EcoFlow 175W
EcoFlow 175W
Rigid Solar Panel
  • TOPCon solar cells
    *The service life depends on the actual use.
  • Up to 25%Solar conversion efficiency rate
  • Durable structure
  • Up to 30-year lifespan*
  • Use in various scenarios
  • IP68 Waterproof rating
  • Easy installation
Utilizing Revolutionary N-Type TOPCon Solar Cells
Generate even more energy
With N-Type TOPCon solar cell technology, we've raised the bar on conversion efficiency, reaching heights of 25%. Generate and store more sunshine than ever before.
Why N-Type TOPCon solar cells are better ?
  • Up to 25% conversion efficiency
    • Monocrystalline Silicon Solar Cells: 21%-23%
    • TOPCon Solar Cells: Up to 25%
  • Performs well in low-light 0.5-1.0% higher power generation rate than P-PERC
    Adapts to dull lighting conditions, maintaining a high power generation rate even on overcast days.
  • High energy conversion in scorching temperatures*
    • Monocrystalline Silicon Solar Cell: 11.7%
    • TOPCon Solar Cell: 9%
  • Up to 30-year lifespan**
    • Monocrystalline Silicon Solar Cell: 25-year
    • TOPCon Solar Cell: up to 30-year
*When the surface of the solar panel reaches 55℃, TOPCon Solar Cell temperature coefficient is 23% less than that of the Monocrystalline Silicon Solar Cell. **The service life depends on the actual use.
Coated with Highly Protective Lamination and Tempered Glass
Designed to weather any storm
Built with a robust anti-corrosive aluminum frame, it's designed for years of solar-ray collection. Its TOPcon cells are coated with highly protective lamination and tempered glass and comes with an IP68 waterproof rating to enhance performance and offer long-lasting durability.
  • Designed to weather any storm
Industry-first design exclusively for Class B vans
With just the right specs to maximize roof space
Quickly charge your RV house batteries and power your van for days with these specially designed Class B solar panels.
  • With a shortened length of 46.3 in, it's just the right length to take advantage of every inch of your van's roof without affecting the awning.
  • The perfect size for a 59-63"L×39"W SUV roof, optimizing solar energy collection.
Perfectly Tailored for Home Use
Long-lasting solar solution for your home
With a 30-year lifespan, it's a durable, low-maintenance solar solution ideal for home use.
  • Long-lasting solar solution for your home
Pair it with a 28" Tilt Mount Bracket to capture solar right from your garden. Fully charge EcoFlow DELTA 2 in as fast as 3.7 hr using two solar panels. Even on cloudy days, it can fully charge in a single day.
  • Pre-Drilled Slots for Secure Mounting
    Ready to install on any surface
    With pre-cut holes along the panel's perimeter, the 175W rigid panel is ready to mount on your van or off-grid build. Pair with the 100W Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
  • Universally Compatible Solar Cable
    Just plug and play with your power system
    Using an all-inclusive solar connector, connect with any existing third-party solar system. Charge 48V power systems and portable power stations with single or multiple panels.
EcoFlow 175W Rigid TOPCon Solar Panel Charging Times
Model
RIVER 2
RIVER 2
RIVER 2 Max
RIVER 2 Max
RIVER 2 Pro
RIVER 2 Pro
DELTA 2
DELTA 2
DELTA 2 Max
DELTA 2 Max
DELTA Pro
DELTA Pro
DELTA Pro Ultra
DELTA Pro Ultra
256Wh
512Wh
768Wh
1024Wh
2048Wh
3600Wh
6144Wh
0-100% Charging Time*
1.8-3.6 hr
3.6-7.2 hr
5.5-11 hr
  • 3.7-7.3 hr
    (175W Solar Panel × 2)
  • 3.7-7.3 hr
    (175W Solar Panel × 4)
  • 5.5-11 hr
    (175W Solar Panel × 5)
  • 2-4 hr
    (175W Solar Panel × 22)
  • 8.8-17 hr
Average Daily Power Generation**
700Wh
700Wh
700Wh
  • 1400Wh
  • 2800Wh
  • 3500Wh
  • 15400Wh
*Calculated at 80% of solar panel power, the time interval takes into account various weather conditions **Taking the US as an example, the data includes weather factors, such as rain, throughout the year
How to choose your solar panel
  • Rigid Solar Panel
    Rigid Solar Panel
  • Portable Solar Panel
  • Up to 25%
  • Up to 25%
Size
  • Larger design for Class B RVs and home use
  • Smaller design for on-the-road
Cost
  • 175W $249
  • 160W $449
Scenarios
  • Fixed use: RV Rooftop & Home
  • Portable Use: Outdoor & Home
What’s in the box
  • EcoFlow 175W Rigid Solar Panel
  • EcoFlow Rigid Solar Panel Mounting Feet
  • EcoFlow Solar to XT60 Charging Cable
  • Quick Start Guide,
Safety Instructions & Warranty Card
    Quick Start Guide, Safety Instructions & Warranty Card
* Please kindly note that the EcoFlow 175W Rigid Solar Panel and the EcoFlow Solar to XT60 Charging Cable will be shipped separately.
  • Rated Power
    175W (+/-3W)
  • Cell Type
    N Type TOPCon Monocrystalline Silicon
  • Efficiency Rating
    Up to 25%
  • Weight (Solar Panel)
    20.5 lb (9.3 kg)
  • Dimensions
    46.3 x 30 x 1.2 in (1176 x 762 x 30 mm)
  • Connector Type
    Adaptable to MC4
  • Warranty (US)
    5 Years
  • Waterproof & Dustproof Rating
  • Short Circuit Current
    8.3 A
  • Open Circuit Voltage
    25.5 V
  • Maximum Operating Voltage
    22.3V
  • Maximum Operating Current
    7.85A
  • EcoFlow
