EcoFlow Portable Power Stations | RIVER 2 Pro | RIVER 3 Plus | DELTA 2/DELTA 3 | DELTA 3 Plus | DELTA 2 Max | DELTA Pro | DELTA Pro 3 |
Battery Capacity | 768Wh | 286Wh | 1024Wh | 1024Wh | 2048Wh | 3600Wh | 4096Wh |
Battery Solar Input | 220W, Max
1*PV Input Port, 11-50V
13A 220W | 220W, Max
1*PV Input Port,11~55V,
13A 220W | 500W, Max
1*PV Input Port
10-60V 15A 500W | 1000W, Max
2*PV Input Port,
11~60V 15A 500W | 1000W,Max
2*PV Input Port, 10-60V
15A 500W | 1600W, Max
1*PV Input Port, 11-150V
15A 1600W | 2600W, Max
2*PV Input Port:
LPV: 11-60V 20A 1000W
HPV: 11-150V 15A
1600W |
Recommended Pairing Quantity and Connection Methods | 2 pieces in parallel | 1 piece | 4 pieces in parallel | 4 pieces in parallel for each PV input ports, 8 panels in total | 4 pieces in parallel for each PV input ports, 8 panels in total | 4 pieces in parallel and 3 strings in series, 12 panels in total | 4 pieces in parallel and 3 strings in series, 12 panels in total |
0-100% Charging Time(hr)* | 3.84 | 2.86 | 2.56 | 1.28 | 2.56 | 3.00 | 3.41 |
Average Daily Power Generation** | 1kWh | 0.5kWh | 2kWh | 4kWh | 4kWh | 6kWh | 6kWh |
