Inrush Current 101: What It Is, Its Effects, and How to Handle It
Imagine trying to push a heavy car that's not moving. You need to push really hard to get it going. Once it's moving, it's much easier to keep it going. It is the same with electric circuits. If you are turning something on for the very first time, then it needs a high, abrupt jolt of electricity. This initial big wave is the inrush current. This is the prime factor in how electronic devices function, but controlling it is vital for the creation of long-lasting devices.
What Is Inrush Current Anyway
Inrush current is a very high spike of electricity that a device draws the moment you turn it on. This spike is super short, usually lasting only a few thousandths of a second. But its size can be huge, often several times and up to tens of times the running current, depending on load type (e.g., motors, transformers, large input capacitors).
The Capacitor Culprit
Capacitors are tiny components that store electricity, just like tiny batteries. When a device is off, its capacitors are draining.
When the switch is turned on, these capacitors will try to fill up with power very quickly. This means there is a huge current draw all at once. You will typically see this in the power supplies for computers, TVs, and modern lights.
The Transformer and Motor Puzzle
Transformers and motors use coils of wire to create magnetic fields. When you first power them on, it takes a lot of energy to build up that magnetic field from nothing.
This requires a big gulp of current at the start. This type of inrush surge current happens in big machines, air conditioners, and even the small power bricks for your gadgets.
To summarize, this initial power demand isn't a fault but a natural consequence of how key electrical components function. Capacitors demand a quick charge and inductive components require energy to create magnetic fields, both of which contribute to the momentary spike.
Distinguishing Surge Current vs Inrush Current
People often mix up "surge current" and "inrush current," but they are not the same. They are both spikes of current, but they come from different places and have different effects. Knowing the difference between surge current vs inrush current is key to protecting your electronics the right way. The table below makes the difference clear:
Feature
Inrush Current
Surge Current
Where it comes from
Inside the device. Caused by its own parts when you turn it on.
Outside the device. Caused by things like lightning or power grid problems.
When it happens
Every time you power on. It's a normal and expected part of starting up.
Random and unexpected. It can happen any time, without warning.
How long it lasts
Very, very short. Lasts for a tiny fraction of a second.
Can vary. It might be very short or last a bit longer than an inrush event.
What it does
Puts stress on startup parts and can trip a circuit breaker.
Can cause major, instant damage to electronics.
How to stop it
Use limiters (like NTCs or soft starters) that control the power at startup.
Use surge protectors that block or redirect the extra power.
To put it simply, inrush current is a predictable part of a device's startup routine that needs to be managed internally. A surge current is like a random outside attack you have to defend against.
The Negative Effects of an Inrush Surge Current
Even though an inrush surge current is very brief, it can cause real problems. This powerful spike can lead to a mix of small issues and big failures. That's why good electronic design always includes ways to control it.
Here are the main problems it can cause:
  • Tripped Breakers: The home circuit breaker may recognize an influx of power as a serious problem and shut the power down. This is annoying and will not allow you to use your device.
  • Component Burnout: It's more like hitting a part with a tiny hammer every time you turn it on. Such frequent hits wear down components like switches and others, so the parts burn out earlier than they should.
  • Flickering Lights: If one appliance suddenly consumes high power, the voltage in your home momentarily drops. This may cause your lights to flicker or other electronic devices to restart.
  • Stuck Switches: On power devices where there are physical on/off switches, a big inrush current will cause the parts on the switch to weld together with heat. This will result in the switch becoming stuck in the "on" position, presenting a safety risk.
If you don't control this initial rush of current, your devices might not last as long or work as reliably. This can lead to more repairs and potential safety issues.
EcoFlow DELTA Pro portable power station charging in garage providing reliable backup power with inrush current protection solutions.EcoFlow DELTA Pro portable power station charging in garage providing reliable backup power with inrush current protection solutions.
Learning How to Calculate Inrush Current
Finding the exact peak of an inrush current is tricky. But you don't always need a perfect number. Figuring out how to calculate inrush current is about getting a good estimate so you can choose the right parts to protect your device.
For Devices with Capacitors
In a device like a power supply, the inrush current depends on how fast its capacitors charge. There's a formula for this:
I=C⋅(dV/dt)
Here, I is the current, C is the capacitance (in Farads), and dV/dt represents the rate of change of voltage over time. In a simple AC-to-DC power supply, the peak current is limited mainly by any small resistances in the circuit, so the theoretical value can be extremely high.
For Devices with Motors and Transformers
Calculating the inrush current for motors is more complex. There is no single formula that works for everything.
The motor spec sheet is most often used by the engineer. This sheet will most often list a figure designated as the "Locked Rotor Amps" (LRA). LRA is the current the motor will draw when the motor is not spinning, and it is used to estimate the peak inrush. With transformers, the inrush current will be 10-15 times the full-load current and will depend on the residual magnetism present in the core when the transformer was turned off. Engineers use specific transformer models to calculate these complex variables.
Why It's Good to Know
Getting a good estimate is important.
  1. If you underestimate it, your circuit breakers will trip all the time.
  2. If you overestimate it, you might use a fuse that's too big, which won't protect your device when there's a real problem.
Therefore, a balanced approach using formulas for basic understanding and datasheets for practical application is key.
In practice, direct measurement using an oscilloscope with a current probe is the most reliable method. For design purposes, engineers often rely on manufacturer specifications and application notes to select the right limiting components.
Taming the Surge: Practical Inrush Current Solutions
Luckily, there are great solutions for managing inrush current. Engineers use a few common parts and circuits to "soften" the power-on moment. These solutions work by adding some temporary resistance at startup to slow down the rush of electricity.
Here are the most popular methods:
  • NTC Thermistors: This is a special kind of resistor. When it's cold (at startup), its resistance is high, which blocks the big current spike. As electricity flows through it, it warms up in a split second. When it's warm, its resistance drops to a very low level, allowing the device to operate normally with minimal power loss. NTC inrush limiters can run hot at rated load and may not limit effectively after a brief outage unless combined with a relay bypass or timed pre‑charge.
  • Inrush Current Limiters (ICLs): This is a circuit that uses a high-power fixed resistor in the line at startup. After a very short set time (e.g., 100 milliseconds), a relay or a switch inside the circuit closes and bypasses the resistor completely. This allows the device to get full power without any extra resistance in the way.
  • Soft Starters: These are used for big motors, like in factory machines or air conditioners. A soft starter doesn't hit the motor with full power all at once. Instead, it slowly ramps up the voltage over a few seconds, giving the motor a smooth, gentle start. This prevents both the electrical shock of a high inrush surge current and the mechanical shock of an abrupt start. Combine soft‑start with sufficient inverter surge capacity for best results. For home backup, DELTA Pro plus Smart Home Panel 2 enables fast, automatic switchover to an essentials subpanel, so high‑inrush loads start without nuisance trips during outages.
Each method has its trade-offs in terms of cost, size, and efficiency, but all share the same goal. They create a temporary roadblock for the initial power surge, making sure devices turn on safely and smoothly.
Power your life with the EcoFlow DELTA Pro. This portable home battery offers a 3.6-25kWh expandable capacity and 3600W output for home backup, RVs, and more.
Find Your Power Solution Today
Now that you know why the power-on jolt occurs, you can take steps to control it. From a simple NTC thermistor for the home brewer to a heftier current limiter for heavy duty gear, the right component is out there. Protecting your gear from that initial spike is straightforward, so browse the choices you have and discover the ideal power solution for you today.
FAQs About Inrush Current
Q1: Can inrush current damage my computer?
A: Yes, it can. Over time, many inrush current events can wear out the parts in your computer's power supply. The power supply has parts built-in to handle this, but very large or frequent surges can still cause stress. This can make parts like capacitors fail sooner than they should. This is a reason why it's not a good idea to turn your computer on and off again very quickly.
Q2: Why is inrush current higher in cold weather?
A: Inrush current can be higher when it's cold for a couple of reasons. First, some of the parts used to limit inrush current work differently based on temperature. Second, and more importantly, the copper wires inside big motors and transformers have lower electrical resistance when they are cold. Based on a rule called Ohm's Law, if resistance goes down, the current goes up. So, a device will pull a larger spike of current on a cold day.
Q3: Is a bigger fuse a good way to solve inrush current problems?
A: No, this is a very bad and dangerous idea. A fuse is a safety part. It's there to protect your device and prevent fires if there's a real problem. If you put in a bigger fuse, it might stop blowing when you turn the device on. But it also won't blow when it's supposed to during a real electrical fault. This creates a serious safety risk. The right way is to use a special "slow-blow" fuse that is designed to ignore the short inrush spike but will still blow if there is a real problem.
Home Solutions
