1280Wh Capacity, 1280W Continuous Output
Group 27 Equivalent
IP65
Waterproof Rating
X-Guard BMS with Low-Temp Cut-Off
Best-in class EV-grade LFP Cells with
6000+
Cycles
1/2
Less Weight
Energy than Lead Acid
Highest-Level UL5VA Flame-Retardant Casing
Professional Lithium Solutions for Every Scenario
EcoFlow 12V 100Ah Lithium Trolling Motor Battery
  • Best lithium battery for 30–70 lb trolling motors
  • 300A@30s instantaneous output current
  • EV-grade LFP cells with 6000+ cycles, 1280Wh capacity, and 1280W continuous output
EcoFlow 12V 100Ah Lithium Battery
  • Best lithium battery for RVs, cabins, and off grid workshops
  • Group 27 equivalent
the power
Up to 2× more capacity
1/2
the weight yet
58% lighter for portability
12×
longer lifespan
12× longer lifespan
$0.03
/kWh
Only $0.03/kWh lifetime cost
*Compared with an average 100Ah lead-acid 12V battery
*Lifetime cost refers to the price of energy that is drawn from the battery over a lifetime
Get constant power and comfort for 2 whole days of off-grid RV living when you connect up to 4 batteries in series.
1 h/day
Coffee Maker 1000W
24 h/day
Refrigerator 120W
1 h/day
Induction Cooker 1800W
24 h/day
Laptop 60W
4S
48V 100Ah | 5.12kWh
RV
Off-Grid Cabin
Workshop
6000+Cycles
$0.03/kWh
Durable and Protective
Advanced Battery Safety System
The structure system offers a sturdy fixation for battery cells, enhancing product reliability and safety significantly. High-performance fireproof foam is used for fixation between cells and the pack, isolating and protecting them, reducing vibration and friction, preventing short circuits and damage, and providing outstanding thermal insulation.
Always-safe and Reliable
Unmatched Protection
Our X-Guard BMS (Battery Management System) algorithm provides around-the-clock protection. Covering up to six monitoring and safeguard measures, including low temperature, over-discharge, overcharge, high temperature, short circuit, and overcurrent, it ensures a fail-safe recovery. Unlike most lead-acid batteries that lack a BMS, our battery mitigates the risk of damage in harsh environments. Whether facing extreme weather conditions or fault recovery, our dual-channel CMOS protection guarantees optimal performance and safety.
Enhanced Safety and Reliability
Water-Resistant & Temperature Safe
Experience enhanced safety with vehicle-grade LFP battery cells. Meeting top UL9540 standards, this 12V battery is designed to minimize heat and resist water, even from low-pressure jets. With a 5VA-grade, self-extinguishing casing, it automatically extinguishes itself within 30 seconds in the unlikely event of a fire, preventing the risk of flames spreading.
AC Charger
2 Hours (14.6V 50A 0.5C)
Solar Panel
2 Hours (≥800W)
Generator
2 Hours (50A DC-DC Charger)
Charge 0-100 in Only 2 Hours
2
hours
Lead-acid 12V Battery
10
hours
2.5M+
Global users
100+
Countries and regions
522
Patented technologies
Learn more
Our Awards
Our Partners
EcoFlow: The Ultimate Pick for Pros
The Ultimate Off Grid Power Solution | Expedition Truck Build | EcoFlow Delta Pro
Destination Adventure
ECO FLOW Delta Pro WOW 2 AC Unit TEST!!
JOHNNY'S WEEKENDS
How Long Can My Batteries Last Off-Grid? EcoFlow Power Kit Review | RV, Van & Tiny Home Electricity!
Nomadic Sarah
9 Day Off Grid Boondocking RV Trip with the EcoFlow Delta Pro
Minute Man Prep
Quality Services You Can Expect
5-Year Comprehensive Warranty
Worry-Free After-Sales Customer Service
UL, CE, FCC, UN38.3, RoHS Certified
title
DELTA Pro 3 can run a well pump in an emergency. I am ecstatic that my pressure washer works with the DP3. I absolutely adore the amazing design and game-changing quiet fans.
Luke L., Monticello, IL
title
Off Grid Stackable Solar Battery - So easy its *Almost* Cheating...
