How Much Electricity Does an Electric Blanket Use? A Full Guide
As the colder months creep into South Africa, many of us reach for that cozy, comforting solution to ward off the evening chill: the electric blanket. It's a wonderful way to ensure a warm bed on a brisk night, but a common question often arises in the back of our minds: what's the real impact on our electricity bill?
Understanding how much electricity does an electric blanket use is key to making informed choices about your winter warmth. Let's delve into the specifics of their power consumption, running costs, and how to use them as efficiently and safely as possible.
Typical Power Consumption of Electric Blankets
In the chilly South African winter nights, an electric blanket is a blessing for many households, offering instant and comforting warmth. However, many people can't help but wonder: how much electricity does an electric blanket use? Understanding the typical power consumption of an electric blanket is crucial for managing your energy bills.
The power consumption of an electric blanket varies depending on its model, size, and settings. Generally, a single electric blanket might use between 60 watts and 100 watts, while a double or larger size could consume 100 watts to 200 watts or more. Compared to larger heating appliances like space heaters or central heating systems, electric blankets typically draw significantly less power. For instance, a typical space heater might consume 1500 watts or even more, while an electric blanket uses only a fraction of that. This means that while electric blankets provide direct, localized heat, their running costs are usually lower.
Factors influencing an electric blanket's power consumption include:
  • Size: Larger blankets generally consume more electricity.
  • Temperature Setting: Setting your electric blanket to a higher temperature will increase its power consumption.
  • Number and Type of Heating Elements: Advanced electric blankets might use more efficient heating technology, leading to lower consumption for the same amount of heat.
  • Preheating Time: Electric blankets usually need some time to preheat before you get into bed. Power consumption is often highest during this preheating phase.
  • Duration of Use: The longer you use it, the more total electricity it will consume.
Understanding these basic concepts is the first step in estimating your electric blanket's running cost. In some cases, households looking to pair comfort with sustainability might choose to supplement heating with a solar panel system, further reducing grid dependence.
How Much Electricity Do Your Electric Blankets Use?
To precisely calculate how much electricity your electric blanket uses, you need to know its wattage and how long you use it for. The wattage of an electric blanket is usually indicated on the product label or in its manual. Electricity consumption is measured in kilowatt-hours (kWh), which is the standard unit electricity companies use to calculate your bill.
The calculation formula is as follows:
Electricity (kWh) = Wattage (W) × Hours Used (h) ÷ 1000
For example, if you have a 100-watt electric blanket that you use for 8 hours a day:
Electricity = 100 W × 8 h ÷ 1000 = 0.8 kWh
This means the electric blanket consumes 0.8 kilowatt-hours of electricity per day. Knowing how much power does an electric blanket use can help you better plan your energy expenditure.
How Much Does It Cost to Run Your Electric Blanket?
To calculate the running cost of your electric blanket, you need to know the electricity tariff per kilowatt-hour in your area. In South Africa, electricity tariffs vary by region and supplier, typically charged by Eskom or municipal authorities. The average residential electricity price in South Africa is approximately R2.50 to R3.50 per kilowatt-hour.
With electricity consumption and the tariff, you can calculate the cost of running your electric blanket:Cost (ZAR) = Electricity (kWh) × Price per kWh (ZAR)
Let's take our previous example of a 100-watt electric blanket used for 8 hours a day, assuming an electricity tariff of R3.00 per kWh:
Cost = 0.8 kWh × R3.00/kWh = R2.40 South African Rand
This means running this electric blanket costs about R2.40 per day. If used daily for a month (30 days), the monthly cost would be approximately
R2.40 × 30 = R72.00 South African Rand.
Compared to using an electric heater or other large heating appliances, the running cost of an electric blanket is significantly lower. For example, a 1500-watt electric heater, if used for 8 hours a day, would cost:
(1.5 kWh × 8 h) × R3.00/kWh = 12 kWh × R3.00/kWh = R36.00 per day
Therefore, from a cost-effectiveness perspective, an electric blanket is a very economical way to keep warm. To take your savings further, consider pairing it with the EcoFlow DELTA 2 Portable Power Station. With its 1–3kWh expandable capacity and fast AC charging, you can store low-cost or solar energy during the day and use it at night, keeping your electric blanket running without relying on peak-time grid power.
EcoFlow DELTA 2 is a plug-and-play home backup power solution. With a high-capacity 1024Wh battery, it is perfect for home backup and off-grid adventures. It can be charged from 0% to 80% in just 50 minutes or fully charged in 80 minutes, supporting charging from solar panels, car outlets, or wall sockets. Featuring X-Boost technology, it can power up to 13 devices simultaneously and be able to run high-wattage appliances up to 2400W.
Tips to Use Electric Blankets Efficiently and Safely
To maximize the efficiency and ensure the safety of your electric blanket, here are some practical tips:
  • Preheat Your Bed: Turn on your electric blanket about 30 minutes before you go to bed to allow it to preheat thoroughly. Once you're in bed, you can lower the setting or even turn it off, as the bedding will retain the heat.
  • Choose the Right Size: Purchase an electric blanket that fits your bed size. An oversized blanket will waste energy, while an undersized one won't provide enough warmth.
  • Inspect Regularly: Periodically check your electric blanket for any signs of wear, damaged cords, or scorch marks. If you notice any issues, stop using it immediately and replace it.
  • Avoid Folding or Bunching: Ensure the electric blanket lies flat when in use, avoiding folding or bunching, which can lead to localized overheating.
  • Don't Cover with Other Items: Do not place other blankets or heavy items on top of the electric blanket, as this can hinder heat dissipation and increase the risk of overheating.
  • Use a Timer: If your electric blanket doesn't have a built-in timer, consider using an external power timer to automatically switch it off after you fall asleep, helping you save electricity and improving safety.
  • Store Properly: When not in use, store your electric blanket flat or loosely rolled, avoiding placing heavy or sharp objects on it.
  • Cleanliness: Follow the manufacturer's instructions for cleaning. Most electric blankets are not machine washable and should only be spot cleaned.
Electric blankets are a relatively economical and efficient way to stay warm, especially on cold South African winter nights. Understanding how much electricity does an electric blanket use and its running costs can help you make more informed energy usage decisions. By choosing the right wattage, using it wisely, and following safety guidelines, you can enjoy the warmth of an electric blanket without worrying about excessive electricity bills.
Compared to traditional heating methods, an electric blanket is often a more energy-efficient choice, particularly when only localized heating is required. For even greater control and off-grid convenience, pairing it with an EcoFlow portable power station lets you power your blanket using stored or solar energy—anytime, anywhere.
Do electric blankets use a lot of electricity?
Relatively speaking, electric blankets typically consume less electricity than other common heating appliances, such as space heaters or central heating systems. Most electric blankets range from 60 watts to 200 watts, while larger heating appliances can consume 1500 watts or more. Therefore, electric blankets are considered a relatively energy-efficient heating option.
How much does it cost to have an electric blanket on for 1 hour?
For a 100-watt electric blanket, assuming an electricity tariff of R3.00 per kWh in South Africa, the cost to run it for 1 hour is calculated as follows:
Electricity = 100 W × 1 h ÷ 1000 = 0.1 kWh Cost = 0.1 kWh × R3.00/kWh = R0.30 South African Rand
So, the approximate cost to run it for 1 hour is about R0.30.
How much electricity does an electric blanket use South Africa?
In South Africa, how much electricity does an electric blanket use South Africa depends on its wattage and duration of use. For instance, a 100-watt electric blanket used for 8 hours a day will consume 24 kilowatt-hours (0.1kW * 8h * 30 days = 24kWh) of electricity per month (30 days). The specific cost will vary according to the electricity tariff in your area.
How much does it cost to run an electric blanket for 10 hours?
For a 100-watt electric blanket, assuming an electricity tariff of R3.00 per kWh in South Africa, the cost to run it for 10 hours is calculated as follows:
Electricity = 100 W × 10 h ÷ 1000 = 1 kWh Cost = 1 kWh × R3.00/kWh = R3.00 South African Rand
Therefore, the approximate cost to run it for 10 hours is about R3.00.
Save Bills
