How to Stay Cool During Summer Outings Without Grid Power
Summer heat can be unbearable, yet it’s also the time of year with the longest days and often the best conditions for outdoor adventures. So, how can you stay cool when out and about without tying yourself to one place for grid power?
You can have it all with a little help. Portable power solutions like solar generators and portable AC units can provide access to your stay-cool necessities from anywhere. Learn how EcoFlow’s products are perfect for comfortable outdoor summer adventures.
Why Beating the Heat Off-Grid Is More Important Than Ever
Beating the heat is much higher stakes today than it used to be. Climate change is driving record-breaking temperatures worldwide, yet grid power isn’t always reliable during extreme weather bouts. Plus, thanks to remote work, more people are embracing outdoor adventures like camping or RV trips. Because of all this, a greater need has emerged for off-grid solutions to staying cool without giving up fun summer outings.
Portable cooling solutions are becoming more common, expanding access to these adventures outdoors while keeping you cool and comfortable no matter where you go or what you’re doing.
A group of people in a woodland areas with EcoFlow products
Off-Grid Portable Cooling Solutions
Different cooling technologies are available for various needs, from small handheld fans powered by batteries to large but portable AC units that can cool an entire room in minutes. When considering different cooling solutions, think about what type of adventures you expect to go on, your power requirements, what size and weight are reasonable to carry, and how helpful versatility might be.
Battery-Powered Fans
Small, battery-powered fans are among the most energy-efficient options available. You can find models that take standard batteries or those with rechargeable batteries installed that can be plugged into a power source via USB when running low. You have many options to meet your needs, from clip-on designs for targeted airflow and tower fans to cool larger areas. Some options even include misting features.
Portable Air Conditioners
When you need serious heat relief, look no further than a portable air conditioner like the EcoFlow WAVE 3. Its compact design makes it easy to carry on the go, but it’s powerful enough to cool RVs, tents, and small cabins in just 15 minutes. Plus, control everything from your phone, even when you’re not near the unit.
Powering Up With Solar
Solar power will be your best friend during summer outings. It takes advantage of bright sunlight to create free, earth-friendly, and unlimited daytime power. And its versatility means you can power just about anything! For example, pair the EcoFlow WAVE 3 with a solar generator such as the EcoFlow RIVER 3 Plus + 160W Solar Panel and enjoy your very own cool breeze all day long, no matter what the actual weather is like.
Hydration, Clothing, and Other Tips to Beat the Heat
Staying cool requires strategy. If you’re not thoughtful in what you pack and what your daily habits are, you may find yourself dehydrated, overheated, and exhausted. Use these tips to beat the heat effectively.
Always Carry a Water Bottle: Dehydration will accelerate the onset of heat exhaustion, so always keep an insulated, refillable water bottle with you. They’ll keep your water cold and your internal body temperature down.
Drink Electrolytes Daily: Sweating depletes essential electrolytes like sodium, potassium, and magnesium. On hot summer days, top up your body’s supply by drinking electrolytes via coconut water, diluted fruit juice, or hydration packets.
Bring AC With You: Don’t count on AC where you’re heading; bring it with you so it’s guaranteed! Small, portable units are easy to carry and ensure you always have a safe retreat during extreme temperatures.
Wear Breathable Clothes in Layers: Loose-fitting clothes will promote air circulation around your body, allowing any breeze to cool you. Removable layers allow you to adapt as temperatures change. Consider wearing cotton, linen, or other natural fibers that breathe better than synthetic materials. Though long sleeves may not sound enticing in the heat, they’ll protect your skin while allowing you to cool off.
Consider UPF Clothing: UPF fabrics block UV radiation and prevent sunburns, which can impair the body’s natural cooling processes. They are typically made of lightweight materials that won’t add an additional heat burden.
Never Leave the House Without Backup Power: Grid access isn’t guaranteed when outdoor adventures fill your summer schedule. Bring your backup solar generator to maintain power for your portable AC anywhere.
Keep Your Drinks Cold on the Go: Cool drinks can help lower body temperature. To make your water or electrolytes even more refreshing and cooling, store them in your EcoFlow GLACIER Classic Portable Refrigerator Freezer and bring it with you on adventures.
How Do I Cool Myself Down ASAP?
The fastest way to cool down is with cool water. Drinking cool water, immersing yourself in it, or applying it to your skin will bring down your body temperature and allow you to beat the heat. If water is unavailable, a fan or cold air works next best.
What Is the Best Way to Power an AC Without Electricity?
If you need to power an AC unit but don’t have grid electricity, you can use a portable solar generator to keep it running. You can use the sun’s rays to generate electricity that you can tap into from anywhere, whether or not there’s access to grid power.
Hot summer days don’t mean you have to suffer or stay indoors. Head outside and keep cool with help from EcoFlow’s range of products, from portable AC units and refrigerators to robust solar generators like the EcoFlow RIVER 3 Plus +169W Solar Panel
No grid power? No problem. All these items feature rechargeable batteries and can be powered up with solar anytime during the day. Stay hydrated, stay cool, and stay outside for the best summer ever!
