What Are the Immediate Steps to Take If There Is a Snowstorm?
When the sky turns dark and local weather alerts start popping up on your phone, the clock starts ticking. In many parts of the U.S., especially the Northeast and Midwest, a serious snowstorm isn’t just about snow on the ground. It can mean power outages, blocked roads, school closures, and being stuck at home longer than planned. This guide walks through the first things to do when a snowstorm is on the way, focusing on keeping your home warm, your family comfortable, and your essentials running if the power goes out.
Do These 5 Things First When a Snowstorm Is Coming
When a snowstorm is on the way, a little prep goes a long way. Snow may look harmless, but in many parts of the U.S. it comes with ice, strong winds, and power outages that can last longer than expected. Taking a few smart steps early helps you stay comfortable and avoid scrambling once the roads get bad.
Check the Snowstorm Forecast and Local Alerts First
Start with the basics. Keep an eye on the National Weather Service or your local weather app. In the U.S., alerts range from Winter Weather Advisories to full Blizzard Warnings, and the timing matters. Knowing when conditions are expected to worsen helps you wrap up errands, reschedule plans, and stay off the roads before things turn slick.
Get Your Home Ready to Hold Heat and Prevent Frozen Pipes
As temperatures drop, your house needs to hold onto as much heat as possible. Close heavy curtains, add plastic window film if you have it, and set the thermostat a bit higher before the storm hits to warm the space ahead of time. To avoid frozen or burst pipes, let faucets drip slightly so water keeps moving through the system.
Pro tip: Open the cabinet doors under the kitchen and bathroom sinks. This lets warm air reach the pipes inside the walls and adds an extra layer of protection during deep freezes.
Stock Water, Food, and Lighting for the Next 24 to 72 Hours
Stores can clear out fast once snow is in the forecast. Aim for at least one gallon of water per person per day, along with easy, shelf-stable foods that don’t need to be cooked much. Check flashlights, lanterns, and batteries now, not after the lights go out, and keep them somewhere easy to grab in the dark.
List Your Essentials by Real-Life Scenarios
Rather than making a random checklist, think through what you’d actually need if the power went out. Breaking it down by situation keeps you focused on the things that matter most.
Heat support: If your furnace blower or a small space heater fan runs on electricity, you’ll need backup power to keep warm air moving.
Note: Portable power stations are best for furnace controls, blowers, or small heaters, not electric baseboard or central resistance heat, which usually pulls more power than portable systems can handle.
Communication: Phones, your Wi-Fi router, and emergency radios are how you stay informed if roads are closed or cell service is spotty.
Medical needs: Equipment like CPAP machines, nebulizers, or baby bottle warmers can’t afford downtime.
Lighting and safety: Basic lighting helps prevent accidents, and being able to open an electric garage door can matter if you need to move a vehicle in a hurry.
Sort Loads Into Must-Run, Should-Run, and Nice-to-Have
When the power goes out, you can’t run everything at once. Being intentional about what gets power first helps stretch your backup supply and avoids draining it too quickly. Grouping devices by priority makes those decisions a lot easier at the moment.
| Priority | Appliance Type | Typical Wattage (W) | Why It’s a Priority |
| Must-Run | Medical CPAP / Ventilator | 30 - 60W | Critical for health and safety |
| Refrigerator (Running) | 100 - 200W | Keeps food from spoiling (startup surge can reach ~1200W) | |
| Wi-Fi Router | 10 - 20W | Access to weather alerts and communication | |
| Should-Run | Smartphones / Laptops | 10 - 65W | staying connected and handling basics |
| LED Bulbs (each) | 8 - 15W | Visibility and nighttime safety | |
| Microwave | 800 - 1200W | Quick reheating of prepared food | |
| Nice-to-Have | Coffee Maker / Electric Kettle | 1000 - 1500W | Comfort during long outages |
| Television | 100 - 150W | News updates and stress relief |
To handle a mix of these needs without constant juggling, a higher capacity system like the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power is built to support core household loads such as refrigeration, lighting, and communications, and in some homes, certain heating system components like furnace blowers or circulation pumps, depending on the setup.
How to Choose the Right Backup Power for Snowstorm Outages
When you’re shopping for backup power ahead of a snowstorm, it’s not just about how big the battery is. Winter outages can be longer, colder, and more inconvenient, so the right setup needs to work well in real conditions, not just on paper.
Expandability for Multi-Day Outages
Snowstorms don’t always wrap up in a few hours. If plows can’t get through or lines are slow to be repaired, you could be without power for days. Systems that let you add more battery capacity give you flexibility instead of forcing you to ration power too early.
Noise Level for Overnight Use
Gas generators are loud and can’t be run indoors, which makes them a poor choice overnight. Some households also rely on whole-home generators for automatic backup during longer outages. If you need power while you sleep, whether it’s for a CPAP machine or basic heating controls, a battery-powered station is quiet and safe to use inside. No engine noise, no fumes, no stress.
Safety reminder: Power isn’t the only concern during a winter outage. If you’re using a fireplace, wood stove, or any fuel-burning heat source, make sure your carbon monoxide detectors are working and have fresh batteries. Battery-powered systems don’t produce emissions, which is why they’re the safest option indoors, especially when generators can pose serious risks.
Output Options for the Appliances
Make sure the power station has the right mix of outlets for what you actually use. Standard AC plugs cover lamps and small appliances, USB-C handles phones and newer laptops, and higher wattage outlets are important if you plan to run kitchen or medical devices.
Pick a Portable Option for Quick, Flexible Use
Not every outage calls for powering the whole house. Sometimes you just need electricity where you are, like the bedroom at night or the kitchen in the morning. A small, moveable option like the EcoFlow RIVER 3 Plus Portable Power Station fits that role well. It’s quiet, easy to carry from room to room, and can expand up to 858Wh. When winter’s over, it’s just as handy for summer camping trips in the Rockies or the Appalachians.
Battery Lifespan for Long-Term Reliability
Battery chemistry matters if you plan to rely on it year after year. LFP batteries are built to handle thousands of charge cycles, which means the power station you buy now will still be dependable through many winters to come.
How to Set Up Your Portable Power Station and Avoid Overloads
A little setup goes a long way when you’re relying on backup power. Taking a few minutes to plan things out helps keep everything running safely and prevents frustrating shutdowns.
Calculate Running Watts and Plan for Surge Loads
Most appliances pull two different amounts of power: what they use while running and a higher burst when they first start. A refrigerator, for example, might run at around 200 watts but need closer to 1,200 watts for a second or two when the compressor kicks on. Make sure your power station can handle those brief surges, not just the steady load.
Manage Ports and Outputs Within Their Limits
Try not to overload the station with stacked power strips. Plug your most important devices directly into the unit so each outlet stays within its limit, especially when the power station output ports are overloaded. This reduces the chance of tripping the internal breaker when everything turns on at once.
Use Proper Cables, Placement, and Ventilation
Even though portable power stations don’t give off fumes, they still generate heat under heavy use. Set the unit on a flat, dry surface and leave some space around the vents. Good airflow helps it stay cool and run reliably for longer periods.
Safety Tips for Using Backup Power During Snowstorms Outage
When the power’s out, and snow starts melting, it’s easy to overlook basic safety. A few common-sense steps can help you avoid accidents while using backup power.
Keep Power Sources Away From Water and Snow
Don’t set your power station near windows, doors, or anywhere snow could blow in or melt onto it. Avoid spots near pipes that might drip or leak. Water and electricity are a bad mix, so keeping everything dry is key.
Use GFCI Protection in Damp Areas
If you’re running power in a kitchen, basement, or near a sump pump, use GFCI outlets or adapters. They shut things down fast if moisture is detected, which helps prevent shocks.
Route Cords Where People Won’t Trip
In a dark house, cords are easy to miss. Run them along walls, tape them down if needed, and keep them out of walkways. Don’t tuck cords under rugs, where heat can build up and cause problems.
A snowstorm doesn’t have to turn your house cold and dark. With a little planning, clear priorities, and a dependable backup setup, like the EcoFlow RIVER or DELTA series, you can keep the basics running and stay comfortable until things clear up. Instead of scrambling, you’re set up to ride it out and turn an outage into a quiet, low-stress snow day at home.
1. Can a Portable Power Station Run a CPAP Overnight?
Most portable power stations can run a CPAP for 8 to 12 hours, depending on battery size and your humidity settings, especially with CPAP Power Solutions. Using a DC adapter instead of AC helps stretch the battery even further. Yes.
2. Do Solar Panels Still Charge During Snowy or Cloudy Winter Days?
Yes, but don’t expect full output. Solar panels still produce power on cloudy winter days, just a lot less than in summer because the sun is weaker and daylight hours are shorter. During or right after a snowstorm, snow buildup can block sunlight almost completely.
Even a light layer of snow can slow production way down or stop it altogether. Once it’s safe, brushing snow off the panels makes a big difference. Keeping them clear and exposed to direct sunlight is the best way to get winter solar charging back and keep some power coming in during longer outages.
3. Will a Portable Power Station Work in Freezing Temperatures?
Usually yes, but cold weather does affect performance. In freezing temps, battery capacity can drop, and some units won’t charge if the cells get too cold. To avoid issues, it’s best to keep the power station inside a heated space while you’re using it or charging it.
4. What Should You Avoid Plugging Into a Portable Power Station?
Stay away from high-draw heating appliances like central AC units or electric water heaters unless you’re using a large system such as the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power. Those appliances pull a lot of power and can overload smaller stations fast. Always check the wattage on what you’re plugging in and make sure it stays within the unit’s limits.
5. What Type of Snowstorm Is Most Likely to Cause Power Outages?
Ice storms and heavy, wet snow cause the most outages. The weight builds up on trees and power lines, which leads to snapped branches and downed lines. Strong blizzards with high winds can also knock out power, especially when gusts bring trees down across the grid.
