- High 5kVA output power, to run 2 × 13500 BTU rooftop a/c units at the same time.
- X-Fusion technology, stable electricity and protects appliances even with weak shore power.
- As quiet as 48 dB, a volume lower than a quiet office.
- 45kWh capacity for up to 7 days off-grid.
- 4 multiple charging methods: shore power, solar, vehicle alternator, and generator.
- Charge 11kWh in only 1 hour.
- Compact & lightweight, stores easily.
EcoFlow Power Kits 5kVA 48V Power System
Silent Journeys, Powerful Adventures
EcoFlow Power Kits is the world's first fully integrated, plug-and-play power solution designed especially for vans and motorhomes.
1 Hour to Fully Charge Up to
FREE Energy 0 Upkeep Costs
Run 2 A/C Units at Once
Up to 7 Days Off-Grid
As Quiet as 48dB[1]
4 Multiple Ways Charging Method
App & Screen Smart Control
Compact & Light, Fits Perfectly
Solutions for All Types of RV
- PowerTrail
- PowerLuxe
- PowerSwift
Suitable for luxurious RV travel in Class A and Class C motorhomes, the EcoFlow PowerLuxe solution ensures comfort and a steady energy flow for your entire motorhome. Its advanced 48V electrical architecture offers industry-leading safety and efficiency. For extended road trips, store up to 45kWh of power and generate tremendous amounts of energy from solar and alternator, for ultimate on-the-go comfort.
Meet All Your Power Needs
Run 2 × 13500 BTU RV A/C Units
Keep the Peace
X-Quiet Volume of Only 48 dB¹
Stay Full of Energy
Power On for Up to 7 Days
Refrigerator
283.5-567hr
Coffee Maker
40.5hr
Microwave
31.5hr
Induction Cooker
45hr
Electric Heater
36hr
Air Conditioner
49.5hr
5-45kWh Expandable
Hybrid Fast-Charging Methods, Stay Charged Anywhere
1-Hour to Fully Charge
*Combine all charging methods to reach the maximum charging capacity.
Go Green & Save
Free Energy with Zero Upkeep Cost
- Intelligent Monitoring & Control
- Multi-Device & Screen
- Customize & Automate
Power Kits integrates water, electricity, and access control systems for smart vehicle monitoring. It offers remote control of charging and discharging, independent management of 16 DC circuits, and reads power usage for each circuit and total charging/discharging amounts.
Safe & Reliable
Our Tech in One System
Durable Structure
Our industry-first CTC (cell-to-chassis) process integrates the battery shell and internal components into a single, robust structure. This innovative design offers higher strength, external security, and improved drop resistance.On Guard 24/7
Our X-Guard BMS (Battery Management System) algorithm provides around-the-clock protection. Covering up to six monitoring and safeguard measures, including low temperature, over-discharge, overcharge, high temperature, short circuit, and overcurrent, it ensures a fail-safe recovery.Safety, Certified.
Experience reliable RV power and safety with our UL1973-certified 48V LFP batteries, UL458-certified Power Hub and UL67-certified distribution panel.
Lightweight, Plug-and-Play, and Eco-Friendly
Compact and Efficient All-in-One Power Solution
50% Lighter, 50% More Compact
Simple Assembly
No Fumes, No Emissions
Utilize Clean Energy
Choice of the Pros
Installation Service
We offer free installation consulting services to guide you in setting up your Power Kits System, or to help you find a nearby installer.
Worry-free Consumer After-sales Service
5-year comprehensive warranty & worry-free customer service.
Worry-free Business Partner Service
With the ERM system, installers can: (1) Manage their own system in a hierarchical manner corresponding to SN (2) View real-time data of all installed products remotely (3) Help users configure their system remotely (4) Diagnose errors remotely 24/7
Power Hub 5kVA
Power Hub has a 5kVA high output power, and includes two MPPT solar charge controllers, a DC-DC battery charger with MPPT, an inverter charger, and a DC-DC step-down converter to recharge your battery. Everything you need to power your RV.
5kWh LFP Battery
Stack up to 9 batteries, with capacities ranging from 5 to 45kWh, for up to a week of power. Whether you're car camping for the weekend or trekking cross country in a Class A motorhome, we've got options to meet your power needs.
30/50A AC/DC Smart Distribution Panel
With 16 fused DC and 12 AC positions, you can manage the power distribution around your RV. Control all 16 DC branches from the EcoFlow app or PowerInsight.
Power Link
Power Link is your ultimate RV information hub. It is designed to monitor water tanks and temperature sensors and establish communication with products/systems using communication protocols like RV-C and NMEA2000. It offers real-time data, auto generator startup, and centralized control for your vehicle's information, all viewable through PowerInsight.
Power Dock
The Power Dock is a versatile power solution, enabling easy configuration of Power Kits, DC charging via a Smart Generator, and compatibility with various DELTA Series portable power stations. It features 48V output, manual switch connectivity, and battery sharing for flexible power management.
PowerInsight (7-in & 10-in)
Conveniently mount the PowerInsight (7-in or 10-in) to control your entire power system from the comfort of your RV. Keep an eye on your energy usage, adjust settings and see your energy input all from the handy screen.
About our free installation consulting service: (a) Our free installation consulting service is exclusively limited to integrating Power Kits 5kVA products into the electrical systems of vehicles (RVs). (b) All installations must be carried out by certified and experienced professionals. It is not recommended that unqualified individuals attempt the installation as a do-it-yourself (DIY) project. (c) While we strive to provide accurate and feasible installation solutions, there may be unforeseen circumstances that could result in the failure of the installation. EcoFlow shall not be held responsible or liable for any such failures or any damages, losses, or expenses arising from or related to such failures (d) EcoFlow shall not be held liable for any risks, damages, or losses arising directly or indirectly from the installation process itself. This includes, but is not limited to, any damage to the RV, the PK system, or any other property and any personal injury or harm caused by improper installation. It is the customer's responsibility to ensure that the installation is performed by a qualified professional and following all applicable safety standards and regulations. (e) EcoFlow offers installation consultation services at no cost to the user; however, the user is ultimately responsible for all installation expenses. About free installation: **EcoFlow will select one user from those who entered their email for pre-sale alerts during the pre-launch period (Sept 3, 2024-Oct 14, 2024) and placed an order on the official website (https://www.ecoflow.com/us) during the pre-sale period (Nov 15, 2024-Nov 29, 2024) to receive free installation services for the Power Kits 5kVA 48V Power System. The result will be announced on the EcoFlow Official Club Facebook Group. EcoFlow reserves the right to make the final interpretation of this promotion. About Elite200 Users: *Refers to orders placed on the EcoFlow brand official website for the EcoFlow Power Kits 5kVA 48V product ***After placing an order, EcoFlow will email the first 200 customers confirming the Elite200 identities and benefits, including an invitation to the Power Kits Elite200 Club Facebook group. General (a) Customer Support: If you encounter any issues, please contact support@ecoflow.com for assistance. (b) Shipping Restrictions: Shipping is unavailable to some remote regions, including Guam, Puerto Rico, Hawaii, and Alaska. For further information, please consult our Shipping Policy. (c) Modification and Cancellation: EcoFlow, to the extent allowed by applicable law, may amend these rules or cancel any promotion at its sole discretion and without prior notice. In cases of fraud or abuse related to the promotion, EcoFlow reserves the right to exclude any customer from participating. (d) Binding Agreement: By participating, you agree to be bound by these Terms and Conditions and acknowledge that EcoFlow's decisions are final and binding. No correspondence or appeals will be considered. EcoFlow retains the exclusive right to interpret these promotions. (e) Compliance with Policies: During the promotion, all orders must adhere to EcoFlow's Purchase Agreement and Return Policy. (f) Late Entries: EcoFlow is not responsible for late entries for any reason, including, but not limited to, network transmission failures. (g) Limitation of Liability: EcoFlow shall not be liable for any direct or indirect losses or damages suffered by any party, including participants, arising from or in connection with any acts or omissions. (h) Unaddressed Matters: Any matters not explicitly covered in these Terms and Conditions will be subject to EcoFlow's final interpretation.
