How to Throw the Best Halloween Party at Home
To throw a memorable Halloween party at home, choose a creative theme, set the mood with spooky décor and plan themed food, drinks and games. Whether you’re hosting in your lounge or garden, this guide helps you organise the evening and work out the power needed for lighting, music and props.
Key Takeaways
  • Start planning your Halloween party three to four weeks ahead and choose a theme that suits your guests.
  • October is spring in South Africa, so keep an indoor backup option ready for a garden or patio party.
  • Focus décor on the entrance and main gathering area, keeping steps and walkways well lit.
  • Keep the menu simple and prepare one or two games to bring guests together.
  • Check both the combined wattage and estimated energy use before choosing a power station, allowing for conversion losses.
Plan Your Party in Six Simple Steps
October is spring in South Africa, so a garden or patio party can work well when the weather allows. Keep an indoor backup option in mind, and start preparing three to four weeks before the date:
  • Set the date and guest list. A Friday or Saturday close to 31 October is often a convenient choice. Decide early whether it's adults only or family friendly.
  • Pick one theme. A clear theme makes every other decision easier, from costumes to snacks.
  • Set a budget. Split it between décor, food and drinks, and entertainment so no single area eats it all.
  • Send invites two to three weeks ahead. Include the date, address, dress code, and start and end times.
  • Map your space. Note where plug points are, where guests will gather and where each prop will go.
  • Plan your power. List each device, its wattage and how long you plan to use it.
Halloween Party Ideas to Set the Tone
These Halloween party ideas give you a starting point for costumes, décor and activities, whether you're hosting adults, teens or families.
Classic Haunted House
Think cobwebs, flickering LED candles, creaky sound effects and dim, moody rooms. This theme works in almost any home and doesn't need a big budget. Dim the main lights in the party area and use lamps and LED string lights for atmosphere, keeping steps and walkways clearly lit.
Sunken Shipwreck
Turn your lounge or garden into a haunted shipwreck with skeleton pirates and tattered sails. Hang blue and green lights, drape fishing nets and scatter fake treasure around the space. Invite guests to dress as the ship’s cursed crew. If you have access to scuba diving equipment, a mask or wetsuit can serve as a prop for a ghostly diver costume or photo corner. Leave air cylinders out of the display.
Neon Glow Party
Use UV black lights, glow sticks and UV-reactive face paint for a colourful party aimed at teens and adults. Dim the main lights around your dance area so the effects stand out, while keeping entrances and walkways lit.
Family-Friendly Spooky Garden
For younger guests, go for friendly pumpkin decorations, a sweets trail and a craft table. If the weather allows, begin these activities outdoors in the late afternoon, then show a short film on a projector after dark. Have an indoor space ready in case of rain or strong winds. Choose a finish time that suits the children's ages and routines.
Halloween Decorations That Do the Heavy Lifting
Focus your Halloween decorations on the entrance and main gathering areas. Use a few carefully placed effects to build the atmosphere:
  • Lighting: Use orange, purple or green LEDs in the main party area, while keeping steps and pathways well lit.
  • Fog: A fog machine adds instant drama. Follow its placement and ventilation instructions and keep it out of walkways. Fog can trigger smoke alarms, which should remain active.
  • Sound: A looping track of wind, creaks and distant howls sets the mood before the music starts.
  • Projection: Project moving ghosts onto a garage door, a wall or a white sheet.
  • Entrance: Frame your doorway or garden gate with paper bats, cobwebs and a themed welcome sign.
Before guests arrive, check your setup:
  • Use LED candles instead of open flames, especially near costumes and paper décor.
  • Keep cables out of walkways where possible, and use cable covers for unavoidable crossings.
  • Use outdoor-rated extension leads and keep plugs and connections dry and off the ground.
  • Keep the power station dry and sheltered, with its ventilation openings unobstructed.
  • Keep the total load within the ratings of your plug point, adaptor and extension lead, especially when using a fog machine, kettle or heater.
Food, Drinks and Games to Keep Guests Busy
Keep the menu simple, with a few themed snacks and something filling for guests staying through the evening. Try these easy Halloween ideas:
  • “Mummy” sausages wrapped in strips of puff pastry
  • Cheese and crackers arranged in the shape of a pumpkin
  • Dark “potion” punch served in a food-safe cauldron-style bowl
  • A boerewors roll station with wors fresh from the braai and a choice of toppings
Keep one or two games ready to fill quiet moments:
  • Costume contest: Give small prizes for the scariest, funniest and best DIY costumes.
  • Pumpkin decorating: Let younger children decorate pumpkins with paint or stickers.
  • Murder mystery round: Hand adult guests character cards, reveal clues in short rounds and finish by asking everyone to identify the culprit.
  • Glow-stick treasure hunt: Hide clues around the garden after dark, marking each stop with glow sticks and leaving a small prize at the end.
Plan Your Party Power
Before you set up, check how much power your lights, speaker and props need, and how long you plan to run them. Your power source needs enough output for devices running together and enough battery capacity for the evening.
Eskom has reported improvements in national electricity supply, but local faults and tripped circuits can still interrupt your plans. A portable power station can bring power to a garden or patio area away from a plug point and provide stored energy for compatible devices during an outage.
For a Halloween party centred on LED decorations, music and phone charging, the EcoFlow DELTA 3 Plus Portable Power Station supplies compatible lights and speakers in a lounge or sheltered patio area. Its USB ports let guests charge their phones directly, while fast AC recharging helps you top up the battery after testing your setup and before guests arrive.
- 1,024Wh battery capacity - 1,800W rated AC output - Dual solar inputs for daytime charging with compatible panels - Fast X-Stream AC charging from 0-100% in 56 minutes
For a garden film night with a projector, speakers and animated Halloween props, the EcoFlow DELTA 3 Max Portable Power Station suits a setup with several devices running together. Quiet operation at lighter loads is useful near the viewing area, while the EcoFlow App helps you monitor energy use as the film and decorations run.
- 2,048Wh battery capacity - 2,400W rated AC output - Energy monitoring through the EcoFlow App - Quiet operation at ≤25dB with a 600W load* - Four AC outlets for connecting a projector, speakers and powered decorations, sharing 2,400W rated AC output
Noise measured at one metre in a 25°C environment during charging/discharging at 600W.
To check whether your chosen model fits your plans, multiply each device’s power draw in watts by its hours of use. This five-hour example shows how the calculation works:
Device
Typical Power
Energy Over 5 Hours
LED string lights (3 strings combined)
20–30W
100–150Wh
Party speaker
30–60W
150–300Wh
Projector
100–150W
500–750Wh
Animated props
10–30W
50–150Wh
Fog machine (heats in cycles)
400–700W while heating
Subtotal excluding fog machine
800–1,350Wh
*Figures are illustrative. The first four rows assume five hours of use, and the lighting figure covers all three strings. Check each device’s electrical input rating or measure its actual consumption.
Fog machines heat in cycles, so estimate their energy use separately, ideally with a trial run. Add that estimate to the subtotal, allow for conversion losses and spare capacity, and check the combined wattage against the power station’s rated AC output.
For outdoor setups, keep the unit dry and sheltered, leave its ventilation openings clear and keep cables out of walkways. Test your lights, sound and props before guests arrive.
Pair the unit with compatible portable panels to create a solar generator setup. Recharge during daylight before the party, allowing enough time for the available sunlight, panel output and the battery’s starting charge level.
After Halloween, the same unit can serve as a backup power supply for home use. Check the running and start-up power of your chosen appliances, especially a fridge, and plan capacity for the backup time you need.
Pick your theme, organise your space and prepare the food and games. Check your power needs and test your lights, sound and props a few days ahead, leaving time for adjustments. With the preparation done, you can enjoy your Halloween party with your guests.
How Do You Throw the Best Halloween Party?
Choose a theme that suits your guests and use it to guide your décor, food and activities. Plan one or two games, leave space for people to chat or dance, and check practical details such as lighting and power before guests arrive.
How Far in Advance Should You Plan a Halloween Party?
Start three to four weeks before the date, and send invitations two to three weeks ahead. Use the final week to confirm guest numbers and finish your preparations. Test your lighting, sound and props a few days before the party so you have time to make adjustments.
What Are Some Cheap Halloween Decorations?
Try paper bats, cotton wool cobwebs, painted pumpkins and ghosts made from old sheets. Reuse lights and decorations you already have, and focus on the entrance and one main gathering area to keep costs down.
How Much Power Do Halloween Decorations Use?
Power draw varies by model and settings, so check each device’s electrical input rating or measure its consumption. For example, lights drawing 20W in total use 100Wh over five hours. Add up each device’s watt-hours, calculating the fog machine separately to account for its heating cycles.
Can a Portable Power Station Run a Fog Machine?
Yes, if the power station’s rated AC output can support the fog machine and any other devices running at the same time. Check the machine’s electrical input rating, voltage and frequency requirements. Runtime depends on battery capacity, how often the heater runs and conversion losses.
Local Hot Topics
