EF-Image
Up to 25%
solar conversion efficiency rate
EF-Image
waterproof rating
EF-Image
2-in-1
bifacial design
EF-Image
Integrated
solar angle guide
Lightweight
& compact
Lightweight & compact
EF-Image
30-60°
adjustable stand
EF-Image
Up to 25%
Lightweight
& compact
EF-Image
waterproof rating
EF-Image
Integrated
solar angle guide
EF-Image
2-in-1
bifacial design
EF-Image
30-60°
adjustable stand
Capture more energy with a dual-sided design
With a 220W primary side, and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your portable power station even faster.
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
Built for the outdoors
With an IP68 waterproof rating, our NextGen 220W Bifacial Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
High-level protection
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Built for the outdoorsHigh-level protection
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
With a universal solar connector, plug and play with almost all power stations on the market, as well as EcoFlow's own.
EcoFlow Solar Panel Comparison
Original vs. NextGen
EcoFlow NextGen Portable Solar PanelEcoFlow Solar Panel
Cell Type
N Type TOPCon monocrystalline silicon
P Type PERC monocrystalline silicon
Conversion Efficiency
25%
23%
Weight
11.2 lb-15.9 lb
(5.1 kg-7.2 kg)
12.3 lb-20.9 lb
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quiet Start Guide, Safety Instructions & Warranty Card
  • Rated Power
    220W(±5W) Front/175W Rear
  • Cell Type
  • Efficiency
    25.00%
  • Weight (Solar Panel)
    Approx. 15.4lb (7.0kg)
  • Dimensions
    Unfolded: 24.2*84.8*1.0 in /615 x 2155 x 25mm Folded: 24.2*23.2*1.3 in /615 x 590 x 32mm
  • Warranty (US)
    12 months
  • Open Circuit Voltage
    21.5V (Vmp 18.4V)
  • Short Circuit Current
    12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
  • Waterproof & Dustproof
  • EcoFlow
