RIVER Max
RIVER Max
Expand Your Horizons
Charging
Charging
Power up to
Power up to
10 devices
Detachable
Design
600W
1800W
1800W
App Controls
App Controls
576Wh Capacity
Double up or go lightweight.
RIVER Max has two 288Wh batteries. Detach the bottom one when weight takes priority or leave it on to power twice as much.
    576Wh Capacity
    600W AC Output
    Powers 80% of what you love most.
    With 600W of output and 9 outlets, RIVER Max powers 80% of essential devices, and even more when X-Boost is on. With that, you’ll be able to handle things up to 1800W.
    • 600woutput
    • 1800wX-Boost
    600W AC Output
    Charging
    It's the world's fastest.
    • Wall Outlet
      Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
    • Solar charging
      Harness the power of the sun by linking up to two 110W solar panels. You’ll be fully charged in under 3 hours.
    • Car charging
      Heading on a road trip? Charge to full in just 6.5 hours by plugging right into your car with the car adapter.
    Battery Management System
    Performance plus safety.
    Confidence comes when you know your battery can take care of its own. The battery management system self regulates to keep your portable power station performing its best when it’s pushed to the limit.
      EcoFlow app
      Monitor
      Real-time energy insights on the go.
      View battery status live anytime, anywhere.
      EcoFlow app
      Control
      Control even from afar.
      Easily turn on/off output and the connected appliances remotely.
      EcoFlow app
      Customize
      Save more on electricity bills.
      Optimize your home's energy use and reduce energy bills by smartly leveraging power from the sun, grid, and batteries during peak and off-peak hours.
      EcoFlow app
      Constant Updates
      Constant updates for optimal user experience.
      Regular upgrades to offer you industry-leading energy management.
      Download the EcoFlow app
      EcoFlow app
      EcoFlow app
      EcoFlow RIVER Max Plus
      Need something a little larger?
      RIVER Max has a bigger brother. EcoFlow RIVER Max Plus. With the same form factor, RIVER Max Plus has a larger capacity at 720Wh, longer cycle life, and comes in white.
        You might also like
        View more
        • EcoFlow
