Black Friday Deals in South Africa 2026: EcoFlow Offers
Black Friday deals give South African shoppers a chance to save on planned purchases ahead of the December holidays. From everyday electronics to home and outdoor equipment, the right offer depends on what you'll actually use. EcoFlow's 2026 sale runs from 9 to 30 November, with selected portable power products featured in the promotion. This article covers five power stations worth considering, along with practical advice on comparing offers and shopping in South Africa.
Key Takeaways
  • EcoFlow's Black Friday sale runs from 9 to 30 November 2026, with discounts of up to 47% on selected products.
  • The featured portable power stations range from compact models for smaller electronics to higher-capacity options for household backup.
  • Compare battery capacity, rated AC output and charging options to find a model that suits your intended use.
  • Check prices in rand, promotional conditions and delivery arrangements before placing your order.
Black Friday Deals in South Africa: Dates and Offers
Black Friday falls on Friday, 27 November 2026, but EcoFlow South Africa's sale runs from 9 to 30 November, with discounts of up to 47% on selected products. The extended promotion gives shoppers more time to explore Black Friday specials rather than limiting purchases to a single day.
Since individual products may have different discounts and promotional conditions, it's worth looking beyond the headline saving. Discounts and promotional conditions vary across selected products, so the headline saving is only a starting point. For shoppers considering equipment they can use at home or take on December trips, the next step is to see which products meet those needs.
Why Consider Portable Power During Black Friday?
Black Friday is often a chance to buy equipment you'll use beyond the holiday season. Alongside everyday electronics and household purchases, portable power may be worth considering if you need electricity in places where a wall socket isn't always available.
At home, a rechargeable power station can supply compatible devices such as a Wi-Fi router, laptop or fridge during an interruption to mains power. It can also provide electricity for lighting, charging and selected camping equipment during South Africa's summer travel season. Unlike a typical phone power bank, a portable power station offers greater battery storage and, depending on the model, AC outlets for compatible appliances.
The main question is what you need to power and for how long. Someone charging a laptop at a campsite has different requirements from a household trying to keep a fridge running. Understanding that difference makes it easier to judge which Black Friday offers are relevant, rather than choosing by discount alone.
Best EcoFlow Black Friday Deals to Watch
If you're shopping for home essentials or planning a December getaway, portable power is worth considering alongside your usual Black Friday purchases. A rechargeable power station can help keep everyday electronics and compatible appliances running at home, while also providing electricity for camping and road trips.
EcoFlow offers portable power stations designed for these different needs, with options ranging from compact units for smaller devices to higher-capacity models for household backup. Here are five EcoFlow power stations worth considering during the Black Friday sale, compared by battery capacity, AC output and intended use.
Model
Rated AC Output
Best For
EcoFlow DELTA 3 Max Portable Power Station
2,048Wh
2,400W
Longer household backup and higher-power appliances
1,024Wh
1,800W
Fast recharging and flexible charging options
768Wh
800W
Camping and December road trips
EcoFlow RIVER 3 Portable Power Station
245Wh
300W
Routers, lights and smaller electronics
1,024Wh
1,800W
Multiple AC outlets and expandable storage
For households that need to keep essential appliances running for longer periods, the EcoFlow DELTA 3 Max Portable Power Station provides greater battery storage and higher AC output than the other featured models. It suits users who prioritise backup capacity over frequent portability, provided their appliances meet the unit's power requirements.
- 2,048Wh LFP battery capacity - 2,400W rated AC output; 3,200W X-Boost for compatible appliances - Up to 500W solar input - 0–80% AC charging in approximately 51 minutes - Under-10ms UPS transfer time for compatible indoor equipment
The EcoFlow DELTA 3 Plus Portable Power Station is worth considering if quick recharging is a priority. Its AC and dual solar charging options suit households that want to replenish stored energy between uses, as well as travellers with suitable charging equipment.
- 1,024Wh LFP battery capacity, expandable up to 5kWh - 1,800W rated AC output; 3,600W surge - Up to 1,000W solar input through two 500W MPPT inputs - 0–100% AC charging in approximately 56 minutes with up to 1,500W input - Under-10ms UPS transfer time for compatible indoor equipment
For December camping trips or weekends away, the EcoFlow RIVER 2 Pro Portable Power Station provides portable power without the size and weight of the larger DELTA models. It is suited to travellers who need to charge electronics, run campsite lighting or power a compatible portable fridge.
- 768Wh LFP battery capacity - 800W rated AC output; 1,600W surge - Approximately 7.8kg net weight - Up to 220W solar input - 0–100% AC charging in approximately 70 minutes - Approximately 3.5-hour solar recharge with a compatible 220W panel
The EcoFlow RIVER 3 Portable Power Station is a compact choice for homes and workspaces where the main priority is powering smaller electronics. It suits users who need a dedicated supply for a router, lights or compatible low-power devices rather than larger household appliances.
- 245Wh LFP battery capacity - 300W rated AC output; 600W surge - One AC outlet - One USB-C port with up to 100W output - Approximately 3.55kg net weight
The EcoFlow DELTA 2 Portable Power Station is a practical option for users who need multiple AC connections and may want to extend their backup time later. Compared with the DELTA 3 Plus, it offers more AC outlets, making it worth considering when connecting several compatible devices is a priority.
- 1,024Wh LFP battery capacity - 1,800W rated AC output; 2,700W surge - Six AC outlets sharing the 1,800W total output - Up to 500W solar input - LFP battery rated for 3,000 cycles to 80% capacity
How to Know If a Black Friday Deal Is Really Worth It
A larger discount doesn't necessarily mean a better purchase. Black Friday shopping deals can involve reduced prices, member-only offers or discounted bundles, so comparing the final amount you pay is more useful than looking at the headline percentage.
  • Look at the real saving in rand. If a product previously sold for R10,000 and now costs R7,500, the saving is R2,500, or 25%. Use a reliable previous selling price for the same model and configuration where possible, rather than relying only on a crossed-out reference price.
  • Member offers can change the calculation. EcoFlow South Africa has advertised member-only prices on selected products. Check the eligibility requirements and the final checkout total. An additional promotional code may not be valid alongside an existing discount.
  • Bundles need a like-for-like comparison. A power station paired with a solar panel or compatible extra battery may cost less than buying the items separately. Compare the exact models and accessories included, along with any required cables. If you're considering a solar package for camping, understanding what size solar panel you need can help you avoid paying for more charging capacity than your setup can use. If you only need the power station, the standalone offer may still cost less.
  • The cheapest purchase and the best value aren't always the same. A lower upfront cost may appeal if you're shopping within a tight year-end budget, but an accessory you'll genuinely use could make a complete package more practical. The important distinction is between useful equipment and extras added mainly because they're discounted.
If you're also planning a longer-term upgrade to your home's power supply, comparing home solar power system options can help you plan your budget and decide whether a portable power station meets your immediate backup needs.
The strongest offer is one that meets your needs at a price you're comfortable paying. Once you've decided on the product and package, delivery and after-sales arrangements are the next things to confirm.
What to Check Before Buying During Black Friday
Once you're happy with the price, check the practical details of your order. Delivery, local compatibility and after-sales conditions can all affect your purchase.
  • Allow for delivery times across South Africa. EcoFlow ships from a South African warehouse, but delivery estimates vary by destination. Its shipping information indicates around 1–3 business days for Johannesburg and Pretoria and 4–7 business days for Cape Town, with delays possible during busy promotional periods. If you're ordering for a December trip, check the latest estimate for your address rather than assuming your power station will arrive before departure.
  • Confirm the South African electrical specifications. Check the AC sockets and output voltage of your chosen model against the plugs and requirements of your appliances. South Africa generally uses a 230V, 50Hz electricity supply, but plug configurations differ. A plug adapter does not resolve voltage, frequency or appliance starting-power incompatibilities.
  • Understand the return conditions. EcoFlow South Africa's published policy allows eligible, unused products to be returned in their original packaging within 30 days of receipt. For non-quality-related returns, shipping charges and payment transaction fees may apply. Check the current conditions before ordering, particularly for larger power stations.
  • Check warranty coverage and order details. Warranty periods vary by model and accessory. For example, EcoFlow South Africa currently lists five-year warranties for the DELTA 2 and RIVER 2 Pro, while the RIVER 3 (UPS) is listed at 24 months. Confirm the coverage for your exact model, then check your selected bundle, delivery address and contact details before payment.
For buyers considering a solar charging setup, choosing the best solar generator starts with checking battery capacity, rated AC output and compatibility with the solar panels they plan to use.
The strongest Black Friday deals match genuine power needs instead of chasing discounts. Identify the capacity and output required for home backup, travel, or camping. Compare regular prices before promotions begin, then check the EcoFlow ZA store when campaign details go live. Confirm current pricing, bundles, availability, and terms before choosing the EcoFlow power station for you.
When Is Black Friday in South Africa?
Black Friday in South Africa lands on the Friday after the fourth Thursday of November. In 2026, that date is 27 November, and in 2027 it moves to 26 November. It is not a public holiday, so the day runs as a normal working Friday, with online and in-store sales continuing.
Are Black Friday deals better on Black Friday itself?
Black Friday deals on the day itself are not always cheaper than the early specials. Retailers often spread offers across November, while some exclusive deals go live at midnight on the Friday and can sell out within hours. Comparing each offer with the regular price you noted earlier shows whether waiting was worth it. Buying early also secures stock of a popular model.
What should you check before buying a portable power station on Black Friday?
Check that the rated AC output exceeds the combined wattage of everything you plan to run at once. Capacity then sets how many hours that load can run after conversion losses. Look for LFP cells with a published cycle rating, such as 3,000 cycles to 80% capacity. Finally, match the charging inputs to how the unit will refill, whether from a wall socket, solar panels, or a vehicle.
Local Hot Topics
