Lightweight
and compact
Lightweight and compact
EF-Image
30-60°
adjustable stand
EF-Image
Up to 25%
solar conversion efficiency rate
EF-Image
Integrated
Solar angle guide
EF-Image
waterproof rating
EF-Image
Up to 25%
Lightweight
and compact
EF-Image
waterproof rating
EF-Image
Integrated
Solar angle guide
EF-Image
30-60°
adjustable stand
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Capture more solar
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
Built for the outdoors
With an IP68 waterproof rating, our NextGen 160W Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
High-level protection
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Built for the outdoorsHigh-level protection
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
With a universal solar connector, plug and play with almost all power stations on the market, as well as EcoFlow's own.
EcoFlow Solar Panel Comparison
Original vs. NextGen
EcoFlow NextGen Portable Solar PanelEcoFlow Solar Panel
Cell Type
N Type TOPCon monocrystalline silicon
P Type PERC monocrystalline silicon
Conversion Efficiency
25%
23%
Weight
11.2 lb-15.9 lb
(5.1 kg-7.2 kg)
12.3 lb-20.9 lb
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide,
Safety Instructions & Warranty Card
Quick Start Guide, Safety Instructions & Warranty Card
  • Rated Power
    160W (±5W)
  • Cell Type
  • Efficiency
    25.00%
  • Weight (Solar Panel)
    Approx. 12.3 lb (5.6 kg)
  • Dimensions
    Unfolded: 23.6×63.4×1.0 in./600×1610×25 mm Folded: 23.6×22.5×1.3 in./600×572×32 mm
  • Warranty (US)
    12 months
  • Open Circuit Voltage
    21.3V (Vmp 18.6V)
  • Short Circuit Current
    9.1A (Imp 8.6A)
  • Waterproof & Dustproof
  • EcoFlow
