Eskom Gauteng Power Outage: How to Check, Report and Respond
An Eskom Gauteng power outage can still affect selected areas, despite improved stability across South Africa’s national power system. Depending on the location, the interruption may be scheduled load reduction, planned network work or an unplanned fault. This guide explains how to check the cause, report the outage and respond to different types of interruption.
Key Takeaways
  • Load reduction still applies to selected Eskom-supplied areas in Gauteng, although South Africa’s national power system remains stable. It does not affect the entire province.
  • Confirm whether Eskom or a municipal supplier serves the property, then review the relevant block schedule, planned-interruption notice or local fault information.
  • Log the outage with the responsible supplier and retain the reference number for progress checks or escalation.
  • Shift flexible electricity use around scheduled load reduction, plan sufficient runtime for maintenance, and prioritise essential loads when restoration time is uncertain, using an EcoFlow portable power station to provide temporary backup for selected devices where needed.
Current Electricity Situation in Gauteng
South Africa’s power system remains stable, and six provinces are currently free of load reduction. Selected Eskom-supplied areas in Gauteng, however, remain on load-reduction schedules, alongside affected areas in the Eastern Cape and KwaZulu-Natal, based on Eskom’s national system information published on 31 July 2026.
  • Current status: Load reduction still applies in parts of Gauteng, but not across the entire province. Eskom uses it where demand may overload local transformers and mini-substations, reducing the risk of equipment damage and longer outages. Understanding the difference between load shedding and load reduction helps explain why local interruptions may continue even when the national power system is stable.
  • Peak periods: Eskom generally schedules load reduction between 05:00–09:00 and 17:00–22:00. These are peak-period windows and do not mean that every affected block will be switched off for the full period.
  • Check your block: To confirm whether your area is affected on a particular day, check the current Gauteng schedule on Eskom’s official Load Reduction page. Match your area with the listed block, date and time slot.
An outage not listed on the load-reduction schedule may be a planned local interruption or an unplanned network fault. Check the latest notice from Eskom or your municipal electricity supplier for the cause and any available restoration time. Eskom aims to end load reduction nationwide in 2027, but affected Gauteng residents should continue checking the current area schedule while the programme remains in place.
How to Check and Report Eskom Gauteng Power Outages
Power outage information in Gauteng comes from different sources because electricity may be supplied by Eskom or a municipal provider. Checking the correct official source helps residents understand the cause and affected area, while reporting an unlisted fault ensures that it is logged with the supplier responsible for investigating it.
Check the Correct Outage Source
Power outage information in Gauteng varies by electricity supplier. Checking the correct official source helps residents understand the outage, while reporting it to the responsible supplier ensures that the fault is logged for investigation.
Then check the relevant official source:
  • Eskom-supplied areas: Visit Eskom’s official Load Reduction page and open the current Gauteng schedule. Find your area and check the applicable block, date and time slot. If the outage does not match the schedule, look for information in Eskom’s Media Statements or official Gauteng service communications.
  • Johannesburg City Power: Check the Media Statements section on the City Power website and the official @CityPowerJhb account for planned interruptions, network faults and affected suburbs. Confirm the date of the notice and whether your suburb or street is included.
  • City of Tshwane: Use the official Public Outage Reporting & Tracking service. Its Outage Map and Known Problems sections show areas with reported power failures, while Check Progress can be used for an existing report.
  • City of Ekurhuleni: Check Services Outages Alert on the City of Ekurhuleni website for notices about electricity interruptions and affected areas. Check the publication date, suburb and any available restoration information.
For each notice, confirm the affected area, outage type, start time and estimated time of restoration, where one is available. Restoration times may change after technicians assess the fault. Information shared in community groups should be checked against the relevant official source.
Report the Outage to the Correct Supplier
If electricity has not returned or the issue has not been reported, residents should report a power outage through the correct electricity supplier responsible for their area. Providing accurate information helps the supplier identify the problem, arrange repairs, and provide relevant updates more efficiently.
Supplier
Reporting channel
Contact
Eskom
Alfred on WhatsApp or Eskom Contact Centre
08600 37566
Call centre
011 490 7484; escalation 0800 003 156
City of Tshwane
Public Outage Reporting & Tracking or call centre
Report a Power Failure; 012 358 9999
City of Ekurhuleni
Report it, call centre or email
0860 543 000; call.centre@ekurhuleni.gov.za
Provide the following when logging the fault:
  • street address and suburb;
  • account or prepaid meter number;
  • time the power went off;
  • whether neighbouring properties are also affected;
  • a short description of the problem;
  • your contact details.
For an Eskom fault, provide the pole number if it is already known or visible from a safe location. Do not approach fallen lines, exposed cables or damaged electrical equipment to find it.
Keep the reference number issued when the fault is logged. Use it when checking progress or escalating an unresolved report. Tshwane’s Check Progress function supports online tracking, while Eskom’s Alfred can provide feedback on a previously reported fault.
Why Do Power Outages Still Happen in Gauteng?
Although South Africa’s overall electricity supply has improved, some areas in Gauteng may still experience power interruptions. These outages can happen for different reasons and may affect homes, businesses, and essential services. Understanding why an Eskom Gauteng power outage occurs can help residents better prepare for unexpected electricity interruptions and take appropriate measures to reduce disruptions.
Local Network Pressure
In some parts of Gauteng, power interruptions can occur when local electricity networks face excessive pressure from high demand or limited distribution capacity. During peak usage periods, overloaded equipment such as transformers and cables may increase the risk of faults or damage, which can affect electricity supply in nearby areas. To prevent larger network problems, Eskom may introduce load reduction in affected communities to temporarily reduce demand and protect local infrastructure.
Ageing Electricity Infrastructure
Ageing electricity infrastructure can contribute to power interruptions in some parts of Gauteng. When transformers, cables, and other equipment become outdated or cannot handle higher demand, faults are more likely to occur and affect electricity supply.
High Electricity Demand During Peak Hours
High electricity demand during peak hours can also put pressure on local power networks in Gauteng. When many households and businesses use electricity at the same time, especially in the morning and evening, overloaded equipment may increase the risk of power interruptions.
Illegal Connections and Electricity Theft
Illegal connections and electricity theft can put additional pressure on local electricity networks in Gauteng. These activities increase electricity demand beyond the designed capacity of some systems, which may lead to equipment failures and power interruptions.
Severe Weather Conditions
Severe weather conditions can also affect electricity supply in Gauteng. Heavy rain, thunderstorms, strong winds, and lightning can damage power lines, transformers, and other electrical equipment, leading to temporary power interruptions in affected areas.
How to Respond to Different Gauteng Power Interruptions
The right response depends on how much notice is available and how long the interruption may last. Scheduled load reduction allows households to shift electricity use, while planned maintenance provides time to arrange longer-term needs. During an unplanned fault, the priority is to conserve available power and respond to changing restoration information.
During Scheduled Peak-Period Load Reduction
Use the published time slot to move flexible household activities to another part of the day:
  • Heat the geyser and run the washing machine, dishwasher or pool pump before or after the affected peak period.
  • Finish cooking that requires an electric stove or oven before supply is interrupted.
  • Top up phones, rechargeable lights and batteries for Wi-Fi, alarms, electric gates and garage doors.
  • Disconnect non-essential appliances before the outage, then bring high-demand equipment back online gradually once electricity returns.
When several essentials need to remain powered during the scheduled interruption, households should consider their combined load and required runtime. The EcoFlow DELTA 3 Max Portable Power Station can be charged before the relevant block begins and reserved for devices such as Wi-Fi equipment, refrigeration or work electronics. Its smart app brings energy use, remaining battery capacity and connected solar generation into one dashboard, while timed charging and discharging can be set around the published interruption window.
- 2048Wh Capacity, 2400W AC Output - X-Boost™ Supports Appliances up to 3200W - <10ms UPS Auto-Switch - 4 Charging Methods, 0–80% in 51 Mins - 24/7 BMS Protection, EV-Grade CTC Structure - Smart App Control for Monitoring Energy Use
During Planned Maintenance
An advance notice provides time to calculate runtime and make arrangements for equipment or supplies that cannot remain without electricity:
  • Build in extra time in case the work continues beyond the published restoration estimate.
  • Where household members depend on powered medical equipment or temperature-controlled medicine, confirm the requirements with the healthcare provider, equipment supplier or pharmacist and put an appropriate emergency plan in place.
  • Match servers and sensitive electronics with a UPS or backup system that provides compatible output and sufficient usable capacity for the announced maintenance period.
  • Minimise refrigerator and freezer openings, and ensure that electric gates or garage doors can be operated manually.
A longer maintenance window may require several essential devices to operate together, particularly when refrigeration, connectivity or home-office equipment cannot wait for grid supply to return. The EcoFlow DELTA 3 Ultra Plus Portable Power Station offers expandable storage for changing backup requirements. Its UPS function can automatically transfer compatible connected equipment to battery power when supply is interrupted, helping reduce disruption to servers, networking equipment and other sensitive electronics.
- 3072Wh Capacity, 3600W AC Output - X-Boost™ up to 4700W, 7200W Surge - Expandable from 3kWh to 7kWh - <10ms UPS Auto-Switch - 5 Fast Charging Methods
During an Unplanned Local Outage
When no firm restoration time is available, stored energy should be directed towards the most important household functions:
  • Isolate high-consumption loads such as the geyser, electric heaters and cooking appliances.
  • Prioritise lighting, phones, Wi-Fi, refrigeration and home security according to immediate needs.
  • Review total power draw and remaining battery capacity, removing lower-priority devices if the estimated runtime falls.
  • During storm-related interruptions, consult current Gauteng thunderstorm warnings before travelling or inspecting the area outside the property.
  • Reassess food storage, access and security arrangements if the outage becomes prolonged.
When using a portable power station during an unplanned outage, automatic switchover is only available if the model includes a compatible UPS function and the equipment was connected beforehand. Devices added after grid failure draw from the available stored energy without automatic transfer.
When an Eskom Gauteng power outage occurs, first confirm whether the property is supplied by Eskom or a municipal provider, then check whether the interruption matches a load-reduction schedule, planned maintenance notice or reported local fault. Log an unlisted outage with the responsible supplier, retain the reference number and use it for follow-up. Meanwhile, prioritise essential loads, avoid damaged electrical infrastructure and match any backup power arrangement to the devices and runtime required.
Why are there power outages in Gauteng?
Power outages in Gauteng can happen for different reasons, including local network pressure, load reduction, ageing electricity infrastructure, equipment failures, and severe weather conditions. In some areas, high electricity demand during peak periods can place additional pressure on local distribution networks, while storms and lightning may damage power lines or transformers. Depending on whether the outage is caused by planned work or an unexpected fault, restoration times can vary from several hours to longer periods.
What should I do if my electricity has not returned after the announced restoration time?
If your electricity has not returned after the expected restoration time, first check official Eskom or municipal updates to confirm whether repairs are still in progress. If there is no updated information, report the issue through the correct customer service channels. Providing details such as your location, meter information, and outage time can help the service team identify and resolve the problem more efficiently.
How long do Eskom power outages usually last in Gauteng?
The duration of Eskom power outages in Gauteng depends on the cause, affected area, and the time required for repairs. Some outages may only last for a short period, while others can continue for several hours if infrastructure requires attention. Residents should follow official Eskom or local municipality updates for the latest restoration information and estimated recovery times.
Power Outages
