dual AC+Solar charging. Smart app integration allows for efficient energy management and real-time monitoring.
Capacity: 2048Wh
Best For: Durban households needing reliable backup during load shedding
Key Features:
  • Expandable Battery up to 6144Wh
  • Dual Solar Charging System
  • 10 Years Life Span before Hitting 80% Capacity
  • Advanced BMS Protection
  • Quiet and Lightweight
Load shedding in Durban forces you to live your normal life in abnormal conditions. Knowing the schedules helps you lessen the inconvenience of power cuts by preparing in advance. This article discusses how to find your load shedding schedule, why Durban faces load shedding, and what the Durban load shedding schedule table is. You have also explored practical power-saving tips to outwit load shedding. Moreover, the article introduced the EcoFlow DELTA 2 Max Portable Power Station as a dependable power backup during load shedding. It’s not about how long you have to wait in the dark, but how well you have prepared until your power is restored.
What stage of load shedding is Durban currently on?
As of July 2025, there is no load shedding in Durban. Specifically, Eskom stated that no load shedding has been implemented since May 15, 2025. This means the power supply is currently stable. There are still unplanned power outages but at a reduced level. The stage of load shedding will depend on Eskom’s national load forecast and the availability of electricity. Durban can experience anything from Stage 1 to Stage 8, depending on the severity of the power shortage.
Does load shedding affect water supply in Durban?
Yes, load shedding can impact the water supply in Durban. Water treatment plants and pump stations rely heavily on a continuous power supply to ensure the distribution of water across the city. When electricity is cut during load shedding, these systems may experience reduced functionality, leading to lower water pressure or, in some cases, a complete interruption in water supply. During higher stages of load shedding, this risk increases. Residents are advised to store water in advance to avoid inconvenience during these periods.
How can I get a load shedding schedule for my suburb in Durban?
To get a load shedding schedule for your suburb in Durban, you can visit online platforms like OurPower.co.za or the official eThekwini Municipality website. These sources provide detailed schedules and updates for specific areas. Additionally, you can use the EskomSePush mobile app, which allows users to set up notifications for load shedding times, helping you stay informed in advance. These platforms are easy to navigate and ensure you can track power outages in real time.
Power Outages
