EcoFlow Smart Gateway
  • Product
  • Bundles
  • Specs
  • Support
Shop Now
Smart Gateway
Smart Gateway
Effortless Energy Simplicity
Smart Gateway
Set It. Forget It. Power Protected.
EcoFlow Smart Gateway is a 200A intelligent panel with six remote-control circuits. Compatible with DELTA Pro Ultra X, solar, EV chargers, and generators¹, it switches in under 20 ms¹ and automatically sheds non-essentials to extend backup—keeping your essentials running longer.
Which panel is right for you?
The Core of Your Long-Term Energy Strategy
The Future-Proof Energy Hub
Smart Gateway powers your whole-home² system: Effortlessly backup with <20 ms switchover². Seamless integrating solar, generators, and EV charging
20 ms Auto Switchover Time³
When Blackouts Hit: Lights Stay On
Smart Gateway transitions from grid to battery faster than a blink, so your home keeps running without interruption.
* Visuals are for illustrative purposes only. Please contact an EcoFlow Authorized Installer for site-specific installation advice. Avoid operating the Smart Inlet Box and Smart Extra Battery in rain, condensation, or salt-fog environments.
42% More Backup Time
Smart Control, Always Reliable Regardless of Weather
Through the EcoFlow app, categorize appliances as “must-haves” or “nice-to-haves.” Critical loads stay on, while non-essentials automatically scale back—giving you up to 42%⁴ more backup time.
Seamlessly Compatible with High-Power Generators³
Backup for Your Backup
Build a multi-source backup system with DELTA Pro Ultra X and your generator. Just connect your split-phase generator—no rewiring or extra hardware required—to power your home and charge your battery for a reliable, seamless backup.
Smart Home Energy, Ready for Any Situation⁵
SOC at 50%, with a 10-hour power outage imminent. Can you provide a power outage endurance report?
Current Battery Capacity: 350.0 kWh. At the current usage rate, power can be sustained for 11.0 hours. Projected Solar Generation: 1.97 kWh during the outage.
Recommendations:
1. Disconnect high-power appliances to extend backup duration.
2. Maintain lower hourly power usage to optimize efficiency. With careful planning, stored energy plus solar can cover your needs during the outage.
See Waste Slash Bills Automatically
Save Up to $6,000 Per Year · 3-Year ROI¹
Savingup to
0
0
0
0
/ Year
Turn Sunlight Into Savings, No Watt Wasted
For DIY solar, Self-Powered For Your Home
Pair Smart Gateway with DELTA Pro Ultra X for true self-power. Once the battery reaches your set reserve, surplus solar flows directly to home appliances—free solar first, cheaper power all day, backup ready at night.
Track and Use Every Solar Watt⁵
Paired with a Current Transformer, Smart Gateway tracks your rooftop generation in real time and directs surplus solar to your DELTA Pro Ultra X. No more waste, no more pennies to the grid⁴.
Smart Saving with Intelligent Mode²
Intelligent Mode automatically manages battery charges and discharges based on solar forecasts and peak/off-peak rates, cutting your power costs. Before forecasted rainy days, it fills the battery using solar or off-peak power, bypassing peak rates with ease.
Slash Bills with Your PowerPulse
With Smart charging—solar by day, off-peak by night—your EV stays ready. If your EV consumes 10 kWh per day, this system can save you up to $1,095 annually³—equal to a year of free commuting.
Hassle-Free Setup, Guaranteed.
Installed in 7 Days—Save up to 80% on Time and Costs³
Learn more
The Fastest Installation⁴ 7 Days, 3 Steps
1
DAY 1-2 Installer Match
After your installation order is placed, we’ll match you with an EcoFlow Authorized Installer. Nationwide coverage—from sunny California to snowy Maine.
Resilient in Extremes, Reliable for a Decade
–30°C to 50°C Operation⁶
Whether in extreme heat or freezing winters, Smart Gateway safeguards your power security.
10 Years
Enjoy complete confidence with a 10-year warranty.
Fast, Hassle-Free Install
Split design for clean indoor and outdoor placement.
Designed for safety, certified with the highest standards (UL67, UL916, UL869A, UL1741).
Rated for outdoor installation. The panel can be placed outdoors, while the inlet box installs indoors near batteries—ensuring safety and stability even in extreme weather.
General Disclaimer
*EcoFlow reserves the right to modify product offerings and disclaimers without prior notice. All claims are subject to the official product documentation. **Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary. ***Unless otherwise noted, all above data comes from EcoFlow Labs in a controlled environment and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors. ****Unless specifically stated, the advertising claims on this page are for comparison with EcoFlow products series.
Features & Compatibility
1. It refers to interoperability tested with DELTA Pro Ultra X, mainstream portable/standby generators rated up to 12 kW, commonly used rooftop solar PV systems, and standard EV chargers. Actual performance and integration may vary depending on specific device models, wiring, inverter, and installer setup. Generators, solar panels, and EV chargers are sold separately and are not included with this product. 2. “Whole-home” power capability is available only when EcoFlow Smart Gateway is paired with DELTA Pro Ultra X. Performance figures are based on EcoFlow internal testing with recommended configurations and may vary depending on home circuits, connected appliances, battery capacity, and installation conditions. 3. It refers to interoperability tested with DELTA Pro Ultra X, mainstream portable/standby generators rated up to 12 kW, commonly used rooftop solar PV systems, and standard EV chargers. Actual performance and integration may vary depending on specific device models, wiring, inverter, and installer setup. Generators, solar panels, and EV chargers are sold separately and are not included with this product. 4. Rooftop solars are sold separately and are not included with this product. 5. Compatibility tested with mainstream rooftop PV systems. Actual integration may vary depending on inverter, wiring, and installer setup. Rooftop solars are sold separately and are not included with this product.
Performance & Testing
1. Switchover time is based on internal lab testing. Actual performance may vary depending on wiring, load type, and installation environment. 2. Switchover time is based on internal lab testing. Actual performance may vary depending on wiring, load type, and installation environment. 3. Switchover time is based on internal lab testing. Actual performance may vary depending on wiring, load type, and installation environment. 4. By supporting three-level priority management, the backup duration of the core circuit can be extended by approximately 42% under the same SOC conditions, when capacity is concentrated on the core load. Calculation logic: Assumption: SOC = 100, distributed across three circuits with different priorities. Without priority strategy: evenly distributed, approx. 33 per circuit. With priority strategy: Lowest priority = 0 Middle priority = 25 (user-adjustable) Highest priority = 75 Result: 75 − 33 = 42 → the core circuit receives 42% more SOC compared to no-priority allocation. The above calculation is an illustrative example under specific assumptions to explain the allocation logic. Actual backup duration may vary depending on user settings, load characteristics, and operating conditions. 5. The app interface and data shown are based on simulated scenarios using typical U.S. household energy profiles. They are for reference only and do not represent actual user data or real-world performance. 6. Extreme-weather protection is based on EcoFlow internal design and testing. Operating range may vary depending on conditions, installation, and maintenance.
Installation & Services
1. The installation time provided is based on EcoFlow’s internal testing under standard conditions. Actual installation time may vary depending on site conditions, system configuration, and installer experience. 2. The installation time provided is based on EcoFlow’s internal testing under standard conditions. Actual installation time may vary depending on site conditions, system configuration, and installer experience. 3. EcoFlow’s 7‑Day Installation Service is calculated in business days, applies only in major metropolitan areas—including Atlanta, Baltimore, Chicago, Dallas, Denver, Detroit, Houston, Las Vegas, Los Angeles, Miami, Minneapolis, New York City, Orlando, Philadelphia, Phoenix, Portland, Salt Lake City, San Diego, San Francisco, San Jose, Seattle, Tampa, and Washington, D.C.—and covers the period starting after (i) the installation service has been purchased and (ii) the later of the product delivery date or the date all required permits/approvals have been obtained, until the completion of the product’s on‑site installation. The 7‑day period does not include delays beyond EcoFlow’s control, including but not limited to: The customer’s failure to confirm the installation date within 2 business days Customer‑requested rescheduling Non‑compliant or unsafe wiring conditions on site Weather conditions Additional permitting processes or inspections Force majeure events 4. “The Fastest Installation” refers to internal comparisons against previous EcoFlow products and reflects improvements in installation process, functionality, and overall performance. Actual installation times may vary depending on site conditions, permitting, and installer availability. 5. Installation Planning timing is estimated and depends on installer availability, homeowner scheduling, access, and local conditions. Findings may affect final scope, price, and timeline. 6. “One-Day Installation” reflects the typical on-site installation time for replacement of an existing electrical panel after permits/approvals, materials, and site readiness are confirmed. Actual timelines vary. The “One-Day Installation” estimate does not apply to scenarios such as: New electrical panel installations (e.g., for new construction or major additions) Major rewiring or circuit modifications within the premises Upgrades from an older panel to a higher-capacity or different type of panel requiring significant electrical system changes Complex site conditions or coordination with utility companies for service disconnection/reconnection These situations typically require additional design, permitting, site preparation, and installation time.
Economics & Savings
1. Payback Calculation Logic (California Example): Daily solar generation: 10kWp system × 6 sun hours/day) × 0.8 = 48kWh/day. Electricity rates: Average rate: $0.30/kWh. TOU peak/off-peak price differential: $0.30/kWh. Daily savings: Solar savings: 48kWh × 0.30 = $14.4 Battery TOU savings: 12kWh × 0.30 = $3.6 Total daily savings: $14.4+$3.6 = $18 Monthly savings: $18/day × 30 days = $540/month Annual savings: $18/day × 365 days = $6570/year The estimated cost is approximately $18,000, including the equipment purchase and installation for DELTA Pro Ultra X with a Smart Home Panel 3 and two batteries, as well as a 10kW solar panel at market price. Payback Period=$18000/$6570≈3 2. DPUX Tou Saving Logic (California Example): TOU peak/off-peak price differential: $0.30/kWh. Daily savings: Battery TOU savings: 12 kWh × 0.30=$3. 6 3. Savings are estimated based on daily consumption of 10kWh, an electricity rate of $0.30 per kWh, and 365 days of use. Actual savings may vary depending on individual usage and electricity rates.
