EcoFlow OCEAN EV Charger (11.5kW)
Go Solar. Charge Smarter. Drive Farther.
Solar-Powered Savings with OCEAN Pro
Maximize your solar investment with OCEAN Pro. Store surplus solar energy during the day and use it to charge your EV at night, slashing your charging costs[1]. With EcoFlow’s integrated solar battery, you can pay less while you sleep and wake up to a fully charged EV—ready for your morning commute. Smart, seamless, and cost-effective[1] charging every day.
EF-Image
Smarter Charging, Effortless Savings
Just set your charging goal or departure time, and EcoFlow Assistant will help you with the rest[2]. The system combines dynamic electricity pricing, solar storage, and optimized scheduling to help lower charging cost. No manual settings or guesswork—just smarter charging that adapts to your needs and grows with your EV, making every charge both affordable and effortless.
EF-Image
11.5kW Fast Charging, Always Ready to Roll
With a robust 11.5kW, 48A output, you can add up to 46 miles[3] of driving range per hour, according to EcoFlow’s laboratory testing. The SAE J1772 connector makes it compatible with most EVs[4]. Note: The OCEAN EV Charger (11.5kW) is designed exclusively for use with EcoFlow OCEAN Pro.
Sleek LCD Display, Real-Time Status at a Glance
Instantly check the charging speed, status, and connectivity on a clear and intuitive LCD display.
EF-Image
Stay Connected, Charge with Confidence
Stay in control wherever you are. With Wi-Fi, Bluetooth, RS485, and CAN communication, you can monitor and manage your EV charger remotely. Even without internet, local Bluetooth offers reliable access—so you're ready to charge at home or on the go.
Reliable, Durable, And Built for Any Environment
25 ft charging cable
5-year warranty
5-year warranty
Energy Star Certification
T&C
Charging performance, compatibility, and savings may vary depending on vehicle model, grid conditions, network connection, and user behavior.
Remote features require Wi-Fi access and the EcoFlow App.
Smart recommendations do not imply full automation and depend on user-defined settings.
All performance metrics are based on EcoFlow internal testing under ideal conditions unless otherwise noted.
[1] Cost reductions depend on local energy tariffs, charging schedules, and user behavior. Actual savings may vary.
[2] Smart recommendations are generated based on user input and real-time energy data. Final charging behavior depends on user-defined settings and system conditions.
[3] Performance data is based on EcoFlow lab testing using a Tesla Model 3 under standard conditions. Actual charging performance may vary depending on vehicle model, battery status, and environmental conditions.
[4] To confirm compatibility with your specific EV model, please contact EcoFlow customer support.
